Serial OutPut of the project
08/28/2022 at 20:06 • 0 commentsThis Appears messy because of wrong font. Must be a fixed lenght.
Aug 28 2022 16:57:561
Station_07 Loader of 18 Modules:
Primary I2C Scan
Got = 23 38 39 70
Primary I2C Scan Done
TCA I2C Scan
Port 0 Got = 00 20 48
Port 1 Got = 5A
Port 2 Got = 10 29 68 76
Port 3 Got = 23 38 39
Port 4 Got =
Port 5 Got =
Port 6 Got = 00 40 5A 60 76
Port 7 Got = 29
TCA I2C Scan Done
00: SCN S[ 23] D[158] OK
01: RAM S[ 181] D[ 1] OK
02: SI7 S[ 182] D[ 53] OK
03: BME S[ 235] D[123] OK
04: ADS S[ 358] D[ 0] OK
05: MCP S[ 358] D[ 10] OK
06: CCS S[ 368] D[204] OK
07: MIC S[ 572] D[ 0] OK
08: SI1 S[ 572] D[ 52] OK
E (626) gpio: gpio_set_level(226): GPIO output gpio_num error
E (636) gpio: gpio_set_level(226): GPIO output gpio_num error
09: VL5 S[ 624] D[ 72] OK
10: TCS S[ 696] D[620] OK
11: MLX S[1316] D[ 1] OK
12: BH1 S[1317] D[ 20] OK
13: MPU S[1337] D[639] OK
14: VE0 S[1976] D[ 4] OK
15: BMP S[1980] D[108] OK
16: VL0 S[2088] D[2001] OK
17: WS2 S[4089] D[ 1] OK
Load Done
RAM: Total 0528 regs of 0248 bytes each.
Starting Timed TasksNOC: 000017 TOC: 000046 TIM: 01:00:49
BME: T[29.43] P[1005.826] H[45.10]
BMP: T[30.22] P[1005.495]
SI7: T[29.46] H[43.67]
CCS: eCO2[ 428] VOL[ 4]
ADS: 1[ 131] 2[ 1348] 3[ 71] 4[17477](3.29V)
MIC: Carb Mono[3.19] Diox Nitr[0.15] Amonio[0.18] Propano[74.27]
MIC: Butano[70.54] Metano[194.24] Hidrog[0.45] Etanol[1.07]
MCP: IN(A)[###-##-#] OUT(B)[--------] Int[--------](0)(0)
BH1: Lux[41.67]
SI1: VIS[ 261] IR[ 261] UV[ 0] PROX[ 255]
TCS1: R[ 3467] G[ 3443] B[ 3588] C[ 7978] IR[ 1260]
TCS2: C_R[ 2207] C_G[ 2183] C_B[ 2328] R_C[ 6718] LUX[48.95]
TCS3: CR[0.16] AGX[ 60] ATMS[ 153] CPL[29.61]
TCS4: MAX_LUX[737.69] K[5409.89]
VE5: UVA[0.00] UVB[0.00] UVI[0.00]
VE0: UVI[0]
VL5: Distance [1739] mm
MLX: Amb[26.93] Obj[25.91]
MPU: Ax[0.00] Ay[0.00] Az[1.01] - Gx[0.01] Gy[-0.05] Gz[0.02]
MPU: Mx[30.29] My[110.58] Mz[229.36] SumG[1.01] T[36.58'C]
MPU: ANx[0.01] ANy[0.05] ANz[90.00] Pitch[-0.01] Roll[0.03] M[0] -
This is the Tasks That Run Periodicaly
08/28/2022 at 20:03 • 0 commentsTimers:
Number Time in ms Description 0 500 MCP23017 Port B1 Led Blink 1 2500 Get And Store All Sensors Data 2 1234 Process Values. NOT USED 3 5000 List All Sensors Data in Terminal 4 5000 Send All Sensors Data to MQTT Server -
Commands That I Created
08/28/2022 at 20:02 • 0 commentsCommands:
Command Description 0 Force Listing of stored Values 1 Force Gather Values from Sensors e Force Boot Modules s Execute Create Timers Function g Start / Stop Timers (g <Timer #> on/off ) r Force Send Data to Influx Database (Does Not Word) i Force Send Sensors Data to MQTT server (Nodered in my case) o Connect to configured WIFI network w Sync with NTP server and Show Clock h Toggle MCP23017 Pin (h <pin # in port B> [optional 1/0, default is 1] j Set Si1145 Led Current (j <0..15>) Its from 1mA to 300mA p Set WS2812 Color (p (Red) (Green) (Blue) [Optional Led #, default 0] Colors in 8bit k Set WS2812 Intensity (k <intensity 8bits>) l Toggle MICS6814 Calibration Source. Preset/ADC mean since boot in 10 samples. x Set MCP23017 pin. (x <1/0> [Pin# in port B] Default is Pin B1 c Toggle all MCP23017 Port B pins on/off. v Set MPC23017 Port B Pin input or output. (v <1/0> [Port B pin. Default 1]) b Boot Specific Module Number. (b <module #>) n Change first 3 WS2812 leds to Red, Green, Blue. d Read VEML6070 sensor data. CRASHES ESP32. DONT KNOW WHY! z Erases 23LC1024 RAM. CRASHES ESP32. DONT KNOW WHY! All other commands are ignored with an error message.
TCA9548A Channels Used
08/28/2022 at 20:02 • 0 commentsTCA9548 channels used:
Channel What is Connected 0 MCP23017, ADS1115 1 CCS811 2 MPU9250, BMP280, TCS34725, VEML6075 3 VEML6070 4 5 6 SI7021, SI1145, MLX90614, BME280 7 VL53L1 -
MCP23017 pins USED
08/28/2022 at 20:01 • 0 commentsMCP23017 Pins Used:
PIN What is Connected A0 TCS34725 Interrupt A1 ADS1115 Alarm A2 CCS811 Interrupt A3 VL53L1 GPIO1 A4 SI1145 Interrupt A5 VEML6070 Ack A6 User Button Active Low B0 TCS34725 LED B1 User Red LED -
Modules Used in This Project
08/28/2022 at 20:00 • 0 commentsModules Used In This Project:
HardWare What I get BME280 Temperature, Pressure, Humidty ADS1115 4 channel 15 bit ADC. Channel 4 connected to 3.3V BH1750 Light Intensity BMP280 Temperature, Pressure CCS811 Equivalent CO2, Amount of Volatile Gases MCP23017 16 pin Input/Output Expander VL53L1 Laser Distance Sensor up to 4 meters VEML6070 UV intensity 23LC1024 128kB External SPI RAM. Store Values. Pointless for now WS2812B 3 modules full RGB configurable LEDS MICS6814 3 Gases Sensor. Uses 3 channels of ADS1115. Measures 8 Gases MPU9250 9 Axis Montion Sensor. Accelerometer, Gyroscope, Magnetometer (3 axis each). Also chip temperature SI1145 Light and proximity sensor. Infrared, UltraViolet, Visible, Proximity (With white LED) VEML6075 Ultraviolet Sensor. UVa, UVb, UV intensity SI7021 Temperature, Humidity TCS34725 Light Sensor. Red, Green, Blue, Clear, IR, (LUX, K, CPL calculated) TCA9548A I2C Switch and level translator for all I2C devices MLX90614 Infrared Temperature Sensor. Object Temperature, Ambient Temperature SoftWare
What I Get WiFi WiFi INFLUX Direct Connection to Database. DOESNT WORK MQTT Send Data to Nodered in raspberry pi 3B+ OTA Auto check for Update in raspberry pi server, webpage server for update I2C Scanner Scans TCA9548 for devices and lists in Serial Port
