Final touch
10/03/2017 at 07:20 • 0 commentsThere is SO much you can do with such a small amount of data collected over time. However I need to start gearing up for my next project, so I am going to mark this project as "completed." For the final phase I allowed users to change the names of the sensors and added some nice labelling to the heat map. Enjoy!
More sensors
09/11/2017 at 13:26 • 0 commentsI have added more sensors to the network and also added a "5 day historical comparison" feature on the web page. I can only test it fully in 5 days though...
Moving forward!
09/08/2017 at 08:55 • 0 commentsSo I have updated the web page so that the report looks much better! Mouse hovers over time were causing some weird memory issues.
One thing I did realise with deploying to the Node from another computer: You will need to install the OneWire library in Arduino (Sketch -> Include Library -> Manage Libraries):
I am hoping to call the Pi server "stable" at some point. Currently I was having wifi issues and I think that was terminating the SSH session and then the server would stop. So now I SSH over a hard LAN cable (I am using a Pi 3 for now)
Learning continues
09/06/2017 at 07:41 • 0 commentsI have (for the most part) finished the project. The web site and node code are fairly complete, as well as having done some more experiments. It turns out that the D8 pin on the NodeMCU ESP8266 is the problem, not the 3v3 pin as I first thought. That means I can salvage my current PCB's and make some new ones without the need for a SPDT slider switch.
There is some more code for just testing a node. I am having problems with some of the boards that I ordered from eBay and Amazon, where they throw this error:
warning: espcomm_sync failed error: espcomm_open failed error: espcomm_upload_mem failed error: espcomm_upload_mem failedI have found a diagnostic web site and a blog that have proven useful in some cases. I'll try to find a consistent solution.
Snag-o-rama
09/03/2017 at 17:09 • 1 commentI have updated the code on the repo, but unfortunately there is a slight problem: You cannot start or flash the NodeMCU chip when there is a connection to the 3v3 pin. This means I am going to need to add a switch to my PCB design. I'll update it when all the components come in from eBay.
Getting a basic node going
09/02/2017 at 08:58 • 0 commentsToday I soldered the PCB together after doing a minor code check on a bread board. The particular NodeMCU boards I had bought from eBay required me to push and hold the FLASH button, press and release the RESET button, and then flashing the firmware.
I managed to burn out 2 boards when I accidentally connected A0 and D0 in series. Don't do that.
To get the NodeMCU board going with Arduino, you need to add:
http://arduino.esp8266.com/stable/package_esp8266com_index.json
To the additional boards manager in preferences. You will also need to then go to the boards manager and download the ESP8266 components. If you can't see the port your board is connected to, download the driver from here:
https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
I had also added the OneWire library to my Arduino: http://www.arduinolibraries.info/libraries/one-wire
Then the basic code was fairly simple:
#include <OneWire.h> #define DS18S20_Pin D8 #define BLUE_PIN D6 #define GREEN_PIN D5 #define RED_PIN D4 OneWire ds(DS18S20_Pin); int CURRENT_COL = RED_PIN; void setup() { Serial.begin(115200); Serial.println(""); Serial.println("Hello ESP8266"); pinMode(LED_BUILTIN, OUTPUT); pinMode(RED_PIN, OUTPUT); pinMode(GREEN_PIN, OUTPUT); pinMode(BLUE_PIN, OUTPUT); } float getTemp(){ //returns the temperature in Celsius byte data[12]; byte addr[8]; if ( !ds.search(addr)) { //no more sensors on chain, reset search ds.reset_search(); return -1001; } if ( OneWire::crc8( addr, 7) != addr[7]) { Serial.println("CRC is not valid!"); return -1002; } if ( addr[0] != 0x10 && addr[0] != 0x28) { Serial.print("Device is not recognized"); return -1003; } ds.reset(); ds.select(addr); ds.write(0x44,1); // start conversion, with parasite power on at the end byte present = ds.reset(); ds.select(addr); ds.write(0xBE); // Read Scratchpad for (int i = 0; i < 9; i++) { // we need 9 bytes data[i] = ds.read(); } ds.reset_search(); byte MSB = data[1]; byte LSB = data[0]; float tempRead = ((MSB << 8) | LSB); //using two's compliment float TemperatureSum = tempRead / 16; return TemperatureSum; } void loop() { digitalWrite(RED_PIN, LOW); digitalWrite(GREEN_PIN, LOW); digitalWrite(BLUE_PIN, LOW); digitalWrite(CURRENT_COL, HIGH); digitalWrite(LED_BUILTIN, LOW); Serial.println("LED OFF"); delay(1000); digitalWrite(LED_BUILTIN, HIGH); Serial.println("LED ON"); delay(500); float temperature = getTemp(); String temp = String(temperature); Serial.print("TEMPERATURE: "); Serial.println(temp); delay(250); if (CURRENT_COL == RED_PIN) { CURRENT_COL = BLUE_PIN; } else if (CURRENT_COL == BLUE_PIN){ CURRENT_COL = GREEN_PIN; } else { CURRENT_COL = RED_PIN; } }All this does is print the temperature to the serial and cycles through the RED, GREEN and BLUE colours
Quintin Balsdon
