Making Programming as Personal as the Device Itself
10/26/2026 at 21:19 • 0 commentsA lot of things have converged over the past few weeks, enough that I'm excited to finally write about one of the hardest and most rewarding parts of designing RCKid: making programming (I almost don’t want to use that word - “algorithmics” is closer to what I mean, but almost nobody uses it, so programming it is) as personal to kids as the device itself.
Here's why this matters so much to me: kids don't have a computer with them 24/7. Not on the school bus, not during a five-minute break, not at the exact moment they get an idea and want to try it. But they can have a small handheld like RCKid in those moments. I think that changes a lot - not just when kids can create, but how much, and how deep.
The constraint that shapes everything
To make that possible, kids need to be able to program on a tiny device with no touchscreen - just a d-pad and a few buttons. I spent a long time trying to make the device itself bigger, fancier, more capable (trust me, I wasted a lot of hours on this :), but every version of that tradeoff made the device less personal - bigger, more expensive, more like "a classroom thing" and less like something that’s truly theirs. So the only path left was adapting how programming itself works.
That led me to a series of on-device editors, all built around one shared idea, with increasing visual expressiveness as kids grow into them - and one underlying language that all the editors are really just different views of.
Hole-based editing
The editors work by letting a program grow through holes - gaps where new code can go. A kid navigates between existing tokens with the d-pad, and selecting a hole opens a menu of valid things to put there. Different editor levels will show icons for pre-literate kids, simplified version with chevron delimiters for the older ones and a full readable text for the teenagers. Critically, only syntactically correct programs can ever be built this way. Types are used to filter and order the menu, so kids see fewer, more relevant choices and spend fewer keystrokes getting to something real. The image above shows one such screen, where this editing model produces a small visual DSL.
The whole environment - and the language underneath it - is designed around sharing and emergent exploration: a kid who gets ahead can build something (a new icon, a new component) that lowers the bar for everyone else, not just for themselves.
A peek at the language
A few things I think are genuinely interesting about the language itself: It is indentation-based, like Python - the editors handle nesting for you, so there's never a need to type a block's start or end.
Numbers are rational, not floating point - built on what kids understand from school and not machine epsilons and IEEE 754 weirdness. Comparisons chain the way they expect them to:
if 1 <= x < 10 ... # this is the hole :)Objects support inheritance, but deliberately not virtual dispatch - a child type can extend a parent and be used anywhere the parent is expected, but it can never override the parent's behavior. Methods are also defined outside the object declaration, which means kids can organically extend an existing object with new behavior at any point, without ever touching the original:
fun Sprite.moveHorizontally(by : num) self.moveBy(by, 0)Everything is event-based. Kids define handlers for the events their game objects expose:
device.onButtonDown += fun(b) ... # called for any button bThe language, despite being primitive tries to teach some good practices. Functions are first class citizens (as seen above in the event definitions). A limited form of pattern matching works on event arguments:
device.onButtonDown += fun(Btn.Down) ... # called only when the down button is pressedAnd separately, for functions that may or may not return a value, which always have to be checked and unwrapped before use:
if let a = myMap["foo"] ... # a exists, and was stored under "foo" else ... # no such keyThere is a
matchstatement (think switch, but sharper), plus simpletest/assertion support, and arrays, maps, and tuples all get dedicated, token-saving syntax and limited generics ability.In keeping with RCKid's whole philosophy, cartridges can add their own game objects - so, for example, an RC cartridge lets a kid program their own LEGO creation using the exact same editors and the exact same language they already know from their games.
Where things actually stand
To be clear about what's real right now: The actual execution engine this language runs on is validated on-device. The asset editor is built; the editors shown here and the full language design are the part I am actively working through right now.
If you want to dig deeper: the editor design is written up here (SPLASH-E), and the full language spec is at Github.
Mark IV
10/19/2026 at 15:07 • 0 commentsSo with the recent Puya tests, I started being very optimistic about the chip and decided to enter the therapeutic phase of PCB layout & routing. This is mkIV as there is no hope of backwards compatibility after the IO MCU change (I mean the SDK is generic enough so that this might be achievable, but absolutely not worth it) and so far I am really pleased with it. For the first time the routing feels intentional, not hacked.
Along the way, I have realized a few things that led to even further BOM optimizations:- the new RGB LEDs not only run from 3v3, but they also have standby current of just 1uA (as opposed to the neopixel standard 1mA) which means I can ditch the 5V charge pump as well as the rail switch
- the rail is thus not necessary simplifying the power routing
- device power on is done via dedicated switch with overcurrent protection and soft start so that high capacitance, or even shorted cartridges should not damage the system
- accelerometer is connected via SPI to the PY32F030 to completely isolate the always on power domain
- ESD protection on the cartridge pins
- SD card ESD & pullups in discrete parts since the CM1624 proved rather complex to source (and more expensive)
- simplified routing around the PUYA and Audio codec (different orientation)
- standardized debug port for RP2350 and PY32F030
- smaller & better suited signal diodes for the button matrix
- better side buttons
- light sensor above the display with a single LED (instead of I2C costly detector)
I am 99.9% finished with the layout - the only thing that remains is the correct capacitor values around the 32kHz crystal which I have to figure out.
And I am not ordering anything yet, letting the new design sink a bit, probably adding some finishing touches a bit later. I would really, really want this to be the last pre-production version, so please, feel free to comment:-)
The RC in RCKid
09/09/2026 at 07:48 • 0 commentsRCKid started as a pile of spare parts that I wanted to convert into a controller for some old Lego motors I had lying around so that I can build RC cars for my kids. It was supposed to be very primitive gamepad-like device. And while that ship sailed a long time ago, it's how RC sneaked into the name.
Over the years there have been some attempts to make it happen, I have (of course:) bought a few components for it )(H bridge modules, converters, etc.), designed a simple API for the wireless protocol and obsessed about form factors, charging and power envelopes. At one point I was particularly proud of myself when I had a breadboard on with a puny ATTiny3216 that controlled 4 programmable IO ports (servo, rgb, analog, digital) and 2 motors, which in their connector selected between 9V and 5V power supply.
But a few weeks ago, I started designing the latest iteration. Instead the ATTiny (which I now consider very expensive) it uses the Puya I am simultaneously trying to bring to life. I also took the BOM optimization ideas that I learned recently to my heart and I have redesigned the controller brick entirely to keep the costs really down. Here is what it is supposed to do, as well as a picture of the designed board:
- runs off 18650 li-ion cell, or 2 in parallel. This means a *lot* simpler charging
- I am using IP5306, which is a Chinese chip designed for power banks. It integrates charger (2A max) and a boost converter to 5V capable of 2.1A output into a single chip and single external coil. It has many drawbacks (can't power the device while charging, cannot be really controlled by the MCU, requires dedicated power button), but is super cheap
- everything runs at 5V, including the motors
- I have kept the 2 motors and 4 GPIO extenders and their reversible connectors made of cheap headers
- onboard is single RGB light for signaling, buzzer for sounds, NRF24L01P+ Si clone for comms and a second button for the MCU for advanced functions
- instead of INA219 and I2C I am using much cheaper INA180 and the ADC on the MCU to determine the battery level, total power envelope and left & right motor current to detect stalls. Motors and GPIO pins can be powered off by the MCU when needed
I have an idea of a really simple and robust assembly of this (with the li-ion cells on the bottom part of the board). And overall, I think I have made the right calls in terms of usability vs price ratio. That said, at this point the board design is wishful thinking since I haven't yet brought the Puya chip - but it is also a lasting record of how well I read the datasheets, i.e. how much the design changes before the ordering.
If all goes well, I would like to have this ready for Xmas delivery:)
Puya has blinked!
09/06/2026 at 21:09 • 0 commentsPuya now blinks;-D All it took was downloading the CMSIS packs for Puya and core Cortex M0+, then creating the linker and startup scripts. This is because the CMSIS packs are for ARM Keil Toolchain, while I am using gcc `arm-eabi-none`. I did some guesswork and tweaking and the scripts now exists and blinky blinks;-D
The simple cmake template with necessary files can be found here: zduka/puya-blinky: An attempt at a blinky for thePY32F030 chip I am considering for rckid. Might evolve into a template for puya projects in the future.
And I am really excited that I will be able to debug the small chip too now - hopefully, compared to the serial printfs on the AtTiny, this will speed up the development where I need to bring up the parts of the chip I need (I2C, RTC, PWM, Neopixel RGBs). So as always, to be continued:)
Puya Has Arrived!
09/06/2026 at 11:21 • 0 commentsThe Puya breakout boards I have created have arrived. More specifically, the PY32F030:
I have been trying to bring it to life so far, and this is report about the work in progress,. because I am not at blinky yet:) But not all is lost:
First I had to change my setup - for rckid's debugging I was using OpenOCD connected to raspberry pi GPIO, which worked nice so far, but required the actual Raspberry Pi. There is also the debug probe from RPi, which is essentially a RP2040 with the SWD and UART out and a few LEDs. I was always thinking that it would be really nice to have a cartridge for RCKid that does exactly this (and more - in the ATTiny3217 days I planned SWD, UART and UPDI interfaces). And because OpenOCD does not work trivially with Puya, this felt like a good option to try to switch.
But as I did not want to debug multiple things at the same time, I first just flashed the default debugprobe code to an old RPi Pico I had lying around unused (fun fact: This pico was used to prototype the rckid *before* the Rpi zero days (see the history log:). I also tried pyOCD, which looks a bit more modern and I was hoping I can run it from my laptop - which I can!
I then tried to list the targets and scope at the gpios to see if the SWD is working, and it seemed it was not/. But my mistake. The debugprobe will *not* detect a device is connected and connect to it automatically, you *must* tell it to. It took me some time to realize this when staring at flat scope lines at night:) But now I connect to the puya, I can flash, and I can inspect the chp state. So I know hardware-wise the puya is really simple to use, almost as much as the ATTiny was.
But this was the easy part - the hard part is figuring out the code to run. In the past I was shielded from all this by the RPi Pico SDK, but now I am digging through Chinese documents, ARM Keil CMSIS and friends. So I do not have a blinky yet. To be continued...
BOM Optimization
08/31/2026 at 20:09 • 0 commentsAlthough the latest prototype (v3.2 Beaver King) has a few problems - most importantly the new headphone detection circuit is not working, I am now in a happy place as across all my prototypes, I have every hardware feature working at least once:) This is great, because technically I can just put together the working parts into a single prototype and call it a day. But at the Lancaster summer school I've been to, Paul Dietz was showing a super neat trick that makes a single LED both emit and sense light and I would really like to use it in my device, partly because the light detection sensor is a bit expensive and hard to get.
But why stop at the light sensor you say:) So I decided that I should look at my entire bill of materials and see if I can improve things. And what I found shocked me!
The numbers below are for my fictional order of 50 units, where the entire BOM of that would be roughly 1k EUR. Out of this, those are the biggest offenders:
- 200 EUR for the accelerometer, which I use in the most primitive way, but I paid the premium because it also counts steps
- 162 EUR (!!!) for 220uF capacitors for 3v3 buffer and headphones filter
- 81 EUR (!!!) for the ATTiny3217 which is glorified IO controller. Note this is *more* expensive than the RP2350 which is the main brain.
- 80 EUR for the light sensor, that is slow to measure, I use it in the most basic way, but I liked it because it also measures the UV light
- 55 EUR for the analog/digital cartridge mux which allows cartridge to output directly to the audio codec inputs (analog)
Combined, this is roughly half of my BOM (the part of BOM that is assembled by JLCPCB anyways), which is crazy. So I started thinking on how to optimize it. As a programmer, I am probably the most upset (in the what is wrong with this world sense) with the fact that the tiny ATTiny (pun intended:) costs more than the powerful RP2350. I started researching at what are the cheaper options here and I was almost ready to defect to the PIC camp (funny enough atmels and pics are now both microchip so maybe not that bad for my karma), but the price difference will only be small.
So I went radical - what are the *cheapest* MCUs available? I need them to work as RTC, have enough pins, have flash in them, and have enough power/peripherals to do what ATTiny did. I was really surprised when I found the Puya microchips line. They are super cheap, come in variety of packages (including my favourite QFN), have enough pins, are a lot more powerful than the ATTiny, and are based on ARM Cortex M0+ (similar architecture to the RP2350's M33). Crucially they can be programmed via ARM's SWD which I already use for the RP2350. And they are cheap - at "volume" pricing of 50 units, they'll cost only 14 EUR.
The light sensor obviously goes and will be replaced by a cheap LED. But I have decided to also part ways with the accelerometer. Instead I'll get the cheapest accelerometer available, and I can always write the pedometer in software on the Puya chip, should I choose to (also, its power consumption is better that ATTiny's:). Cheap accelerometers will cost me 9 EUR for 50 units.
As for the capacitors, I have two options. For some reason, I was using some really expensive ones - I can get 220uF caps for essentially half the price, or if I use 2x100uF instead, I can drop the price to 29 EUR only (if I find place on the board).
Finally, the analog multiplexer for the cartridge is purely optional item and I do not have to have it assembled (I can revisit this in the future if I ever change my mind).
Overall, my savings can be up to 10 EUR per device in BOM alone, which is HUGE:
Component Before After Accelerometer 200 (LSM6DSVETR) 9 (MSA3S02) Capacitors 162 (220uF) 29 (2x 100uF) MCU 82 (ATTiny3217) 14 (PY32F030K28U6TR) Light Sensor 80 (LTR-390UV) 2 (cheap LED) Analog Mux 56 (DG2723DN-T1-E4) 0 (do not fit) TOTAL 580 EUR 54 EUR I was a bit worried though about the Puya MCU and I want to test it before redrawing my device and paying the money for it, so I created a simple Puya breakout board and ordered it from JLCPCB. It has just the barebones Puya chip, the external RTC crystal and SWD header out. I got a notice last week that I have a package ready so I ran to the post office today. But instead of the breakout boards, it was a notice informing me that I owe some TV license fees:( My package is still on the way, so to be continued...
Jacdac!
08/06/2026 at 20:17 • 0 commentsI have been very busy with version 3.2 because I entered RCKid into the Device Prototyping summer school organized by the University of Lancaster (LINK). And while I have the feeling that I should have done this some 3 years ago, it was absolutely amazing and if you have a project you want to prototype, I highly recommend going in the coming years! The event is organized by https://prosquared.org/ where you should find more.
First and foremost, you meet great people from all embedded walks of life, and they will have interesting comments about your device. For me this was the first time I talked about my device to others in person, and words cannot describe how cool it is:)
The days are also filled with lectures and tutorials on various aspects of device creation and prototyping - technical, deeply technical, administrative, research-y. This year they covered things from how to solder (unsurprisingly I have failed that one:), SMT parts, creating devices simply and cheaply (two separate talks:), the evils and importance of certification (I still have nightmares about this), very cool tricks you can do with MCUs and LEDs (I will be using those in RCkid's next revision), and some cool HCI projects. It's pretty packed so I am sure I forgot some, but the point is that there is something for everyone, and even the talks where I thought I know stuff already are good to attend as the presenters are real professionals who often give things in context & perspective.
The projects submitted range from ideas on paper to almost finished like rckid and the judges select a few good projects to give brief presentations and win some money (yay for rckid:), then all attendees vote for a project they like the most (yay for someone else:). (consolation price: quite a few people told me they really liked rckid and voted for it, if you are reading this and are one of those, thank you, it means a world to me!)
The whole affair is organized by people deeply involved with the BBC:microbit and one of them, Steve Hodges, gave me a Jacdac starter kit under promise I will do something with it. And since for RCkid, everything is a cartridge away, I was pretty busy in the past few weeks with the Jacdac cartridge for RCKid, ta da:
Its very cool how little is needed to make it work - the cartridge supports dual mode - RCkid can be either a service and provide peripherals it has such as accelerometer, buttons, rumblers, LEDs, etc., or it can be a brain (controller in Jacdac terms), in which case other devices are connected to it and the cartridge provides Jacdac bus with power as well (hence the extra circuitry).
Software-wise Jacdac protocol is essentially an UART with extra tweaks over a single wire and this is rather easy and fun to program on RP2350 in PIO. So a few evenings after the board has arrived, I have RCKid expose its accelerometer as a Jacdac service.
The Jacdac connector requires cartridge board thickness to be 1.6mm which in the long run is probably better for RCKid as well, as the standard width boards are ubiquitous and cheapest to manufacture, will likely work better with my plans for cartridge connector I will use if I ever create larger numbers of RCKid (simpler assembly, better electrical characteristics and tolerances, but requires custom stamped part), and overall the 0.4mm in extra space in the cartridge is probably not worth it anyways.
But it means new version for the case & connector to accommodate the thicker pcb. I am also thinking how to actually make use of Jacdac in RCKid and I have a few ideas, so as always, stay tuned:)
Beaver King is here!
07/12/2026 at 15:18 • 0 commentsPast few weeks I have been busy with bringing the mk3.2 to life, and it has mostly been success:
- the enclosure (after some manual adjustments) looks great and fits nicely. The raised edges around the front cover work great too
- battery connector works nicely - it is not perfect though, the clearance between it and the rumbler enclosure in the bottom case is a bit too tight and the battery wire is a bit longer than necessary
- rumbler with sprint contacts works great! So much easier than clipping & soldering wires. The only thing that clouds my joy is the fact that LCSC discontinued (apparently, the page just says 404) the exact model I used.
- speaker with spring contacts works absolutely great too - even the enclosure made of the case works rather nice as it is already. I made some small mistakes so I had to print a frame ring for the speaker and I realized that I can actually turn this into feature as it makes the whole enclosure a bit easier to do & to glue the protective cloth. I might post details on this a bit later
- new top buttons are great too! Their feel is so much better and the assembly is a lot simpler too. I also realized I can manually swap color mid-print, which means no more gluing of the two button parts together
- and finally, the microphone seems to work rather well this time. I have only tested it with looking at the waveform, but I *can* produce a waveform this time;-D
That said, there were some hiccups, two most important are:
- the new headphone detection does not work at all. And I do not know why - the headphone detection line reads 0.3V whether headphones are connected, or not. I have verified the obvious (i.e. the headphone jack switch does indeed switch on/off)
- the new side buttons do not feel better than the old ones - maybe even worse. Furthermore of the 3 devices I assembled already, 1 button was soldered wrongly (fixed that with a wire), and one was not properly working (part problem, not soldering, you need to really press hard on it in a special way to work)
But overall, I am very excited as I can always go back to the old buttons & old headphone detection that worked. So finally, all hardware issues seem to be fixed now. Also, the new debug connector with the UART TX from both RP2350 and AVR are absolute godsend!
v3.2 Beaver King (version 2)
05/30/2026 at 17:58 • 0 commentsI have decided to actually print even the prototypes in beautiful black & ENIG finish. How else can I judge if it really is as beautiful as I hope:) As part of that I have also decided to remove almost all of the visual clutter from the silkscreen. The outlines where top panel touches the PCB are not necessary to be visible. The text is not very useful for pre-literate children so I swapped it with pretty icons. The component markings are not necessary either, they mostly belong to assembly layer and will just make the board look uglier.
In EasyEDA this is super easy, I just right-clicked on the component, then Edit footprint -> for all and I moved all the silkscreen markings from silkscreen to assembly layer. The board preview looked super pretty, product like.
BIG MISTAKE
I placed the order and a few days later comes an email from JLCPCB to verify component placement. This has happened in the past a few times, but was always a formality - not once did I spot any error. But the boards were pretty expensive this time so I still do my due diligence and look carefully. I found 22 components to be badly oriented. 22!! Ranging from diodes all the way to big chips.
I verified all of them manually, indicated correct placement and sent the images back to JLCPCB. They were very nice and accommodating. I was very careful, tested everything twice, but I still have the nagging feeling in my head that I missed something and the boards will be broken.
I went to the editor and put all the orientation marks from assembly back to silkscreen. They will hopefully save me a lot of stress in the future, and they are barely noticeable. Clean silkscreen is great - empty silkscreen is not.
v3.2 Beaver King
05/18/2026 at 20:56 • 0 commentsPast few weeks I have been busy with yet another almost final revision of RCKid, 3.2, codename Beaver King (from now all versions will have names based on currently favourite animals of my kids as they get super excited when they see the names written on the boards). Below are shots of the final PCB - presented here in beautiful black & ENIG finish that I plan for the more bulkier orders later on. This one will be the boring green & HASL for cost savings though:)
The version incorporates the lessons learned from building the SDK 1.0, some cost saving decisions and hopefully a lot of DFM improvements, namely:
- the FM radio is gone. It can return in the cartridges, where fundamentally it belongs better. It simplifies the assembly process by not having to worry about the antenna placement, makes the BOM much easier (this was the only part that was not available directly from JLCPCB) and makes the audio design much cleaner because of the extra space I gain there. It clears one pin on the RP2350, which I put to use immediately in the analog/digital demux switch for cartridge pins (see below)
- I am taking a bold step and making my own speaker enclosure. Previously I have used an already enclosed speaker from Samesky with wires that I had to solder manually. Now I am using non-enclosed speaker with spring contacts for much easier assembly, which is great. But I have to make the enclosure for it. The idea is that natural enclosure forms between the PCB and the top plate (you can see its outline in the image above on the PCB). I am not yet sure about the quality of the seal this will make, but I reckon its worth a try. The new speaker is cheaper, and louder, according to the datasheet.
- I am changing buttons too: the side buttons which I had to solder manually to the bottom side are replaced with sinking ones that are larger, better centered (the actuators are actually close to the middle of the buttons) and will be soldered by JLCPCB. For the top buttons, I have used the super thin ones, without plungers, but making the plungers on the buttons themselves proved very difficult. Also I did not like the feeling. So now I switched to buttons with integrated silicone plungers, hoping that this would simplify the mechanical tolerances, and hence assembly complexity for the buttons
- I have replaced rumbler motor with one that uses spring contacts as well and will sit under the PCB for yet simpler assembly
- I have also changed the battery connector - I have found that I can buy the batteries I need with JST-PH connector as well, which is just large enough to fit under the PCB, and at the same time I am trying even different option where a special daughterboard with spring contacts will be soldered to the battery wires, making the assembly even simpler (I am scared that the battery wire will get squished when I close the PCB on the JST-PH connector and without transparent cases, there is no way to tellFive things were changed electrically:
- LTR-390UV sensor for ambient light & sun detection. There was free room on the PCB, I already have the chips purchased back from mkII so no extra cost, and my hope is that the light detector will allow me to do very crude wireless transmission between two devices by blinking the display white opposite to the light sensor so that kids can exchange tiny pieces of information this way.
- with the FM radio removes, I have added analog multiplexers & control line to two of the cartridge pins. These can now be used either as digital pins, or can be used as analog inputs to the audio codec (where the FM radio previously connected). This means cartridges can provide extra audio HW with ease (such as the FM radio:)![]()
- previously the board had electret microphone, but they did not work. I have tried everything to make them work, but to no avail. This time I am switching to MEMS microphone hoping this would solve the problems.
- instead of double ground connection, the headphone detection circuit has been reworked to use the integrated tip switch in the jack connector. This should allow me to detect even headsets with microphones reliably (previously this was flaky, I suspect because the microphone on the second ground ring changed the signal electrically to sometimes fall outside of the reliable high-low region)
- AVR and RP2350 are no longer connected with interrupt line (it was not used in the past). Instead those pins go to the now larger debug connector and are UART TX for both chips, which should ease debugging a lot
I have also reworked the case a bit - first room had to be made for the new components (speaker case, rumbler, battery connectors), but then I am also adding a slight curved rim to the top (see the incomplete picture below for the difference). The transparent SLA prints look very nice, but are very, very brittle, both of my kids managed to chip theirs already. So current plan is to print the back cover from nylon and the extra curved rim will protect the clear front case similarly to how phone protectors work.
That's it. I am running latest visual changes now and then letting the design sink a bit as usual in case I have forgotten something very important. Then in about a week, I am ordering the boards:) So wish me good luck, and if you happen to spot a mistake in the circuits above (especially the microphone which I am the least sure about), please, please, let me know:) Thanks!
Zduka
