System Overview
Raspberry Pi based streaming radio with CRT-style terminal interface and physical hardware controls.
Audio System
Custom-built stereo speaker enclosure using repurposed PC speaker components, optimized for compact dimensions and sealed operation.
User Interface
Physical toggle switches, potentiometer and status indicators for direct hardware interaction.
A CRT-style terminal interface provides visual feedback and system status.
Connectivity
WiFi-based audio streaming via librespot (Spotify) and direct PCM audio streaming over SSH from network devices.
Service & Recovery
Dedicated USB service port for local access via keyboard, allowing direct system control in case of network or SSH failure.
Enclosure
Sealed industrial-style metal housing with weather-resistant construction and internal component compartments.
Project Status
Final assembly and system integration in progress.
Markus Hüttner
RodolpheH
Zduka
mircemk
Arcadia Labs
