This project is about building a new kind of water well that does not need any power source except weight of people to pull water out from the ground up by using pascal’s law.
This is done by using the wall casing of the well as a large cylinder with surface area A1, a plate that act as piston on the static water level which is 4.76m to 7.8 meter depth so that a person(s) can stand on it acting as a self-pushing piston rod with force of F1 to push the water found at the static water level down forcing the water up in to the pipe with surface area A2 found on a center of the well with high force of F2 to direct it in to water tank found higher elevation.
The peoples who stand on the large pistons use an extendable ladder or rope ladder to go up without affecting the operating system of the piston. The peoples exert force of F1 that can be calculated from summation of their weight on to the water down ward since the only path of water is through the pipe located on the center of the well, water travel with a force of F2 calculated by multiplying F1 with surface area of the pipe divided by the surface area of the wall casing. This F2 force can also give as the height it will travel upward with ρgh analysis.
The only remaining system that is being developed at this time is the upward return system of the standing piston towards the static water level. We will use the rope ladder or the extendable ladder for people to go up and stop the force on the piston to reverse the mechanism.
This new design is about using a weight balance system to push the piston downward incase weight of person is not enough to overcome the pressure of the water in the well. This will automate the whole system avoiding a person contact by using the water tank as a counter balance weight when enough weight water enters in to it. In opposite side of the weight balance there will be a load of X Kg enough to push water in the well to Y meter depth. Ideally the load weight and the water tank full of water have same weight. When the water tank is empty the load in the well will push the ground water down ward filling the water tank. As the water tanks starts to fill up it will start pulling the load up balancing the weight which will act as an automatic filling mechanism. When people use the water in the water tank the load will start pushing the piston down ward starting the filling process again.
3D model is not in actual size shown here. https://hackaday.io/project/202915-water-well-design-50/log/240442-piston-plate-downward-push
Anteneh Gashaw
Sorry to be blunt: This is not going to work and you are wasting your time.
The issue is the weight needed to press the piston down. You need a pressure that is high enough to lift the water to the level of the top of the pipe. For this you need a force equivalent to a cylinder of water of the same height but the area of the piston. So 2.5qm times 5m of water are 12.5 metric tons. No idea how to convert this to African women.
You are basically replacing a totally functional hand pump with a totally impractical and impossible to use pump.
