I have an AC knob in my Honda Odyssey that broke where it holds onto the shaft of the switch. I decided to try fixing it with a 3d printed part. I took measurements, made templates to test fit, and modeled the part using Sketchup. After some minor adjustments to the part after test fitting, I was able to print a piece that could be glued into the knob to make it functional again.
Files
Knob Insert v2.stl
Glue in replacement for the inside of a 2001 Honda Odyssey AC knob.
Standard Tesselated Geometry -
20.69 kB -
02/19/2018 at 00:01
Here is the second ( and final) version of the printed insert. I fixed the capping of the end, and adjusted the 1 mm gap.
Here I checked the fit in the knob. very nice fit.
Testing the fit on the shaft of the switch. It fit well, though It is loose enough that it can be removed without too much force. I allowed for 0.2 mm of clearance from the actual measurement of the shaft, but I probably could have gone with 0.15 mm.
Final placement after gluing the insert into place. I used some UV curing resin to tack it into place quickly, followed by superglue. I probably could get away with just the super glue, but I had the resin on hand.
Test fitting the print into the knob. It was a tight fit. I sanded the edges a bit to get it to fit snugly, but there was a problem with the measurements that caused it to be off.
Here you can see there is a 1 mm gap on the flat side of the insert.
LOL, I just submitted this.....
https://hackaday.io/project/59054-3d-printed-honda-odyssey-replacement-knob
