Hackaday.io Hackaday.io
Sign up Log in
blinking things
this is a rebranded project, sorry guys. take your skulls/likes back if you want :)
davedarkodavedarko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.2k views
5 comments
2.5k followers
  • Description
  • Details
  • Files 7
    • View all
  • Components 0
  • Logs 13
    • View all
  • Instructions 0
  • Discussion 5
View Gallery
3.2k
5
2.5k
15
Team (1)
  • davedarkodavedarko
Join this project's team
hardware
ongoing project
blink cmos arduino OTHERS
This project was created on 02/17/2016 and last updated 3 years ago.
Starting from
Buy on Tindie
has orders / reviews
Ships from
Description
This is supposed to be a generic 555 timer, 4017 decade counter and ULN2004 multiple stage blinking prop board. Every classic science fiction has a prop that blinks. Most of them have four stages. classic 4 stage blinking prop board. Also attiny85 versions to find here and other mcus, this is a blinking things project.
Files
starblinken.sch
sch - 720.64 kB - 07/29/2018 at 10:05
Download
starblinken.brd
brd - 790.30 kB - 07/29/2018 at 10:05
Download
board.sch
ws2812 wemos shield
sch - 232.86 kB - 05/11/2017 at 19:12
Download
board.brd
ws2812 wemos shield
brd - 77.95 kB - 05/11/2017 at 19:12
Download
711_mirr_matrix.sch
sch - 324.62 kB - 05/11/2017 at 19:10
Download
View all 7 files
Project Logs
Collapse
  • boom, starblinken kit is on tindie!
    davedarko • 09/06/2018 at 09:34 • 0 comments
    I've tested and verified my design and put it on tindie btw. :)
    --End of Advertisement--
    https://www.tindie.com/products/davedarko/starblinken-diy-kit/
  • here's a little video
    davedarko • 07/29/2018 at 14:23 • 0 comments
  • verified the board design
    davedarko • 07/22/2018 at 14:34 • 0 comments
    I hand wired a combo of NE555, CD4017 and two ULN2003 chips. I also spray painted the protoboard before that. The capacitor I chose is a bit too small, so the animation is a bit too fast. I'll need to grab a 2uF instead of a 1uF cap. Definitely need to add a 100nF cap for the 555 and maybe some more all around.
    here's a link to it working:
    https://www.instagram.com/p/BliYSjGDVXg/?taken-by=davedarkocom
  • working on a star blinken thing
    davedarko • 07/20/2018 at 07:10 • 0 comments
    finally came back to this :)
  • RGBY LEDs
    davedarko • 05/14/2017 at 09:55 • 0 comments
    http://www.ebay.de/itm/172664995172
    I've ordered some of CNLohr's RGBY LEDs for my WeMos shield, will update this once they arrive :)
  • HT16K33 board arrived
    davedarko • 05/11/2017 at 19:09 • 1 comment
    Board works :)
  • HT16K33 board for 11x7 LED matrix
    davedarko • 04/15/2017 at 16:04 • 5 comments
    I recently bought a cool 11x7 matrix, that is just great to display 4 3x5 digits and I want to control it with the well supported HT16K33 - so here's a not so beautiful and highly convoluted board for that.
  • 2nd try - this time with SK6812 LEDs
    davedarko • 03/03/2017 at 17:51 • 0 comments
    Definitely mooooaaar white :)
  • Got scammed on aliexpress? meh
    davedarko • 03/01/2017 at 11:40 • 7 comments
    So I thought I've bought the new SK6812 with RGBNW on aliexpress.com, but instead I received some standard RGB WS2812 LEDs - not cool :( but the shield works. Now I've bought half of the LEDs for the same price on eBay, let's see how that will turn out ;) dispute on aliexpress was opened, hoping for at least some refund.
    Order from OSH Park
  • 3 little boards - blinky stuff
    davedarko • 02/10/2017 at 19:37 • 2 comments
    Wemos 2812B moaaaar LEDs shield
    After seeing RGBW LEDs on the Adafruit stream I quickly went on Aliexpress to buy some and then designed a Wemos D1 shield for them, just not with only one LED.
    SMD LED bargraph for breadboards (with Resistors)
    A classic, but I was in the mood to design it.
    RGB LEDs charlie-plexed pinout
    This is basically the layout of one column of a 4x4x4 RGB LED cube...
View all 13 project logs
Log In/Sign up to comment
Sign up with Github
OR
rajulavanya924 wrote 02/18/2016 at 05:57 • point
this really amazing
Benchoff wrote 02/17/2016 at 20:04 • point
You know you can rent the "star trek random science prop" for $700/week, right?
https://www.modernprops.com/Details1b.asp?dept=195&category=290&item=1
davedarko wrote 02/18/2016 at 09:06 • point
yes, I've seen that :) It's been in many movies and series so far.. I guess I have to build that with the board as well, but smaller :D
Mangus Tiranus wrote 03/01/2017 at 13:00 • point
The laser neon blinky thing has also been in Alriplane 2 :p And Battlestar Galactica, Prolly the most widely used prop ever :D
davedarko wrote 03/01/2017 at 14:21 • point
love it :)
A Monome-like 4x4 tilable pad with RGB leds
Project Owner Contributor
Moka
pierre-loup-mPierre-Loup M.
Blinky leaves, enamel wire trunk, arduino roots
Another LED tree
pP
an ESP8266 board for cool displays
ACABxie
davedarkodavedarko
Hackaday Prize 2019
An 8x8x8 RGB LED cube kit using addressable LEDs!
CUBEx8
burkethosburkethos
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "blinking things", please tell us the reason.
Send message
Remove Member
