this is a rebranded project, sorry guys. take your skulls/likes back if you want :)
starblinken.schsch - 720.64 kB - 07/29/2018 at 10:05 |
starblinken.brdbrd - 790.30 kB - 07/29/2018 at 10:05 |
board.schws2812 wemos shieldsch - 232.86 kB - 05/11/2017 at 19:12 |
board.brdws2812 wemos shieldbrd - 77.95 kB - 05/11/2017 at 19:12 |
711_mirr_matrix.schsch - 324.62 kB - 05/11/2017 at 19:10 |
I've tested and verified my design and put it on tindie btw. :)
--End of Advertisement--
https://www.tindie.com/products/davedarko/starblinken-diy-kit/
I hand wired a combo of NE555, CD4017 and two ULN2003 chips. I also spray painted the protoboard before that. The capacitor I chose is a bit too small, so the animation is a bit too fast. I'll need to grab a 2uF instead of a 1uF cap. Definitely need to add a 100nF cap for the 555 and maybe some more all around.
here's a link to it working:
https://www.instagram.com/p/BliYSjGDVXg/?taken-by=davedarkocom
finally came back to this :)
http://www.ebay.de/itm/172664995172
I've ordered some of CNLohr's RGBY LEDs for my WeMos shield, will update this once they arrive :)
Board works :)
I recently bought a cool 11x7 matrix, that is just great to display 4 3x5 digits and I want to control it with the well supported HT16K33 - so here's a not so beautiful and highly convoluted board for that.
Definitely mooooaaar white :)
So I thought I've bought the new SK6812 with RGBNW on aliexpress.com, but instead I received some standard RGB WS2812 LEDs - not cool :( but the shield works. Now I've bought half of the LEDs for the same price on eBay, let's see how that will turn out ;) dispute on aliexpress was opened, hoping for at least some refund.
Wemos 2812B moaaaar LEDs shield
After seeing RGBW LEDs on the Adafruit stream I quickly went on Aliexpress to buy some and then designed a Wemos D1 shield for them, just not with only one LED.
SMD LED bargraph for breadboards (with Resistors)
A classic, but I was in the mood to design it.
RGB LEDs charlie-plexed pinout
This is basically the layout of one column of a 4x4x4 RGB LED cube...
You know you can rent the "star trek random science prop" for $700/week, right?
https://www.modernprops.com/Details1b.asp?dept=195&category=290&item=1
yes, I've seen that :) It's been in many movies and series so far.. I guess I have to build that with the board as well, but smaller :D
The laser neon blinky thing has also been in Alriplane 2 :p And Battlestar Galactica, Prolly the most widely used prop ever :D
P
burkethos
alpha_ninja
this really amazing
