Me building projects from hackaday.io
This is where I build and talk about projects designed by the great people of this community.
Some boards are already here for a while, some are on their way!
  1. Pro Trinket USB Keyboard by Stefan Lochbrunner
  2. Nyan Board by Radomir Dopieralski
  3. R-2R DAC inspired by tiny7 by al1
  4. nRFIoT - Easy IoT Sensors by Justin
  5. RPi wifi hat by ajlitt [part 2]
  6. MobileVise by SUF
  7. Bicycle Drummer by serdef
  8. Snail Mail Notifier by Solenoid
  9. Tote Had by Radomir Dopieralski
  10. PCB3 - Christmas Tree PCB by Brian Lough
If you like projects that are containing other projects being build, you can check out these projects:
  • Supercon 23 badge
    davedarko • 10/28/2023 at 21:24 • 1 comment
    Don't have all parts yet, but enough to get started. I've send two PCBs to @Alex as well - but I have a head start ;)
    We had to figure out some errata ourselves, since we've ordered boards that weren't the final version apparently. The BOM itself is also different now. The MOSFET in our version had to be soldered on in dead-bug style and turned by some degrees.
    The badge worked in the end and I did two small modifications: the simple add-on was powered from the batteries, I changed that to also get 3.3V from the regulator. There was also a good use-case for an additional reset button, so I did that.
    The badge worked great after the latest firmware was pushed on it, very happy with the result!
    The 3d printed buttons arrived from JLCPCB, a long with the expander PCB, so this is complete now :)
    https://github.com/Hack-a-Day/Vectorscope
  • PCB3 - Christmas Tree PCB - by @Brian Lough
    davedarko • 12/24/2018 at 06:39 • 0 comments
    #PCB3 - Christmas Tree PCB - by @Brian Lough
    It has been a while that I made an entry here :) I was soldering the kit by Brian last weekend as a present for my Grandparents! Worked quite well, as it uses the same technique as my #PCB word clock - soldering LEDs upside down and shining through the PCB. There are a lot of PCB art trees out there, but this is one of my favorites. Probably because the code was inspired by my #sloth badge and Brian was cool about it and gave a lot of credits on his tindie page ;)
    Of course I had to run into troubles while soldering it, a USB breakout board had all the pins connected, so I had to reprint and resolder the base.
    You can download the base designed by @Tobias over here https://twitter.com/Tobi4sDE/status/1073852240287465472?s=19 but be warned, I had to scale it up to 108% on my zortrax 3d printer to make it fit.
  • #RPi WiFi Hat - by @ajlitt (PART 2:FAILFIGHTING)
    davedarko • 08/28/2016 at 18:24 • 1 comment
    so I finally came around the other day to try out the boards I've done in Part 1 and follow the detailed instructions https://hackaday.io/project/8678/instructions
    As suggested, I also followed the OTG tutorial to control it over just one usb cable from my usb3 port. awesome.
    So here it is - PROTIP: don't make shields like that! I tried to debug it for a whole while until I noticed that I had it put in backwards. Now I'm able to ssh via USB into a raspberry and scan for SSIDs and stuff. Nice.
  • Tote Had by Radomir Dopieralski
    davedarko • 04/02/2016 at 09:42 • 13 comments
    #Tote HaD by @Radomir Dopieralski
    So I've ordered the boards and servos and already soldered a bit, although my free time is rare these months, but I wanted to bring my Tote with me to #Hackaday | Belgrade and code for it a bit. The simplicity of the #Tote is something I really liked and I never had a walking robot before, so this was a thing about to happen. Having a 3D printer at home and loving designing 3D parts I wanted some sturdier looking legs and took some basic servo mounts I designed earlier for #Johnny IV
    As soon as the parts are all printed, I will update this post.
  • Snail Mail Notifier by Solenoid
    davedarko • 03/09/2016 at 21:34 • 2 comments
    #Snail Mail Notifier by @Solenoid
    This is a long time shelfie, because I never had the 0805/0603 parts - and I'm not done yet. I'm just now able to use and program the receiver as a digispark. Rewarding hacking around though. I hope I can get some decoding of weather stations going. This is one of the first boards I got from a member of this community, and I like that very much. And by the way, look at those diodes! And of course, the LED is in backwards 🙈
    An interesting link I found, where the digispark is being used as a crude oscilloscope, takes PIN 2 as an input, which is coincidentally the same pin the data goes on the 433MHz.
    http://digistump.com/wiki/digispark/tutorials/digiscope
    Bootloader: https://github.com/micronucleus/micronucleus/tree/master/firmware/releases
    avrdude -p t85 -c usbasp -B 20 -U efuse:w:0xFE:m
    avrdude -p t85 -c usbasp -B 20 -U lfuse:w:0xE1:m
    avrdude -p t85 -c usbasp -B 20 -U hfuse:w:0xDD:m
    avrdude -p t85 -c usbasp -U flash:w:t85_default.hex:i
    And some cheat sheets, since I always forget:
  • ​Bicycle Drummer by serdef
    davedarko • 02/27/2016 at 20:16 • 0 comments
    #Bicycle Drummer by @serdef
    One of my first projects that I've posted here is my most skulled and at the same time most neglected project - #Open Bicycle Computer - around the time when I posted it, I've checked for other interesting projects around that subject and found serdef's #Bicycle Drummer. It's essentially an arduino controlling a "Dreamblaster S1" board via TTL midi signals, where the speed of a loop is defined by your cycling speed. Sounds awesome - not just the idea but the actual baseline as well! The dreamblaster is build around the SAM2195 chip, which has 127 instruments and the first thing I did was playing a note with every instrument there is. I was disappointed by the steel-drum, but the rest was nice to listen to.
    http://www.serdashop.com/waveblaster
    What you can see here is a first result of a 'getting to know' session with the board. If you think the same way about my talking speed (too slow) then you might want to check the settings of the player, because you can speed it up to 1.5x and still get along easily :D I'm always tired when filming... meh. I'm sorry.
    *DISCLAIMER: because I feel I have to say this, serdef send me this board and the arduino+expansion board kindly to play with it and come up with some projects. I'm happy to do so, because I always wanted to get into midi and this connects well with my music hobby and electronics hobby. It's also cool to switch from blinking to making noises sometimes :D
  • MobileVise by SUF
    davedarko • 01/18/2016 at 14:09 • 4 comments
    #MobileVise - by @SUF
    Since I first saw the #Stickvise - low profile soldering vise by @Alex Rich I wanted to have one, but I'm cheap when it comes to pay for a decent tool. When @SUF posted his mobile 3D printed version, I thought I can print that! I found a M6 bolt and two nuts and I finally have something to holt my protoboards and arduinos ;)
  • ​RPi WiFi Hat - by ajlitt
    davedarko • 12/11/2015 at 12:17 • 8 comments
    [update 2015-03-05] new simplified design based on newest development of @ajlitt
    Using an ESP8266 (ESP03) connected to a Raspberry PI over the SDI interface - that just looks too awesome! I still have an ESP03 that doesn't fit my #Ignore this ESP8266 board so I have to try this! If it works, I might be crazy enough to make a pi Hat, since the ESP8266EX does not need that many external parts.
    Just for the clicks I'll add a screenshot for a mocked up panelized version of a board that isn't routed or thought through much. I should add a 3.3v converter.
    https://www.adafruit.com/images/product-files/2471/0A-ESP8266__Datasheet__EN_v4.3.pdf
    https://www.sparkfun.com/products/13231
    Oh. I have to sleep on this. If anyone wants to look over it, feel free, would make me happy :) if you have a suggestion, please leave a comment.
    https://github.com/davedarko/PIzero
    I panelized the board that is based on ajlitt's latest update, fitted to a 5x5 cm2 board and ordered it at dirtypcbs.com - I went with blue because I thought the ESP12F was blue, but it's actually black. Ah well.
  • nRFIoT - Easy IoT Sensors by https://hackaday.io/justind000​
    davedarko • 11/09/2015 at 10:26 • 1 comment
    #nRFIoT - Easy IoT Sensors by https://hackaday.io/justind000
    This is my take on the idea of a nRF24L01 shield for arduino minis. They are cheap like the nRF24 modules and I want to work on a remote for my droids and drones in the future. I used 1206 parts and mini usb because I have a lot of them.
  • R-2R DAC inspired by tiny7 by al1
    davedarko • 11/04/2015 at 09:51 • 8 comments
    Inspired by #tiny7 by @al1
    Following @Elliot Williams on youtube I noticed his next "logic noise" HaDblog post will feature R-2R DACs and an hour later I had this idea for a little project, using a shift register with some 6.8kOhm resistors I have too many of. Since I really liked the Idea of using the accessible ISP header on arduinos to send data to the shift register like the #tiny7 by @al1 does, I had to put this on a protoboard. Expect some weird sounds to follow, because they are nowhere near to be accurate with 5% tolerance resistors. This just screams for a self checking arduino script that writes data out and checks the output with analog input.
View all 12 project logs
Craig Hissett wrote 10/29/2015 at 10:28 • point
Well this is a beauty! @Stefan Lochbrunner and you have made a great product :)
I need to re-work an old project of mine (an arduino-based footswitch for passing keyboard commands to my laptop for recording music hands free) into a small, handheld version ( to be attached to my brass instruments for quick and easy triggering of my software).
I'd also like one or two for attaching to my PCs at work to pre-program shortcuts for some of the idiots that use my systems in my absence.
This little beauty would be great! I have a few Arduino Pro Micros which would do what the trinket does; if the pin outs are compatible it's game on!
Stefan Lochbrunner wrote 10/29/2015 at 11:27 • point
You can also solder the circuit (MCU, crystal, USB, ...) of the Pro Trinket directly on the PCB so you don't necessarily need an additional board. But if you'd like to use a Pro Micro, the schematics and board files are all in a GitHub repo for that project so you could easily modify it to fit a Pro Micro.
Craig Hissett wrote 10/29/2015 at 11:31 • point
Hmmm, I may just have to invest in some Pro Trinkets!
I was just being lazy/tight, trying to use what I already had at my disposal. Since writing that comment, however, I haven't stopped thinking about how good a fleet of these would be, so it would be worth the cost to have them made as you guys intended :)
Stefan Lochbrunner wrote 10/29/2015 at 11:43 • point
I still have 8 of those boards left over so if you go with the Pro Trinkets I'd be happy to send you some. I also wouldn't mind making a version for the Pro Micro so if you were planning on ordering PCBs you might as well order ones that match (and have all the latest features).
Craig Hissett wrote 10/29/2015 at 12:29 • point
I'd absolutely love some boards mate!
If you drop me a message letting me know costs and I'll get you paid asap. Hero!
Mike Maluk wrote 10/29/2015 at 02:09 • point
Nice use of servo arms! :P
davedarko wrote 10/29/2015 at 07:25 • point
otherwise the arduino would have fallen off ;)
Adam Fabio wrote 10/29/2015 at 01:43 • point
Dave - This is awesome!
davedarko wrote 10/29/2015 at 07:24 • point
Stefan Lochbrunner wrote 10/28/2015 at 18:34 • point
The purple buttons go great with the black PCBs! Having the HaD Trinket right next to it makes me think I should have ordered the board with ENIG finish though ;)
davedarko wrote 10/28/2015 at 18:42 • point
I love the look! Totally worth the money! Ah well... debatable luxury, paid 25bugs for parts, but I swear I'm going to use it! The gold stuff will be covered with tin soon enough ;)
Stefan Lochbrunner wrote 10/28/2015 at 18:53 • point
You're right, the gold will be covered but those three colors look great together. I can't quite imagine red, green and blue LEDs but maybe warm white/yellow? Or perhaps cold white to go with the silver of the tin?
I can't wait to see the finished version so get soldering already! ;P
davedarko wrote 10/28/2015 at 19:10 • point
well I've noticed I'm also missing some LEDs ;) Is it 0603 or 0805? gotta check eBay out. And yes, the colors are awesome :)
Stefan Lochbrunner wrote 10/28/2015 at 19:32 • point
It's 0805. Keep in mind that they are in series, so 2x their forward voltage should be below 5V. If necessary you can 'reconfigure' them to be in parallel, like I did with blue ones.
davedarko wrote 10/28/2015 at 20:02 • point
Hmmm, [yellow, orange and warm white] OR [red, blue and warm white] ?
davedarko wrote 10/28/2015 at 20:33 • point
went with yoww :)
Stefan Lochbrunner wrote 10/28/2015 at 20:37 • point
Just looked at some yellow ones and I think most will have a green tint so those probably wouldn't look too good. I really like the orange/amber ones you used in #fixietube clock [why haven't I followed & skulled this ?!? ...yet ;) ] and how they look with the blue ones (which kind of look purple in the 2nd image). So I guess my suggestion is [orange/amber, blue & warm white].
edit: D'OH! ...too late ;)
Stefan-Xp wrote 10/28/2015 at 22:16 • point
Awesome ;) Did you know you could also buy 80% Gold Solder? ;)
http://www.indium.com/solders/gold/
