BAT54C Schottky Diodes Datasheet
05/27/2022 at 06:38 • 0 commentsProduct Overview
Planar Schottky barrier diodes with an integrated guard ring for stress protection,encapsulated in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package.
This blog will introduce BAT54C systematically from its features, pinout to its specifications, applications, also including BAT54C datasheet and so much more.
BAT54C Features
- Low forward voltage
- Low capacitance
- AEC-Q101 qualified
BAT54C Pinout
The following figure is the diagram of BAT54C pinout.
BAT54C Applications
l Ultra high-speed switching
l Voltage clamping
l Line termination n
l Reverse polarity protection
If you want to know more about BAT54C, you can read its datasheet.
STM32F107RCT6 Microcontrollers Datasheet
05/09/2022 at 09:10 • 0 commentsProduct Overview
The STM32F105xx and STM32F107xx connectivity line family incorporates the highperformance ARM® Cortex®-M3 32-bit RISC core operating at a 72 MHz frequency, highspeed embedded memories (Flash memory up to 256 Kbytes and SRAM 64 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses. All devices offer two 12-bit ADCs, four general-purpose 16-bit timers plus a PWM timer, as well as standard and advanced communication interfaces: up to two I2Cs, three SPIs, two I2Ss, five USARTs, an USB OTG FS and two CANs. Ethernet is available on the STM32F107xx only.
This blog will introduce STM32F107RCT6 systematically from its features, pinout to its specifications, applications, also including STM32F107RCT6 datasheet and so much more.
STM32F107RCT6 Features
• Core: ARM® 32-bit Cortex®-M3 CPU
– 72 MHz maximum frequency, 1.25 DMIPS/MHz (Dhrystone 2.1) performance at 0 wait state memory access
– Single-cycle multiplication and hardware division
• Memories
– 64 to 256 Kbytes of Flash memory
– 64 Kbytes of general-purpose SRAM
• Clock, reset and supply management
– 2.0 to 3.6 V application supply and I/Os
– POR, PDR, and programmable voltage detector (PVD)
– 3-to-25 MHz crystal oscillator
– Internal 8 MHz factory-trimmed RC
– Internal 40 kHz RC with calibration
– 32 kHz oscillator for RTC with calibration
• Low power
– Sleep, Stop and Standby modes
– VBAT supply for RTC and backup registers
• 2 × 12-bit, 1 µs A/D converters (16 channels)
– Conversion range: 0 to 3.6 V
– Sample and hold capability
– Temperature sensor
– up to 2 MSPS in interleaved mode
• 2 × 12-bit D/A converters
• DMA: 12-channel DMA controller
– Supported peripherals: timers, ADCs, DAC, I2Ss, SPIs, I2Cs and USARTs
• Debug mode
– Serial wire debug (SWD) & JTAG interfaces
– Cortex®-M3 Embedded Trace Macrocell™
• Up to 80 fast I/O ports
– 51/80 I/Os, all mappable on 16 external interrupt vectors and almost all 5 V-tolerant
• CRC calculation unit, 96-bit unique ID
• Up to 10 timers with pinout remap capability
– Up to four 16-bit timers, each with up to 4 IC/OC/PWM or pulse counter and quadrature (incremental) encoder input
– 1 × 16-bit motor control PWM timer with dead-time generation and emergency stop
– 2 × watchdog timers (Independent and Window)
– SysTick timer: a 24-bit downcounter
– 2 × 16-bit basic timers to drive the DAC
• Up to 14 communication interfaces with pinout remap capability
– Up to 2 × I2C interfaces (SMBus/PMBus)
– Up to 5 USARTs (ISO 7816 interface, LIN, IrDA capability, modem control)
– Up to 3 SPIs (18 Mbit/s), 2 with a multiplexed I2S interface that offers audio class accuracy via advanced PLL schemes
– 2 × CAN interfaces (2.0B Active) with 512 bytes of dedicated SRAM
– USB 2.0 full-speed device/host/OTG controller with on-chip PHY that supports HNP/SRP/ID with 1.25 Kbytes of dedicated SRAM
– 10/100 Ethernet MAC with dedicated DMA and SRAM (4 Kbytes): IEEE1588 hardware support, MII/RMII available on all packages
STM32F107RCT6 Pinout
The following figure are the diagrams of STM32F107RCT6 pinout.
STM32F107RCT6 Applications
The STM32F105xx and STM32F107xx connectivity line microcontroller family are suitable for a wide range of applications such as motor drives and application control, medical and handheld equipment, industrial applications, PLCs, inverters, printers, and scanners, alarm systems, video intercom, HVAC and home audio equipment.
If you want to know more about STM32F107RCT6, you can read its datasheet.
MCZ33298EG Power Switch Datasheet
04/28/2022 at 08:14 • 0 commentsProduct Overview
The 33298 is a smart eight output low side power switch. It is a versatile device incorporating an 8-bit serial-in shift register to control an 8-bit parallel output latch providing control of eight independent "ON/OFF" output switches. Applications include the control of solenoids, relays, lamps, small DC motors, and other moderate current loads (1.0 – 3.0A).
The 33298 interfaces directly with a microcontroller to control various inductive or incandescent loads. Input control is fast. Data rates are guaranteed to 2.0 MHz but the device is capable of rates to 8.5 MHz @ 25°C.
This blog will introduce MCZ33298EG systematically from its features, pinout to its specifications, applications, also including MCZ33298EG datasheet and so much more.
MCZ33298EG Features
• Designed to operate over wide supply voltages of 5.5 to 26.5V
• Interfaces to microprocessor using 8-bit SPI I/O protocol up to3.0MHz
• 1.0A peak current outputs with maximum RDS(ON) of 1.8Ω at TJ - 150°C
• Outputs current limited to accommodate in-rush currents associated with switching incandescent loads
• Output voltages clamped to 65V during inductive switching
• Maximum sleep current (IPWR) of 25µA
• Maximum of 4.0mA IDD during operation
• Pb-free packaging designated by suffix code EG
MCZ33298EG Pinout
The following figure is the diagram of MCZ33298EG pinout.
If you want to know more about MCZ33298EG, you can read its datasheet.
P89V664FA Microcontrollers Datasheet
04/06/2022 at 09:22 • 0 commentsProduct Overview
The P89V660/662/664 are 80C51 microcontrollers with 16 kB/32 kB/64 kB flash and 512 B/1 kB/2 kB of data RAM. These devices are designed to be drop-in and software compatible replacements for the P89C660/662/664 devices. Both the In-System Programming (ISP) and In-Application Programming (IAP) boot codes are upward compatible.
Additional features of the P89V660/662/664 devices when compared to the P89C660/662/664 devices are the inclusion of a secondary 100 kHz byte-wide I2C-bus interface, an SPI interface, four addition I/O pins (Port 4), and the ability to erase code memory in 128-byte pages.
The IAP capability combined with the 128-byte page size allows for efficient use of the code memory for non-volatile data storage.
This blog will introduce P89V664FA systematically from its features, pinout to its specifications, applications, also including P89V664FA datasheet and so much more.
P89V664FA Features
Principal features
- n Dual 100 kHz byte-wide I2C-bus interfaces
- n 128-byte page erase for efficient use of code memory as non-volatile data storage
- n 0 MHz to 40 MHz operating frequency in 12x mode, 20 MHz in 6x mode
- n 16 kB/32 kB/64 kB of on-chip flash user code memory with ISP and IAP
- n 512 B/1 kB/2 kB RAM
- n SPI (Serial Peripheral Interface) and enhanced UART
- n PCA (Programmable Counter Array) with PWM and Capture/Compare functions
- n Three 16-bit timers/counters
- n Four 8-bit I/O ports, one 4-bit I/O port
- n WatchDog Timer (WDT)
- n 30 ms page erase, 150 ms block erase
- n Support for 6-clock (default) or 12-clock mode selection via ISP or parallel programmer
- n PLCC44 and TQFP44 packages
- n Ten interrupt sources with four priority levels
- n Second DPTR register
- n Low EMI mode (ALE inhibit)
- n Power-down mode with external interrupt wake-up
- n Idle mode
Additional features
P89V664FA Pinout
The following figure is the diagram of P89V664FA pinout.
STM8S103F3P6TR Microcontrollers Datesheet
03/28/2022 at 07:42 • 0 commentsProduct Overview
The STM8S103F2/x3 access line 8-bit microcontrollers offer 8 Kbyte Flash program memory, plus integrated true data EEPROM. The STM8S microcontroller family reference manual (RM0016) refers to devices in this family as low-density. They provide the following benefits: performance, robustness, and reduced system cost.
This blog will introduce STM8S103F3P6TR systematically from its features, pinout to its specifications, applications, also including STM8S103F3P6TR datasheet and so much more.
STM8S103F3P6TR Features
Core
- 16 MHz advanced STM8 core with Harvard architecture and 3-stage pipeline
- Extended instruction set
- Program memory: 8 Kbytes Flash; data retention 20 years at 55 °C after 10 kcycles
- Data memory: 640 bytes true data EEPROM; endurance 300 kcycles
- 2.95 to 5.5 V operating voltage
- Flexible clock control, 4 master clock sourcesLow power crystal resonator oscillatorExternal clock inputInternal, user-trimmable 16 MHz RCInternal low-power 128 kHz RC
- Clock security system with clock monitor
- Power management:Low-power modes (wait, active-halt, halt)Switch-off peripheral clocks individually
- Permanently active, low consumption power-on and power-down reset
- Nested interrupt controller with 32 interrupts
- Up to 27 external interrupts on 6 vectors
- Advanced control timer: 16-bit, 4 CAPCOM channels, 3 complementary outputs, dead-time insertion and flexible synchronization
- 16-bit general purpose timer, with 3 CAPCOM channels (IC, OC or PWM)
- 8-bit basic timer with 8-bit prescaler
- Auto wake-up timer
- Window watchdog and independent watchdog timers
- UART with clock output for synchronous operation, SmartCard, IrDA, LIN master mode
- SPI interface up to 8 Mbit/s
- I2C interface up to 400 kbit/s
- 10-bit, ±1 LSB ADC with up to 5 multiplexed channels, scan mode and analog watchdog
- Up to 28 I/Os on a 32-pin package including 21 high sink outputs
- Highly robust I/O design, immune against current injection
- 96-bit unique key for each device
Memories
RAM: 1 Kbytes
Interrupt management
Timers
Communication interfaces
Analog to digital converter (ADC)
I/Os
Unique ID
STM8S103F3P6TR Pinout
The following figure is the diagram of STM8S103F3P6TR pinout.
If you want to know more about STM8S103F3P6TR, you can read its datasheet.
AD8605ARTZ Operational Amplifiers Datasheet
03/04/2022 at 08:26 • 0 commentsProduct Overview
The AD8605 are single, dual, and quad rail-to-rail input and output, single-supply amplifiers. They feature very low offset voltage, low input voltage and current noise, and wide signal bandwidth. They use the Analog Devices, Inc. patented DigiTrim® trimming technique, which achieves superior precision without laser trimming.
This blog will introduce AD8605ARTZ systematically from its features, pinout to its specifications, applications, also including AD8605ARTZ datasheet and so much more.
AD8605ARTZ Features
- Low offset voltage: 65 μV maximum
- Low input bias currents: 1 pA maximum
- Low noise: 8 nV/√Hz
- Wide bandwidth: 10 MHz
- High open-loop gain: 1000 V/mV
- Unity gain stable
- Single-supply operation: 2.7 V to 5.5 V
- Photodiode amplification
- Battery-powered instrumentation
- Multipole filters
- Sensors
- Barcode scanners
- Audio
AD8605ARTZ Pinout
The following figure is the diagram of AD8605ARTZ pinout.
AD8605ARTZ Applications
- Multipole filters
- Sensors
- Barcode scanners
- Audio
If you want to know more about AD8605ARTZ, you can read its datasheet.
BNO055 Orientation Sensor Datasheet PDF
02/26/2022 at 07:48 • 0 commentsProduct Overview
The BNO055 is a System in Package (SiP), integrating a triaxial 14-bit accelerometer, a triaxial
16-bit gyroscope with a range of ±2000 degrees per second, a triaxial geomagnetic sensor
and a 32-bit cortex M0+ microcontroller running Bosch Sensortec sensor fusion software, in
a single package.
The corresponding chip-sets are integrated into one single 28-pin LGA 3.8mm x 5.2mm x
1.1 mm housing. For optimum system integration the BNO055 is equipped with digital bidirectional I2C and UART interfaces. The I2C interface can be programmed to run with the
HID-I2C protocol turning the BNO055 into a plug-and-play sensor hub solution for devices
running the Windows 8.0 or 8.1 operating system.
This blog will introduce BNO055 systematically from its features, pinout to its specifications, applications, also including BNO055 datasheet and so much more.
BNO055 Features
- Includes all sensors, sensor hub and optimized software
- Low power consumption, supports various power modes for switching sensors on and off and algorithm modules to speed code development
- Advanced 9-axis sensor fusion algorithms
- Fast background calibration of all sensors and calibration monitor while in use
- Enhanced magnetic distortion detection and suppression
- Real-time motion tracking due to built-in group delay compensation
- Gyroscope drift cancellation
- Supports multiple operating mode, i.e. 6-axis based applications (inertial measurement Units)
- 3-axis accelerometer (14Bit)
- 3-axis gyroscope (16Bit)
- 3-axis geomagnetic sensor
- 32 bit ARM Microcontroller
- 5.2 x 3.8 mm² footprint
- Bosch Sensortec Sensor Data Fusion with fast magnetic calibration (optimally integrated & tuned)
BNO055 Components
If you want to know more about BNO055, you can read its datasheet.
PCA9306 PDF Level Translator
02/11/2022 at 08:33 • 0 commentsProduct Overview
The PCA9306 is a dual bidirectional I2C-bus and SMBus voltage-level translator with an enable (EN) input, and is operational from 1.0 V to 3.6 V (Vref(1)) and 1.8 V to 5.5 V (Vbias(ref)(2)).
The PCA9306 allows bidirectional voltage translations between 1.0 V and 5 V without the use of a direction pin. The low ON-state resistance (Ron) of the switch allows connections to be made with minimal propagation delay. When EN is HIGH, the translator switch is on, and the SCL1 and SDA1 I/O are connected to the SCL2 and SDA2 I/O, respectively, allowing bidirectional data flow between ports. When EN is LOW, the translator switch is off, and a high-impedance state exists between ports.
This blog will introduce PCA9306 systematically from its features, pinout to its specifications, applications, also including PCA9306 datasheet and so much more.
PCA9306 Features
• 2-Bit bidirectional translator for SDA and SCL lines in mixed-mode I2C Applications
• I2C and SMBus compatible
• Less than 1.5-ns maximum propagation delay to accommodate standard-mode and fast-mode I2C devices and multiple controllers
• Allows voltage-level translation between
– 1.2-V VREF1 and 1.8-V, 2.5-V, 3.3-V, or 5-V VREF2
– 1.8-V VREF1 and 2.5-V, 3.3-V, or 5-V VREF2
– 2.5-V VREF1 and 3.3-V or 5-V VREF2You can download PCA9306 datasheet(PCA9306 PDF) from the link given below:
CC2531 Zigbee Datasheet
01/27/2022 at 09:09 • 0 commentsProduct Overview
The CC2531 USB is a USB enabled true system-on-chip (SoC) solution for IEEE 802.15.4, cc2531 Zigbee and RF4CE applications. It enables USB dongles or USB upgradable network nodes to be built with low total bill-of-material costs. The CC2531 combines the performance of a leading RF transceiver with an industry-standard enhanced 8051 MCU, in-system programmable flash memory, 8-KB RAM, and many other powerful features.
The CC2531 has various operating modes, making it suited for systems where ultralow power consumption is required. Short transition times between operating modes further ensure low energy consumption.
This blog will introduce CC2531 systematically from its features, pinout to its specifications, applications, cc2531 home assistant, cc2531 zigbee, texas instruments cc2531, also including CC2531 datasheet and so much more.
CC2531 Features
●RF/Layout
- 2.4-GHz IEEE 802.15.4 Compliant RF Transceiver
- Excellent Receiver Sensitivity and Robustness to Interference
- Programmable Output Power Up to 4.5 dBm
- Few External Components
- Only a Single Crystal Needed for Asynchronous Networks
- 6-mm x 6-mm QFN40 Package
- Suitable for Systems Targeting Compliance With Worldwide Radio-Frequency Regulations: ETSI EN 300 328 and EN 300 440 (Europe), FCC CFR47 Part 15 (US), and ARIB STD-T-66 (Japan)
●USB
- USB 2.0 Certified Full Speed Device (12 Mbps)
- 5 Highly Flexible Endpoints
- 1-KB Dedicated FIFO
- DMA Access to FIFO
- No 48-MHz Crystal Required
- Low Power
- Microcontroller
- Peripherals
- Active Mode RX (CPU Idle): 24 mA
- Active Mode TX at 1 dBm (CPU ldle): 29 mA
- Power Mode 1 (4 μs Wake-Up): 0.2 mA
- Power Mode 2 (Sleep Timer Running): 1 μA
- Power Mode 3 (External Interrupts): 0.4 μA
- Wide Supply-Voltage Range (2 V- -3.6 V)
- High-Performance and Low-Power 8051 Microcontroller Core With Code Prefetch
- 256-KB or 128-KB In-System-Programmable Flash
- 8-KB RAM With Retention in AIlI Power Modes
- Hardware Debug Support
- Powerful Five-Channel DMA
- IEEE 802.15.4 MAC Timer, General-Purpose Timers (One 16-Bit, Two 8-Bit)
- IR Generation Circuitry
- 32-kHz Sleep Timer With Capture
- CSMA/CA Hardware Support
- Accurate Digital RSSI/LQI Support
- Battery Monitor and Temperature Sensor
- 12-Bit ADC With Eight Channels and Configurable Resolution
- AES Security Coprocessor
- Two Powerful USARTs With Support for Several Serial Protocols
- 21 General-Purpose I/0 Pins (19x4 mA, 2 x 20 mA)
- Watchdog Timer
●Development Tools
- CC2531 Development Kit
- Certified CC2531 USB Dongle Reference Design
- SmartRFTM Software
- Packet Sniffer
- IAR Embedded Workbench Software Available
CC2531 Pinout
The following figure is the diagram of CC2531 pinout.
If you want to know more about CC2531 USB, you can read its datasheet.
LT1014 Op Amp Datasheet
01/06/2022 at 02:47 • 0 commentsProduct Overview
The LT ®1014 is the first precision quad operational amplifier which directly upgrades designs in the industry standard 14-pin DIP LM324/LM348/OP-11/4156 pin configuration. It is no longer necessary to compromise specifications, while saving board space and cost, as compared to single operational amplifiers.
This blog will introduce LT1014 systematically from its features, pinout to its specifications, applications, also including LT1014 datasheet and so much more.
LT1014 Features
- Single Supply Operation
- Pin Compatible to 1458 and 324 with Precision Specs
- Guaranteed Offset Voltage: 150μV Max
- Guaranteed Low Drift: 2μV/°C Max
- Guaranteed Offset Current: 0.8nA Max
- Guaranteed High Gain
- Guaranteed Low Supply Current: 500μA Max
- Low Voltage Noise, 0.1Hz to 10Hz: 0.55μVP-P
- Low Current Noise—Better than 0P-07, 0.07pA/√Hz
Input Voltage Range Extends to Ground
Output Swings to Ground While Sinking Current
5mA Load Current: 1.5 Million Min
17mA Load Current: 0.8 Million Min
LT1014 Pinout
The following figure is the diagram of LT1014 pinout.
LT1014 Applications
- Battery-Powered Precision Instrumentation
- 4mA to 20mA Current Loop Transmitters
- Multiple Limit Threshold Detection
- Active Filters
- Multiple Gain Blocks
If you want to know more about LT1014, you can read its datasheet.
PT4115 LED Driver Datasheet
12/24/2021 at 10:01 • 0 commentsProduct Overview
The PT4115 is a continuous conduction mode inductive step-down converter, designed for driving single or multiple series connected LED efficiently from a voltage source higher than the total LED chain voltage. The device operates from an input supply between 8V and 30V a and provides an externally adjustable output current of up to 1.2A. Depending upon the supply voltage and external components, the PT4115 can provide more than 30 watts of output power.
This blog will introduce PT4115 systematically from its features, pinout to its specifications, applications, also including PT4115 datasheet and so much more.
PT4115 Features
- Simple low parts count
- Wide input voltage range: 8V to 30V
- Up to 1.2A output current
- Single pin on/off and brightness control using DC
- voltage or PWM
- Up to 1MHz switching frequency
- Typical 5% output current accuracy
- Inherent open-circuit LED protection
- High efficiency (up to 97%)
- High- Side Current Sense
- Hysteretic Control: No Compensatio
- Adjustable Constant LED Current
- ESOP8 package for large output power application
PT4115 Pinout
The following figure is the diagram of PT4115 pinout.
PT4115 Applications
- Low voltage halogen replacement LEDs
- Automotive lighting
- Low voltage industrial lighting
- LED back-up lighting
- Iluminated signs
- SELV lighting
- LCD TV backlighting
If you want to know more about PT4115, you can read its datasheet.
TIP102 Transistor Datasheet
12/04/2021 at 02:59 • 0 commentsProduct Overview
The TIP102 is a silicon Epitaxial-Base NPN power transistor in monolithic Darlington configuration mounted in TO-220 plastic package. It is intented for use in power linear and switching applications.
TIP102 Features
- High DC Current Gain - hFE = 2500 (typ) @ IC = 4.0 mAdc
- Collector-Emitter Sustaining Voltage--@ 30 mAdc
- VCEO(sus) = 60 Vdc (Min)-TIP100, TIP105
- VCEO(sus) = 80 Vdc (Min)-TIP101, TIP106
- VCEO(sus) = 100 Vdc (Min)-TIP102, TIP107
- Low Collector-Emitter Saturation Voltage
- VCE(sat) = 2.0 Vdc (Max) @ IC= 3.0 Adc
- VCE(sat)= 2.5 Vdc (Max) @ IC= 8.0 Adc
- Monolithic Construction with Built-In Base-Emitter Shunt Resistors
- TO-220 AB Compact Package
- Pb-Free Packages are Available
TIP102 Pinout
The following figure is the diagram of TIP102 pinout.
TIP102 Applications
■ linear and switching industrial equipment
■ audio power amplifier
■ general power switching
■ DC-AC converter
■ easy driver for low voltage DC motorIf you want to know more about TIP102, you can read its datasheet.
LIR2450 Battery vs CR2450 Battery
11/30/2021 at 02:56 • 0 commentsLiR2450 Battery
LiR2450 is a typical label for rechargeable 2450 batteries. Depending on the exact chemistry used, the LiR2450 battery typically features nominal voltages of 3.0, 3.2, 3.6, and 3.7 volts.
CR2450 Battery
Lithium 3.0V CR2450 battery is a non-rechargeable button/coin cell battery commonly used in watches, computer motherboards, medical devices, LED flashlights, toys, remote controls, car remote keys, security systems, wearable electronics, etc.Differences between LiR2450 vs CR2450
The main differences between CR2450 and LiR2450 batteries in the voltage, capacity, and of course, rechargeable feature.Voltage difference - due to the voltage difference of ~0.6-0.7 volts, not all devices powered by the CR2450 battery will operate properly when powered by the LiR2450 battery. Actually, this voltage difference may even damage some more sensitive units.
Thus, unless the Owner's Guide of the device you have lists 3.6-3.7V LiR2450 batteries as supported battery type, do NOT replace CR2450 battery with LiR2450 battery.
Capacity difference - CR2450 battery features a much larger capacity than the LiR2450 battery. But, the LiR2450 battery may be recharged up to 500-1000 times, which is a lot.
Note: When charging LiR2450 batteries, be sure to use battery chargers specifically intended for such batteries.
Also, LiR2450 batteries feature a much larger self-discharge rate than CR2450 batteries, and is usually 10-30% per year, sometimes even more.
LiR2450 vs CR2450 Interchangeability
LiR2450 is a typical label for rechargeable 2450 batteries. Depending on the exact chemistry used, the LiR2450 battery typically features nominal voltages of 3.0, 3.2, 3.6, and 3.7 volts.3.0V rechargeable LiR2450 batteries can be used as a direct replacement for CR2450 batteries since they feature the same (similar) output voltage that never exceeds 3.0 volts and pose no threat for sensitive electronics.
If you want to know more about LiR2450 vs CR2450, you can read its datasheet.
TDA1543 DAC Datasheet
11/05/2021 at 02:33 • 0 commentsProduct Overview
The TDA1543 is a monolithic integrated dual 16-bit digital-to-analog converter (DAC) designed as an economy version for use in hi-fi digital audio equipment such as Compact Disc players, digital tape or cassette recorders, digital sound in TV sets and in digital amplifiers.
This blog will introduce TDA1543 systematically from its features, pinout to its specifications, applications, also including TDA1543 datasheet and so much more.
TDA1543 Features
• Low distortion
• 16-bit dynamic range
• 4 × oversampling possible
• Single 5 V power supply
• No external components required
• No requirement for external deglitcher circuitry due to
fast settling output current
• Adjustable bias current
• Internal timing and control circuits
• I2S input format: time multiplexed, two's complement,
TTL.
TDA1543 Pinout
The following figure is the diagram of TDA1543 pinout.
TDA1543 Applications
- Compact disc players
- Digital tape or cassette
- Recorders
- Digital sound in TV sets
- Digital amplifiers
If you want to know more about TDA1543, you can read its datasheet.
2N2222A Transistor Datasheet
10/27/2021 at 03:00 • 0 commentsProduct Overview
2N2222A is a NPN transistor hence the collector and emitter will be left open (Reverse biased) when the base pin is held at ground and will be closed (Forward biased) when a signal is provided to base pin. 2N2222A has a gain value of 110 to 800, this value determines the amplification capacity of the transistor. The maximum amount of current that could flow through the Collector pin is 800mA, hence we cannot connect loads that consume more than 800mA using this transistor. To bias a transistor we have to supply current to base pin, this current (IB) should be limited to 5mA.
This blog will introduce 2N2222A systematically from its features, pinout to its specifications, applications, also including 2N2222A datasheet and so much more.
2N2222A Features
- Bi-Polar high current NPN Transistor
- DC Current Gain (hFE) is 100
- Continuous Collector current (IC) is 800mA
- Emitter Base Voltage (VBE) is 6V
- Collector Emitter Voltage (VCE) is 30V
- Base Current(IB) is 5mA maximum
- Available in To-92 Package
2N2222A Pinout
The pin configuration of the 2N2222A transistor is shown below. This transistor includes three pins & its each pin functionality is discussed below.
2N2222A Advantages
The main advantages of using the 2N2222 transistor include the following.
- This is the most commonly used type of transistor
- In electronic circuits, most of the switching applications can be done by using this transistor
- It is capable of handling fairly high magnitude currents as compared to other similar transistors.
- This transistor switches the load current with 800 mA through it, which is high as compared to others.
- So this capability will make the device ideal in the applications of linear amplifiers.
- Small size
- Less weight
- Voltage gain is high
- Low source voltage
- Low cost
- Longer life
If you want to know more about 2N2222A, you can read its datasheet.
1N5711 Diode Datasheet
10/11/2021 at 05:41 • 0 commentsIf you want to know more about TDA7377, you can read its datasheet.If you want to know more about TDA7377, you can read its datasheet.
The 1N5711 is a very high speed small-signal Schottky diode which is well suited for high level detecting, mixing, switching, gating, log or A-D converting, video detecting, frequency discriminating, sampling, and wave shaping.
This blog will introduce 1N5711 systematically from its features, dimensions to its specifications, applications, also including 1N5711 datasheet and so much more.
1N5711 Features
- Guardring for over-voltage protection and high reliability
- Picosecond switching speed
- Very low turn-on voltage
- High breakdown voltage up to 70V
- Matched characteristics on request
- UHF/VHF detection
- Pulse applications with broad dynamic range
- Protection of MOS devices
- Steering, biasing and coupling in fast switching and low logic level
1N5711 Applications
- UHF/VHF detection
1N5711 Dimensions
The following figure is the diagram of 1N5711 dimensions.
Dimensions In Millimeters And (inches)
If you want to know more about 1N5711, you can read its datasheet.
PT2399 Delay Datasheet
09/23/2021 at 05:45 • 0 commentsProduct Overview
The PT2399 is a CMOS echo/delay processor developed by Princeton Technology Corp. This digital chip includes an ADC (Analog to Digital converter), 44Kb of RAM to store the samples and a DAC (Digital to Analog converter). Although this chip was created as a simple solution to add delay/reverb/echo to karaokes and set-up entertainment systems, it became very popular in the guitar pedal community due to its ability to emulate BBD-based delay circuits, good price, through-hole package, 5V power supply and tolerance to modifications.
PT2399 Features
- CMOS Technology
- Least External Components
- Auto Reset Function
- Low Noise, No< 90dBV Typical
- Low Distortion, THD<0.5% Typical
- External Adjustable VCO
- Available in 16 pins, DIP or sO package
- Video Tape Recorder
- Video Compact Disk
- Television
- CD Player
- Car Stereo
- KARAOKE Mixer
- Electronic Musical Instrument
- Audio Equipment with Echo Processor
PT2399 Pinout
These is pinout of PT2399,If you need more pinouts please download PT2399 datasheet.
PT2399 Alternatives
BU9253
Advantages of the PT2399
The first advantage of the PT2399 is its simplicity of use. Since it integrates many of the components we need, we can make a delay with only the chip and a few components ! Contrary to the BBD which needs a lot of external circuits.
The clock frequency is also much higher than the one used with a BBD. This results in less problems with aliasing and audible clock noise.
The second advantage of the PT2399 is the cost. Where a BBD costs from 3€ to more than 20€ for the famous MN3005, you can find a PT2399 between 1 and 2€. And since it already includes the clock and op-amps, the cost is even lower compared to a BBD circuit.
Disadvantages of the PT2399
The memory in the PT2399 is very limited, so the more you want long times, the less information the memory will be able to store. The sound quality will therefore be deteriorated over the long delays, causing like the BBD some noise problems.
Another problem is that the digital part cannot be accessed directly. You can’t add external memory to it to improve performance with long times.
Another example, the delay time is only controlled with the current on a pin. This is perfect to control the time with just one potentiometer connected to this pin. But it becomes more complicated if you want to precisely control the time with another external circuit, to add a tap tempo for example. Whereas with the BBD, you can generate the clock with any microcontroller.
If you want to know more about PT2399, you can read its datasheet.
