BOM files
09/29/2025 at 05:24 • 0 commentsI added BOM files to the project. I provided the parameters for the CPLD and the memory chip.
On eBay:
Z8001P, Z8581
On Digikey:
RAM chip
Other chips:
See your favorite suppliers (Digi_Key, eBay, Ali Express, etc.)
PC104 Version on hold
09/27/2025 at 06:53 • 0 commentsDue to some personel circumstances, I would like to put this project on hold, unless someone would take it over.
The schematic has been modified to allow using of different EPROM. or EEPROMs.
Files available here.
PC104 version under way
09/23/2025 at 21:59 • 0 commentsFor fun, I'll make a PC104 version of the BBTC. The only DIP chips will be the Z8001, clock generator and the 2 EPROMs. I'll make the EPROM configurable for different chips.
I'll only provide the files, no PCBs.
PCB received and assembled
09/03/2025 at 21:15 • 0 commentsI just received the PCB from JLCPCB and assembled all the component. I need to program the EPROMs and the CPLD.
Disks and docs for the Trump Card
08/23/2025 at 10:25 • 0 commentsIt's not the Eipstein files but there are zip files for the floppy disk and some documentation.
See here:
I found this in this forum:
https://forum.vcfed.org/index.php?threads/z8000-board-for-ibm-pc.1237909/#post-1443617
PCB is ready!
08/22/2025 at 17:05 • 0 commentsThe PCB is completed and Gerbers files are available. See the Github link.
BBTC
08/18/2025 at 05:47 • 0 commentsI made a prototype of the Trump Card a long while ago, but got rid of it.
Now, all the components are easily available and PCB fabs can make your own PCBs for a small price.I made the schematic in KiCAD and the PCB is under way presently. There's not much components so I should finish within a month.
Meanwhile, you can modify the schematics to make a full retro computing version or a fancier version with many more features.
Jacques Pelletier
