Features
- a USB device port with cable shield filtering and transient suppression
- a 3.3V LDO with bypass caps and filters to separate analog VDD from digital VDD
- a 32.768 KHz crystal for the master clock
- a reset pushbutton with debounce cap and pullup resistor
- a blue LED on pin 13 for the classic Blinky test
- PDIP-28 package compatible (+ VBUS pin available on one side)
- the ATSAMD21E18 in QFN package
- firmware based on the Arduino Zero core
Licences
- HACK hardware is OSHW, licensed under CERN OHL 1.2
- HACK software is LGPL 2.1 (because it's based on the Arduino Core)
Installation
- Download Arduino IDE >= version 1.6.8
- Go under File->Preferences...
- Add the following URL to Additional Boards Manager URLS:
http://mickmad.github.io/hack/package_had-mickmad_samd_index.json
- Go under Tools->Boards->Boards manager...
- Select HACK - HackAday Cortex Kit - SAMD21E by Hackaday / Michele Perla and press Install
NOTE for Windows users: When you plug the board in your USB socket, Windows will fail to install its drivers; this will happen twice: the first time you use it in Bootloader mode, and the first time you use it in Sketch mode. When this happens, please click on Start, right-click on Computer, select Properties, then select Device Manager from the left-side menu of the newly opened window, then find an Unknown Device, double-click on it, go under the Drivers tab, and click on Update driver..., click Browse my computer for driver software, click Let me pick from a list of device drivers on my computer and then click Have Disk, then in the Install From Disk dialog box, click Browse, and go to C:\Users\your-username\AppData\Local\Arduino15\packages\had-mickmad\hardware\samd\1.0.0\driversand select the hack.inf file, then finally accept the warning that the driver is not signed.
TO DOs / MAYBEs:
- Fix the bootloader double tap feature to be more reliable
- Implement a bootloader pin that when grounded turns on the bootloader
- I2S support
- Adapt #Teensy Audio Library to work with the Arduino Zero/HACK Core
- Any suggestion? Write me up!
Michele Perla
mit41301
jurc192
Sander van de Bor
doctek
Hey Michele, your board was featured quite prominently in my video:
I hope that's OK. I also opened a pull request a while back to let your project be included on kitnic.it from your repo direct, not sure if you saw that. https://github.com/MickMad/HACK/pull/2
