Applix 1616 Documentation
OCRd and typeset as html where possible. A work in progress.
An interesting 68000 machine, using just TTL and two PAL16R8 chips to produce 2-bit and 4-bit colour video. I collected all the scanned articles I could find, and OCR'd as much as I could to get them into a more readable form.
I'm aware of many issues with my collection. I've been informed that not every is attributable to ETI, for example the Forth manual was written by Eric Lindsay directly for Applix. I should probably file the lot under the com/Applix directory, and say which ones were published in ETI.
Note that I am not here to pass off other people's work as my own, but merely to OCR and re-typeset material in html format, freeing them from obsolete Desktop Publishing software.
I only made a start on the Forth manual, because it is not a very popular language and does not merit spending much time on it. It is not top-priority hobby work because 1616 enthusiasts are a minority.
I can't actually host the html on hackaday so I'm more than happy for the copyright owners to do so.
I was buried in paid work until recently, but am happy to comply with copyright holders' wishes.
Recreating the PAL devices is my main concern, as they are the only obstacle to recreating the 1616 completely. I have the timing diagrams of an Atari machine, which is a good starting point. Without any information or access to the 1616 chips or waveforms, it is impractical to try cloning them. However, I thought it might be possible to make a primitive 1616 circuit that is just a 68000 (or 68008) chip that runs a loop generating video access DRAM cycles. I have some spare CPUs in my collection. Alternatively I could try creating a model in FPGA.
Recently I was kindly sent a 1616 PCB remake designed by Forthnutter. So I bought the bits to make it up as the ultimate testbed - the real thing.
Most recently I was sent a pair of original PAL chips, and found the security bits had not been blown so they were readable! That avoided a lot of hard work guessing the fusemaps from the behaviour.
There are now three 1616 boards under construction.
Mine seems reluctant to work fully. Even if I got it working, it is not particularly useful to me, so I am reluctant to spend further time on it when I have other more urgent things to do.
2026-04-13-Applix-1616-circuit-7027481776117892635.pdf
Circuit of revision C, which has some errors. This is the one I have.
Adobe Portable Document Format - 4.97 MB - 08/24/2026 at 19:04
Preview
1616test.s.txt
Rough test code patch for ROM. A work in progress. Uses no RAM.
plain - 6.66 kB - 08/10/2026 at 19:56
Download
Bellcore MGR Window Manager.html.zip
The pdf file converted into an html file.
Zip Archive - 59.22 kB - 06/19/2026 at 19:24
Download
Applix-1616-Bellcore-Windows-Manager.pdf
Bellcore MGR Window Manager software provides an API to manage windows on a high resolution screen. This requires hardware mods for a 30 MHz pixel clock, and replacing U3 (a 74LS298) with a PAL16L8. And of course a suitable monitor.
Adobe Portable Document Format - 202.41 kB - 06/19/2026 at 14:06
Preview
Applix 1616 programmable logic files.zip
1616U5.JED, 1616U51.JED PAL16R8 chip fusemaps, read by Dataman-48 1616U5.EQN, 1616U51.EQN The JED files above, disassembled 1616U5P.JED 1616U51P.JED Compiled for PAL16R8 1616U5E.EQN, 1616U51E.EQN The disassembled, edited to make human readable. 1616U5E.JED, 1616U51E.JED The above, compiled for PAL16R4 1616U5G.JED, 1616U51G.JED and for GAL16V8 analyse.bat DOS file to generate files check.sh BASH file to compare the PAL16R8 fuse maps are the same (apart from pin names) after my edits.
Zip Archive - 12.38 kB - 06/13/2026 at 17:53
Download
View all 21 files
  • 1 × 68000 CPU, DIP64, 10MHz or better.
  • 16 × 41256-15 256 x 1-bit DRAM, 150ns
  • 2 × PAL16R8 or GAL16V8B NOT 16V8CQ or 16V8ZP !
  • 1 × 85C30 SCC Serial Communications Controller
  • 1 × 6845 CRT controller
View all 8 components
  • CRTC register modification
    Keith1 天前 0 comments
    The pixels are a little off to the left of my TV screen, so I wondered if the CRTC was properly programmed for PAL TV. The CRTC registers are copied from a block of ROM defined in crtcint.c like so:
    uchar crtc_tab[] =
      119,       /* Horizontal total: 15625 Hz line rate */
      80,        /* Horizontal displayed */
      96,        /* Hsync position */
      10,        /* Hsync width */
      77,        /* Vertical total: 312/4 - 1 */
      0,         /* Vertical total adjust */
      50,        /* Vertical displayed: 200/4 char lines */
      63,        /* Vsync position */
      0,         /* No interlace */
      3,         /* Max scan line address: 4 rows/char */
      0x20,      /* No cursor */
      0,         /* Cursor end */
      0,         /* Start address high */
      0,         /* Start address low */
      (uchar)(CRTC_SAVE/256),    /* Cursor register high */
      (uchar) CRTC_SAVE    /* Cursor register low */
    The standard square-pixel resolution for PAL video is 768 × 576 at a sampling rate of 14.75 MHz.
    This was not a common oscillator back in the 1980s, so Applix used 15 MHz derived from a 30 MHz master clock. They could have used the 29.4912 MHz baud rate generator frequency, which is only 0.03% out.
    I bought some 29.5 MHz oscillators which can be halved to 14.75 MHz. This is exactly right for PAL video and very good for setting baud rates.
    Using the online tool for calculating CRTC registers: https://mrboot.de/mc6845.php, select PAL-DVD and the following:
    pixel clock = 14.75 MHz
    columns per character = 8 pixel/character
    rows per character = 4 lines per character
    and we get horizontally:
    front porch   1.6 µs =   3 chars =  1.63 µs
    sync length   4.7 µs =   8 chars =  4.34 µs
    back porch    5.7 µs =  11 chars =  5.97 µs
    total vsync  12.0 µs =  22 chars = 11.93 µs
    active video 52.0 µs =  96 chars = 52.07 µs ; 96*8=768 pixels
    total line   64.0 µs = 118 chars = 64.00 µs ; 15.625 kHz
     and vertically:
    visible lines        288   lines = 72 chars * 4 lines each =288
    vertical front porch   8   lines 2
    vertical sync length   8   lines 16 lines
    vertical back porch    8.5 lines 0 lines
    total lines          312.5 lines 78 characters + 0 lines
    VSYNC is 15.625 kHz
    HSYNC ideally 50 Hz is actually 50.08 Hz
    but the computer screen is not a full TV-screen, so there are still 80 displayed characters (not 96) and 200 lines (not 288). (96-80)/2 = 8 off each side and (288-200)/2 = 44 off top and bottom. Well, I did a spreadsheet and to the best of my knowledge this is what the CRTC table should be:
    uchar crtc_tab[] =
      117,   /* Horizontal total: 15625 Hz line rate (Exact for 29.5 MHz)*/
      80,    /* Horizontal displayed (unchanged) */
      91,    /* Hsync position (moves pixels 5 characters to the right) */
      8,     /* Hsync width = 4.34 µs (slightly shorter than ideal) */
      77,    /* Vertical total: 312/4 - 1 (unchanged) */
      0,     /* Vertical total adjust     (unchanged) */
      50,    /* Vertical displayed: 200/4 char lines (unchanged) */
      63,    /* Vsync position (unchanged) */
    // unchanged hereafter:
      0,     /* Cursor end */
    The CRTC table begins at 51d872 hex. Only 3 bytes change
    Original:
    51D872  77  DB  119   ; Horizontal total: 15625 Hz line rate
    51D873  50  DB  80   ; Horizontal displayed
    51D874  60  DB  96   ; Hsync position
    51D875  0A  DB  10   ; Hsync width
    Modified:
    51D872  75  DB  117  ; Horizontal total: 15625 Hz line rate
                         ; (Exact for 29.5 MHz)
    51D873  50  DB  80   ; Horizontal displayed (unchanged)
    51D874  5B  DB  91   ; Hsync position (moves pixels right a bit)
    51D875  08  DB  8    ; Hsync width = 4.34 µs
  • Upgrading the 74LS244 DRAM data buffers
    Keith08/23/2026 at 22:14 0 comments
    I removed these by snipping the pins, removing the body, then desoldering the pins one at a time. I clear the holes with a solder sucker, solder wick and a pin drill. I fitted a pair of sockets and 74ACT244 chips, hoping the better speed might help.
    Alas it did not, and putting 74LS244 chips back in there did not restore functionality. Reset just produces the tiled pattern of the uninitialised DRAM.
    There are various possible explanations. I may have damaged the board or left some solder swarf that is shorting a pin. I had a good look and only found one piece of loose swarf.
    At this point I am getting a bit fed up with the amount of time this is soaking up. More time than I can spare, or it is really worth. I have reverse engineered the PAL chips which was my original goal. The new PCB is not a 'faithful copy' of the original, the new board has been autorouted with thinner wires and smaller via holes. Perhaps making it more fragile.
    I decided to do a quick connectivity check that all the data pins connect to the CPU. All good except for the D0 line. I heated U30 pin 18 hoping that the solder would wick to the other side of the board and its tracks. This restored previous functionality.
    Swapping the LS for ACT did not cure the fault, in fact it made things worse. So I returned to using LS chips.
    The only difference between these chip families is speed, which suggests timing is the issue.
  • Disabling the bus error timeout
    Keith08/07/2026 at 18:02 0 comments
    I wondered if the bus error circuit was generating spurious errors.
    I guessed that bug-free running software would never access an invalid address, so it ought to be alright to disable bus error detection. So I did.
    I cut the track between U33B pin 5 and U24C pin 10, near to U33B, then tied the track to VCC.
    Power on and ... nothing. Not even CRTC initialisation and screen start up.
    It looks like the bus error handling is essential to sweep the CPU into executing some valid code.
    But really, I would expect the code to present a sign-on screen before trying to access some expansion boards that may be present or not, and not have exception screens overwrite each other before locking up completely. It doesn't seem to be handling itself gracefully.
    Jo is having more success than me, with a couple of known board errors and fixes. So I think any faults are likely to be component or assembly faults. This will take an unknown amount of time.
  • Electrical review
    Keith08/05/2026 at 00:40 0 comments
    Many people learn electronics as a join-the-dots exercise in textbooks written by academics who teach but seldom make practical products. Power lines are drawn with the same pencil-thin lines as signals, connections have zero resistance, inductance or capacitance, and so on.
    Your CAD system will check you have made all the right connections, but it won't tell you if your thin copper track is going to melt as soon as a power transistor gets switched on. Well, as of 2026, but one day AI will be able to do this.
    I have seen professional products designed by people with no appreciation of real-world current flow. Like the battery charger my employers once paid a lot of cash to a subcontractor to design. Heavy currents, thin wires... it did not blow up but it got hopelessly confused trying to measure currents. But that's another story,
    Back to the board we are looking at...
    Power rails
    The power enters on the left, next to the expansion slots. This makes sense because the expansion board could take a lot of current, but I have none so is is not an issue. Or cause of problems that the board is having.
    A good way of telling which chips are using the most current is to feel which are warm or hot.
    My NMOS CPU was rated at 8 MHz, and the board timings demanded at 10 MHz (or faster) part. I fitted a 16 MHz CMOS CPU, and that runs stone cold.
    The NMOS SCC ran warm even when idle, so I bought and fitted a CMOS version.
    The 6845 CRTC is also running warm, but that seems to be running without errors so it doesn't seem to be starved of power.
    DRAM is notorious for needing power, and huge gulps of it every time a row address strobe refreshes the charge on a row of capacitors. They are tiny, but there are many on a row and they need topping up in a fraction of a microsecond. Hence the huge current pulse, and the need for a decoupling capacitor for every DRAM chip.
    Some people say that you really need power and ground planes for serious RAM designs, but these extra layers push up the board price. So board designers have to take more care for two-layer boards.
    The Applix 1616 has the DRAM chips on the opposite side of the power inlet. So all those row-charging current gulps have to travel through the copper tracks across the board, dipping the rails of everything else on the board.
    The BBC micro got round this by having power input connections specifically for the DRAM chips. This might be something worth adding to the Applix board.
    Let's take a look at the voltage drops.
    First I set my PSU to deliver 5.2 volts on the power input of the board, then measure the voltage across the power pins of various chips.
    5.008  Input measured at J13.
    4.812 at CPU, ROM chips (3.76% low.
    4.816 at CRTC
    4.817 at SCC
    4.847 at furthest DRAM chip (the worst case) is 3% drop, which is acceptable.
    4.982 at U49
    4.986 at U5 and U51, the PAL chips
    4.990 at U2, , the IC nearest J13.
    With 5.2 volts at J12, furthest DRAM is 5.035 volts.
    So it looks like the 5V power is okay across the board.
    Termination
    I went to a lecture about the BBC micro, and the speaker said that the BBC failed to run reliably until someone held their fingers on the board tracks. They didn't know why, but they added some resistors to the data bus to simulate the resistance of fingers, and the BBC worked.
    Well I could have told them straight away why it didn't work. When you have wires over a board the size of a BBC micro, they stop being a join-the-dots textbook wire and start behaving like a transmission line with inductance, capacitance and reflection. Fingers or resistors act as terminating loads, absorbing energy that would otherwise be reflected to cause overshoots and undershoots.
    The Applix is about the same area as a BBC micro. But it does not have any bus termination at all!
    Right, that needs sorting out!
    Fortunately I have a known-good termination circuit from the STEbus. I'll start by tying...
  • Fixing the reversed characters
    Keith08/02/2026 at 19:55 0 comments
    I managed to reduce the blurring by simply turning the TV brightness down. The text became much more readable.
    The text translates roughly into this:
    Exception: Bus error, process '', load = $0, last syscall = 28
    FC:4256 Acc addr:0051B122 IR:4242 Next PC:0051B122 SR:2008: t-S--------xNzvc
    D0-D3: 0006FC86 00000000 FFF60009 FFA7FFFF 00000780 00000010 FBE50002 0????????
    A0-A7: 0051D95C 0006F0C0 0006F1AC 0006FODB 0000FF2F 005001EA 0006F150 0006?????
    Stack Frame:
    06F0BC-0000 0780
    06F0C0-0051 7202 0000 0001 0006 F0EA 8083 8483
    With a stable screen, it looks worthwhile correcting the video shift-register error.
    The shift register sockets look like this:
    Blue are the correct connections on the chip pins, yellow are the wrong positions on the socket holes.
    Therefore, for each LS166 chip:
    • Isolate the blue pins by bending them out of the socket,
      or if they are soldered in then cut the legs off the board but leave pin stumps,
      and remove the pin material from the holes.
    Connect:
    • Hole 2 to pin 14
    • Hole 3 to pin 12
    • Hole 4 to pin 11
    • Hole 5 to pin 10
    • Hole 14 to pin 2
    • Hole 12 to pin 3
    • Hole 11 to pin 4
    • Hole 10 to pin 5
    I didn't manage to isolate the pins neatly, so I removed them, cleaned the holes  and did this.
    First add wires to the wrongly positioned signals:
    Then deplete the erroneous pins from some turned-pin sockets, then fit them:
    Then connect the wires to the right pins:
    Yes, it looks messy but it takes less space than forthnutter's correction board.
    With hindsight, it would have been easier to solder wires to the chips first, the poke them through the socket and PCB holes.
    I must have got all the wires right, because I get a sign-on screen with the letters the right way round:
    which immediately does at least two Exception screens before settling. This is a second:
    I get the impression the system is less stable than before, when it would usually just throw one exception.
  • Programmable logic chip investigation
    Keith08/02/2026 at 17:51 0 comments
    I asked forthnutter to send the JEDEC fuse map he compiled with WinCUPL, to compare it with the one I compiled with eqn2jed.
    There was one error in the fuse map defining the green pin behaviour, but not enough to cause the complete lack of pixels on all but the right-hand column of characters.
    There were major differences in the configuration bits. WinCUPL had specified signature bits, while jed2eqn had not specified any. Also, jed2eqn had cleared fuses to ignore unused rows, which saves power. WinCUPL had left them set.
    So apart from current consumption and the minor bit error, forthnutter's GAL should have worked exactly as mine did.
    Forthnutter is using his original PAL chips and his display is working. I had tried them, without success, but that was before I swapped /CE and /OE drive signals on the Flash ROM chips. So I tried them again.
    The behaviour is not stable, but significantly better. It usually briefly displays the sign-on screen, which is very blurred and has individual letters horizontally reversed but should look something like this:
                     Applix 1616/OS V4.5a  Level 0 reset
                  Copyright (c) 1987-1991 Applix pty limited
                                 Andrew Morton
                         Compiled: 25th February 1991
                           ROM checksum: $5710FFC2
                        24K RAM disk,  32K video memory
                    0 drivers occupying $0 bytes at $6F1C0
                        System processor: 7.5 MHz 68000
    Switch 2 open: ;using SA: for console
    It then jumps to the usual  Motorola 68000 exception crash dump screen.
    Another improvement is that it doesn't keep rebuilding an exception screen over and over again.
    I wondered if there was any differences using GAL chips versus the original PAL chips. It turns out there are.
    The GAL16V8 starts up with outputs high. I had noticed this when comparing the PAL vs GAL behaviours. However, this is the inactive state for most control signals so it is desirable.
    The GAL16V8CZ series are designed for aggressive power saving. They have Input Transition Detection (ITD) circuits that wake the chip very quickly (say 5ns) after any input pin (apart from CLK and /OE) change. This reduces power while inputs are steady. Up to the point where the inputs change so often that the chip never has time to sleep.
    This causes problems for the counter, because if the matrix is waking while the outputs are being fed back, the macrocells can experience setup-and-hold violations relative to the system clock.
    Modern GAL chips are usually much faster, so the fast rising and falling edges can cause ringing and timing problems. So you might be better off with slower speed versions like the 16V8B.
    The power-saving feature can't be disabled on the 16V8, but it can on the 22V10. Which is a good reason for upgrading the 1616 board to use them. It also allows the 15 MHz upgrade logic to fit inside.
    So that is a good step forward.
    TPAL1 U51 is NS PAL16R8 ANC +B8648 (25 ns)
    VPAL1 U5 is MMI PAL16R8 BCN 8625 (15ns)
    I then bought eight AMD PAL16R8-7 chips. AMD bought up MMI, so they should be the same as MMI chips. At 7 ns, they are a superior replacement for the originals.
    I programmed a pair, and they did not improve matters. In fact, I can see there are now screen bytes not cleared at start-up. The faster speed may be causing the problem. In fact, that is the only real difference from the original chips, so it must be the problem.
    I have a gut feeling that if faster logic chip causes a problem, then there is something wrong with the overall logic.
    Right now I just want to replace the originals with copies that work just as well, not worse. So I have ordered:
    MMI PAL16R8ACN is 25ns, to replace the NS PAL16R8 ANC (which my LV48 can not program).
    The 15ns versions are a bit scarce/pricey on eBay right now. So I am ordering some GAL16V8B chips of the matching speed.
    I programmed a 16R8ACN for U51, and a NS GAL16V8A-LNC for U5. Both worked as well as the original, that is the board does a couple of exception errors and quits.
  • Logic analyser results
    Keith07/30/2026 at 20:53 0 comments
    Two 30 MHz oscillators arrived, and I replaced the 29.5 MHz one I was using. I didn't think it will make much difference, but it did. The 30 MHz oscillator caused the display to keep blinking!
    Maybe it wants more current. Data sheet says 40 mA, about normal for legacy modules.
    I restored the 29.5 MHz oscillator, display is stable. Maybe could do with more decoupling there.
    There are times when a logic probe just won't cut it, and this is one of them.
    Time to get the big guns out, in the shape of my 500MSPS logic analyser.
    Having a look at the outputs of the timing GAL, things look as expected. The 15 MHz clock in is divided to 7.5 and 3.75 MHz. This is divided again to 1.875 MHz, slightly delayed, to be the CRTC character clock (CCLK).
    The /RAS, /CASL, /CASU and /LP signals have the right timing relationship. The image below shows the video accesses reading upper and lower bytes at the falling edge of CLCK. It is okay for /RAS to rise before /CAS, this does not end the cycle early.
    /DTACK is only used to tell the CPU that data is ready. The CRTC is synchronous and runs whether data is ready or no. So /DTACK is idle for video access.
    Video cycles only:
    Now let's set the trigger to /DTACK, which is the timing GAL telling the CPU that data are ready.
    CPU cycles:
    Here we can see CPU accesses taking place. Again this looks good, /DTACK is low during /RAS and /CAS of the CPU access.
    Both cycles:
    Here we can see both CPU and video accesses taking place. Again this looks good, /DTACK is low during /RAS and /CAS of the CPU access.
    DRAM Data Bus Enables
    Sometimes they are long, like this:
    I'd say these were normal. This looks like a CPU reading 16 bits.
    Often they are very short, like this:
    In the image above, only /CASL is asserted, so the CPU is accessing a lower byte. And writing, because /BDRE (U28 pin 1) is high. The data bit are written to the RAM while /CAS is low, so the brief /BDRE pulse should cause no conflict. I'd say these are glitches, but harmless ones.
    Replacing the NMOS SCC with a CMOS SCC did not improve things, apart from reducing the current drain to 1.1 amps.
    I fitted a 1000u cap in C2, it did not fix anything but it did allow the 30 MHz oscillator to be fitted and run without glitching. I also noticed the screen would sometimes resemble (with many errors) the proper sign-on screen or formatted output (before being overwritten).
    Decoupling seems to be very sparse. There are no 100n decouplers for the CRTC and SCC which are the most current-hungry chips, judging by their warmth. The CPU and the 6522 VIA have only one 100n cap between them. U16 and U24 have no decoupler at all.
    These caps added underneath:
    This cap added on top:
    This did not cure the problems. Usually just crashed with random garbage on screen.
    Sometimes I got what looks like a top line of garbage:
    Possibly text:
    Or several lines of text:
    I'm guessing this one is some kind of register dump. Registers on the 3rd and 4th rows, flag dump on the right of the 2nd row. Perhaps users with working machines can recognise what this screen is. AI suggested it to be a Motorola 68000 exception crash dump screen with something like this kind of text:
    Exception: Address Error      SR=$2700  PC=$00014B20
    Vector: 03  Instruction: 4E73   (Note: S=Supervisor, I-L... )
    D0-D7: 00000000 0000FFFF 00000000 00000000 0001C120 000021A4 00000000 00001000
    A0-A7: 00FF0000 00001F24 00000000 00000000 0001D1A2 00FFFFFF 0000E000 00FFFE00
    Stack Frame:
    00FFFE00: 0000 0001 4B26 0003 4E73 0000 0000 0000    [ ....K....Ns.... ]
    00FFFE10: 0000 1F24 00FF 0000 0001 C120 0000 21A4    [ ...$....... .!. ]
    00FFFE20: 0000 0000 0000 1000 0001 D1A2 00FF FFFF    [ ............... ]
    00FFFE30: 0000 E000 00FF FE00 0000 0000 0000 0000    [ ............... ]
    00FFFE40: 0000 0000 0000 0000 0000 0000 0000 0000    [ ............... ]
    00FFFE50: 0000 0000 0000 0000 0000 0000 0000 0000    [ ............... ]
    00FFFE60: 0000 0000...
  • Sequential start-up tests
    Keith07/30/2026 at 01:03 0 comments
    The original firmware reads SW2 and performs either 1 of 8 primitive tests, or 1 of 8 running modes.
    The tests rely on output ports to indicate information, but that requires some LEDs to monitor the states which might be pulsing rapidly. I feel this is rather unsatisfactory.
    In a previous job, I worked for a smart card company. Smart cards are small but highly critical single-chip microprocessor systems. Any bugs would be disastrous, so checking smart card security costs literally millions of pounds. I only know a hand-waving amount about they work, but the start-up process is useful.
    I propose this start-up test sequence:
    • Check registers work
    • Check the ROM contents have a valid checksum
    • Check the CRTC is present (write/read a register)
    • Initialise the CRTC (so that RAM gets refreshed)
    • Check the VIA is present (write/read a register)
    • Set the video colours
    • Check the stack RAM is working (so you can use it for subroutines)
    • Check the SCC is present (write/read a register)
    • Check the video RAM stores data written to it
    • Send failure report to the screen or serial port
    • If no failures, boot up as normal
    It could write a digit code to the output port to indicate the last test that succeeded, or a binary pattern showing which ones had succeeded or failed.
  • Flash ROM issue
    Keith07/27/2026 at 17:37 0 comments
    When examining the piggy-back SRAM idea, I noticed the original design used this wiring:
    R/!W --> inverted --> ROM !CS
    ROMSEL --> inverted --> ROM !OE
    This was a way to reduce EPROM access time. It would be activated early on, and then take only the shorter output buffer switch-on time to provide the data when selected.
    Flash ROMs are not exactly like EPROMs, because they want the address to be stable while they are selected. If not, they internally start accessing a garbage address then try restarting when the address changes. With the original wiring, every read cycle will start an access.
    This probably explains why start-up tests that didn't involve the DRAM were not reliable. Most of the time, a test would run for seconds, but then crash.
    At this point, I could either try using a 32-pin EPROM, or try swapping the !CS and !OE wires over.
    This would ensure the address is always valid (!AS asserted), and as a bonus the !OE signal could be shared with piggy-backed SRAM chips.
    I only have 28-pin EPROM chips so I'd have to modify tracks. And if I have to do that, I might as well save a step and modify tracks to suit the Flash ROM.
    Here are the mods to be made on the underside:
    Cut tracks at the red Xs, then make the purple wire.
    This isolates the pin signal from !CE and routes it to !OE.
    Now we need to isolate the signal that goes to !OE and route it to !CE.
    Make the yellow wire to drive !CE.
    Then turn over and cut the track marked with a red X.
    Switch on, some tests running.
    0 pulsing. Screen shows gradient of grey, because VIDLATCH increments background colours.
    2 CRTC not initialised. LED pulses (VIA test)
    4 CRTC not initialised. LED pulses (Iporttest)
    6 CRTC not initialised. No pulsing so fail (memtest fail)
    1 CRTC initialised. No pulsing so fail (SCC test)
    3 CRTC initialised. No pulsing so fail (Crtcrwtest test)
    5 CRTC initialised. No pulsing so fail (RAM test fail)
    7 CRTC initialised. No pulsing so fail (screen RAM fail)
    When the screen is initialised, it is just DRAM garbage, no characters.
    Run mode (15) is a little better than before, because it does appear that the screen RAM is being written to, however this does seem random so I assume the software is running amok.
    So I thought the ROM behaviour had improved but the RAM is still failing.
    Then I checked the Exception report, it says the last instruction was in ROM.
    ROM changed to Atmel 29F002T-70 chips, but these worsened the issues if anything at all.
    UPDATE:
    The original design swapped the signals over, but Jo's modern design does not. So all the mods I made above had to be undone!
    The swapping probably only needs doing if you are upgrading an original board to use Flash ROM. I have not got an old board so I cannot check this out.
  • Piggy-backing SRAM
    Keith07/26/2026 at 13:37 0 comments
    All pins compatible except:
        Skt.    RAM
    31    PU    A15 wire to A15 on skt pin 29
    29    A15    !WE flying wire to CPU.9, TPAL.8, U55.12, or U54.13
    24    !OE    !OE wire to Skt. 22 (which is !RD)
    22    !CE    !CE
    ROM.!OE is !ROMSEL
    ROM.!CS is labelled BR/!W on circuit rev. A, and /R/W on  circuit rev. B.
    The circuit shows it is inverted CPU R/!W, so it is more of a shared !RD signal.
    That makes sense, but intuitively I would have expected the !RD to go to ROM.!OE and !ROMSEL to go to ROM.!CS.
    Maybe OE access time is faster than CS?
    Now the SRAM needs activating at the bottom block, I need to activate it there.
    /RAMSEL is actually /DRAMSEL, it goes to TPAL.3 to activate the DRAM signals.
    So I removed the link between pins 1 and 2 of link area P1 to disable the DRAM there.
    To disable it everywhere, it would need a pull-up resistor.
    So instead, I shall enable it just before the ROM.
    IC59 decodes memory into eight 1-megaword blocks.
    Two 512K SRAM chips would appear twice in a block.
    I shall relocate the DRAM to block 4 at 0x400000,
    so that it is safely driven high.
    A23 22 21 20
    0   0  0  0    !SRAM
    0   0  0  1
    0   0  1  0
    0   0  1  1
    0   1  0  0    !DRAM
    0   1  0  1    !ROM
    0   1  1  0    !IOSEL
    0   1  1  1    !EVPA
     Next issue will be to drive the CPU !DTACK when SRAM is accessed.
    One could do this by pulling the !EXTDTACK signal low.
    This is the open collector signal from external devices on the expansion slots.
    I don't have any expansion cards, so until I do I can wire the !SRAM signal straight to !EXTDTACK.
    The system should then be able to boot up using SRAM.
    No video, so it has to use the serial port as a user interface.
    The DRAM should still be accessible for testing.
    UPDATE:
    ROM.!OE is !ROMSEL only on the original board, for EPROM chips.
    For reasons discussed in Flash ROM issue, this should not be done for Flash ROM chips and the forthnutter board wired correctly. So /OE is in the right place for RAM chips.
View all 30 project logs
kdhildred5 wrote 04/27/2026 at 07:24 point
aggghhh just realised thats you lol
Dave wrote 04/29/2026 at 06:53 point
He he yes he did a great job with the resto and well documented.
And I sent you a PM, please let me know if you received it. Thanks
kdhildred5 wrote 04/27/2026 at 07:20 point
and this one https://microbeetechnology.com.au/forum/search.php?action=results&sid=d9201b4992e4323fdf8ed3018eb519f1&sortby=lastpost&order=desc
full of software and manuals...
kdhildred5 wrote 04/27/2026 at 07:18 point
hey found this as well https://forum.acms.org.au/t/retrochallenge-2023-10-applix1616-restoration-documentation/503
kdhildred5 wrote 04/27/2026 at 06:45 point
not sure how to add photos in here or if i can
Dave wrote 04/27/2026 at 07:03 point
Hey thats great I'll PM you. As I'm not sure either.
kdhildred5 wrote 04/27/2026 at 06:42 point
searched through my chip stash and found these ROMs 27512 V3.0b H and L (high and low) ; 27256 V1.4a H an L ; SSDDROM V1.4a and V2.0. TPAL1 V51 and VPAL1 V5
Keith wrote 05/09/2026 at 03:05 point
Do you have the actual PAL chips, and if so would you lend them to me?
kdhildred5 wrote 04/25/2026 at 07:12 point
Will check re the PAL's might even have the original ROM as well... did have the 3.5 floppies until a few years back but don't anymore..
Dave wrote 04/25/2026 at 12:54 point
Oh wow ... yeah if you could check that would be great. Thanks :)
kdhildred5 wrote 04/23/2026 at 08:58 point
i remember this. Bought the pcb kit - bare min pcb plus Pals.. Then bought all the chips and soldered it together. Worked first time. Was only the 2nd one I built. 1st was with the RCA1802 processor. Spent hours on that one typing in HEX code just to play Pong. Good days they were. Unfortunately don't have them anymore but I did remove most if not all of the chips from the pcbs. Think they are still in my draws somewhere in IC conductive foam..
Dave wrote 04/25/2026 at 07:04 point
That's cool, it's a pretty complex kit and getting it going first time is an achievement it its self. Would you still have the PALs by any chance? The code to program more no longer exists so looking for these PALs so we can reverse engineer. Then we can replicate them for preservation and to build a complete system. Thanks
Keith wrote 04/14/2026 at 13:36 point
Having merged and hex dumped the ROMs, I found the text:
Applix 1616/OS V4.5a, Compiled: 25th February 1991
Dave wrote 04/13/2026 at 22:16 point
With the mainboard ROMs here what version are they? I believe the last was v45.
