Hackaday.io Hackaday.io
Sign up Log in
Five Bar Parallel Robot - Janus Jr
Janus Jr is a small five-bar parallel robot designed to work with brushless motors, ESP32 (Arduino IDE) and 3D printed parts.
david-gonzalezDavid Gonzalez
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.6k views
4 comments
20 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
3.6k
4
20
20
Team (1)
  • david-gonzalezDavid Gonzalez
Join this project's team
  • Code and resources
ongoing project
Robotics Five Bar parallel robot kinematics direct drive brushless motor BLDC Motor L293 ESP32 SimpleFoc foc
Related lists
Featured Projects
Featured Projects on Hackaday.io
This project was created on 07/21/2020 and last updated 5 years ago.
Description
Janus Jr was developed in the Arduino IDE. It's using the SimpleFOC Arduino library for position control of the brushless motors. The ESP32 hosts a HMI which allows a user to move the end effector in the plane. The correct angular positions of the motors is calculated with the inverse kinematic model of the robot. You will be able to find everything about this robot on Github: https://github.com/byDagor/Five_Bar_Parallel_Robot-Janus_Jr
Demo video: https://youtu.be/umr-SqC9WUI
Components
  • 2 × 2206 Brushless Motor 140KV - 10.5 ohm
  • 1 × ESP32 Sparkfun Thing
  • 2 × L293 Interface and IO ICs / Peripheral Drivers and Actuators
  • 2 × AMT103 Rotary Encoder
  • 1 × Power source 5V - 2A
View all 6 components
Project Logs
Collapse
  • Janus Jr Brain
    David Gonzalez • 07/30/2020 at 20:35 • 0 comments
    This is the brain and power stage of the robot. You can find the schematics of the PCB in the Github repo.
View project log
Log In/Sign up to comment
Sign up with Github
OR
ekaggrat singh kalsi wrote 07/23/2020 at 23:05 • point
it is using bldc motors of what type? and also what position sensor are you using? more details on this project would be great. It would make a nice drawbot
David Gonzalez wrote 07/25/2020 at 05:38 • point
I will post more details in the following days.
Dan Maloney wrote 07/22/2020 at 21:22 • point
Silly question: why are these called "five-bar" linkages when all I ever see them with is four bars?
David Gonzalez wrote 07/22/2020 at 21:28 • point
Because the distance between the motors is considered as a bar. So you have: a "fixed bar" between motors, two bars coupled directly to the motors and two bars coupled to the previously mentioned bars. :)
Supplyframe DesignLab: 2023 Hackada…
The purpose of this project is to create a robot car with ominidirectional step motor wheels, and replace one of humans by a Robot
Project Owner Contributor
Omnidireccional Robot controlled by Amazon
miguel-wisintainerMiguel Wisintainer
A 5-bar robot with variable geometry to dinamically ilustrate changes in the spacework of the robot based on its dimensions
Modular 5-bar robot
juan-salvoJuan Salvo
Hackaday Prize 2019
I read opensurgery.net, and have a doubt. can we make some kind of surgery robot with maker utilities?
An Arduino Arm for ROS, wait a medical usage.
qq95538qq95538
Robot that moves from one square to another, after receiving commands by Infrared, Amazon Alexa assistance and Image Recognizer
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Five Bar Parallel Robot - Janus Jr", please tell us the reason.
Send message
Remove Member
