Here are some of the most important key facts:
- Compact design: Total size 120 x 50 mm. Approx. 70.5 x 50 mm area for electronics and additional 49.5 x 50 mm to mount a scintillator.
- All-in-one: No external parts (e.g. sound card) required to record gamma spectra.
- Standalone spectra recordings on built-in flash.
- Easily programmable using drag-and-drop firmware files or the standard Arduino IDE.
- Low-voltage device: No HV needed like with photomultiplier tubes.
- Can use SiPMs in the voltage range of 27.5 V to 33.8 V.
- 4096 ADC channels with built-in 3 V voltage reference.
- Energy resolution of up to 7% @ 662 keV possible; highly dependent on your SiPM/scintillator assembly.
- Energy Mode: ~10 µs total dead time while measuring energy (default settings).
- Geiger Mode: ~1 µs total dead time without energy measurements (default settings).
- Low power consumption: ~15 mA @ 5 V with default firmware at normal background.
- Built-in ticker (buzzer) for audible pulse count rate output.
- Additional broken-out power pins and I2C, SPI and UART headers for custom parts (e.g. display, µSD card, etc.).
- Simple OLED support out of the box (SSD1306 and SH110x).
- Built-in True Random Number Generator.
More information can also be found in the GitHub repository...
Ok nice, but how do I get it?
- DIY version: Download BOM and Gerber files or use Kitspace.
- Buy a complete board: Head over to Tindie.
- If you don't want to deal with all of that, feel free to contact me. Just send me an e-mail if you want and we'll figure something out.
The principle of operation for the detector looks like this:
NuclearPhoenix
hello, I am trying to create a cosmic ray detector by replacing the scintillator with a bc412. And I would like to know if it was possible to do as in his links
https://physicsopenlab.org/2019/12/21/muon-rate-monitoring/
https://physicsopenlab.org/2017/06/26/cosmic-ray-detection-with-gamma-spectrometer/
