This is my main project now, and I am exploring the opposite of end of spectrum from my serial processor - while serial CPU processed with 1 bit a time, here there will be intrinsic parallelism, as each instruction could theoretically update 5*n bits (n = 16 in this implementation). Currently, the little test code I have is able to achive about 1.25 operations per instruction. I built in runtime counters that count instructions per second and operations per second. The max clock speed is 25MHz (12.5MIPS), probably with some tweaks full 50MHz could be achieved.
zpekic
Michael Morton
Stefan
ammarbhayat28
Hi Zoltan, I keep meaning to give you a 👍 but keep forgetting. I like that you are exploring non-traditional architectures. Someday I might get a round tuit to read your project in depth, and take the wrapping off the FPGA dev board I got some time back. In fact I need lots of round tuits. Have a great holiday season!
