Uses a PS/2 Keyboard and a ATMEGA328 to run BILLYTERM which displays the text on the screen and will soon have special functions. Has a piezo speaker for audio and RCA jack for black and white video out.
PS/2 keyboard that displays keys pressed on a TV; like a word processor.
You'll need to install support for an additional hardware configuration to run without the big external clock circuit:
Once you've done this, you can burn the bootloader and upload programs onto your ATmega328 as described above. Be sure to select "ATmega328 on a breadboard (8 MHz internal clock)" when burning the bootloader. (If you select the wrong item and configure the microcontroller to use an external clock, it won't work unless you connect one.)
Wire the circuit like this,
Connect the [Video] in the picture to the inside ring of the component RCA jack. Connect the outer ring to ground. The CLK and DATA is shown how to be wired on the second picture shown above. Connect the speaker up to the resistor and ground. Your BILLYTERM is ready to be programmed.
Download the Source code from https://github.com/billybobpickle/BILLYTERM and wire an arduino and the BILLYTERM like so:Upload the sketch and it should be good to go. BILLYTERM V1.5 Boots like so:
how did you connect the keyboard?
