WiFi and USB for pocketbeagle
no wifi - 4 stars ... RTL8188 module and small usb hub with usual suspects
adding some WiFi over USB to the pocketbeagle I got at MFNY17 :)
Quick googling seems to make FE1.1S a good choice for a controller.
http://referencedesigner.com/blog/designing-low-cost-4-port-usb-hub/2962/
#PiAngle Zero - Not just another Pi Zero USB Hub
#Yet Another Pi Zero USB Hub
#(One More) Raspberry Pi Zero USB Hub
#RASPICON: Retro Gaming and Media Center Platform
WiFi done with RTL8188 module
pocketbeagle_USB_hub+wifi.sch
sch - 852.03 kB - 01/01/2018 at 11:45
Download
pocketbeagle_USB_hub+wifi.pdf
Adobe Portable Document Format - 41.22 kB - 01/01/2018 at 11:45
Preview
pocketbeagle_USB_hub+wifi.brd
brd - 106.09 kB - 01/01/2018 at 11:45
Download
  • getting started again for testing
    davedarko08/16/2018 at 09:58 0 comments
    call this on a mac in your browser http://beaglebone.local/ - if you get the beagle page, it works! (connecting over usb that is)
    ssh debian@beaglebone.local
    with password temppwd (you should change that)
    sudo iwlist wlan0 scan | grep ESSID
    shows you stuff if
    sudo iwconfig
    shows you stuff if
    lsusb
    shows you stuff
  • prototype works (kind of)
    davedarko01/01/2018 at 11:42 0 comments
    My wifi and usb hub for the pocketbeagle kinda works now. Little mistake to fix with a bodge wire. @oshpark boards work fine :) I can scan wifi ssids but have trouble with setting up the connection.
  • Design choices
    davedarko10/07/2017 at 14:19 0 comments
    Seems like there aren't any capacitors needed for the crystal, although it seems unusual coming from every other chip I've used that needed a crystal. I've added 10pF like in #(One More) Raspberry Pi Zero USB Hub but doubt they're necessary.
    Only one extra USB port has a plug, out of size restrictions etc. - a second one has the RTL8188 directly connected. Therefore only one LED is really necessary for the "connected" status.
    Added a PRTR5V0U2X as ESD protection for the "external" USB port.
View all 3 project logs
jaromir.sukuba wrote 12/31/2017 at 18:42 point
I see you are searching for reference designs - FE1.1s + USB wifi module combo is used in my #raspberry pi zero handheld computer
davedarko wrote 12/31/2017 at 21:03 point
I found my mistake already, had one pin pulled low instead of hig ;) works now, but will check against your design later :) thanks
oshpark wrote 10/08/2017 at 14:36 point
@Michael Welling  @Jason Kridner  @Jason Kridner  Is there SDIO on the headers?   @ajlitt and @davedarko are interested
Michael Welling wrote 10/08/2017 at 17:12 point
There is no SDIO broken out on the PocketBeagle except for the microSD card slot.
davedarko wrote 10/08/2017 at 17:46 point
thanks for clearing that up, would have been great for an ESP12-F WiFi pocketcape.
ajlitt wrote 10/06/2017 at 22:42 point
I haven't looked, but did they bring out SDIO on any of the cape?  It would be a shame to waste the only USB host on networking like some other low cost SBC.
davedarko wrote 10/07/2017 at 01:33 point
I'm working in an USB Hub chip (FE1.1S) as well, not sure about sdio, can't see it on http://www.14core.com/pocketbeagle-mini-computer/ but maybe Drew @oshpark  can say more? You're probably talking about doing the same like on #RPi WiFi ?
ajlitt wrote 10/07/2017 at 04:55 point
You read my mind...
I spent a few minutes looking at the pinout and the AM335x datasheet, and it doesn't look like MMC0-2 are represented as alt functions on any of them.  Kind of a shame, since the AM335x SoC has 3 SDIO interfaces.
