Environmental Toolkit for an Ecological Area
LoRaWAN IoT system with the Arduino MKR WAN 1300, that help my community to monitor the air quality and water of our ecological area
I live on the shores of a big city, and there're still ecological reserves with natural lakes and migrating birds of all species. However, there is a big struggle between those who pollute and those who make efforts to clean up these places. Here, people periodically organize ourselves to collect trash, prune green areas, and clean the lakes of water lilies and PET bottles, we even reforest more green areas with plants and trees in order to recover its richness of vegetation. But this is not enough, so I developed a LoRaWAN System with the Arduino MKR WAN 1300, that helps us to monitor the air quality and water ot the ecological reserve of our community. INNOVATION: I have replaced the commercial Gateway with a hardware and software solution between the Arduino MKR WAN 1300 and Arduino NANO 33 IoT, so this project is original and cheaper than any other. Now, plants receive enough quality water, and adequate nutrients thanks to real-time sensor monitoring
Air pollution has a number of negative impacts on the environment, including damage to human health and natural ecosystems. The World Economic Forum has stated that air pollution is the ‘deadliest form of pollution’, while the World Health Organization claims that in 2016 over 92% of the world’s population reside in places where air pollution exceeds health and safety limits. Despite these unbelievable facts, some countries - like the UK, US, Australia and New Zealand - are seeing a decrease in the amount of air pollution. Although urban green spaces are not solely responsible, it’s undeniable that these areas have contributed to the overall decline.
How does it works?
  1. I collect data with sensors such as: Humidity, temperature, Carbon Monoxide, Carbon Dioxide, Volatile Organic Compound (TVOC), Smoke, water level, etc;
  2. I select and pre-program the time intervals when the system is monitored, and then it go into low consumption for energy saving;
  3. I'm using connection via RF through Carrier frequency LoRa (433/868/915 MHz)
  4. I read the captured data and activate alarms to be seen on an LCD screen or on a Laptop or a PC.
  5. Additionally, this system connects to the cloud of an IoT server through an Arduino NANO 33 IoT board.
Below I show you a demo of this project in action.
I want to thank all the people who have seen this project, those who like it, and the followers. Above all, I want to thank Hackaday for giving me the chance to make one of my dreams come true.
datasheet.zip
Hardware datasheet
x-zip-compressed - 926.44 kB - 07/26/2022 at 22:35
Download
stl_files.zip
STL files for the 3D printer
x-zip-compressed - 2.28 kB - 07/26/2022 at 22:31
Download
lorawan_and_iot_connection.zip
Chapter 11 code
x-zip-compressed - 5.71 kB - 07/26/2022 at 22:30
Download
modifying_receiver_code_for_multiple_sensors.zip
Chapter 8 code
x-zip-compressed - 1.85 kB - 07/26/2022 at 22:29
Download
adding_multiple_sensors_dsS18B20_dht22_and_mq135.zip
Chapter 7 code
x-zip-compressed - 1.79 kB - 07/26/2022 at 22:28
Download
View all 8 files
  • 2 × Arduino MKR WAN 1300
  • 1 × Arduino NANO 33 IoT
  • 1 × DS18B20 Waterproof temperature sensor
  • 1 × MQ-135 Air quiality sensor
  • 1 × DHT22 Humidity Sensor
View all 20 components
  • 13. Summary and Report Updated
    Guillermo Perez Guillen10/05/2022 at 02:27 0 comments
    Summary
    Below, I show you the project wrap-up and lessons learned of this cost-effective solution:
    Getting Started
    Here I describe the technical characteristics of the Arduino MKR WAN 1300 board, the installation of the board in the Arduino IDE application, as well as the firmware update. Finally we test the Blink.ino demo code to check if the boards are working fine.
    Communication Between Two MKR WAN 1300
    Here we start with the most basic, which is the point-to-point communication between two Arduino MKR boards. The transmitter sends data from the Waterproof DS18B20 sensor, and every time the receiver receives data, an LED on the board flashes and the serial port shows us the temperature of the sensor.
    LoRaWAN System Range Testing
    The next test is to check the link quality between the transmitter and receiver. So I make a comparison between different RF antennas, and finally the ones that showed the best performance are the manufacturer's dipole antennas. It is important to take care of this detail to avoid bad RF communication or corrupt messages.
    Assembling the Transmitter
    It’s time to assemble the transmitter module and add a LCD display to it. Here I have used the case and the Grove-LCD RGB Backlight, and the assembly steps can be found in this tutorial.
    Assembling the Receiver, and LoRaWAN´s Field Test with a DS18B20 Sensor
    I have also added the steps to assemble the receiver module with a 20x4 LCD display in this section as shown in the image below. Once we have assembled the LoRaWAN transmitter and receiver modules, its time to test them in the field. As a preliminary test, I did hardware and software verification before going out to the field.
    Adding Multiple Sensors: DS18B20, DHT22 and MQ-135
    We still continue with the point-to-point links between two Arduino MKR WAN boards, but this time we will do it with multiple sensors. I have added the DHT22 humidity sensors and the MQ-135 air quality sensor to the transmitter module. Here I have used a method to join the data using the comma character.
    Modifying Receiver Code for Multiple Sensors, and LoRaWAN´s Field Test with Multiple Sensors
    Here I show you how to modify the code of the receiving module to separate the data from multiple sensors and display them on the 20x4 LCD display. All by using code and the comma character to separate the data. Once we have assembled the LoRaWAN transmitter and receiver modules using multiple sensors, it´s time to test them in the field. Also, as a preliminary test, I did hardware and software verification before going out to the field.
    How to Connect LoRaWAN to an IoT Provider through the Arduino NANO 33 IoT
    In this section I show you a cheapt way to make an IoT connection with our Arduino MKR WAN 1300 boards. That is, through the Arduino NANO 33 IoT board. Here I show you the theoretical information and the reference that supports me.
    LoRaWAN and IoT Connection
    Here I show you the changes that must be made in hardware and software to achieve the connection to an IoT provider, and using a multiple sensors. I have modified the code of the receiver module to connect it to the Arduino NANO 33 IoT board taking into account the explanation that I showed you in the previous chapter. I also show you the code of the Arduino NANO 33 IoT board to connect to the ThingSpeak IoT provider, but you can do it with any other IoT provider. We have several options to monitor this data: a) on the display of the transmitter and receiver module, b) on the PC connecting to the ThinSpeak shared channel, and c) through the Android Application ThingView.
    Testing LoRaWAN and IoT Connection
    In the final chapter we can see the hardware and software verification tests, as well as the field tests. This was a good experience since I learned to improve the quality of the signal by placing the transmitter module in different trees until getting the best reception....
  • 12. Testing LoRaWAN and IoT Connection
    Guillermo Perez Guillen07/26/2022 at 21:19 0 comments
    CHANNEL CONFIGURATION IN THE THINGSPEAK PLATFORM
    Below you can see the new channel created on the ThingSpeak platform.
    Don't forget to take note of the Write API key.
    TESTING LORAWAN AND IOT CONNECTION
    In the video below I show you two tests carried out: a) in the first, the transmitter and the receiver are inside a room in order to verify that everything is working well; b) in the second, the transmitter is placed in the ecological reserve.
    IMAGE GALLERY
    On this occasion, I decided to solve the problem of having better signal reception. For this reason, I made a case with straps to attach the transmitting device to test on various trees and improve line of sight.
    This is the second tree in my attempt to improve signal quality.
    And finally my third attempt to improve the quality of the signal.
    What I can guarantee is that I am ecstatic with the beauty of nature.. Below is a screenshot with the ThingView app.
    Here is an example of temperature capture with the ThingSpeak platform
    Now a screenshot of the relative humidity.
    And finally a capture of carbon dioxide pollution.
    This area has low levels of contamination at the moment. You should know that ThingSpeak can also give you the area map as long as you give it the GPS coordinates.
  • 11. LoRaWAN and IoT Connection
    Guillermo Perez Guillen07/26/2022 at 21:16 0 comments
    LORAWAN TRANSMITTER
    Below I show you the schematic diagram of the transmitter with multiple sensors.
    Below I show you the code used to upload it to the Arduino MKR WAN 1300 transmitter board.
    LoRaSender_v5.ino
    // AUTHOR: GUILLERMO PEREZ GUILLEN
    #include <SPI.h> // LoRa->
    #include <LoRa.h>
    #include <OneWire.h> // DS18B20->
    #include <DallasTemperature.h>
    #include <Wire.h> // LCD->
    #include "rgb_lcd.h"
    rgb_lcd lcd;
    const int colorR = 173;
    const int colorG = 255;
    const int colorB = 47;
    #include "DHT.h" // DHT22 ->
    #define DHTPIN 3    // Pin where the sensor is connected
    #define DHTTYPE DHT22   // DHT22 sensor
    DHT dht(DHTPIN, DHTTYPE);
    // DS18B20-> Data wire is plugged into port 2 on the Arduino
    #define ONE_WIRE_BUS 2
    OneWire oneWire(ONE_WIRE_BUS);
    DallasTemperature sensors(&oneWire);
    #define anInput     A0 // MQ135-> analog feed from MQ135
    int counter = 0;
    void setup() {
      // set up the LCD's number of columns and rows:
      lcd.begin(16, 2);
      lcd.setRGB(colorR, colorG, colorB);
      lcd.print("ECOLOGY!");
      pinMode(anInput,INPUT); // MQ135
      lcd.setCursor(0, 1); // LCD
      lcd.print("LoRa Sender");
      if (!LoRa.begin(915E6)) {
      lcd.print("Starting LoRa failed!");
        while (1);
      sensors.begin();   //temperature sensor starts
      dht.begin();
    void loop() {
      int co2now[10]; //int array for co2 readings
      int co2raw = 0; //int for raw value of co2
      int co2ppm = 0; //int for calculated ppm
      int zzz = 0; //int for averaging
      for (int x = 0;x<10;x++) // MQ135-> samplpe co2 10x over 2 seconds
        co2now[x]=analogRead(A0);
        delay(200);
      for (int x = 0;x<10;x++) // add samples together
        zzz=zzz + co2now[x];
      co2raw = zzz/10; // divide samples by 10
      co2ppm = co2raw;
      int h = dht.readHumidity(); //We read the Humidity
      sensors.requestTemperatures();   //The command to read the temperature is sent
      int temp = sensors.getTempCByIndex(0); //The temperature is obtained in ยบC
      // send packet
      LoRa.beginPacket();
      LoRa.print(temp);
      LoRa.print(",");
      LoRa.print(h);
      LoRa.print(",");
      LoRa.print(co2ppm);
      LoRa.endPacket();
      lcd.clear();
      lcd.setCursor(0, 0); // LCD
      lcd.print("P=");
      lcd.setCursor(3, 0); // LCD
      lcd.print(counter);
      lcd.setCursor(8, 0); // LCD
      lcd.print("T=");
      lcd.setCursor(11, 0); // LCD
      lcd.print(temp);
      lcd.setCursor(14, 0); // LCD
      lcd.print("C");
      lcd.print("H=");
      lcd.setCursor(3, 1); // LCD
      lcd.print(h);
      lcd.setCursor(6, 1); // LCD
      lcd.print("%");
      lcd.setCursor(8, 1); // LCD
      lcd.print("CO2=");
      lcd.setCursor(13, 1); // LCD
      lcd.print(co2ppm);
      counter++;
      delay(13000);
    LORAWAN RECEIVER
    Below I show you the schematic diagram of the receiver. device
    Below I show you the code used to upload it to the Arduino MKR WAN 1300 receiver board.
    LoRaReceiver_v5.ino
    #include <SPI.h>
    #include <LoRa.h>
    #include <Arduino.h>   // SERCOM1
    #include "wiring_private.h" // SERCOM1
    // SERCOM1: Rx->D9 & Tx->D8
    Uart Serial3 (&sercom1, 9, 8, SERCOM_RX_PAD_1, UART_TX_PAD_0);
    void SERCOM1_Handler()
      Serial3.IrqHandler();
    #include <Wire.h> // Library for I2C communication
    #include <LiquidCrystal_I2C.h> // Library for LCD
    LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 20, 4); // Change to (0x27,16,2) for 16x2 LCD.
    char cadena[30]; //We create an array that will store the characters that we will write in the PC console. We assign a limit of characters, in this case 30
    byte posicion=0;  //Variable to change the position of the characters in the array
    int valor;  //Integer Variable
    void setup() {
      lcd.init();  // Initiate the LCD:
      lcd.backlight();
      pinMode(LED_BUILTIN, OUTPUT);
      Serial.begin(9600);
      Serial3.begin(9600); // SERCOM1
      // Assign pins 8 & 9 SERCOM1 functionality
      pinPeripheral(8, PIO_SERCOM);
      pinPeripheral(9, PIO_SERCOM);
      Serial.println("LoRa Receiver")
        Serial.println("Starting LoRa failed!");
        while (1);
    void loop() {
      int...
  • 10. How to Connect LoRaWAN to an IoT Provider through the Arduino NANO 33 IoT
    Guillermo Perez Guillen07/26/2022 at 20:53 0 comments
    In this part of my project, the challenge is to connect my LoRa network to an IoT provider, but one with cost-effective. Below is the schematic diagram.
    In this project I am going to connect my LoRa network with an IoT provider through the Arduino NANO 33 IoT board. Reason:
    Its an economic solution, since the Arduino NANO 33 IoT board has an average cost of $20.70 USD.
    On the other hand, the Gateway Lora RAK2245 board has a price of: $ 154.55 USD.
    Creating a New Serial Port to the Arduino MKR WAN 1300 Board
    When I checked out the ATSAMD21 chip (the processor used in the Arduino MKR WAN 1300 board), I was very happy to see that the chip has 6 "SERCOM"s, a.k.a SERial COMmunication modules. Each one of these modules can be used for I2C, SPI or Serial. That means you can have 3 UART's & 3 SPI's, or maybe 2 SPI's and 4 I2C's. Basically, you have a ton of options for adding more hardware support for the most common 3 chip-to-chip protocols.
    UART has only 2 pins, RX & TX. UARTs are a real pain to emulate or bitbang due to their very precise timing and their asynchronous RX lines are very difficult to do if you dont have hardware interrupt pins available. For that reason, being able to create new Serial's is awesome.
    Now, what I need is to create a new serial port on the Arduino MKR WAN 1300 board to connect it with the Arduino NANO 33 IoT board via serial port. In this way the Arduino NANO board will receive the data from the sensors and can send them to any IoT provider.
    How Serial is Created Now
    You can find the actual code that is used to create the "Serial" SERCOM in variant.cpp
    You will see the serial objects on:
    The actual definitions of those macros is available in variant.h
    OK so let's make a new Serial SERCOM already
    I want to make a Serial! Lets try creating a new SERCOM and testing it out. Let's make a Serial device on SERCOM #1, lets look at what pin muxing options we've got:
    PIN numberPIN arduinoSERCOM
    PA16D8 (MOSI)SERCOM1.0
    PA17D9 (SCK)SERCOM1.1
    PA19D10 (MISO)SERCOM1.3
    PA18D24 (USB)SERCOM1.2
    Rules:
    • Tx only works on PAD 0 and PAD 2
    • RX works in any PAD
    I have selected next pins:
    • D8 FOR TX
    • D9 FOR RX
    In the next chapter I will show you how to program this data into the Arduino MKR WAN 1300 receiver board.
  • 9. LoRaWAN´s Test with Multiple Sensors
    Guillermo Perez Guillen07/26/2022 at 20:41 0 comments
    LORAWAN´S SIMPLE TEST
    Before doing the field test, I decided to do a basic test indoor in order to correct any hardware or software issues. In the figure below I show you the devices assembled and ready for the basic test.
    In the video below I show you the test inside my house and the three sensors work without problems and the receiver device receives the data.
    LORAWAN´S FIELD TEST
    This is the place I chose to test my LoRa devices.
    In the image below I show you the transmitter and the receiver ready to work.
    Finally, in the video below I show you the tests carried out with this system.
    Notes:
    • Today there was some wind so the air is very clean, some cold fronts are even arriving from the north, so the weather is getting colder and rains are beginning to fall.
    • The tests were carried out successfully. In the following chapters I will show you how to link the data to an IoT service provider cheaply, and without spending a lot of money on hardware.
  • 8. Modifying Receiver Code for Multiple Sensors
    Guillermo Perez Guillen07/26/2022 at 20:19 0 comments
    RECEIVER SCHEMATIC DIAGRAM
    In the figure below I show you the electrical diagram of the receiver device
    As you can see, there are no hardware changes, however the code must have changes since we will receive data from three sensors and these must be separated and shown on the display. All this through code. In the figure below I show you the transmitter and the receiver.
    RECEIVER CODE
    There were no hardware changes on the receiving device. However, in the software there were changes, and these are shown in the code below:
    LoRaReceiver_v3.ino
    #include <SPI.h>
    #include <LoRa.h>
    void setup() {
      lcd.backlight();
      Serial.begin(9600);
      Serial.println("LoRa Receiver");
        while (1);
    void loop() {
      // try to parse packet
      int packetSize = LoRa.parsePacket();
      if (packetSize) {
        memset(cadena, 0,sizeof(cadena));//memset deletes the contents of the array "cadena" from position 0 to the end sizeof
        // received a packet
        Serial.print("Received packet... ");
        // read packet
        while (LoRa.available()) {
          char dedos= (char)LoRa.read();
          Serial.print(dedos);
          cadena[posicion]=dedos;//Read a character from the string "cadena" from "posicion", then read the next character with "posicion++"
          posicion++;
        posicion=0;
        int signal_rx = LoRa.packetRssi();
        // print RSSI of packet
        Serial.print(" with RSSI ");
        Serial.println(signal_rx);
        int parte1 = getValue(cadena,',',0).toInt();
        int parte2 = getValue(cadena,',',1).toInt();
        int parte3 = getValue(cadena,',',2).toInt();
        Serial.println(parte1);
        delay(100);
        Serial.println(parte2);
        delay(100);
        Serial.println(parte3);
        delay(100);
        // LCD data
        lcd.clear();
        lcd.print("RSSI =");
        lcd.setCursor(7, 0);
        lcd.print(signal_rx);
        lcd.print("dBm");
        lcd.print("Temp =");
        lcd.print(parte1);
        lcd.setCursor(11, 1);
        lcd.print("C");
        lcd.setCursor(0, 2);
        lcd.print("Hum =");
        lcd.setCursor(8, 2);
        lcd.print(parte2);
        lcd.setCursor(11, 2);
        lcd.print("%");
        lcd.setCursor(0, 3);
        lcd.print("CO2 =");
        lcd.setCursor(8, 3);
        lcd.print(parte3);
        lcd.setCursor(11, 3);
        lcd.print("PPM");
        digitalWrite(LED_BUILTIN, HIGH);
        delay(2000);
        digitalWrite(LED_BUILTIN, LOW);
    String getValue(String data, char separator, int index)
      int found = 0;
      int strIndex[] = {0, -1};
      int maxIndex = data.length()-1;
      for(int i=0; i<=maxIndex && found<=index; i++){
        if(data.charAt(i)==separator || i==maxIndex){
            found++;
            strIndex[0] = strIndex[1]+1;
            strIndex[1] = (i == maxIndex) ? i+1 : i;
      return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
    • First you have to receive the data in a character string.
    • How did I separate the data from the three sensors? There are several methods to do it, I did it using the comma (,).
    In the next post we will see a demonstration of how this project works.
  • 7. Adding Multiple Sensors: DS18B20, DHT22 and MQ-135
    Guillermo Perez Guillen07/26/2022 at 19:52 0 comments
    TRANSMITTER SCHEMATIC DIAGRAM
    In the figure below I show you the electrical diagram of the transmitter after adding the DHT22 humidity sensor and the MQ-135 air quality sensor.
    ADDING THE DHT22 SENSOR
    In the figure below I show you the DHT22 sensor.
    In this sensor I only obtain humidity readings with value ranges between 0 to 100%. I omit the temperature readings as the DS18B20 temperature sensor has a better measurement range (-55°C to +125°C). You can get the library used to program this sensor here: DHT-sensor-library
    ADDING THE MQ-135 SENSOR
    In the figure below I show you the MQ-135 sensor.
    Sensitive material of gas sensor is SnO2, which with lower conductivity in clean air. When target pollution gas exists, the sensor’s conductivity gets higher along with the gas concentration rising. Users can convert the change of conductivity to correspond output signal of gas concentration through a simple circuit.
    I use this sensor to detect and measure carbon dioxide (CO2) particles in parts per million (ppm). In the following links you can find the reference information and the code to obtain it:
    https://github.com/5cottyD/Projects/blob/master/co2ppm_meter.ino
    Since these sensors have small differences, I made a small adjustment to this code to calibrate the CO2 level to 0. This is done in the following line of code:
    #define co2Zero 55 //calibrated CO2 0 level
    After mounting the three sensors, the device would look like the image below.
    TRANSMITTER CODE
    After adding the DHT22 and MQ-135 sensors, the transmitter code would be as shown below:
    LoRaSender_v3.ino
    #include <LoRa.h>
    rgb_lcd lcd;
    #define co2Zero     0 // calibrated CO2 0 level
    int counter = 0;
    void setup() {
      lcd.begin(16, 2);
        while (1);
      sensors.begin();
      dht.begin();
    void loop() {
        delay(200);
      co2ppm = co2raw - co2Zero; // get calculated ppm
      if (co2ppm <= 0) {
        co2ppm = 1;
      else {
        co2ppm = co2ppm;
      // send packet
      LoRa.beginPacket();
      LoRa.print(temp);
      LoRa.print(",");
      LoRa.print(h);
      LoRa.print(",");
      LoRa.print(co2ppm);
      LoRa.endPacket();
      // LCD display data
      lcd.clear();
      lcd.print("P=");
      lcd.print(counter);
      lcd.print("T=");
      lcd.print(temp);
      lcd.print("C");
      lcd.print("H=");
     lcd.print(h);...
  • 6. LoRaWAN´s Test with a DS18B20 Sensor
    Guillermo Perez Guillen07/26/2022 at 19:39 0 comments
    In the video below I show you the test inside my house and the system worked without problems.
    FIELD TEST
    This is the place I chose to work.
    In the image below I show you the transmitter already working.
    In the image below I show you the receiver receiving the data more than 100 meters away from the transmitter.
    Finally, in the video below I show you the tests carried out with this system. This design will serve as an experience to make the system with three sensors and that will be shown in the later chapters.
  • 5. Assembling the Receiver
    Guillermo Perez Guillen07/26/2022 at 19:35 0 comments
    In the figure below I show you the pieces that I print on the 3D printer. These pieces are used to fix the Arduino MKR WAN 1300 board and the LCD display.
    In the image below you can see the assembly of the Arduino MKR WAN 1300 board.
    And now in the image below you can see the assembly of the 20x4 LCD display.
    After fixing the Arduino MKR WAN 1300 board, the 20x4 display, the antenna and the battery; the receiving device looks like the one shown in the figure below.
    As a power supply I used Anker PowerCore II 6700. In addition to providing more accurate voltages, this device gave me better results since it has a power button, a voltage regulator and detects when a device is connected or not.
    I also recommend using a heavy-duty USB to make a good connection
    SCHEMATIC DIAGRAM
    After adding the 16x2 display, the wiring diagram of the receiver is as shown below.
    CODE
    After several attempts to find a library that works well with the Arduino MKR WAN 1300 board, I finally found this one that worked very well for me: LiquidCrystal_I2C
    After making these changes, the receiver code is shown below:
    LoRaReceiver_v2.ino
    #include <SPI.h>
    #include <LoRa.h>
    void setup() {
      lcd.backlight();
      Serial.begin(9600);
        while (1);
    void loop() {
      if (packetSize) {
        // read packet
          posicion++;
        valor=atoi(cadena);//Convert the string to integers
        Serial.println();
        Serial.print(" temp=");
        Serial.print(valor);
        posicion=0;
        int dedal = LoRa.packetRssi();
        Serial.print(" with RSSI: ");
        Serial.println(dedal);
        lcd.clear();
        lcd.setCursor(0, 0); // Set the cursor on the first column and first row.
        lcd.print("Temp:");
        lcd.setCursor(6, 0);
        lcd.print(valor);
        lcd.setCursor(0, 2); // Set the cursor on the first column and second row.
        lcd.print("RSSI:");
        lcd.setCursor(5, 2); //Set the cursor on the fifth column and the second row (counting starts at 0!).
        lcd.print(dedal);
        delay(2000);
  • 4. Assembling the Transmitter
    Guillermo Perez Guillen07/26/2022 at 19:30 0 comments
    In the figure below I show the lid of the box to make the marks for the drill holes.
    Now below we see how this piece was after drilling.
    Once the holes are large enough, then it's time to attach the connectors.
    In the image below you can see how to assemble the 16x2 LCD display that comes in the kit.
    Then we fix the Arduino MKR WAN 1300 board, the 16x2 LCD display, the DS18B20 sensor and the antenna.
    The transmitter would look like the figure below.
    As a power supply I used a generic 5V Portable Charger Power Bank 16800 mAh. In addition to providing more accurate voltages, this device gave me better results since it has a power button, a voltage regulator and detects when a device is connected or not.
    SCHEMATIC DIAGRAM
    CODE
    All the information needed to install the library you can get in this link: Grove-LCD RGB Backlight Library from Github
    After making these changes, the transmitter code is shown below:
    LoRaSender_v2.ino
    #include <SPI.h>
    #include <LoRa.h>
    #include <OneWire.h> // DS1B20->
    rgb_lcd lcd;
    // Data wire is plugged into port 2 on the Arduino
    // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    // Pass our oneWire reference to Dallas Temperature.
    int counter = 0;
    void setup() {
      lcd.begin(16, 2);
      // Print a message to the LCD.
        while (1);
      sensors.begin();
    void loop() {
      int temp= sensors.getTempCByIndex(0); //The temperature is obtained in ยบC
      lcd.clear();
      lcd.print("Packet:");
      lcd.print(counter);
      lcd.print("Temp:");
      lcd.print(temp);
      // send packet
      LoRa.beginPacket();
      LoRa.print(temp);
      LoRa.endPacket();
      counter++;
      delay(4000);
View all 13 project logs
View all 3 instructions
Rich text editor
Guillermo Perez Guillen wrote 10/23/2022 at 04:49 point
My  project is an innovative and hardware tangible solution, since I'm using open source to help solve sustainability. climate resiliency, and circularity of one of our planet's most pressing issues.
Guillermo Perez Guillen wrote 08/23/2022 at 19:23 point
My project is innovative because I've captured the environmental data with the Arduino MKR WAN 1300 board and sended it to an IoT provider through the Arduino NANO 33 IoT board... In other words, I've replaced the Gateway with this Hardware and Software solution, which is original and cheaper
Guillermo Perez Guillen wrote 07/26/2022 at 22:41 point
My project fits the "Climate Resilient Communities" challenge because help my community to monitor the air quality and water of our ecological area... Today, plants receive enough quality water, and adequate nutrients thanks to real-time sensor monitoring.
