Spinner Pay
Have you ever tried to make a transaction with a spinner?
We have many different projects relating with mag-stripe information using motor controllers or audio to encode the mag-stripe data. In this project, I will explain how I modified a Bluetooth Spinner Speaker to make mag-stripe payments with it. Initially, I designed a project called BlueSpoof: https://salmg.net/2017/06/13/bluespoof/ Which could be used to make payments with mag-stripe data using a Bluetooth speaker board. Its library ViolentMag could be used to generate magnetic stripe data using audio. So I will implement the same library and methodology for this project.
This a PoC of this project!
  • 1
    Step by Step
    - Carefully open up the spinner case
    - Cut the speaker cables close to the speaker side
    - Soldering the coil in the speaker position so it could be completely cover with the spinner case
    - Generate the mag-stripe data with ViolentMag library
    - Connect to the Bluetooth spinner and approach the spinner to the card reader
    - Play the audio & enjoy
View all instructions
Rich text editor
ozaik wrote 12/03/2019 at 12:09 point
Hi, do you thinks we can directly connect the coil to the jack aux. of the phone ? You do really great job +1
Dan Maloney wrote 02/05/2019 at 15:35 point
TIL there's such a thing as a Bluetooth speaker fidget spinner...
Salvador Mendoza wrote 02/05/2019 at 18:48 point
It could work with any bluetooth speaker board just the only thing to be aware is the coil size
