The DIYson and the home:re:make, the beginning of a new movement? The project was born after seeing the Dyson vacuum cleaner advertisement. The doubt that the description, with carefully-sought words, hid a relatively simple idea came into our minds. I did some research to understand how it worked, and what inspired them in turn. Understanding how it worked, I realized that the key components of the project could be implemented with RC model aircraft components, at a low cost since they are easily available.
In addition to having verified the hypothesis that it is possible to make a DIY cyclonic vacuum cleaner with very good performance (refining version 1), the project now has a broader vision: to create the “Maker version” of many household appliances, using modern components with the best value for money, to understand, compared to the commercial version of the same product, the areas of improvement and the cases in which the economic value and the technical characteristics are more distant. From a future point of view, the home:re:make project could also send a signal to companies, which would encourage them to improve the repairability and improve the functions of their products, knowing that there is someone who analyzes their products and reproduces them, maybe even better, publishing all the results with the open source formula.
The DIYson: History
The idea behind the cyclone vacuum cleaner is based on dust collectors design, that have been around since 1921. A dust collector is a system used to enhance the quality of air released from industrial and commercial processes by collecting dust and other impurities from air or gas. Designed to handle high-volume dust loads, a dust collector system consists of a blower, dust filter, a filter-cleaning system, and a dust receptacle or dust removal system.
Sir James Dyson then in 1978, decided to build a better device than the popular vacuums of the day, and based its concepts on the dust collector design.
Madaeon
Josh Starnes
Kostas Lagogiannis
Greg
Matt
Yes this is looking very impressive project I like this vacuum cleaner. I am also working on vacuum guide project that is very similar to it.
