naminukas
Pneumatic walking, driving, wall climbing and tool using robot
Naminukas is an ultimate indoor robot which can explore almost any part of the house including climbing on walls, ceiling and furniture. Robot is able to transform to either a bipedal walking robot which can hold on any hard flat surface with vacuum suction cups or a two wheel balancing robot which can drive on soft and porous surfaces like a carpet. Robot can also be used as 4 degrees of freedom pick & place arm. It even carries detachable tools which can be picked and used by feet. In addition the robot carries UVA+UVC LED which can be used to disinfect a path traversed by the robot.
Goal
To create a portable robot (should fit in a hand luggage) that could traverse almost any surface, would be able to carry a significant payload (at least 0.5 kg) and manipulate objects.
Current state
Here is a summary video of robot's abilities:
Here is a detailed list of what robot can do with links to corresponding videos:
What's next
Near term goal is to explore even more ways of locomotion. Rubber foam vacuum suction cups look like a promising way to traverse non smooth surfaces and to grab non flat objects. Find a way to move on grass and soft/dry sand.
Medium term goal is to add more autonomy. This might require a replacement for BeagleBone Blue as it doesn't have enough power to run modern tools and complex algorithms.
Long term goal is to upgrade mechanical parts (for example, replace 3D printed PLA parts with metal and carbon fibre to increase rigidity, reduce gear backlash and wear) and push the limits with more bizarre modes of locomotion.
  • 1 × BeagleBone Blue single board computer Used to control all robot functions
  • 1 × Brushless -77kPa parallel micro vacuum pump HXB05KNDC 12V EPDM Pump has 2 heads: one connected to the left foot, other to the right foot.
  • 2 × Pololu voltage regulators U3V50AHV One converter boosts 2S LiPo battery output to 12V for vacuum pump, other to 12V for Dynamixels
  • 2 × High speed rotary pneumatic joints KSL 06-01S Allows wheels to turn while providing vacuum to suction cups
  • 2 × Nitrile or silicone rubber o-rings 95mm ID, 105mm OD, 5mm width for tires
View all 20 components
  • Converting wheeled robot to tracked
    Mykolas Juraitis08/07/2021 at 14:55 0 comments
    Robot's wheels were replaced by tracks which allows it to traverse previously inaccessible terrain, especially outdoors:
  • Nanny robot
    Mykolas Juraitis07/25/2021 at 12:10 0 comments
    naminukas robot used as a nanny with a new way to control it - via hobby RC radio:
  • Beach trip
    Mykolas Juraitis05/30/2021 at 22:13 0 comments
    Robot attempts various modes of locomotion on the sand and pebbles:
  • Robot crawls on water
    Mykolas Juraitis03/21/2021 at 20:10 0 comments
    Naminukas robot can crawl like a caterpillar by periodically tilting its feet. I decided to try if similar motion can work not only on a solid surface but also on a liquid, allowing the robot to crawl on water. Here is a result:
  • 4 ways robot can move on snow
    Mykolas Juraitis02/10/2021 at 23:13 0 comments
    Naminukas robot has many ways of locomotion. 4 of them (including 1 completely new one!) were tested on a slippery pavement partially covered by snow and ice:
  • Self-righting mechanism
    Mykolas Juraitis01/27/2021 at 20:55 0 comments
    I have created a 3D printed self-righting mechanism for naminukas robot which can be directly controlled by the robot's wheel without any additional sensors or actuators:
  • Transformation to balancing mode in slow motion
    Mykolas Juraitis12/30/2020 at 20:01 0 comments
    Recently I have been working to improve 2 wheel balancing mode. To debug robot's behaviour I captured few slow motion clips:
  • Ski driving stunt
    Mykolas Juraitis12/13/2020 at 15:58 0 comments
    Skiing is an automotive driving stunt where the car is driven while balanced only on two wheels, either the pair on the driver side or on the passenger side. Since only 2 wheels are used to perform this stunt, I decided to try it on naminukas robot. Opposite to the car, this robot's center of gravity is quite high, therefore robot tilts only a little bit. The robot uses an onboard accelerometer and gyroscope to determine to which side it is falling, and tilts wheels accordingly to maintain the balance. Oscillations could probably be minimised by better PID tuning. Currently, only proportional and derivative parts are being used.Steering is implemented by turning wheels at different speeds.
    Unfortunately, while filming this video, I accidentally plugged my laptop charger to the robot's BeagleBone Blue charging port, which fried the charging circuit. Surprisingly, it seems that nothing else was fried, but I can't charge my robot any more :( Here is the damage:
    fried charging circuit
  • Stereo camera in action
    Mykolas Juraitis12/07/2020 at 13:02 0 comments
    After endless hacks and upgrades I finally got Intel RealSense Depth Camera D415 working reliably on BeagleBone Blue computer. Using USB2 connection camera is only capable of 6 FPS but at least simple computer vision applications are possible at this speed. For example tracking object position and orientation:
  • Robot than can move even placed in a bag and submerged underwater
    Mykolas Juraitis11/09/2020 at 08:43 0 comments
    In previous videos it was demonstrated how the robot can move like a caterpillar by periodically tilting its feet back and forth out of phase with each other. Such motion allows the robot to traverse narrow passages. This video demonstrates another advantage of such motion. Since robot's feet in this mode of locomotion doesn't need to turn full circle, robot would be able to move even if enclosed in a flexible material. For example, putting the robot in a plastic bag, waterproofs it without affecting ability to move.
View all 33 project logs
  • 1
    High level schematic
  • 2
    Model files to 3D print
    All 3D printable parts were developed using OpenSCAD. Part model files are available in GitHub repository. To use these files the following libraries are required:
  • 3
    Parts to buy
    List of parts with links where to buy them is available on project home page.
View all 4 instructions
Rich text editor
jonathan wilhelm wrote 09/18/2020 at 04:09 point
Where are you sourcing the vacuum pump?
Mykolas Juraitis wrote 09/28/2020 at 12:59 point
I have a list of all parts with links where to buy them here: https://naminukas.kikaitachi.com/build#parts
Jonathan wrote 09/08/2020 at 06:51 point
This is very nice man !
Mykolas Juraitis wrote 09/08/2020 at 16:25 point
Thanks!
Peter Robinson wrote 08/17/2020 at 15:12 point
Very interesting. I never saw anything like it before.
Peter from https://www.gardenloka.com/guide-on-tree-trimming/
John Loeffler wrote 07/13/2020 at 18:37 point
I would Try green bananas at a distance far enough away that heating effect would not cause burning.  Masking it would also give you a better contrast see this video (https://www.youtube.com/watch?v=7FbDVX7wvgI)
clive wrote 06/26/2020 at 01:25 point
Yes the wheels are funny ,its like its doing the splits .You might even think about , making it amphibious,, water proof .The wheel in some way have paddles  ,I am just guessing. Top marks !! :)
Mykolas Juraitis wrote 07/09/2020 at 14:40 point
Thanks! Robotis recently released waterproof Dynamixels (for example https://emanual.robotis.com/docs/en/dxl/x/xw540-t140/), electronics could be put in a sealed box and vacuum pump should work with non corrosive fluids out of the box so amphibious version seems feasible without too many changes.
M Druiven wrote 04/29/2020 at 20:14 point
Nicely done! What are you using to generate vacuum?
Mykolas Juraitis wrote 04/29/2020 at 21:36 point
Thanks. Black thing in robot centre is a dual head vacuum pump which is making all the noise in walk/climb mode.
Mike Szczys wrote 04/27/2020 at 19:06 point
That is awesome! The walking up walls is a delight, but moving from walking to rolling is the robot equivalent of the moonwalk. Wicked!
Mykolas Juraitis wrote 04/28/2020 at 08:43 point
Thanks!
Dan Maloney wrote 04/09/2020 at 17:00 point
OK, gotta admit I didn't see the wheels thing coming. That's pretty clever!
Mykolas Juraitis wrote 04/09/2020 at 20:15 point
Thanks. I was super excited when this idea came to me. Still working on how to make transition from walking to wheel mode autonomously (without me holding robot in the air) with minimal or no additional hardware. Servos are powerful enough to drag vacuum suction cups without robot being lifted and also one leg could be transformed while other leg is stuck to the floor but balancing process is not good enough for a transition phase. Software still can be improved a lot but it is not clear if it will be enough.
