STORY of the HYPER S3 ROCKET and the STEM FORGE Rockets & Engineering Challenge
A water rocket's whole flight is over in a handful of seconds: launch, apogee, parachute, touchdown. Blink and you've missed the data.
As a technology and engineering teacher, I wanted my students to see every one of those seconds. I wanted an immersive water-rocket challenge with data logging, onboard sensors, and automated parachute deployment. But no commercial option fit the bill. Everything was too restrictive, too expensive, or lacked safety & customizability.
So I did what any maker-educator would do (having a previous life in micro-electronics engineering). I consulted fellow engineering teachers, researched rocketry physics, telemetry, battery safety, and a whole lot more, then designed a flight-capable, battery-vaulted, development board from scratch (with future options to expand).
The result is the HYPER S3 ROCKET: a 4 gram, 20 mm × 33.5 mm ESP32-S3 board built around four ideas:
- Power: a dual-core 240 MHz ESP32-S3 and a 2 A, 3.3 V buck-boost rail that keeps the processor alive when servos and radios surge, charged from USB-C or a solar panel.
- Protect: a hardware "double safety vault" that guards the battery on both charge and discharge, even if your code crashes.
- Precise: a nano-power MEMS real-time clock, an optional 10-DoF motion and altitude sensor array, and a fast 4-bit MicroSD logger.
- Portable: small and light enough to ride inside a soda-bottle rocket nose cone, or solder flat onto your own board as a castellated module.
It was engineered for water-rocket telemetry, but it packs a serious punch for any battery and solar project my students can dream of. I want you to have this option too so I'm crowd-funding this through Crowd Supply and Mouser Electronics.
This project page is made as a structured guide for anyone who wants to learn to build with microcontrollers, batteries and solar panels, but I have focused the story here on my original project needs - the STEMFORGE Rockets & Engineering Challenge.
Hope you enjoy the journey with me.
stemforge.phil
_lB3kNeO9U1.png?auto=compress,format&w=740&h=555&fit=max)
Kris Winer
AVR
First project on Hackaday for me. Any tips would be appreciated. Or let me know if I can help in any way.
