These are the notes for my Split-Flap display project. It's relatively compact and fairly cheap component-wise, that is if you forget to count the time needed to assemble each unit.
Please watch the video, it shows it in detail.
In the Project Logs below I dive deeper into the process, resolved problems, and especially the unresolved problems.
For details consult github repo: https://github.com/svofski/mini-split-flap-display/
Particularly for CAD files, go directly to https://github.com/svofski/mini-split-flap-display/tree/master/printables/cad README should giive a good idea about the printed parts parts, both in their CAD form and exported .step files.
svofski
I guess that's it. Definitely do not want to build more.
Luckily my simple algorithm turned out to be robust enough to cope with irregularities. I decided to add another tunable parameter, the tracking divisor. It adjust min/max leakage rate. The larger the value, the slower the peaks decay towards the middle. It proved to be quite useful when tuning individual displays.
Xasin
Giovanni Leal
deʃhipu
