SIFP - Single Instruction Format Processor
A super-scalar, reduced instruction set processor where microcode and machine code are the same thing!
Public Chat
NOTE: Latest updates in the logs, including relevant code deeplinks!
This project is in progress and lot of it is already working:
-write the CPU in VHDL
-"wrap it" in a simple system with RAM/ROM/VGA/UART for debug/demo/development purposes (virtual "Single Board Computer"
- extend/change my microcode compiler to become the assembler for the CPU
- write boot / monitor program using the assembler, and run it on the SBC
-document as much as I can
CPU is:
-executing each instruction in 2 clock cycles (fetch + execute)
-able to execute up to 5 operations in parallel in each clock cycle
-out of those 5 operations, there can be max 1 memory read or write
-memory efficient, almost every cycle is a memory cycle, CPU utilizes the memory over 95% of time
-supports 16 bit data width and 16 bit address bus
-able to work in Harvard and Von Neumann modes
This is my main project now, and I am exploring the opposite of end of spectrum from my serial processor - while serial CPU processed with 1 bit a time, here there will be intrinsic parallelism, as each instruction could theoretically update 5*n bits (n = 16 in this implementation). Currently, the little test code I have is able to achive about 1.25 operations per instruction. I built in runtime counters that count instructions per second and operations per second. The max clock speed is 25MHz (12.5MIPS), probably with some tweaks full 50MHz could be achieved.
  • Minor instruction set update
    zpekic02/19/2024 at 06:44 0 comments
    After writing some rudimentary assembler routines (with the idea of incorporating them later into a monitor type program), it appears that programming the SIFP is sometimes clunky, sometimes elegant. Lack or registers and absence true base + index addressing modes requires frequent stack saving and retrieving. On the other hand, each register having own flags, and parallelization of some operations in same instruction can offset that inconvenience. To improve the instruction set a bit I implemented following modifications:
    • Added SBC (subtract with carry)
    • Removed SLC (shift left through carry) - because I needed 1 opcode for SBC
    • Renamed SRC to RRC (rotate right through carry)
    SBC
    SBC is same as 6502-type SBC, except 16-bit instead of 8. AC (accumulator carry) value 1 means "no carry". While XOR and then ADC can substitute SBC, it is inconvenient if one is to implement decimal arithmetic. I plan to do that for SIFC, exactly like 6502, by adding a D (decimal) flag.
    D flag value0 (binary mode)1 (BCD mode)
    ADC - second operandno changeno change
    SBC - second operand1's complement (XOR with 0xFFFF)9's complement
    ResultNot adjustedBCD adjusted
    SLC
    This was actually "RLC" (rotate left through carry), which can be replicated by this simple sequence:
    PUSHA;
    ADC, M[POP];
    Given the infrequent use of this instruction, trade-off with SBC is probably good choice.
    RRC
    Only the name has changed, it always behaved like a Z80-style RRA. Accumulator and AC flag are treated as one 17-bit register (AC is LSB) and bits in it are rotated towards LSB.
    The new instruction set table now looks like this:
    CLRx
    These instructions were always there and working, but I decided to "expose" them using the microcode compiler's primitive ".alias" pragma. From sifp.mcc :
    // Convenient clear operations (internal data bus is 0 by default if not driven)
    CLRA	.alias  r_p = NOP, r_a = LDA, r_x = NOX, r_y = NOY, r_s = NOS;
    CLRX	.alias  r_p = NOP, r_a = NOA, r_x = LDX, r_y = NOY, r_s = NOS;
    CLRY	.alias  r_p = NOP, r_a = NOA, r_x = NOX, r_y = LDY, r_s = NOS;
    CLRAX	.alias  r_p = NOP, r_a = LDA, r_x = LDX, r_y = NOY, r_s = NOS;
    CLRXY	.alias  r_p = NOP, r_a = NOA, r_x = LDX, r_y = LDY, r_s = NOS;
    CLRAXY	.alias  r_p = NOP, r_a = LDA, r_x = LDX, r_y = LDY, r_s = NOS;
     What is going on here?
    Each register P, A, X, Y, S has only 1 input. This input is internal data bus, which gets its value by logical OR of all the registers that have output enabled. In case no register is "projecting" data, it the value of the internal data bus is 0. In the processor implementation this is visible here:
    -- MUX to allow pushing, storing F to stack memory
    int_fdbus <= reg_f when ((i_is_ftos or i_is_pushf) = '1') else int_dbus;
    -- internal data bus is logical OR of all registers that project data
    int_dbus <= p2d or a2d or x2d or y2d or s2d or d2d;
    p2d <= p when (reg_p_d = '1') else X"0000";
    a2d <= a when (reg_a_d = '1') else X"0000";
    x2d <= x when (reg_x_d = '1') else X"0000";
    y2d <= y when (reg_y_d = '1') else X"0000";
    s2d <= s when (reg_s_d = '1') else X"0000";
    When the internal data bus is 0, any register can pick up that value for a convenient "clear", which is somewhat common operation.
    Inherent "superscalar" architecture allows any combination of A, X, Y to be cleared in one instruction. Some of these are exposed as aliases.  It is also possible this way to clear P and S:
    • clearing P - this is effectively jump to location 0, which is where execution start after RESET. I have not decided yet whether to use this as "soft reset" or maybe even "software interrupt"
    • clearing S - this would destroy stack, therefore only useful during cold or warm restart.
  • Toolchain notes
    zpekic12/19/2023 at 05:28 0 comments
    Tooling is one of the most important things in software engineering. Better tooling means better quality and productivity, and often security, documentation, list goes on.
    The description below applies to this project but also other similar ones.
    Build time
    Two main tools are used:
    • Microcode compiler. This is 2-pass command-line compiler I wrote in C# for all my micro-coded CPUs and controllers. For this project it was modified to:
      • support alternative mnemonics (delimited by "bar" | )
      • better #include processing (dynamic .org statements)
      • various minor fixes
    • Ancient Xilinx (now AMD) ISE 14.7 - obsolete, but still free and still works, sufficiently well for FPGA boards I mostly use.
    Microcode compiler consumes .mcc or .sif text source files and can generate various output formats, for example Intel .hex or .vhd. Either of these can be used to prime the "ROM" memory of the system.
    ISE14.7 - in addition to project files, also includes either .vhd produced by mcc or during build time loads the .hex file using a helper function.
    The output is a .bin file which gets downloaded to the target device (FPGA board) using a utility tool.
    Run time
    Currently, system build around SIFC processor implements:
    1. VGA (32*64 character only) as primary output device
    2. UART (bi-directional, connected to USB2UART device appears as COM: port) as "console" device (text-only input and output)
    3. UART (one-directional, connected to USB2UART device appears as another COM: port) trace output device
    There are two devices inside the target system that help with debugging:
    • CPU which can be in trace mode (outputs register values) or non-trace. In addition it can be run with frequency 0 (single - step) to 25MHz
    • Debugtracer which can intercept any bus cycle and "freeze" the CPU until that bus cycle data is output on the serial COM port (#3 above)
    debugtracer mods \ CPU modeTRACEONTRACEOFF
    EnabledAllows tracing all bus cycles (except INTA)Allows tracing instruction fetch and memory read/write only
    DisabledSlow system speed (8 clock cycles per instruction)Full system speed (2 clock cycles per instruction)
    On the host PC, COM port #2 must be connected to some terminal emulator type of application to allow command interaction with the system.
    However, for COM port #3, there are 3 options:
    • do not connect (ignore trace output even if present)
    • connect to terminal emulator app (and observe raw trace output)
    • start tracer system tool (command line, written in C#) - it will take over the COM port and use trace output it intercepts to look up and highlight symbolic code, update memory map etc. Tracing can be stopped / restarted by "space" key on host which flips RTS pin on COM: ports which is picked up by the tracer. Symbolic breakpoints could be implemented using this capability in the future.
  • P, A, X, Y, S: more than a just another register
    zpekic12/13/2023 at 06:50 0 comments
    Most CPUs contain some number of internal registers, a subset of which are available for programs to use. These are often not much more than very fast internal memory connected to internal bus(es) and ALU(s), meaning that the the transformation of bits crucial for program execution is happening elsewhere and not within logical confines of the register.
    SIFP-16 somewhat extends the concept of register to a "processing element" - each of these in addition to fast value storage is also given own simple ALU, flags inputs and outputs, as well as part of control over CPU data and address paths to make it a self-contained unit of data processing.
    All 5 processing elements present in SIFP-16 have the following basic internal structure:
     Main elements:
    • 16-bit data value, "register", loaded with rising clock signal which is connected to all others PEs, and reset with also common reset signal (only for P and S is reset of importance as CPU boot depends on both being initialized to 0)
    • operation - 3 or 4 control bits, selecting 1 of 7 or 1 of 15 operations (1 is always NOP). These are coming directly as a slice of the currently executing instruction code.
    • single data input
    • single data output
    • carry and zero outputs, which depending on operation can be "passthrough" or coming from ALU
    • control output signals reg_d, reg_a that drive the address and data paths
    • control output signal "active" which is 0 only when operation is NOP. These signals are used to count CPU throughput, how many operations can be executed in single operation (min = 0, max = 5)
    • register is updated through the ALU, which is in most cases a simple binary adder with some passthrough (e.g. NOP is always implemented as register reloading self-value)
    • (optional) output MUX is needed as different value than register should be sometimes projected out (e.g. S + 1 before the value is updated)
    • (optional) condition codes fed into P (program counter) branch / no branch decision logic.
    Processing element operations are declared in the include file that defines the instruction field bits. This way the microcode source becomes a CPU assembly source file, and assembly instructions can use:
    • any variation of the operation mnemonic (these are delimited with |)
    • "aliases" which are handy shortcuts for most frequently used operation combinations (such as PUSH/POP etc.)
    • each assembly instruction must be closed by ; but it can contain 1-5 operations and those must be delimited with ,
    P (program counter)
    All program control depends on the operations that P supports. It is important to note that at time of execution of these operations P has been incremented and is pointing to next location in program memory, which can be used either as data (destination for jump, branch offset, immediate) or next instruction.
    • STPx - because there can be no push and jump in same instruction (that would require 2 memory cycles and only 1 is possible), these allow to push "forward" P value to internal data bus
    • JUMP|GOTO - allows use of absolute targets, for example system calls in ROM
    • BRANCH - relative jumps can reach any target in the memory, but if confined to same module can implement relocatable code
    • LDP - beside return, this operation allows jumping to location in any other processing element or memory pointed by it (e.g. LDP, X; LDP, M[Y]; etc.). This allows data driven "case" statements or dispatch tables.
    // 16-bit program counter (has no flags, always increment during fetch phase, changes as below during execute phase)
    r_p    .valfield 4 values
        NOP,            // continue (increment P during next fetch phase)
        M[IMM],            // output value as address, increment (used for immediate values)
        BRANCH|IF_TRUE,        // unconditional branch (add word pointed by P)
        JUMP|GOTO,        // unconditional jump (load with word pointed by P)
        LDP,            // load from incoming data (mostly from stack, for return)
        STP4,            // put P + 4 to internal data bus
        STP2,            // put P + 2 to internal data bus
     STP, //...
  • Datapath: circle more, bus less
    zpekic12/12/2023 at 08:06 0 comments
    CPU internal data paths come in many topologies and complexities - from simple bidirectional bus all the way to n*m matrix switches and everything in between.
    SIFC16 datapath mostly resembles a circle, in the sense that outputs of all registers end up as inputs of these same registers:
    There are also a few side loops along the way (for external data bus and F (flag register). Signal names are same like in the implementation, for easier following.
    Reading data (from registers or memory)
    Each of the registers (P, A, X, Y, S) generates two signals:
    • 1-bit data output enable, which depends on the operation
    • 16-bit data (register value)
    For example index register X (and Y):
    -- value
    reg <= r;
    -- projecting as data
    reg_d <= '1' when (operation = r_x_STX) else '0';
     So if reg_x_d is 1 (in case of STX or STY operations), then then "and" gate (which is actually a 32 to 16 MUX) will pass the value along to be combined in a OR gate array (16 OR gates, each 6 inputs wide, seen on center left):
    • 5 inputs of the OR array are gated register values
    • 6th input comes from DBUS (memory data bus). This input source is passed through if:
      • interrupt vector is being read (cpu_intr control signal) - OR -
      • memory address is valid (VMA = 1) and "read" mode (RnW = 1)
    The combinatorial logic above drives the 16-bit internal data bus (int_dbus) which is then fed back to each register.
    Here are some examples how this works out:
    LDA, STX, STY;
    This is A <= X or Y, because both X and Y are projecting data, which will be OR'd and A is loading on next rising clock so it will load that value from internal data bus.
    LDX, M[POP];
    This is a POPX (pop X from stack). S is projecting address, so VMA will be 1, but because no register is writing, RnW = 1, so DBUS will be passed through to the OR gate array to drive int_dbus. This value will be loaded in X register on next reg_clk rising edge.
    Writing data (from registers)
    Values gathered through OR gate array and present on int_dbus are circled back towards a MUX that drives DBUS through a tri-state gate (cpu_hold combined with RnW signal). If VMA = 1, and RnW = 0 (see address generation log entry for explanation how this happens), it means that values from registers can be written to memory. For example:
    SRC, STX, M[S];
    X is written to stack top memory - A does not generate "project data" only internal operation so it won't be present in the internal data bus, but X will be, and because of that RnW will be 0 (Write). S "projects address", so VMA = 1.
    M[X];
    Valid, but useless instruction (effectively a NOP) - no register "projects data" so RnW = 1, X register "projects address" so there will be a valid memory read, and internal data bus will carry the value of memory location at address X, but no register will load it.
    Writing F (flags)
    F register can only be written to memory, and only using stack operations. Two special instruction combinations allow this:
    constant c_FTOS: std_logic_vector(15 downto 0)     :=    r_p_NOP & r_a_NOA & r_x_NOX & r_y_NOY & r_s_M_S;        -- mostly for flag output in trace mode
    constant c_PUSHF: std_logic_vector(15 downto 0) := r_p_NOP & r_a_NOA & r_x_NOX & r_y_NOY & r_s_M_PUSH;    -- flags to stack
    When these combinations are detected (simple combinatorial match of the 16-bit instruction word), then the MUX in bottom right corner would flip the input to the F side, so F register would be written to DBUS (VMA = 1 because S "projects address", and RnW = 0 as explained in the address log)
    Reading F (flags)
    F register - just like all the others - is updated on EVERY rising edge of reg_clk. To avoid losing the flag values, in almost all cases this means every flag bit makes a full round trip through its register. For example ac and az (accumulator carry and zero flags):
    -- zero flag output
    with operation select zo <=
          zi when r_a_NOA,
          zi when r_a_STA,
          y_z when others;
    -- carry flag output
    with operation select co <=
     y(...
  • Memory addressing modes without instruction fields
    zpekic12/12/2023 at 06:43 0 comments
    SIFC16 CPU instructions - unlike on most processors - do not have any address mode specifiers, or fields. Yet, 5 distinct address modes are supported:
    • Immediate, M[IMM] (or M[P+])
    • Indirect M[X], M[Y], M[S]
    • Indexed with base M[X+Y], M[P+X] etc...
    • Stack M[PUSH], M[POP]
    • Register implied (INX, SRC, DEY, etc.)
    How does this happen? The address generation logic happens through purely combinatorial logic driven by operations on the registers.
    In following simplified diagram, names of signals are same like in the implementation code for easier reference. Let's trace the memory address bus signals backwards, to their origin!
    ABUS - tri-state output, 16-bit
    This is usual, non-multiplexed address bus, able to address 64k words of memory. I/O devices are also memory mapped, MOS65xx or MC68xx style. The bus is tri-stated with cpu_hlda signal, which is generated by the control unit as a response to HOLD external DMA signal.
    The raw address is generated by two sources:
    • cpu_upc (microcode address) in case processor is executing trace sequence (that way external circuit can know which internal register DBUS is presenting). During trace sequence, cpu_bctrl signal is low which disables the VMA (valid memory address) signal.
    • Register value sum (when cpu_bctrl = 1, which is normal operation). P, X, Y, S registers are able to contribute to this sum, but not F or A.
    The register opcode itself determines if it will contribute to the address or not. This is done by driving the reg_?_a signal. This signal then either gates the  register output value to be 0 (to not sum) or allows it, so it is added. For example register S (stack pointer) will drive this signal to 1 for M[S], M[POP], M[PUSH] only, but not the other 5 operations it supports:
    -- projecting as address
    with operation select reg_a <=
    	'1' when r_s_M_POP,
    	'1' when r_s_M_PUSH,
    	'1' when r_s_M_S,
    	'0' when others;
    Other registers (X, Y, P) have similar logic (in reality just a 8 to 1 MUX with hard coded inputs!). It is now easy to see how M[X], M[Y] will be interpreted as base + index address mode, as both register values will be sent through the adder circuit.
    VMA - tri-state output, 1 bit
    Valid Memory Address signal is tri-stated also by cpu_hlda. Beyond that it is generated by simple combinatorial logic:
    • if CPU is in interrupt vector read cycle, it will be 0 (interrupt vector is expected on DBUS not any memory location value)
    • if CPU is not in interrupt vector read cycle, if ANY register projects address (reg_?_a is 1) then VMA will be 1 too.
    RnW - tri-state output, 1 bit
    This is a Read (1) / Write (0) signal. Tri-stated by cpu_hlda as expected. But origin is a bit more complicated:
    • If VMA = 0, then it is always "Read" (1) - except in the case of tracing (output of register values, this is not represented in the diagram above due to mistake)
    • if VMA = 1, it is "0" (Write) when at least 1 register is projecting data (for example STA projects data, but SRC does not). This is indicated with the NOR gate with 7 inputs. 5 of these are connected to P, A, X, Y, S registers (reg_?_d outputs) and 2 are detecting FTOS and PUSHF instructions when F register is to be written to memory.
    PnD - tri-state output, 1 bit
    Program (1), Data (0) - this optional signal can be used to allow implementation of "Harvard" system with program and data memory split (64k words each). It is simply connected (through usual cpu_hlda tri-state) to reg_p_a signal generated by P (program counter) register. If 1, it means that P is involved in address generation, so the address is either program code, or data stored in the program memory (for example M[P+X] lookup etc.).P is projecting address in 11 opcodes, out of 16:
    		'0' when r_p_NOP,
    		'0' when r_p_LDP,
    		'0' when r_p_STP2,
    		'0' when r_p_STP4,
    		'0' when r_p_STP,
    		'1' when others;
  • Single instruction format is more than enough!
    zpekic12/11/2023 at 03:36 0 comments
    Even simple 4 or 8-bit microprocessors or microcontrollers have many different instruction formats to encode a wide variety of instructions. How can a CPU work with just one format:
    bits15...1211..98...65...32..0
    registerPAXYS
    Execute general purpose programming language code?
    Let's explain on example of a short routine which outputs to UART (MC6850 or similar) a character string terminated by zero (0x0000, all data is 16-bit, LSB 8-bit contains the ASCII code).
    From uart.sif
    UART_OutStr:LDA, M[X];
            IF_AZ;
            .branchto @UART_Done - $;
            MARK2;
            BRANCH;
            .into @UART_OutChr - $;
            INX, BRANCH;
            .data @UART_OutStr - $;
    UART_Done:  RTS;
     While this looks like regular assembly code, it is actually microcode. So it can be compiled using the "mcc" microcode compiler. This produces following VHDL code (which can be directly compiled into the system ROM):
    -- L0046@00E8 0980.UART_OutStr:  LDA, M[X];
    --  r_p = 0000, r_a = 100, r_x = 110, r_y = 000, r_s = 000;
    232 => X"0" & O"4" & O"6" & O"0" & O"0",
    -- L0047@00E9 9000.  IF_AZ;
    --  r_p = 1001, r_a = 000, r_x = 000, r_y = 000, r_s = 000;
    233 => X"9" & O"0" & O"0" & O"0" & O"0",
    -- L0048@00EA 0006.  data16 =  @UART_Done - $;
    --  data16 = 0000000000000110;
    234 => X"0006",
    -- L0049@00EB 6003.  r_p = STP2, r_s = M[PUSH];
    --  r_p = 0110, r_a = 000, r_x = 000, r_y = 000, r_s = 011;
    235 => X"6" & O"0" & O"0" & O"0" & O"3",
    -- L0050@00EC 2000.  BRANCH;
    --  r_p = 0010, r_a = 000, r_x = 000, r_y = 000, r_s = 000;
    236 => X"2" & O"0" & O"0" & O"0" & O"0",
    -- L0051@00ED FFEC.  data16 =  @UART_OutChr - $;
    --  data16 = 1111111111101100;
    237 => X"FFEC",
    -- L0052@00EE 2080.  INX, BRANCH;
    --  r_p = 0010, r_a = 000, r_x = 010, r_y = 000, r_s = 000;
    238 => X"2" & O"0" & O"2" & O"0" & O"0",
    -- L0053@00EF FFF9.  data16 =  @UART_OutStr - $;
    --  data16 = 1111111111111001;
    239 => X"FFF9",
    -- L0054@00F0 4002.UART_Done:  r_p = LDP, r_s = M[POP];
    --  r_p = 0100, r_a = 000, r_x = 000, r_y = 000, r_s = 010;
    240 => X"4" & O"0" & O"0" & O"0" & O"2",
    Each instructions engages 0 to 5 registers present in the CPU simultaneously. Register P (program counter) has 16 possible actions (4-bit in the instruction field), while registers A, X, Y, S have 8 (3-bit fields).
    It is useful to look up instruction field definitions in the sifp.mcc file which is included when compiling the assembly code.
    LDA, M[X];
    Register X outputs content to address bus adder (code 6). Because no other register does this, the address bus value is 0 + X + 0 + 0 and it is valid (VMA = 1)
    Register A loads data from the internal data bus. Because no other register outputs to this bus, it is in read mode (RnW = 1) and because there is valid address (VMA = 1), it means there will be memory read cycle. Loading A affects the AZ flag (1 if value is 0x0000).
    All other registers are NOP, unaffected.
    IF_AZ;
    During EXECUTE phase, P (program counter) points to next address after the current instruction. P projects to internal address bus, so value is P + 0 + 0 + 0, and VMA = 1. No register is outputing value, so cycle is read (RnW = 1). Based on the value of flag (in this case A[ccumulator]Z[ero]), P is either incremented (no branch) or added with value read from memory (relative branch).
    All other registers are unaffected (NOP)
    .data16 =  @UART_Done - $;
    While all instructions are single word, P register in some cases (such as conditional) increments the value, which allows next word to be data. It this case the relative offset is branch target - current location. Value here is 0x0006, as 6 words forward is the UART_Done label.
    MARK2 alias resolves to this sequence. SIFP16 can execute only 1 memory access per instruction, so it can't do both a push of return adress and load of the P (program counter). This instruction first pushes...
  • CPU control: don't decode, just execute
    zpekic12/10/2023 at 23:33 0 comments
    Classic CPUs execute instructions by going through a predetermined set of machine states. With SIFP16's unique design, these machine states are at the same time proper CPU instructions. This means, that regardless of the program, SIFP-16 always only executes 14 CPU instructions and goes over 14 possible states.
    In absence of special execution conditions (HOLD, TRACE, INTERRUPT), only 2 instructions / states are executed:
    1. FETCH:
      1. CPU executes following instruction: r_p_M_IMM & r_a_NOA & r_x_NOX & r_y_NOY & r_s_NOS (this will generate VMA and RnW both high)
      2. FETCH signal is asserted on the bus (useful for debugging)
      3. Data bus input is loaded into 16-bit reg_i (instruction register)
    2. EXECUTE:
      1. CPU executes whatever is in reg_i
      2. go back to FETCH
    The simplest control unit implementation could simply be a flip-flop, driving a 2->1 MUX, one input hard coded to fetch, other connected to reg_i.
    But to make a full-fledge processor, handling additional states makes it a bit more complex:
    Notes for the diagram above:
    1. Machine instruction is "NOP", but instead contents of reg_i is executed, loaded in step 0
    2. If TRCE (trace condition) is asserted, all processor registers are output on the data bus, and their index on address bus. This is useful to inspect state of each register after each instruction
    3. LDP loads P (program counter) from data bus, but instead of VMA (valid memory address), INTA (interrupt acknowledge) signal is asserted to indicate that an interrupt vector should be presented to the data bus.
    4. FETCH cycle is started after RESET, and all other states eventually lead here
    5. State / instruction 15 is a "dead loop" as long as external circuit holds HOLD high. During that time HOLDA output is high and bus is tri-state ("Z" in VHDL)
    Following control signals determine the flow:
    • HOLD - serviced after each fetch, before execution starts
    • CONT - no interrupts or tracing, allows for fast fetch -> execute -> fetch ... sequence
    • INTR - interrupt enable flag is true, and external interrupt signal went from low to high (edge triggered)
    • TRCE - trace mode - external trace pin, or internal flag is set, causing all registers to be output after each instruction
    [0003]CLC:  r_a = STA, r_s = M[PUSH];
    MW,FFFD DEAD
    RV,  F= 0010
    RV,  A= DEAD
    RV,  X= BEEF
    RV,  Y= BEEF
    RV,  S= FFFD
    RV,  P= 0073
    [0004]  r_p = M[IMM], r_a = LDA;
    MR,0074 0000
    RV,  F= 0018
    RV,  A= 0000
    RV,  X= BEEF
    RV,  Y= BEEF
    RV,  S= FFFD
    RV,  P= 0075
    [0006]ACSet:  SLC;
    RV,  F= 0018
    RV,  A= 0000
    RV,  X= BEEF
    RV,  Y= BEEF
    RV,  S= FFFD
    RV,  P= 0076
    [0007]  r_a = LDA, r_s = M[POP];
    MR,FFFD DEAD
    RV,  F= 0000
    RV,  A= DEAD
    RV,  X= BEEF
    RV,  Y= BEEF
    RV,  S= FFFE
    RV,  P= 0077
    The actual implementation of control unit is centered around a ROM of 16 instructions (2 are not used). The instruction width is 32 bits:
    • 2 bits to select the internal condition ("if") - note that 5 conditions are possible, if "then" and "else" are same, this becomes "true"
    • 4 bits to determine next instruction if condition is true ("then")
    • 4 bits to determine next instruction if condition is false ("else")
    • 6 control bits
    • 16-bit instruction driving the P, A, X, Y, S registers
    -- instruction word
    signal cpu_instruction: std_logic_vector(31 downto 0);
    alias cpu_if:      std_logic_vector(1 downto 0) is cpu_instruction(31 downto 30); -- select condition ("IF")
    alias cpu_then:  std_logic_vector(3 downto 0) is cpu_instruction(29 downto 26); -- next state if condition true ("THEN")
    alias cpu_else:  std_logic_vector(3 downto 0) is cpu_instruction(25 downto 22); -- next state if condition false ("ELSE")
    alias cpu_hlda:  std_logic is cpu_instruction(21); -- 0: bus hold (tri-state) machine cycle
    alias cpu_inta:  std_logic is cpu_instruction(20); -- 0: load interrupt vector
    alias cpu_done:  std_logic is cpu_instruction(19); -- 1: last machine cycle in instruction
    alias cpu_bctrl: std_logic is cpu_instruction(18); -- 0: alternative bus control (ABUS = register address; VMA, PnD, RnW = '0')
    alias cpu_irexe: std_logic is cpu_instruction...
View all 7 project logs
Rich text editor
Ken Yap wrote 12/19/2023 at 06:40 point
Hi Zoltan, I keep meaning to give you a 👍 but keep forgetting. I like that you are exploring non-traditional architectures. Someday I might get a round tuit to read your project in depth, and take the wrapping off the FPGA dev board I got some time back. In fact I need lots of round tuits. Have a great holiday season!
zpekic wrote 12/19/2023 at 16:02 point
You are welcome! I always like the feedback and thoughts by fellow tinkerers! Have a great holidays too, and more hobby time in 2024 :-)
zpekic wrote 12/11/2023 at 21:22 point
Yes, it is like an iceberg - 90% of cost is that hidden software :-) I am reusing existing tooling from previous projects, for example I have a C# tracer that listens to trace logs from the device and allows me to see memory, registers and code execution in real time. I have 1 control signal through USB2UART I can use to communicate back so I am thinking to add "F9" debug. https://hackaday.io/project/190239-from-bit-slice-to-basic-and-symbolic-tracing/log/218998-run-time-visualization-of-memory-and-io-space
Yann Guidon / YGDES wrote 12/11/2023 at 07:21 point
hmmm interesting.
zpekic wrote 12/11/2023 at 18:01 point
Thanks @Yann Guidon / YGDES - please stay tuned for more updates! I am pleased how the CPU works and has pretty good throughput for such simplicity but now the problem I am facing is slow progress on "system software" (like a simple monitor). My toolchain is now to compile the assembly code and then recompile the VHDL project to bake that into the "ROM". That is slow and painful cycle. I have few options to solve that: (a) write some emulator to test/develop outside of the target system (b) write simple memory load/dump routine to allow bootstrapping, and (c) bake in a hardware component I already have https://hackaday.io/project/182959-custom-circuit-testing-using-intel-hex-files
Yann Guidon / YGDES wrote 12/11/2023 at 18:44 point
Software is the hardware killer.
Even for my minimalistic processor #YGREC8 I spend insane amounts of time on writing the support tools. And computer designers are not the best application writers so things tend to stretch and thin... Committing to a clear roadmap is essential, and baking the debug system in from the very beginning (what some call "Design For Test") the best approach.
Good luck !
