I'm converting an Enermax EG465AX-VE(G) into a bench power supply for my hacks.
Create drilling templates for the front and base plates
Figure out how many 3.3V, 5V, 12V, -5V, and -12V banana jacks you want to have in your front plate. I used two each for the high-current voltages (3.3V, 5V, and 12V) and one each for the low-current ones (-5V and -12V, prepared a hole for -3.3V just in case I need it later).
The front plate will also hold a switch and two 3 mm LEDs (red for standby and green for power good). I also added holes for two cable glands.
Mark the positions of each hole on a piece of paper (or print the whole thing, it doesn't matter).
Do the same thing for mounting the front plate on the base plate. I used 4 M8 screws for that.
Here's a picture of my front template:
It's missing the marks for the switch and the LEDs, I added them later.
Drill front and base, mount front on base plate
Straight forward: My banana jacks needed 8 mm holes, the cable glands needed 12 mm-ish (12.5? I'm not sure what I used), then there's 5 mm for the switch and 3.2 mm for the LEDs, and finally 8.5 mm for the mounting screws:
I used additional spring washers for the M8 screws.
hi christoph and thanks. i'm a total beginner with this, but have used atx psu's to power arduinos and motors in my sound installations for a couple of years now.
usually i only need to connect the green cable to a black ground and it works fine but i tried this on a new unit i just bought and it's runs for a fraction of a second then cuts out... is this where the minimum load comes in?
and do you need to add a minimum load on every output as in this project, or usually only on the 5vsb output?
also, if i am unable to get my hands on these power resistors (or even this doesn't work) do you have any other suggestions please?
