PDPii
PDP-11 compatible motherboard in mini-ITX form factor
Public Chat
Buy KR1801VM2 microprocessor (КР1801ВМ2 in Cyrillic) on eBay and follow me ;)
At present PDP-11 computer systems are mostly forgotten, but there are PDP-11 compatible Soviet microprocessors still available on eBay (never used "new old stock") as KR1801VM2 (КР1801ВМ2 in Russian) and I'm going to bring PDP-11 of some sort back - I'm designing an open source computer (licensed under CERN OHL v1.2) around that chip (VM2 was 2nd version of Soviet single chip implementation of LSI-11 system [ not a clone!!! ] which could be used to build PDP-11/03 kind of machine) with open source modules and backplane in mini-ITX form factor 170*170mm (see GitLab) that could fit into regular mini-ITX computer case (that is cheap) to make a true 16-bit modern retro computer with PS/2 keyboard (and may be mouse) and connected to [S]VGA monitor:
As you can see design is inspired by famous RC2014 ;)
UPDATE1: On April 26th this project was featured on hackaday.com
https://hackaday.com/2018/04/26/a-mini-itx-pdp-11/
UPDATE2: Mailing list about all nedoPC projects (not only this nedoPC-18 "PDPii"):
https://groups.google.com/d/forum/nedopc
UPDATE3: You can order PDPii printed circuit boards (multiple of 3) from OSHpark:
CPU module: https://oshpark.com/shared_projects/1tyHeC3z
ROM module: https://oshpark.com/shared_projects/84DgcRqv
Mini-ITX spec with all sizes could be found here
I didn't want to use Q-bus (called "LSI-11 bus" in earlier DEC documentation) as is (in it's original edge-connector form) because it's huge and almost half of contacts are not used, so I put all meaningful signals of Q-bus in 1-row header (slightly re-arranged) and in the same row (after 1 missed pin) I added all other signals from VM2 microprocessor and also de-multiplexed and inverted address lines - there are no modern ICs that could decode multiplexed Q-bus with proper handshaking natively (except for some number of old Soviet memory chips that mostly defective) so presence of already demultiplexed and inverted address will help to connect regular memory RAM and ROM chips. So it's 62-pin header (37th pin is missing) that could fit in 6.3 inches ( or 160mm that is coincidentally a limit for Eagle v5 Standard Edition that I own since 2007 ; ) and collectively I call this interface "Bread-Board friendly Q-bus extended" or BBQ-bus+ :)
PositionName (bold if Q-bus)
Where connected
1GNDGround - pin 1 and 20 of VM2
2BDMR L/DMR - pin 12 of VM2
3BSACK L/SACK - pin 13 of VM2
4BDMGI LDaisy chained BDMGO
5
BDMGO L /DMGO - pin 14 of VM2
6BHALT L/HALT - pin 29 of VM2
7BDCOK H/DCLO - pin 26 of VM2
8BPOK H/ACLO - pin 25 of VM2
9BINIT L/INIT - pin 27 of VM2
10BEVENT L/EVNT - pin 30 of VM2
11BIRQ4 L/VIRQ - pin 28 of VM2
12BIAKI LDaisy chained BIAKO
13BIAKO L
/IAKO - pin 24 of VM2
14BDIN L/DIN - pin 22 of VM2
15BDOUT L/DOUT - pin 18 of VM2
16BRPLY L/RPLY - pin 17 of VM2
17BSYNC L/SYNC - pin 21 of VM2
18BWTBT L/WTBT - pin 19 of VM2
19BBS7 LLogical 0 if A15=A14=A13=1
20BDAL0 L/AD0 - pin 9 of VM2
21BDAL1 L/AD1 - pin 8 of VM2
22BDAL2 L/AD2 - pin 7 of VM2
23BDAL3 L/AD3 - pin 6 of VM2
24BDAL4 L/AD4 - pin 5 of VM2
25BDAL5 L/AD5 - pin 4 of VM2
26BDAL6 L/AD6 - pin 3 of VM2
27BDAL7 L/AD7 - pin 2 of VM2
28BDAL8 L/AD8 - pin 39 of VM2
29BDAL9 L/AD9 - pin 38 of VM2
30BDAL10 L/AD10 - pin 37 of VM2
31BDAL11 L/AD11 - pin 36 of VM2
32BDAL12 L/AD12 - pin 35 of VM2
33BDAL13 L/AD13 - pin 34 of VM2
34BDAL14 L/AD14 - pin 33 of VM2
35BDAL15 L/AD15 - pin 32 of VM2
36PWR5V+5V (switchable) - pin 40 of VM2
37
NOT CONNECTED (a key)
38CLCICLCI - pin 16 of VM2
39CLCOCLCO - pin 15 of VM2
40A0Latched inverted /AD0
41A1Latched inverted /AD1
42A2Latched inverted /AD2
43A3Latched inverted /AD3
44A4Latched...
nedo1820_v1_0.zip
Eagle v5.1 files for RAM 32KB (16 Kwords) module - 160x70mm
Zip Archive - 50.98 kB - 05/12/2018 at 20:21
Download
nedo1810_v1_0.zip
Eagle v5.1 files for ROM 64K module - 160x37mm
Zip Archive - 50.14 kB - 05/07/2018 at 05:29
Download
nedo1800_tmpl.zip
Eagle v5.1 files for module templates: nedo1800.sch & nedo1800.brd - 160x70mm; nedo1800s.sch & nedo1800s.brd - 94x70mm (short version).
Zip Archive - 14.89 kB - 05/05/2018 at 15:27
Download
nedo1802_v1_0.zip
Eagle v5.1 files for CPU module with 1801VM2 - 160x100mm.
Zip Archive - 100.76 kB - 05/02/2018 at 04:00
Download
cern_ohl_v_1_2.pdf
Open hardware license CERN OHL v.1.2.
Adobe Portable Document Format - 95.73 kB - 04/17/2018 at 08:14
Preview
  • Separate Project for Hackaday Prize
    SHAOS04/22/2019 at 04:48 0 comments
    In order to be able to participate in HacladayPrize2019 I created separate project #PDPjr that will be focused on creating simplified (but still usable) version of PDPii so please LIKE that project as much as you LIKE this one ;)
    https://hackaday.io/project/164866-pdpjr
  • Hello, World!
    SHAOS03/20/2019 at 05:57 0 comments
    I don't have backplane yet, so I can use breadboard instead ( it is Bread Board friendly Q-bus after all ; )
    Couple yellow diagonal wires on the left are for BDMGO-BDMGI and BIAKO-BIAKI deasy-chains.
    Actually if CPU module is the last board then those two wires should be rotated, because CPU generates both BDMGO and BIAKO so they should go from right-top to bottom-left, but for now it doesn't matter because we don't use DMA or interrupts...
    Now we will try to do something with LCD 16x2 that has 8-bit parallel interface. Simple circuits from 74LS32 OR-gates and couple 74LS374 registers does the trick - by writing to address 0xFF00 it will store 16-bit value on registers to be used to control LCD. Important thing when you are playing with LCD is delay between commands during LCD initialization and work that should be long enough for LCD to work properly. To implement precise delays we will use PDP-11 instruction sob (subtract 1 and branch if not equal to 0):
        mov #100,r0 ; 100 cycles of sob
    delay1:
        sob r0,delay1
    Step-by-step run of the 1st draft of the test program showed that 1 cycle takes 24 CLCI ticks (8 ticks to read sob instruction from memory, another 8 ticks to read NEXT instruction and then another 8 to execute branch), so we can easily compute for how long we should cycle to perform 15ms, 5ms and 1ms delays:
    decimalnumbers
        org 0
        .word 0100H,0E0H ; reset vector
        org 0100H
    start:
        mov #12500,r0 ; delay 15 ms for 20 MHz
    delay0:
        sob r0,delay0
        mov #init,r4
    initloop:
        movb (r4)+,r0
        beq endinit
        com r0 ; invert character
        bis #0FF00H,r0 ; set all bits of higher byte
        mov r0,@#0FF00H
        bic #800H,r0 ; inverted E=1
        mov r0,@#0FF00H
        bis #800H,r0 ; inverted E=0
        mov r0,@#0FF00H
        mov #4167,r0 ; delay 5 ms for 20 MHz
    delay1:
        sob r0,delay1
        jmp initloop
    endinit:
        mov #msg,r4
    loop:
        movb (r4)+,r0
        beq endloop
        bic #200H,r0 ; inverted RS=1
        mov r0,@#0FF00H
        mov r0,@#0FF00H
        mov r0,@#0FF00H
        mov #833,r0 ; delay 1 ms for 20 MHz
    delay2:
        sob r0,delay2
        jmp loop
    endloop:
        mov #0FFFFH,r0
    delay:
        sob r0,delay
        jmp start
    msg:    .byte    "Hello, World!!!",0
    init:    .byte    30H,30H,38H,8H,1H,6H,0CH,0
    As I wrote before I have one strange VM2 that is capable of running on 20 MHz and it says "Hello, World!!!" now :)
    But I see that 20 MHz is too much for VM2 anyway - it is glitching and eventually stops showing anything meaningful on LCD. Lower frequency 16 MHz is much more stable (no glitches)...
  • NOP test with ROM module
    SHAOS03/16/2019 at 06:19 0 comments
    A few days ago I received 3 PCBs from OSHPark:
    and today built one of them:
    It could be inserted into large solderless breadboard together with CPU module for testing without backplane:
    I flashed ROM with very simple program - a lot of NOP instructions (for PDP-11 it is word 0240 or 0x00A0 that should be inverted and stored to ROM as 0xFF5F because our databus in PDPii is inverted). With 1 MHz oscillator we see this:
    It is possible to calculate that most significant address LED (green one on the left) blinks about every 0.4 seconds and it sounds about right because 1 NOP is 12 external ticks (6 internal) and 32768 NOPs (whole address space) with 1 MHz external clock should be done in 1/(1000000/12/32768)=0.39 sec.
    Now I should write something more complex for it ;)
    P.S. Also I successfully tried 3 MHz, 4 MHz and 10 MHz oscillators on black VM2s with 1 dot on the package (rated 10 MHz on the factory), but higher frequencies expectedly failed to work (namely 16 MHz and 20 MHz).
    P.P.S. Black VM2s without dots (highest rated) appear to be working with 16 MHz oscillator!!!
    P.P.P.S. One recently bought black КР1801ВМ2 with dot (so it has to be <=10MHz) worked not only on 16 MHz, but even looked functioning on 20 MHz ( but not 25 ; )
  • CPU module testing without memory
    SHAOS05/21/2018 at 05:56 0 comments
    As I already wrote before, CPU module alone could be used to test 1801VM2 CPUs - with manual clock (when user presses button periodically) and without memory (databus always returns all zeros). This board was tested today:
    This is video in 1080p60 mode:
    and this is a success! ;)
  • CPU module PCB built
    SHAOS05/13/2018 at 05:11 0 comments
    for testing purposes all ICs have sockets - now it's time to test :)
  • Live video of RAM module making
    SHAOS05/12/2018 at 04:49 5 comments
    Live video stream 1280x720 from my PowerPC G4 laptop ended - speed-up video is here:
    This is a result of almost 6-hour work:
    ZIP with SCH and BRD uploaded to Files
  • Live video of ROM module making
    SHAOS05/06/2018 at 03:56 11 comments
    I live streamed creation of ROM module board in Eagle v5 running in MacOS X 10.4 on the one of the latest PowerPC G4 laptops that I own since 2007 ;)
    Later I edited archived videos to remove pauses and made it 8x faster:
    Results (ROM 64K board) added to GitHub and here in Files:
  • Board templates
    SHAOS05/05/2018 at 15:38 0 comments
    I added board templates here and at GitHub repository (moved to GitLab in June 2018)
    it's full size board with height 70mm to make sure it fits under the power supply in mini-ITX computer case. Schematics have just header in it and nothing else:
    Shorter version, that use only Q-bus part of BBQ-bus+ interface (and fits into limits of Eagle v5 free edition):
    Schematics:
    Here you need to do address latch on your own, but PCB might be much smaller.
    Also in both cases if you don't use DMA or interrupts then you should connect BDMGI to BDMGO and BIAKI to BIAKO to make sure those daisy chains are keep functioning for the next boards connected to backplane after your board.
  • CPU module PCB ordered
    SHAOS05/02/2018 at 04:05 5 comments
    CPU module v1.0 was ordered through OSHPark:
    SCH and BRD files for Eagle v5 attached in Files section:
    https://cdn.hackaday.io/files/673692882315296/nedo1802_v1_0.zip
    and also uploaded to GitHub and later moved to GitLab:
    https://gitlab.com/shaos/pdpii
  • Working on CPU module
    SHAOS04/27/2018 at 06:36 0 comments
    1st module that I'm trying to create right now is CPU module with 1801VM2 onboard - I'm buffering everything (VM2 pins are very weak) and also this module has address decoding and indication for some important signals:
    CPU might be clocked by button, by TTL oscillator or by external clock (CLCI):
    Board will look like this (160x100 mm):
    It could be vertically inserted into mini-ITX backplane (not yet designed), but also might be used as a standalone VM2 tester
    BTW thanks to OSHPark for rendering this image ;)
    Printed it on paper to see how it may fit into mini-ITX computer case:
    As you can see CPU module is a little too high - power adapter will not allow to put it in most of the slots of mini-ITX backplane but if it will be the last board (as pictured above), it should be ok, because power adapter is a little bit shorter than mini-ITX board and we have some free space there on the side...
View all 14 project logs
Starhawk wrote 11/21/2019 at 02:41 point
For reasons that are entirely unrelated to either computing or the history thereof, in really any meaningfully establishable way at all, the name of your project invokes in my mind the name and character of an extraordinarily prominent user and "content creator" (ugh, I hate terms like that) on YouTube.
SHAOS wrote 11/22/2019 at 06:06 point
but it's PDPii and not PDPi ;)
Starhawk wrote 11/22/2019 at 10:42 point
Shhhhh...! ( :P )
Eugene Zaikonnikov wrote 06/14/2018 at 11:30 point
Cera package (white) VM2s come in several grades, as much of Soviet electronics. 1st grade is plain package, one dot under the name is 2nd grade, two dots - 3rd grade. Have to be downclocked accordingly to operate.
SHAOS wrote 06/14/2018 at 13:51 point
I was not able to run ceramic VM2 reliably even on ~0 Hz ;)
SHAOS wrote 04/08/2019 at 22:40 point
But on 1 MHz and up they are surprisingly running pretty well :)
jbroxson wrote 04/27/2018 at 21:26 point
...also since the 1801's are a bit hard to find, it might be interesting to build a mod around an FPGA (as Modzer0 mentioned)..  here is a project at OpenCores that would go a long ways to helping: https://opencores.org/project/w11
SHAOS wrote 04/28/2018 at 01:21 point
Actually 1801 is much easier to find than anything else PDP-11 related ;)
Three CPUs from this family 1801VM1 (SMD), 1801VM2 (with his CMOS version 1806VM2 in SMD package) and 1801VM3 (in DIP64!!!) are easily purchasable (but I'm currently focusing on black KR1801VM2)
Math co-processor 1801VM4 is not so easy to find - the same as more advanced Soviet PDP-11 chips - especially if they are still in use by Russian military...
Modzer0 wrote 04/28/2018 at 01:34 point
The only ones I've seen on ebay at the moment are KM1801VM2. That's from the US, other locations may have different results.
SHAOS wrote 04/28/2018 at 01:54 point
As I already said below - I bought all black ones already :)
I did this on impulse when I realized that all black VM2s that I have are running successfully through my tests ;)
So I will include tested VM2 with every kit if I will sell the kit :)
White ones (KM1801VM2 from late 80s) are still available on eBay, but I have problems to make them work reliably (may be I'm doing something wrong - for example handshake has to be delayed for earlier exemplars and so on - I'll do more experiments later with CPU board that I'm drawing right now)
P.S. Also I think it should be relatively easy to design CPU boards for PDPii that has other PDP-11 compatible processors on it - like T11, 1801VM1, 1806VM2 or even 1801VM3 (but I should decide what to do with 6 extra address lines)
SHAOS wrote 04/28/2018 at 02:09 point
Hm, 1801VM1, 1806VM2 and 1801VM3 all disappeared :(
eBay currently have only 2 lots for white 1801VM2s - from Russia and from Romania
SHAOS wrote 05/02/2018 at 01:22 point
Now I see a lot of J11 on eBay (for some reason I didn't see them before), but they are pricey ;)
Modzer0 wrote 04/28/2018 at 01:27 point
That's no longer maintained on opencores. The github w11 project is the most current. https://github.com/wfjm/w11
That is a SOC core however. It still fits on a midrange Artix-7 FPGA. If we isolated the CPU logic it should be possible to fit it on an even smaller FPGA, hopefully one with a QFN/QFP package to make it solderable by more people.  There are some FPGA DIP dev boards that would make things easier for everyone if the IP core can be fit on those chips.
There are some NOS J-11 "Jaws" CPUs still in their original packaging available on ebay. They're not exactly cheap at just under $100 USD, but it doesn't take much to get it running.
https://www.ebay.com/itm/DEC-Digital-DCJ11-AE-CPU-57-19400-09-/142036805152?hash=item21120da620
I bought some in another listing as things featured on HaD tends to get associated items bought up.
My justification to myself being I can hook one up and run it in lockstep with any FPGA solution to verify cycle accurate execution.
zpekic wrote 11/21/2019 at 00:34 point
Not sure if it was discussed here, but there is also FPGA re-creation of the actual VM1, VM2, VM3 versions: github.com/1801BM1/cpu11
jbroxson wrote 04/27/2018 at 21:20 point
I may have missed it, but have you thought about how to expose "Front Panel" controls? Since you are targeting an ITX case, you could make a PCB that would fit a 5.25 slot on the front of the case and allow for the full blinken-lights experience...
SHAOS wrote 04/28/2018 at 01:13 point
I'll think about it
SHAOS wrote 04/28/2018 at 01:56 point
Actually my mini-ITX case doesn't have front slots at all :)
SHAOS wrote 05/01/2018 at 01:28 point
I have another mini-ITX case that is a little longer - that one actually has 5-inch bay, but I better put CD-ROM there ;)
don.vukovic wrote 04/27/2018 at 00:42 point
It seems that all the chips on ebay have already been taken.
Shame.
SHAOS wrote 04/27/2018 at 06:30 point
Yes, it looks like I bought them all :(
Modzer0 wrote 04/18/2018 at 03:10 point
The J-11 is hard to find at a reasonable price. The Russian chips work but be sure to leave space for a heatsink as they get rather hot. I have the datasheets on those if you need them, in Russian, but the pinouts can be identified.
SHAOS wrote 04/18/2018 at 03:24 point
Thank you, but I have all information already and I can read Russian ;)
I even tried successfully run black 1801VM2s manually (step by step) - I'll soon document my experiments here...
Modzer0 wrote 04/18/2018 at 23:18 point
I'm working on learning more Russian. I am a fan of old computer systems. The older Russian designs is something I haven't had the opportunity to examine in depth. The PDP-8 and PDP-11 are two of my favorite architectures, and I know there were clones produced. I've restored systems and built replacement boards using FPGAs to repair and make spare parts for a couple of old systems that are still running RT-11 on a contract. I unfortunately can't share those as the client owns the designs and IP. I also don't want to make them angry as I had a lot of fun working with them. When you get your backplane specifications finished I look forward to designing some boards for it if I manage to find some free time.
SHAOS wrote 04/19/2018 at 01:02 point
Great, I'll probably will need your advice in very near future, because I'm familiar with PDP-11 instruction set only in scope of Russian machines build around PDP-11 compatible processors like Elektronika MK-85 (I own this one since 1991), Elektronika BK-0011M (recently bought one on eBay) and DVK-2 (first computer that I actually used in 1990 to learn coding in high school) and those machines were NOT clones of PDP-11 machines (no RT-11 or something was running on them). Total clones of PDP-11 line sure existed in Russia too (like Elektronika 60 and 100), but I never saw them and not even knew that they existed until like a few years ago...
P.S. Actually nobody told us in that time that 1801-series of microprocessors was PDP-11 compatible - I found out about that much later on Internet :)
