[T] Current Tetent layout
01/02/2023 at 12:47 • 0 commentsI've ordered the letters based on appearance (though 13K Hackaday log words iirc), with lower movement taking priority over lower average actuation force. I've also aligned the C, V and X locations for Copy/Paste/Cut commands.
For Finger5, there would be higher dedent resistance between row 2 and 3. Tetent Search is also forceless so that a user has a chance of stumbling on it by just sliding the Tetrinsic.
Row 5 of Finger5 is mainly for quick text navigation.
[T] Even thinner? Solution required.
01/01/2023 at 20:44 • 0 commentsMy fingers are my client; at least, that's how I should consider this development process if I was some freelancer. I make a solution. I give it to the "test group". The test group hates it because I didn't really listen to them.
Finger5 is most likely to fail the entire solution, followed by 1, 4, 2 and lastly 3. This is because Finger5 needs the most accomodation.
The thickness that matters is the distance between the top of the ball-chain and the bottom of the assembly. I don't want to take Finger5 out of the equation though, because Thumb1/Finger1 has the force, speed and dexterity to actually offer 4 character chording. I'm not thinking of constantly inputting 8 characters at a time, but 4 on a single hand will be very beneficial. Remember that when this project started, I was expecting to get 4 characters out of both hands.
I've also determined that the most comfortable angle (for all but Finger1) is determined by Finger5 and is the same angle for all. It seems to be 4 or 5 degrees in the direction of Finger5 and not away from it, as I've done in #Tetent TimerSpy [gd0136].
I've thought of a concept already that could obtain this solution, where you have one side that has the tall, 20mm-ish block that has the electronics and then a thin section where the ball track. Again, this strain guage (or other pressure sensing method) is an unsolved question mark. The track would likely have to be bolt reinforced so that the part furthest from the strain sensors don't bend, reducing the accuracy of the readings.
Part of the thinness is also because the Finger1 actually intersects the other ones, mainly Finger2. This will allow parts of the track to go under others like some kind of micro overpass bridge.
I also feel like this could still be used as a VR controller of sorts. Sure all fingers would be locked into a single plane, but you could still probably get half the way to the sensation of force feedback gloves. It's not designed for that, but with the expected price tag of a single Tetrinsic, and development into AR with #T^2 TyMist [gd0138], I'd like to cover as much of a solution as possible. Everything after learning and typing fast is a free bonus.
[A] Mining for a solution... ends, in 30 days.
01/01/2023 at 20:33 • 0 commentsThe title is a reference to the line "The world ends in 30 days." said in episode 1 of "The Day I Became A God", but I don't remember ever seeing that day and the anime always had a countdown of days left at the end of each episode, so "The World Ends In 30 Days" (emphasis on bold) is what I personally call it, especially since this was in the action packed year of 2020.
l've simulated a simple yet seemingly inescapable deadline: Feb 1. This second term of Uni is sounding like it's really going to drain-touch my time, and all my mental simluations basically predict that if I try and obtain Tetent (unless it's practically almost done by then) afterwards, I'm unlikely to get either Tetent or satisfactory academic results.
This means that I've actually got to finalise what plan I'm doing for all Tetent projects and start ordering AliExpress parts essentially by the end of next week. The new proposed TimeSpy solution should finally address all problems that could arise, and if it doesn't... well if it was not invented here and I instead bought it, it'll be unlikely that I'd return it.
Other than #Tetent TestCut and TimerSpy, all other Tetent projects are being shelved. TestCut is really just a mount since the Tetrinsics are doing all the computational work anyway, and in an ideal solution TimerSpy would be the only Tetent needed; it could be used in the most situations and fufills a niche that existing solutions like stenography and Charachorder haven't been able to break into.
I think it would make the most sense to talk about things like the typing layout in this project too instead of Tetent, so that the information on the overal Tetent project is more centeralized.
I think the programmer industry calls this approaching-deadline situation a "sprint", so...
[P] Chain in a channel
12/30/2022 at 11:11 • 0 commentsSo I'm looking for where I misplaced my tin foil box, and I see something in the bag of TCT360 goodies I got months ago:
It feels amazing.
Except for Finger5 that seems to just slide off to a side, the chain just glides beautifully under Finger1-4. (Finger1 = thumb). It looks lovely whilst doing it, and makes a very soft, metal sliding sound that's actually quite relaxing. I found a video of something that sounds like it (39 seconds mark):
It's a shame that most of the cost and complexity is in the absolute encoder and force sensor, so trying to make a Tetrinsic Tiny that doesn't have the screen + BLDC motor or limitless chain movement might just be an excessive detour.
[R] Looking at the start of Plover
12/28/2022 at 22:59 • 0 commentsRight now I'm reading how Plover got started through blog posts written by the project founder and it sounds like her and I are on the same page. I'm still at the 2010 blogs though, when multi-touch touchscreens were talked about as the next new thing in technology, but it sounds like she never got the wearability part (I don't know of any wearable steno machines).
The bigger problem that I haven't seen addressed is that even with the cheaper keyboards and free lessons and software, the vibe I'm getting from Quora is that stenography takes years of dedicated, multi-hour practice just to get to 120wpm... on 2 hands. I don't know of any 1-handed steno methods either.
Ms Knight also dreamed of a steno solution with haptics (I think using a multi-touch touchscreen or something to that effect) and I don't think that's materialised 12 years later. What happened to that?? Why hasn't even Apple done it in their persuit of thinness? They did it for their touchpad. Perhaps too expensive, even for them? They could always just have 1 haptic motor per column since it's not like anybody can get 2 fingers on the same column at relatively the same time.
Speaking of laptops, I don't think a BLDC motor would fit, but otherwise, a thin slider with a vibration motor and strain guages could be used for the Tetent layout.
[T] USB Connection?
12/27/2022 at 20:29 • 0 commentsI just got word from Me Solving Timespy that there isn't really any solutions shorter than the TFT one I've got now, and so it looks like Tetrinsic 2.0 with TFT will be the only version worth persuing if Timespy doesn't cause this solution to fail, meaning that I'd have to go back to my Tetrinsic 1st Generation days.
I'm also thinking of Tetent, and how I'd connect the two halves. Perhaps it might make sense to have a USB host controller on the PCB so that, ideally, a master Tetrinsic on one side can connect to the other side.
Me2: Why do you need USB to connect the two again?
Me1: Wasn't it for a wired Tetent connection and for audio?
Me2: With #T^2 TyMist [gd0138], I no longer need audio in Tetent.
Me1: Oh yeah. That's right.
It might still be useful to quickly transfer over LCD gifs/videos between all the Tetrinsics. With up to 16MB of flash, it might take a while for all Tetrinsics to update through I2C. I probably should try it first and compute a solution if it actually becomes an issue.
[M] Load Cell Simulations
12/27/2022 at 10:43 • 0 comments[8:45] One of the smallest load cells I found on the internet:
There was a model on GrabCAD. For all these simulations, I'm using 10N.
I then went and designed a 4.25x30x6mm load cell for 7.1x4.1mm strain guages. I used the PET material in Fusion360.
Trying a more bone-like shape just made things worse:
What if I keep the circles at 2mm and make the slot thinner?
Remove the circles and leave the slot:
Displacement's getting better, but I'm not getting much bending on one side.
Yeah if I look back at the aluminium, the left side is all orange by the time it goes past the circle. What if there's just a circle on that side?
That didn't seem to do much.
Better deformation but worse safety factor and displacement.
I know. What if I have the strain guages face such that the solder pads are pointing towards the ends of the beam instead of the centre?
Nope.
Getting there, but the safety factor is questionable.
What if diamonds were used?
Pass.
Ok 0.8mm walls on those circles gives the desired strain points. The safety factor is through the floor though, and the displacement is so bad that the "adjusted" deformation isn't that much worse than the "actual".
Squares might be going places though. These are 2mm squares with 1.2mm walls and 1mm fillets.
There's got to be more optimal designs out there on the internet.
Moving on, once imported into the Tetrinsic assembly, the 3D printed guage is looking even more problematic:
Ok this is what I've got:
4.9N (500g) simulation:
[10 minutes later] Ok. I've thought about it and it seems I have a simple yet inescapable choice. The total length needs to be longer or I need to pay more for shorter strain guages.
[5 minutes later] Or is there a third option? There's been a 3D printer probe sensor that uses SMD resistors and the Smartknob View project recently incorporated the findings into their PCB.
[Some modelling time later]
Let me simplify out those cuts...
Results:
In any case, because of the mounting hole issue, I still haven't escaped my simple yet inescapable choice. And it's [16:30] now.
[17:00] The choice I've made is to go down to a single hole on each side and compute a solution to prevent unwanted rotations at another point in time.
4.9N weight simulation:
[M] The All New Tetrinsic 2.0: Initial concept
12/26/2022 at 19:37 • 0 commentsWouhhhpf! Looks Good To Me 😁👍
Me In The Recent Past, thank you for not immediately dismissing the idea of getting an LCD back into this project again. There was an LCD when I first started designing Tetent, which got removed due to the layout. Then it came back again in the transition between Tetwin and Tetrinsic but was ultimately lost. Until now. If I can get everything to fit geometrically, this will fufill all requirements I set out to accomplish when starting #Tetent [gd0090].
It's quite interesting how most of Tetent's complexity has been absorbed into Tetrinsic. I can imagine some alternate dimension where TTGo or Waveshare made this thing instead and creating Tetent would've been super easy and barely an inconvinience. Unfortunately, Tetrinsic isn't some off-the-shelf part that exists here.
I've actually been thinking of using something like black or copper ball chain, but now seeing the stainless steel variant in this render, I'm more than fine with sticking with it. Speaking of the render, the white part is just a standalone enclosure "serving suggestion".
This is what the top-down path of the planning sketch looks like:
The concerns I have is that the total length is now 50mm and the distance between the bottom edge of the screen and the bottom edge is around 10mm. Both concerns stem from #Tetent Timespy [gd0136]. I also expect that I'd need to cover the screen with a protector to prevent damage during use.
Oh and I've only got 5.6mm of thickness for this singular load cell. It does look like I've got a decent amount of length to implement it (<32mm), as well as a generous amount of space for the PCB.
Exciting. I think I can delete the belt version from the Fusion360 file and go all-in on this new version.
More Renders
[T] TFT, angle sensor and 16MB flash
12/26/2022 at 16:58 • 0 commentsFocus on TFT screen
I'm thinking of only designing for the TFT variant of Tetrinsic 2.0 and only doing the COB LED strips (one on each side) either if the need arises or it's actually super easy, barely an inconvinience to implement.
For PWM driving the backlight, it sounds like an N-Channel MOSFET is what I'm looking for.
Cheaper angle sensor found
Both chips are full-bridge sensors. The TLE5501 is an 8SOP chip though. Hopefully though, I'd have enough PCB space.
Flash
I searched on Google what the general consensus was for picking RAM and FLASH values for microcontrollers, and it was recommended to pick the highest possible when regarding a hobbyist project (with the option of scaling down later).
With that in mind, I'm going to use a 16MB FLASH chip. Searching around AliExpress, all the RP2040s use a W25Q chip. I'll likely use the smaller package option:
Conclusion
[T] To LED or not to LED...
12/25/2022 at 22:15 • 0 commentsYesterday, I've mostly been thinking about how I'm going to attach the motor to the rest of the build, and how to go about a 3D printed load cell.
Motor Updates
For starters, I'm thinking of cutting off 2 of the 3 tabs and M2.5 tapping the remaning one. I also was able to easily open up the motor and thread the ribbon cable back through the hole and through the gap between the rotor and stator. The stator electronics seems pretty attached in there, so it doesn't seem like I could 3D print a custom stator mount, forgoing the aluminium one entirely.
Load Cell Thoughts
LED or LCD?
I was planning to have a left and right variant of Tetrinsic to give me the most amount of space for this mystery load cell, but then I started thinking "Should I have this thing (the ball chain) LED backlit?" and that soon turned into "Should I use a single daylight white COB LED under a thin, printed sheet, or should I opt for a IPS display where the ball chain slides across its surface?".
I've found both a suitable LED strip and LCD screen, but I couldn't find an addressable LED that would likely fit.
I can see a possible option for the screen version. The screen is 17.6mm, so it covers the entire top section. This means that I wouldn't be able to screw a bolt into the single motor tab and instead would have to do something like a grub screw mount on the cylindrical face of the stator. Half of the initial route, shown in blue, and the possible route, shown in red is shown below.
The LED strip would be more adjustable, taking advantage of the ball chain. Unlike belt loops, I wouldn't have to specifically buy different lengths to make a longer Tetrinsic. Instead, I should be able to just take a length of ball chain and DIY it into a loop without much of a trace. The COB led strip length can also be changed for different applications unlike the display which is fixed at 24.9mm of active area.
Me2: But come on! Think of the aesthetic! And most of r/mechanicalkeyboards is, generally speaking, the same layout with an artistic choice in keycap colours.
I've got an idea. I could design for the screen, then make a 3D printed part that takes an LED (or nothing) instead. Then one could choose between no / solid colour / animated backlighting. Playing all sides, so that the solution always comes out on top.
I'm likely going to need more pins then.
Microcontroller Search
The next M032 up looks decent. 2X the RAM and FLASH for a larger package. Only pennies more.
Oh right yes I should also mention why I've completely skipped over the RP2040. Dual core, loads of RAM, 30 I/O pins oh and probably great software support... where's the issue?
Then again, I should look into it though since it supports up to 16 megabytes of FLASH (which, for a microcontroller, sounds like A LOT). The AliExpress boards I found were like £2 or less with 16MB, so it can't be that expensive. I'm assuming it's the relatively large looking 8-pin chip.
This looks like a good one. No idea why 10pcs costs slightly more than 1, but at 34p per each I'll look the other way.
That would put the total for the RP2040 at £1.14 for 256K of RAM and 512K of FLASH, which sounds decent actually. More than decent; isn't the RP2040 undercutting the entire (Digikey) market in almost every way in every metric other than available PCB surface area requirements???
If I can actually fit that 8-pin FLASH, then I could get access to a seemingly easy microcontroller to run Tetrinsic on. I'd have loads of memory, an entire core I could dedicate specifically for the screen, and likely a magnitude more internet documentation than Nuvoton's M032 line.
Conclusion + Concerns
It's looking more and more like mining a solution for a "Tetrinsic 2.0 even though 1.0 hasn't even happened yet" will bring forth a slew of benefits but be more expensive as a result. It's certainly a harder solution to mentally process, but the benefits would be:
- Higher quality material in contact with skin
- stainless steel instead of rubber
- Better aesthetic
- ball-chain looks more elegant and less mechanical/technical than a rubber belt
- potential option for LED or LCD backlighting
- Potentially cheaper PCB and easier to program microcontroller
- Potentailly less friction / resistance
- Smaller size
- Potentially better pressure sensitivity if I'm able to integrate a full-bridge load cell instead of the half-bridge solution I currently have.
The drawbacks would be:
- Potentially higher overall cost, especially factoring in the ball chain splicer
- Potentially noisier operation
- Potential for play in the ball-chain
- Higher build complexity
Things I'll have to further look into:
- Load cell space
- Available pins for RP2040 to see if I have enough and of the right kind.
- Amount of extra complexity in PWM controlling 5V LED when I have 3.3V logic.
- Thickness of 5mm LED strip
