Raspberry Pi Ceph Cluster
A Raspberry Pi Ceph Cluster using 2TB USB drives.
I needed an easily expandable storage solution for warehousing my ever growing hoard of data. I decided to go with Ceph since it's open source and I had slight experience from work. The most important benefit is that I can continuously expand the storage capacity as needed simply by adding more nodes and drives.
Current Hardware:
  • 1x RPi 4 w/ 2GB RAM
    • management machine
    • influxdb, apcupsd, apt-cacher
  • 3x RPi 4 w/ 4GB RAM
    • 1x ceph mon/mgr/mds per RPi
  • 18x RPi 4 w/ 8GB RAM
    • 2 ceph osds per RPi
    • 2x Seagate 2TB USB 3.0 HDD per RPi
Current Total Raw Capacity: 65 TiB
The RPi's are all housed in a nine drawer cabinet with rear exhaust fans.  Each drawer has an independent 5V 10A power supply.  There is a 48-port network switch in the rear of the cabinet to provide the necessary network fabric.
The HDDs are double-stacked five wide to fit 10 HDDs in each drawer along with five RPi 4's.  A 2" x 7" x 1/8" aluminum bar is sandwiched between the drives for heat dissipation.  Each drawer has a custom 5-port USB power fanout board to power the RPi's.  The RPi's have the USB PMIC bypassed with a jumper wire to power the HDDs since the 1.2A current limit is insufficient to spin up both drives.
  • 1 × Raspberry Pi 4 w/ 2GB RAM
  • 3 × Raspberry Pi 4 w/ 4GB RAM
  • 18 × Raspberry Pi 4 w/ 8GB RAM
  • 22 × MB-MJ64GA/AM Samsung PRO Endurance 64GB 100MB/s (U1) MicroSDXC Memory Card with Adapter
  • 22 × USB C Cable (1 ft) USB Type C Cable Braided Fast Charge Cord
View all 11 components
  • Raspberry Pi Cluster Retired
    Robert Rouquette03/24/2026 at 16:12 1 comment
    I've retired the Raspberry Pis as Ceph machines and replaced them with asustor NAS boxes.  The USB hard drives started suffering alarmingly frequent failures in the USB-to-SATA controllers.  The actual 2.5" drives were fine, with one exception, but the high failure rate of the USB controllers became a showstopper.  The complete lack of availability of new Raspberry Pis during Covid and the price increase on the 5th generation led me to the conclusion that I would be better off with fewer systems even if they cost slightly more.  I ended up choosing the asustor AS670xT series because they were capable of running most Linux server distros on the bare metal with out any bios or hardware tweaks.
    I've repurposed the Raspberry Pis for various purposes including an Incus cluster and various data logging hacks.
  • Instability Followup and Resolution
    Robert Rouquette03/30/2022 at 15:36 0 comments
    The OSD instability I encountered after the kernel update persisted though with less frequency.  I've finally determined that cause is a confluence of small issues that amplify each other:
    • Power Supply Aging - The 5V 10A supplies have lost a small amount of their output headroom with age.
    • CPU Governor Changes - The ondemand CPU governor is no longer as aggressive at reducing the CPU frequency
    • CPU Aging - The CPU and PCIe controller appear to have become more prone to core undervoltage.
    I've remediated the instability by underclocking the CPU.  Underclocking was insufficient on its own, so I've also applied slight overvoltage as well.  The OSD RPi's have been holding steady after applying both changes.
    Here's the current state pf my usercfg.txt:
    # Place "config.txt" changes (dtparam, dtoverlay, disable_overscan, etc.) in
    # this file. Please refer to the README file for a description of the various
    # configuration files on the boot partition.
    max_usb_current=1
    over_voltage=2
    arm_freq=500
    These changes have not appeared to impact my Ceph performance.
  • Unstable Kernel (5.4.0-1041-raspi)
    Robert Rouquette08/24/2021 at 16:42 0 comments
    The linux-image-5.4.0-1041-raspi version of the Ubuntu linux-image package appears to be unstable.  I've had two of the OSD RPi boards randomly lockup.  The boards recover on their own once power-cycled, but this is the first time I've observed this behavior.  There no messages in the system logs. The logs simply stop at the time of the lockup, and resume on reboot.  I've upgraded all of the RPis to the latest image version (1042) which should hopefully resolve the issue.
  • Rebalance Complete
    Robert Rouquette06/28/2021 at 14:26 0 comments
  • Two More OSDs
    Robert Rouquette06/17/2021 at 01:40 0 comments
    I've added the last two drives for this round of expansion which brings the total for the cluster to 34 HDDs (OSDs).  Amazon would not allow me to purchase more of the STGX2000400 drives, so I went with the STKB2000412 drives instead.  They have roughly the same performance, but cost about $4 more per drive.  The aluminum top portion of the case should provide better thermal performance though.
  • Additional Storage
    Robert Rouquette06/09/2021 at 01:32 0 comments
    Added the first two of four additional drives.  I plan to add the other two once the rebalance completes.
  • OSD Recovery Complete
    Robert Rouquette05/19/2021 at 03:24 0 comments
    Once the failed drive was replaced, the cluster was able to rebalance and repair the inconsistent PGs.
      cluster:
        health: HEALTH_OK
      services:
        mon: 3 daemons, quorum ceph-mon00,ceph-mon01,ceph-mon02 (age 33m)
        mgr: ceph-mon02(active, since 13d), standbys: ceph-mon00, ceph-mon01
        mds: cephfs:2 {0=ceph-mon00=up:active,1=ceph-mon02=up:active} 1 up:standby
        osd: 30 osds: 30 up (since 9d), 30 in (since 9d)
      data:
        pools:   5 pools, 385 pgs
        objects: 8.42M objects, 29 TiB
        usage:   41 TiB used, 14 TiB / 55 TiB avail
        pgs:     385 active+clean
      io:
        client:   7.7 KiB/s wr, 0 op/s rd, 0 op/s wr
     After poking around on the failed drive, it looks like the actual 2.5" drive itself is fine.  The USB-to-SATA controller seems to be culprit, and randomly garbles data over the USB interface.  I was also able to observe it fail to enumerate on the USB bus.  A failure rate of 1 in 30 isn't bad considering the cost of the drives.
  • OSD Failure
    Robert Rouquette05/04/2021 at 19:13 0 comments
    The deep scrubs turned up a few more repairable inconsistencies until a few days ago when they grew concerning.  It turned out that one of the OSDs had unexplained read errors.  Smartctl showed that there were no read errors recorded by the disk, so I initially assumed it was just the result of a power failure.  It became obvious that something was physically wrong with the disk when previously clean or repaired PGs were found to have new errors.
    As a result I've marked the suspect OSD out of the cluster and I have ordered a replacement drive.  The exact cause of the read errors is unknown, but since it is isolated to a single drive, and the other OSD on the same RPi is fine, it's most likely just a bad drive.
    Ceph is currently rebuilding the data from the bad drive, and I'll post an update once the new drive arrives.
    The inconsistent PGs all have a single OSD in common: 2147483647 (formerly identified as 25)
  • Inconsistent Placement Group
    Robert Rouquette04/08/2021 at 16:54 0 comments
    The OSD deep scrubbing found an inconsistency in one of the placement groups.  I've marked the PG in question for repair, so hopefully it's correctable and is merely a transient issue.  The repair operation should be complete in the next few hours.
    [UPDATE]
    Ceph was able to successfully repair the PG.
  • Zabbix Monitoring
    Robert Rouquette01/22/2021 at 00:30 0 comments
    I decided I have enough nodes that some comprehensive monitoring was worth the time, so I configured Zabbix to monitor the nodes in the ceph cluster.  I used the zbx-smartctl project for collecting the smart data.
View all 20 project logs
rich.quackenbush wrote 09/01/2024 at 18:31 point
Holy crap - just learned about CEPH and found this project. Nice setup!
Mystik Incarnate wrote 04/03/2024 at 14:33 point
I'm planning something similar, hopefully in the near future.  Presently I'm waiting for the ComputeBlade aka BladePi project to start selling, then setting up a cluster starting with at least 6 nodes; I'm wondering if you have any advice for someone who is relatively new to Ceph?  I'm thinking of tinkering with Ansible or similar to do provisioning for my project.
The short term plan would be 3 mon nodes, plus 3 OSDs. Long term, adding upwards of 14-34 more OSDs (total of either 17 or 37); my focus is on IO performance more than throughput.  The ComputeBlade OSDs would have M.2 NVMe drives, and I'm thinking of picking up 1 or 2TB models; this is to host OS disk storage for virtual machines in my homelab.
What are you using this cluster for? what is your IO throughput? any other comments are welcome.
Robert Rouquette wrote 04/24/2024 at 13:53 point
USB drives are slow (regardless of the underlying physical media).  The ceph architecture itself was originally designed to utilize low performance drives, and my experience has been that aggregate ceph IO performance does not reach sustainable levels until the 20-25 OSD mark.  I've seen a similar threshold at work even with enterprise level hardware (SSDs and NVMe journals).
I'm using my raspi cluster primarily for git repos, nightly backups, and Plex media storage.
All of my raspi installs are manual bare metal installs.
bconner wrote 01/15/2024 at 14:54 point
Hello--thanks for posting this project, very cool!  Like the custom power distribution board and actually ordered several of them.  Personally am not familiar with designing circuit boards, can you provide any recommended links (or describe) this custom board?  Thinking that as USB Type A is phased out that redesigning to USB-C for any future boards would be worthwhile.  Similarly, would look into making larger boards (i.e. 10 ports using LRS-100-5).
Alessandro wrote 01/08/2024 at 10:49 point
Hello Robert,
I've another question about your project. Have you ever encountered /dev/sd* assignment problem to USB disk during reboot of a node? Do you force the assignment?
Thanks.
Robert Rouquette wrote 04/24/2024 at 13:40 point
I've not encountered assignment issues.  The ceph osd daemons don't rely on the drive letter, and instead use the partition UUID to locate the drive associated with the osd instance.  As such, the osd daemons are not affected by drive letter reordering.
michel.bathe.1996 wrote 10/19/2023 at 00:08 point
Hi,
running an CephCluster with 3 Orange Pis 8GB and 6 Pis with 8GB with one 4TB SSD per Pi. Unfortunately the Performance isn't that great.
Did you do any performance tweaks or is it vanilla? When yes which?
Thanks
Robert Rouquette wrote 04/24/2024 at 13:56 point
ceph clusters, typically, do not become truly performant until they reach the 20-25 osd mark.
Alessandro wrote 09/11/2022 at 19:23 point
Can I ask you an average of power consumption? I would like to replicate a similar setup on smaller scale.
Thanks
Robert Rouquette wrote 09/15/2022 at 14:15 point
It  averages around 200W when idle, and tops out around 270W-280W when active.
Ulrich Staerk wrote 02/15/2022 at 17:05 point
Just out of curiosity, what clients do you serve and how do your clients connect to the cluster? CephFS? RDB? A Samba Gateway?
Robert Rouquette wrote 03/30/2022 at 15:14 point
I currently only have CephFS and RBD clients.
William Voorhees wrote 12/27/2021 at 06:31 point
This is such an interesting project, I'm considering building something similar (using
Uptime Lab's CM4 Blade) I'm really interested in seeing what the aggregate performance of your cluster is, if you use a higher bandwith interconnect, your switch supports 10gb modules, do you have a computer you could connect to it to test it out? there are some interesting TB3 to 10GB adapters, if that's an option.
Robert Rouquette wrote 03/30/2022 at 15:15 point
I don't currently have any machines with 10G networking
6355 wrote 08/25/2021 at 17:04 point
Very interesting approach, thank you!
But, I suspect the following problems.
The most (if not all) current 2TB 2.5" HDD's are SMR. And I doubt any of these SMR are HM-SMR. Seagate can be very secretive when it comes to which drives are SMR (instead of CMR), so goes for STGX2000400.
And currently, Ceph+SMR gives very surprising performance. Some experiments to support HM-SMR with BlueStore are going ( https://docs.ceph.com/en/latest/dev/zoned-storage/ ), but just for HM-SMR, not for DM-SMR, or even for HA-SMR...
Another problem, according to my experience, could be Type A USB connectors. I've seen many cases they got oxidized and lose electrical contact (since then I prefer Type C USB connectors), there are rumors some connector grease can resolve this though...
Robert Rouquette wrote 03/30/2022 at 15:19 point
The drives are all ST2000LM007 units under their shells.  I shucked the ones that failed, and so far the USB/SATA controllers have been failing before the drives.  The drives themselves have all been fine so far.
I haven't had any issues with USB corrosion.  The contacts are all gold plated and the cluster is in a dray area.
Robert Tisma wrote 08/01/2021 at 02:27 point
Phenomenal! This is truely amazing. I am planning on creating a much smaller version of your setup. Two questions.
What is your approach for backups? At this scale, it doesnt seem practical (for a home lab atleast).
How much time does it really take to maintain the cluster? Since you have put cluster online, how much maintenace have you had to do (not including adding or removing nodes or hdds)? Im curious if jumping into this is something that will be a second child or something that wont require much time doing maintanace (a failure a week vs a few failures a year for example). I know thats a loaded question and dependent on alot of things, but im curious for your particular setup.
Robert Rouquette wrote 08/02/2021 at 03:50 point
There are no backups of the stored data itself.  The Ceph cluster, by design, has built-in data redundancy for protection against drive and hardware failure.  The only part that is backed up is the monitor databases, since a total loss of the monitors would be catastrophic.  Individual drive or node failure isn't particularly worrisome since Ceph is self healing and will automatically rebuild any lost data using the remaining space on the cluster.
Aside from the one failed drive and adding storage, the cluster has been relatively maintenance free.  I perform software updates every few months whenever there are critical security updates or bug fixes, but that's about it.  I've averaged less than two hours per month in maintenance and monitoring time so far.
Stefano wrote 02/12/2021 at 23:50 point
Really compliments! From the photos you should be a fan of r/cableporn ! :)
marazm wrote 02/04/2021 at 11:50 point
Słabo z chłodzeniem.
Moim zdaniem lepszym sposobem była by tuba. Zobacz jak projektowano cray-1 albo nowy mac
płyty ułożone dookoła wytwarzają naturalny obieg powietrza jak w kominie. Do tego można spokojnie wstawić człodzenie wewnątrz i na zewnątrz (np. pojemnik z wodą)
Robert Rouquette wrote 02/04/2021 at 16:39 point
From my own observations of the hardware temperatures over time, the cooling is already adequate.  While none of the hardware is running cold, it's still certainly well within acceptable operating limits.  More aggressive cooling would simply increase the power consumption and increase the TCO.
josephchrzempiec wrote 02/04/2021 at 11:26 point
Hello, Do you or is there a way to set thiss up? I'm having a hard time trying to figure this out.
I wold be nice if there was a video tutorial on how to setup the raspberry pi cluster for this.
Robert Rouquette wrote 02/04/2021 at 16:45 point
I'm not particularly inclined to create a video tutorial.  There are already countless online tutorials available (not counting the official Ceph documentation) that walk through the planning, creation, and stand-up of Ceph clusters.  There are no special steps or tricks to the RPi OS installation either, and any distro that supports the RPi will work.
josephchrzempiec wrote 02/05/2021 at 12:54 point
Hello i understand. I just don't know where to start in software after setting up all the hardware. Where to begin.
Robert Tisma wrote 08/03/2021 at 04:02 point
did you use ceph-ansible for provisioning the RPis?
Robert Rouquette wrote 08/24/2021 at 16:28 point
@Robert Tisma My provisioning process was script based.  I stand up the RPi with the standard ubuntu server raspi image.  Once the RPi boots and has a DHCP lease, I ssh in and change the default password. (Required by the ubuntu image on first login.)  Once the password is set, I have provisioning scripts that set the system hostname, install ssh keys, install the base packages I want, perform package updates, and reboot the RPi.
I do the initial ceph related package installation and configuration with ceph-deploy.
Kevin Morrison wrote 02/03/2021 at 17:56 point
This is so overkill for what it does. Technology should be used to simplify a need or a process, not pervert and over complicate it!
Robert Rouquette wrote 02/03/2021 at 20:18 point
I agree with your sentiment about over complication. However, after many years of maintaining RAID arrays both large and small, and having watched as Ceph and other distributed storage systems have matured, I've come to appreciate that the distributed storage approach is significantly better in terms of failure tolerance and data integrity.  In terms of data warehousing, which is the principal purpose of this project, distributed storage offers the best long-term viability compared to RAID systems in terms of both data loss probability and capacity expansion.  I have personally experienced instances where rebuilding a failed drive on a RAID array triggered secondary drive failures.
I do ultimately agree that for the average person, this type of storage would be inappropriate, but in a situation where substantial continuous growth is expected, conventional single-machine approaches have their limits.
Kevin Morrison wrote 02/03/2021 at 21:32 point
The more I look into this the more sense it makes and like you I have decades building and working with RAID systems and this does look like a more flexible way to work with storage.
Timo Birnschein wrote 02/03/2021 at 17:18 point
I'm not familiar with Ceph but from what you described (based on the 8GB RP4 requirements) and what's written online, it seems like the RAM is being used as a cache and Ceph distributes the data to the disks. That would make writing extremely fast but reading is still bound to the read speed of the drives. Or do I misunderstand the concept?
Robert Rouquette wrote 02/03/2021 at 19:58 point
The data is distributed on the client side among the OSD service instances.  The OSD in-memory cache fulfills the same purpose as a kernel disk cache would, but allows the OSD daemons more nuanced access for it's internal operations and data integrity verification.
In terms of IO performance, the caching does help repetitive reads, but, for the most part, the performance is strictly limited by the RIO performance of the physical storage media.  Ceph write operations block on the client side until the data is actually committed to disk.  The only exception is CephFS where there is some limited client side buffering to allow for data chunking on large block writes.
andrewroffey wrote 01/29/2021 at 02:14 point
I've been looking at doing something similar, but the cost of 4TB drives looks to be better per GB. Is there any reason for going for 2x2TB drives per Pi, e.g. performance, cost? Could you go 1x4TB, or even 2x4TB per Pi? 8TB per OSD would still technically meet the "~1GB RAM per 1TB" rule of thumb for Ceph.
Robert Rouquette wrote 01/29/2021 at 22:16 point
I went with 2TB drives because they seemed like a good trade off between capacity on rebuild time.  There's also the fact that Ceph performance is directly tied to the number of OSDs.  More OSDs gives you more throughput especially with low performance hard drives.
That being said, there's no reason you can't stretch the OSD memory that far, but it's important to keep in mind that the full 8GB on the RPi is not truly usable by the OSD daemons.  The kernel carves out its own dedicated chunk, and you need to leave some for the kernel disk cache.  I would not use more than 7.5GB of the 8GB if you the RPi to remain stable.
Andrew Luke Nesbit wrote 01/24/2021 at 16:59 point
I was thinking of doing almost the exact same thing, except instead of using RPI 4's I was going to use Orange Pi +2E boards.  Does anybody have any comments on how this change will affect the feasibility of the project?
Robert Rouquette wrote 01/24/2021 at 17:17 point
The main limitation with that approach would be the lack of USB 3 and memory. The +2E only has USB 2 and 2G RAM.  It would certainly be possible to run an OSD daemon, but I don't think you would  get usable read/write performance.
Andrew Luke Nesbit wrote 01/24/2021 at 17:42 point
You know, you're absolutely right... without USB 3 it's going to be practically unusable.  But I just had another thought.... what about if, instead of using a USB-connected SSD, I use a large SD flash card for the "user storage" and use the eMMC and/or SPI (still trying to work out the differences and capabilities of each) for the OS?
christian.boeing wrote 12/29/2020 at 06:43 point
Thanks for your answer. I have expected that you are going 64 bit. (sure, 8GB Pi´s I saw now)
I use a ceph cluster for some years at home too.
Started with 3 nodes and ceph hammer. First I used odroid XU4, but because of USB-HD issues changed to odroid hc1/hc2. Disadvantage is that they are only 32 bit.
But I love the flexibility of ceph.
Now my cluster is a little mixed: 3 mon/mgr/mds with octopus 64 bit, 12 osd mimic 32 bit. With armhf I found no possibility to go more than mimic. The octopus version for armhf in ubuntu 20.04 is broken.
Jeremy Rosengren wrote 12/28/2020 at 16:39 point
What kind of throughput are you getting when you're transferring files to/from cephfs?
Robert Rouquette wrote 12/29/2020 at 00:49 point
Cephfs can fully saturate my single 1 Gbps NIC indefinitely.  I don't currently have any machines with bonded ports, so I don't know the tipping point.
for.domination wrote 01/11/2021 at 13:54 point
Since seeing your project two weeks ago I couldnt get it out of my head and now I'm trying to find a usecase that would necessitate building a cluster ;)
Have you ever benchmarked your setup? Red Hat has a go-along written up on  https://access.redhat.com/documentation/en-us/red_hat_ceph_storage/4/html/administration_guide/ceph-performance-benchmarking
I'd be quite interested how performance increases in such a large scale compared to the other rpi clusters found on the net which are mostly 3-5 units only. If you have a client with multiple ports it'd be interesting to see how much LA increases speeds... Maybe that can circumvent the client as the limiting factor.
christian.boeing wrote 12/28/2020 at 15:51 point
Looks very nice.
I think you are using the raspies in 64 bit mode because of limited support of ceph for armhf?
Which version of ceph is running?
Robert Rouquette wrote 12/29/2020 at 00:46 point
The rpi4's are running Ubuntu 20.04 aarch64, and I'm using Ceph Octopus (15.2.7) from the Ubuntu repos (not the Ceph repos)
