1Step 1
For mechanical assembly, follow the instructions for #Tote at http://tote.readthedocs.org
2Step 2
The code repository at https://bitbucket.org/thesheep/tote0/src contains all the files needed -- copy them to the pi
3Step 3
Get ServoBlaster from https://github.com/richardghirst/PiBits/tree/master/ServoBlaster and compile it and install
4Step 4
Copy the 'servoblaster' startup script from the code repository to /etc/init.d and make it start at startup
5Step 5
Run the run.py program
6Step 6
PROFIT!!!
deʃhipu
