Grid-2-Audio
A convenient adapter to view the electrical grid waveform through your PC's sound card.
Public Chat
There is a lot to be observed from the waveform of the electrical mains. Harmonics, transient changes, periodic fluctuations, frequency shifts, impedance, power line communications - These all give clues as to the state of the country's electrical transmission system (or what loads your neighbour has connected). Platforms like MATLAB allow for the easy analysis of waveforms through powerful software tools, but only once the signal has been acquired.
The purpose of this project is to allow easy and safe access to the electrical grid waveform without a hassle. It's as simple as power cable in and 3.5mm audio out.
Just want to "listen"? See here: https://youtu.be/xahvkZKF86c
Current status (12/01/2019):
-->Project is COMPLETE!
-->All hardware and final enclosures are complete.
-->Reliability has been established (it doesn't burn the house down).
-->MATLAB code is done and generates figures correctly.
The Grid-2-Audio module is comprised of three main parts (plus an extra forth):
1. The case and IEC all-in-one power entry connector - As part of teaching myself AutoDesk Inventor, I decided to start with the mechanical aspect of the project. The presence of mains voltage potential is no joke and the design of the case reflects that. The utilisation of an IEC power socket with built in switching, fusing and illumination minimises any mains wiring around the internal space of the unit.
2. The PCB power supply and mains input - As the unit is design to measure the grid voltage and introduce minimal noise, the power supply needs to ideally draw a minimal sinusoidal current (at the fundamental frequency) in phase with the voltage. Additionally, there needs to be isolation between the mains measurement circuit and the output side, forcing the requirement of multiple transformer taps for the whole PCB.
3. The PCB signal conditioning - The mains signal needs to be conditioned to the 3.5mm audio format and protected from shorts. As an extra feature, a 50Hz high-pass filter will be included to provide an alternate "harmonic only" output to increase the dynamic range for harmonic analysis. EDIT - The filter has since been removed and will now be accomplished via software libraries within MATLAB, etc.
4. Cooling fan add-on! Let's not start fires here.
Here's some pictures of the project and my favourite results:
Now the good stuff! The waterfall spectrums captured while some interesting equipment was in operation:
(Bonus vertically-mirrored 3D print of the first 40 minutes above):
This third one is from 6.00pm-9.40pm of the hottest day EVER in Adelaide, Australia (24/01/19):
A good transient captured (unrelated to above):
The process of capturing some data:
And finally, what does the grid "sound" like (with a high pass filter)?
Note:
Brian was kind enough to write about this project on the main page some time back: https://hackaday.com/2018/08/23/listening-to-mains-power/
There were some interesting ideas in the comments about retrieving isolated signals, but what I certainly took to heart was the emphasis on isolation distances. Although I couldn't achieve 6mm clearance (I increased it to 5mm), I added slots (for extra creepage) and increased the mains voltage divider resistance values to only allow a "2mA shock" if the isolation AND earth fail.
Edit:
Part 2: https://hackaday.com/2019/01/14/listening-to-mains-power-part-2/
3D Print Files.zip
An upload of the 3D print STL file for the first waterfall diagram generated that had interesting results. This also contains an excel file with the raw data.
x-zip-compressed - 40.63 MB - 01/30/2019 at 10:31
Download
Final Post Selection for Upload.zip
This contains a 3 minute RAW .WAV audio recording along with the "interesting" high-pass filtered "sound" of the grid that is featured up the top in the youtube video. Also included are the results (jpg) from the matlab run. Basically, this is the last set of results obtained before I finished this project. I'd just upload everything, but there is a 50MB limit per file upload...
x-zip-compressed - 29.89 MB - 01/12/2019 at 09:23
Download
Hottest Day on Record.zip
This contains the images from my project log on the hottest day ever in Adelaide. Unfortunately, it's only the images as the data is way beyond the 50MB size limit. Still, it's always nice to have them collected here and not lost in the endless log list.
x-zip-compressed - 2.95 MB - 01/28/2019 at 01:50
Download
WaterFall Era Pics Selection.zip
Selection of some JPGs of MATLAB plots, along with two actual plots in the MATLAB figure format. I'd like to just upload everything, but the waterfall plots are making these figures huge and that's just not possible any more. From now on it'll just by JPGs.
x-zip-compressed - 38.32 MB - 01/10/2019 at 11:03
Download
MATLAB Scripts.zip
The MATLAB code used to acquire data. Configuration is made in "main" and "sample grabber". Realistically, don't expect it to work with different sample rates, etc. without modification. Or just don't expect it to work at all. Run everything from "main". Written in MATLAB R2017a.
x-zip-compressed - 36.82 kB - 01/10/2019 at 10:46
Download
View all 16 files
View all 14 components
  • Suprise! 3D Printed Spectrum Plot!
    David Scholten01/30/2019 at 00:21 0 comments
    As a bonus for the project, I found my old MATLAB scripts for converting surface plots to STL files and decided to have some fun. So I now present to you a 3D print of the grid harmonics over a 40 minute window:
    Here is the original data plus more (which is mirrored on the frequency axis from the print):
    NOTE: The 3D print is the first 40 minutes of the above spectrum only.
    Unfortunately, the data is not smooth. Filtering is not really practical as the data of the fainter harmonics is spatially very narrow. Although it's not really captured in the images, holding the object in the right light makes all of the harmonics very visible. If I can reduce the size of the STL file I'll upload it, but this is unlikely.
    However, printing a difficult spectrum plot like this does seem like a great place to try colour changing filament that is temperature dependent. The physically higher the data printed, the higher I set the temperature (and thus the more of a colour change). Perhaps the perfect application actually?
    Another project for one day :)
  • Data from the Hottest Day Ever in Adelaide, Australia
    David Scholten01/28/2019 at 01:38 0 comments
    I couldn't miss this opportunity! Adelaide recently experienced its hottest day in recorded history! It was 46.6 degrees Celsius in the city! This occurred on the 24/01/19.
    Two years ago South Australia experienced a state-wide blackout and in response we have had the largest lithium-ion battery in the world installed by Elon Musk and additional emergency generators installed to help prevent future blackouts such as this. Storage and backups like this are especially important due to our weather which basically ensures that every air-conditioner in the country is turned when every one gets home and the solar panels start to ramp down. Normally SA can import power from our neighbouring state Victoria, but they has a similar problem on that day. In addition, Victoria couldn't import any power from their neighbour New South Wales as the link was down (likely due to the heat!).
    So, with all that in mind, here's the state of the Australian electrical grid at 9pm that day.
    The prices above are in AU$ per mega watt-hour. Yes, that says $14,500, it actually hit the market cap.
    You may notice that the inter state links are NOT maxed out. I believe this is because the market operator would rather leave them as a backup and instead first rely on the more expensive (but reliable) emergency generation within the states (the SA-VIC link tripping is what caused the previous SA blackout). However, I'm not a market operator so that's just my guess. Though I can confirm that when the prices suddenly dropped back down to $100 per MWh, the links did take the load as the emergency options were shut down.
    Here's the demand curve and the wholesale price:
    And here's a blackout map:
    According to a news report from the ABC, these blackouts were caused by blown fuses on transformers and not load shedding (which is what is looks like according to the map above). Apparently, it was still 35 degrees Celsius at 10pm (a time with no local solar production throughout the neighbourhoods). See:
    https://www.abc.net.au/news/2019-01-25/sa-blackouts-related-to-heat-not-network-sapn-says/10748884
    So, what did I record? I had to work during the day, but I did record the grid from 6pm-9.40pm:
    The hottest time was about 5pm, so I did miss the peak, but you can still see some fun stuff.
    Yes, I would have left it running all day, but ironically it would have heated the room that my family was trying not to burn to death in (i.e. in front of the air-conditioner).
    Also I'm sorry I didn't record any actual audio - It's a difficult process due to weird reasons.
    Here's a zoom of the spectrum from above:
    Anyway, I'm happy there wasn't a blackout, but I'm scared to think how this will affect electricity prices going forwards.
    I'll upload one more little treat tonight once it's done.
  • It's Finished - All the Fun Stuff is Here!
    David Scholten01/12/2019 at 08:49 0 comments
    It's done! After all this time it's finished!
    Here's all the good stuff that you probably wanted after seeing the title of this project.
    First of all, here is the "sound" of the grid after filtering away the lower frequencies (5 min):
    As the description reads:
    "This is a 5 minute snippet of the sound of the electrical grid in Adelaide during a period where something was connected that generated a "lot" of noise in harmonics. It slowly comes in over the first 20 seconds and then abruptly changes at 2:45. The image is the waterfall of the 8 hour period of sampling, but the 5 minute clip is from the centre of the circled section. The high pass filter is set to crossover at about 2-2.5kHz."
    Here is the process of obtaining the data (a 1 hour snippet that includes the live audio high pass filtered):
    From the video description:
    "This is a 1 hour recording of the MATLAB data recording and processing of my Grid-2-Audio project. For size limitation reasons, only a 1 hour snippet can be shown. The audio you are hearing is the high-pass filtered voltage of the electrical mains during the measurements. The high pass filter is set to crossover at about 2-2.5kHz."
    Also, here is an example of the waveform in Soundcard Scope:
    Note that nothing really happens at all in this video...
    I've also uploaded an example audio recording of the the grid voltage without the high-pass filtering.
    SPOILER ALERT: It sounds like hum.
    Other than fixing up the project description to include all the best bits for people dropping by randomly (hello from Jan 2019!), there is nothing else to be done here - I'm finished. I have a new job starting on Monday and I need the head space. I'll mark the project as complete and that will be that.
    Of course I'll still record the grid every now and then. Should I find something good I'll upload it, but there are no guarantees.
    So good morning, good afternoon, good evening and good night. It's time to start something new.
    -David
  • MATLAB Code Finished
    David Scholten01/10/2019 at 10:40 0 comments
    So, after all this time I've finally drawn the line and said enough is enough - The code is done.
    Here is the final format of the MATLAB figure that is produced throughout measurement:
    On the left side (first column) we have from top to bottom:
    -The historical Vrms voltage.
    -The historical fundamental frequency.
    -The historical THD%.
    -The historical frequency waterfall spectrum.
    (2 second sampling/averaging period!)
    On the right side we have:
    -The highest peak voltage captured since the recording started (red circle shows location). This is a plot of the actual moment it was detected.
    -The highest THD recorded. The plot is of one 20ms period from the sample where the highest THD was recorded. This is NOT the period with the highest THD itself.
    -The current cycle is the first 20ms from the current 2 second sample.
    -The zoom is the same but zoomed into pi/2 to 2pi/3.
    -The left frequency plot is for the first 20 harmonics.
    -The right frequency plot is for the 1-20kHz harmonics (i.e. switching frequencies and other strange things). This is best seen as a representation of the current sample for the waterfall of the bottom left.
    Here is a 30 minute recording of the data gathering process:
    During this recording (I used VLC) the washing machine was running it's cycle and the kettle was used.
    The sudden transient spike in the THD near the end is a bug and I have no idea why it is present.
    If you watch carefully during the strange activity on the waterfall (example video time stamp: 2.20-2.25), you''ll see the front of the waveform chopped off. While I want to believe that's the washing machine's phase controlled voltage regulation, it's more likely that VLC's stream recording from the desktop was momentarily holding up the soundcard from MATLAB. This is especially apparent when you notice that there period of the waveform shortens by about 20%.  I've never seen this before without VLC recording - So it's a very plausible theory.
    I've uploaded the MATLAB code and a bunch of results that I've collected.
    What I'll try and do next is record the audio (via soundcard scope) while recording the MATLAB data acquisition using VLC. Then, I'll sink it all up (with the 50Hz hum removed, etc) and make a youtube video. There are two huge problems with this though:
    -The sound card is now shared between three programs? I'm sure that will work just fine.
    -I need an interesting signal to be present like the changing one in those nice two waterfall diagrams. THIS IS RARE.
    So good luck to me and having everything work at once, but it has to happen eventually.
  • Waterfall Success!
    David Scholten01/03/2019 at 08:23 0 comments
    Finally having some success with the FFTs through MATLAB. Most of the difficulty was tuning the visual display and colour chart to display anything of interest (and then waiting for something to happen to test a configuration of display variables). A very frustrating process.
    I initially had some success plotting a waterfall using only the harmonics from the "thd" function, but I quickly realised this, when exported to an array, only includes the actual harmonics (i.e. 100, 150, 200, 250Hz, etc) and not the other frequencies in between.
    Now, using the FFT library and some guides (with only a moderate understanding of the process), I have produced the following, which captures the weird signal (along with some other faint ones):
    Now as with everything with MATLAB, there are some hidden conveniences! I can rotate the plot into 3D:
    Just ignore the magnitude of the voltage though, I do not trust that it is scaled correctly!
    Soon I'll match these plots up with the Vrms, THD and frequency plots to try and see what is triggering these signals (i.e. are they grid distribution control signals or just harmonics from something?).
    EDIT:
    Here are some more!
    I'll just stick to the 2D view from now on as the 3D seems a bit useless (I really nailed the colour map tuning - go team me).
  • A Good Set of Results!
    David Scholten01/01/2019 at 02:36 0 comments
    Okay, I know it's been a while (I'm a Daddy now!), but I have obtained the longest stretch of results that I possibly could without leaving the computer unattended.
    Everything on the right side is just the final instantaneous snapshot of the measurement run and isn't that interesting. However, everything on the left is a running set of results where each time division (1x10^4) represents almost 4 hours of time.
    The results started recording about 10am in the morning and ran till about 12am (~14 hours).
    What I've learnt from this is that yes, I can see any time that a heavy load is turned on in the house (hair dryer, compressor, kettle or microwave). This can be seen on the Vrms plot as little sharp drops of 2-3 volts). I also see larger slower drops that must be from local industry (there is a vehicle works shop 3 houses down the road).
    The grid frequency over that day is its own thing and is primarily controlled by the collective behaviour of all of the customers and the generation regulation.
    The peak voltage is interesting in that is sometimes seems to capture some little transients. However, this will never be reliable as the sampling by MATLAB goes long periods without actually looking at the grid (it's luck if I grab a transient peak really).
    The THD is great as it seems to vary in an interesting way in reaction to loads. For example, a linear load (resistor) like a kettle will simply drop the voltage across all frequencies. However, a heavy load with power factor correction and input filtering SHOULD (as far as I can casually comment) only draw fundamental current. Thus, the fundamental voltage component of the grid will sag a few volts, but the harmonic ripples will NOT. As a result, the ratio of the harmonics to the fundamental voltage (i.e. the THD) will increase. As a result, such fundamental current only devices should increase the grid voltage THD when they are turned on. Good luck observing this! And good luck separating such an effect from other variables that may overwhelm and make the opposite occur!
    I'll also upload this MATLAB plot, along with others that are okay or decent.
    When taking these results I have also noticed some very strange frequencies that seem to shift in reaction to THD or Vrms thresholds (cause and effect confusion maybe?). To show this to you I plan on getting the harmonic waterfall plotting working. This should allow a nice visual representation of what's going on over a day.
    As you may have guessed, I'm certainly looking to wrap this project up (it's been a long time and I've lost interest).
    Before I finish I'd like to:
    -->Have some waterfall plots.
    -->Video output of the grid.
    -->Some kind of audio representation.
    -->Raw data file for others.
    Oh and here's the hair dryer turning off:
    This also shows some mysterious 5kHz and 10kHz signals (bottom right black spectrum).
  • More Results
    David Scholten12/10/2018 at 11:07 0 comments
    After leaving the computer on for an hour straight (and teaching MATLAB not to move the graph in front of my web browser) I have some interesting results:
    I seems to have captured a significant peak voltage surge and 15 minutes later, a sudden rise and drop in the THD.
    What's interesting is that the 5, 10 and 15kHz signals came in at exactly the same time that the THD dropped.
    As the THD is calculated only from the first 40 harmonics (<2kHz), it is not the signals causing the THD change. Rather, this may be some kind of signalling from the energy distributor?
    Anyway, I'm installing MATLAB on a laptop so I can monitor for longer periods of time (and have battery power to allow for the capture of blackouts!)
    This plot is currently uploaded as a MATLAB figure file for a limited time.
  • It's all downhill now!
    David Scholten12/08/2018 at 11:12 0 comments
  • Quick MATLAB Progress
    David Scholten12/04/2018 at 11:44 0 comments
    So, first of all, sound card samples through MATLAB look like this raw:
    So I have to purge near 10 cycles (also not seen is the initial transient spike for the first 100 or so micro seconds).
    After this though, I can grab some nice data!
     I'll have a go at adding some FFT functionality over the next few days and get back to you.
  • Heat Problem is Under Control
    David Scholten11/03/2018 at 07:04 0 comments
    Okay, so after developing another version of the cooling add-on (that's far more mechanically robust and requires no printing supports), I have finally managed to keep the thing cool.
    And by cool I mean stupidly cool - We're talking only a 5-10 degrees Celsius rise above the ambient.
    It turns out it needed minimal air flow (of any amount) to move the little amount of heat it's producing.
    Here we go:
    It's not the prettiest looking case accessory, but it certainly gets the job done via the 1W/5V USB fan. Now instead of going from 23C to 75C in 2 hours it goes from 23C to 30C in 20 minutes.
    I also had a look at the waveform directly to see if the fan attachment was coupling any EMI to the measurement circuit. Turns out it isn't! I also tuned the output filtering pF capacitor a little to ensure that the RF/op-amp oscillation fluff was minimised.
    Next step is the MATLAB stuff!
View all 31 project logs
David Scholten wrote 12/04/2018 at 00:15 point
No updates recently, I know, but some progress is being made.
MATLAB is proving easier to use than I remember (I finally updated to the latest version) and plotting is ridiculously easy.
David Scholten wrote 09/27/2018 at 12:45 point
I've spent waaaay too much time on this and won't dedicating another project log to it, but I've uploaded a 50MB collection of very beautiful Fusion 360 PCB/enclosure renders to the files section. The best of the best (naturally) have become the cover photos you see up the top and top-left. Enjoy!
David Scholten wrote 09/06/2018 at 01:26 point
UPDATE:
Orders for the PCBs V2 are away as of the 2nd September! Some critical changes to footprints and safety warranted a new revision. The total cost for 10 unloaded boards was about $30 (including express DHL shipping) from Seeed Fusion (posted to Australia).
KD9KCK wrote 08/23/2018 at 21:26 point
Would this work properly on 60Hz 120V American Power lines? Or would some parts have to be slightly changed?
David Scholten wrote 08/24/2018 at 00:00 point
Hi Chibill, to adapt it to 60Hz/120V you would need to to replace the two transformers:
http://au.element14.com/block/vb1-0-2-15/transformer-1va-2-x-15v/dp/1131617
with equivalent 60Hz/120V variants.
Additionally you would need to remove one of the divider resistors and change the tiny input filtering capacitor that is in parallel with that same resistor (or just remove it, I doubt it will have much of an effect).
Once I have the PCBs/parts and I can test the design I'll upload the CAD files along with regional variations (if I can find alternate transformers in the same footprints).
KD9KCK wrote 08/24/2018 at 00:31 point
okay. Sort of figured the transformers would have to be replaced. (As that would lower the voltage on the inside of the device if it wasn't changed)
David Scholten wrote 08/15/2018 at 12:54 point
Orders for the components are away as well! The total cost shared between Element14 and Digikey (including shipping and everything) was $137AUD. I did over-order on a fair few parts to provide a few likely spares though.
I'd rate that new sub-$1000 Australian GST tax a solid 3/10. Ouch.
David Scholten wrote 08/11/2018 at 02:10 point
Orders for the PCBs are away! The total cost for 10 unloaded boards was $18USD (including shipping) from Seeed Fusion (posted to Australia).
