Current Motor Layout Plan
04/12/2022 at 07:58 • 1 commentFrom asking around, and research, it sounds like Klipper might run into issues with the dual MCU setup I'd need. This is becuase boards like the RPi (and I assume the Orange Pi) are not realtime. The main concern is the dual ZM (main z gantry) axis, which ideally should move at the same time.
This is what I'm currently planning:
- Octopus Pro
- X1
- Y1
- ZM
- ZM
- W1
- V1
- E1
- S1
- Octopus Pro
- X2
- Y2
- Z1
- Z2
- W2
- V2
- E2
- S2
Where
- X[number] = X for IDEXY head [number]
- W = Either the rotational bed axis motor or the belt bed motor
- V = Rotational axis motor in the Slime [gd0088]
- S = Extruder motor in #SecSavr Select [gd0091]
- (also, I just found out about Hackaday.io's hashtag feature while typing this log)
- Octopus Pro
Octopus Pro
04/10/2022 at 22:58 • 0 commentsI've got the firmware flashed and the PSUs wired up, ready for testing tomorrow.
AIO II Issues
04/05/2022 at 13:23 • 0 commentsI can't seem to get the extruder motor to move on the AIO II. It uses some ST820 drivers and the AIO wiki doesn't tell me what resistors or logic voltage it uses for me to use the equation on the ST820 drivers.
Thus I'm going to get the Octopus Pro set up. This will also be a good chance to try the S6609s at 36V.
Hotend Testing
04/05/2022 at 13:01 • 0 commentsThe nozzle thermistor doesn't have desirable contact with the nozzle to get an accurate reading.
The CHC took 70s to go from 26C to 236C, and the nozzle took another 40 seconds to equalise at 153C.
Then I tried without the melt extenders:
There was a much larger temperature lag and eventual difference, only reaching 103C.
Next was a regular volcano nozzle:
Temp detected at nozzle: 170C
Lastly, I tested out the supervolcano with 3 9mm extenders (Ideally, I'd just use 1 30mm extender but I'd need to get a suitable M6 tap)
Temp detected at nozzle: 123C
TriangleLab's copper melt zone extenders may work better for this application. Regardless, next I will be testing out the flow rates in a future Project Log.
[P] Octopus Pro
03/30/2022 at 18:21 • 3 commentsAhh yeus the Octopus Pro has finally arrived. Coming with 8 stepper drivers that can all be used to 48V and costing £36 + VAT (on the cheaper end of boards with 8 drivers), it's the best option for what I need to do. I'm no professional but I do need another 3 for my dual core SecSavr setup.
Testing the GC6609 / S6609 Stepper Drivers
03/22/2022 at 13:21 • 0 commentsCurrently trying these drivers on the DP2:
https://hackaday.io/project/184230-dp2-repair-gd0014/log/204221-trying-the-gc6609-stepper-drivers
[M - T] 8 Entire Millimetres
03/21/2022 at 22:38 • 0 commentsMe In The Past put in a great deal of effort and considerations to get the SecSavr Space to 224mm using the supervolcano.
In other news, I've got a visual concept of what the remote air Slime could look like:
[T] Hotend
03/21/2022 at 14:48 • 0 commentsHeatbreak issues
While I was able to find this cool motor that has 2 independently controllable shafts, I wasn't able to find a heatbreak like this one that had a thread length of 5mm instead of the 4mm I've got. I have discovered that the white insulation is likely ceramic, as TriangleLab has this.
This means that while the 40mm nozzles, the supervolcano and the normal volcano + volcano adapter could work, stock volcanoes or v6 + volcano adapter doesn't.
Spacers and TIM
I'd also need to look into a long M6 tap for the 30mm alu spacers. For now though, 3 9mm spacers could work. I'll see what thermal interface material options are out there for 300C operating temps.
Slime
I'm annoyed that the current Slime concept is around 150mm from the V axis rotational pivot to the front of the Slight. I've also have to think about a vacuum and Slime internal cooling, so I've decided to remove the onboard 6028. Now, I think 100mm is possible.
[T] Dust (and other milling) Concerns
03/20/2022 at 18:02 • 0 commentsA few days ago, I found out, among other things, that (FR4) dust is pure poison, especially the very fine particles from specific materials and not the larger shavings from plastics and metals.
I was already planning on HEPA filters, but I wanted to avoid the need for a vacuum and instead use the 6028 blower on the Slime. Other than blowing the particles onto some kind of catcher around the bit, I don't think I'd be able to go with that method.
On the same note, I want to make the printer as easy to clean as possible. This means things like centralising air intake locations so that dust only has to be cleaned in a few locations, as well as easily wipable surfaces. This is why I'm thinking of using large diameter shrinkwrap tubes as sleeving instead of cable chain / hose tube / braided sleeving (and also because I think it'll look better)
[M - E3] Room
03/20/2022 at 17:50 • 0 commentsSo I started to write the dependencies of components down and realised that Room > Frame > Gantry > Slime is wayyyyyy better than trying to go the other way around. Thus, I'm currently modelling the location in the room where the printer is going.
Edit 1
Edit 2
Quick render:
eeeeeeeee
