R909 Airband Receiver Gets a Raspberry Pi Pico CPU
08/22/2026 at 11:27 • 0 commentsI reused the Raspberry Pi Pico board originally designed for my R909-tester project as the CPU board for my R909-DSP airband receiver.
The existing receiver firmware required only minor modifications, and the receiver is now working.
The R909-DSP project is my ongoing DIY development of an airband receiver.
{PHOTO}![]()
For the R909-tester, I designed a PCB using a **Raspberry Pi Pico Zero module from Waveshare**. I made a mistake when placing the I2C connector for the OLED, so the first PCB was not assembled as intended.
Instead of throwing it away, I decided to reuse it as an experimental CPU board for the R909-DSP.
I ported the existing R909-DSP receiver sketch to the Pico.
It now works with the existing TA2003 + Si5351A + Si4732 RF front-end.
The R909 CPU has evolved through several platforms:
ATmega328P → ESP32-C3 → Raspberry Pi Pico
One pleasant surprise is the amount of memory available on the Pico. Compared with the ATmega328P, there is plenty of room left, so I can even add Japanese character display support.
For the next step, I need to tune the RF front-end for better **sensitivity and stability**.
I will continue this development as R909-DSP6.
Update: What I learned about the front end filter instead of 2 stages stagger resonator after assembling the PCB circuit.
06/30/2026 at 12:50 • 0 commentsThe front-end filter of this receiver originally used a two-stage staggered configuration, but I switched to a three-stage Chebyshev design to improve the skirt characteristics. This resulted in better attenuation performance in the FM broadcast band and the upper image frequency range.
Details are on my blog and GITHUB
06/03/2026 at 08:29 • 0 commentsDetailed source code, assembly manual, and full schematic analysis are archived on my tech blog: [https://nobcha23.hatenadiary.com/entry/2024/09/04/201324],[https://github.com/Nobcha/R909-SDR/tree/main/R909_manual03_en.pdf],[https://github.com/Nobcha/R909-SDR/blob/main/R909-DSP3_test1.ino]
Log#2 UI / Control Specification
05/18/2026 at 10:51 • 0 commentsA compact receiver requires a simple but consistent user interface.
All parameters are updated immediately when adjusted, eliminating the need for an explicit ‘apply’ operation.
Frequency tuning resolution is defined by a dedicated step mode.
EEPROM storage is used only to restore parameters after power cycling.
The interface separates real-time control from persistence, keeping operation simple while maintaining flexibility.
1. Control Interface
Input device: Rotary Encoder
Actions:Rotate/Push/Double Push2. Global Behavior
All parameters are updated immediately when changed (live behavior)
No explicit “apply” or “confirm” operation exists
Parameter values are always active once adjusted
Store current parameters to EEPROM for restoration after power cycling3. Mode Switching Behavior
Push→ Switch to Select Mode
Double Push→ Store current parameters to EEPROM
→ Parameters are restored after power cycle
→ When MEM mode, store the frequency in the MEM channel
→ When SCN mode, going into Automatic scan mode4. Mode List
FREQ : Frequency
STEP : Frequency Step
MEM : Memory Channel
SCN : Scan Channel
VOL : Volume
SQU : Squelch Level
BAND : AM (air band) / FM
B_W : AM band width
F_COR : Crystal Frequency Calibration
ACA : Automatic scan mode5. Mode Specifications
FREQ Mode
Parameter : Receiving frequency
Range : 118 – 136 MHz (AM) / 76 - 109 MHz (FM)
Resolution: Defined by STEP mode
Behavior : Changes immediately (live)STEP Mode
Parameter : Frequency step size
Options : 10Hz / 1kHz / 10kHz / 100kHz / 1MHz / 25 kHz
Behavior : Defines increment/decrement step in FREQ modeVOL Mode
Parameter : Audio volume
Range : 0 - 63
Behavior : Immediate effect on audio outputSQL Mode
Parameter : Squelch threshold
Range : 0 - 63
Behavior : Audio muted below threshold levelMEM Mode
Parameter : Memory channel
Range : CH0 – CH49
Behavior : Select memory channel number / assign current frequencySCN Mode
Behavior : Assign memory channel frequencyBAND Mode
Parameter : AM (air band 118 - 136 MHz) / FM (76 - 109MHz)B_W Mode
Parameter : Si4732 AM band width
Unit : 0 - 6 (0:6kHz,1:4kHz, 2:3kHz, 3:2kHz, 4:1kHz, 5:1.8kHz, 6:2.5kHz)F_COR Mode
Parameter : Crystal frequency correction
Unit : Frequency offset (±Hz for 25MHz of Si5351a)
Behavior : Adjusts local oscillator accuracy6. Frequency Control Rule
Frequency increment/decrement is quantized by STEP setting
Changing STEP immediately affects FREQ tuning resolution7. Persistence Behavior
EEPROM stores:
Current parameters (mode-dependent)
Stored values are:→ Restored automatically at power-onAutomatic scanning
Double Push on SCN mode → Automatic scanning mode
Sweep MEM channels every 200mS, if there is signal, stay 1 Sec more.
Signal detection (squelch open / RSSI threshold) -
Log #1: RF Front-End Filter Design and Practical Trade-offs
05/16/2026 at 11:41 • 0 commentsThe RF front-end filter plays a critical role in airband reception, where strong out-of-band signals such as FM broadcast (88–108 MHz, 76-100MHz in Japan) and image frequencies can significantly degrade receiver performance.
Initial Approach
At the beginning of this project, a 5-pole Chebyshev band-pass filter was considered in order to achieve high selectivity and strong out-of-band rejection. However, practical constraints quickly became apparent.
A higher-order filter requires:
Larger PCB area
Careful control of inter-stage coupling
Complex tuning and adjustmentIn a compact DIY implementation, these factors make the design difficult to realize reliably. As a result, a simpler and more practical 3-pole configuration was selected.
3-Pole Filter Implementation
The implemented filter is a compact 3-pole band-pass design using air-core inductors and discrete capacitors. This approach prioritizes:
Simplicity
Small PCB footprint
Ease of constructionAir-core inductors were chosen for the resonant elements due to their stability and suitability for small inductance values in the VHF range.
Measurement Results
The filter response was measured using a nanoVNA. The results are summarized as follows:
Insertion loss (passband around 120 MHz): approximately -9 dB
FM broadcast band (~100 MHz): approximately -30 dB attenuation
Image frequency region (~160 MHz): approximately -27 dB attenuationThese results confirm that the filter provides effective suppression of strong out-of-band signals, particularly in the FM broadcast band, which is critical for practical airband reception.
Observations and Limitations
While the out-of-band rejection is satisfactory, the insertion loss in the passband is higher than expected.
This led to an important realization:
In VHF filter design, practical factors such as component Q and PCB layout can dominate over the theoretical filter response.
In this implementation:
Small inductance values (e.g., single-turn coils) limit achievable Q
Parasitic effects from PCB layout and component leads contribute to loss
Strong coupling between stages can reduce filter sharpnessAs a result, increasing filter order alone does not guarantee better performance in a real-world design.
Design Trade-offs
This filter represents a deliberate trade-off:
Pros
Good suppression of strong FM interference
Compact and simple construction
Stable and reproducible behavior
Cons
Higher insertion loss than ideal
Moderate selectivity compared to higher-order filtersRather than pursuing a more complex topology, the design prioritizes practical usability and robustness.
Next Steps
Based on these observations, the next step is to improve the filter performance by focusing on component quality and implementation details rather than increasing filter order.
Conclusion
Although a higher-order filter was initially considered, a simpler 3-pole design proved to be more practical for this project. Measurement results highlight that, in VHF designs, real-world implementation factors often outweigh theoretical advantages.
This reinforces an important lesson:
Improving component quality and layout can be more effective than increasing filter complexity.
nobcha
