Overview
- homebrew CPU written in Verilog implemented on an FPGA
- 32-bit word-oriented stack machine architecture
- running at 77 MHz on an Arty-A7 board with four clocks per instruction
- has its own instruction set architecture, compatible with nothing
- additional IO controllers on FPGA: UART (serial console), SD-Card, VGA
- Pascal compiler written from zero
- CPU and compiler were designed together
- minimal operating system
- editor, compiler, assembler run natively
- so you can develop programs directly on the machine
- small: CPU has ~500 lines of Verilog, compiler ~9000 LoC
- compiler written in Pascal and can compile itself
- cross-compiler/-assembler can be compiled with FPC
- compiler does its own Pascal dialect with some restrictions and some extensions
- emulator available here
The name comes from a certain fictional monster with three heads. The prefix tri- is greek for three, and the Tridora-CPU has three stacks instead of just one like almost all other CPUs. It also has a strange mixture of features from three different eras of computing:
- a simple instruction set without integer multiply/divide like an 8-bit CPU
- speed is like a fast 16-bit CPU, also 16-bit instruction words
- 32-bit word size from the 32-bit era
It might remind you of the UCSD-P-System and early Turbo-Pascal versions.
Other inspirations were, among others, in no particular order:
- the Novix 4016 CPU (a stack machine CPU designed for Forth, mainly by Charles Moore)
- the J1 CPU by James Bowman (which is not entirely unlike the Novix 4016)
- the Lilith computer by Niklaus Wirth and his team (a stack CPU designed for Modula-2)
- the PERQ workstation (also a stack CPU designed for Pascal)
- the Magic-1 by Bill Buzbee
- the OPC by revaldinho
Source Repository
Sources are published on Gitlab.
Supported Boards
- Arty A7-35T (with two PMODs for microSD cards and VGA output)
- Nexys A7 (planned)
Demo Videos
See the README on Gitlab or the YouTube channel.
Pascal Language
- Wirth Pascal
- arbitrary length strings (2GB)
- safe strings (runtime information about max/current size)
- tiny sets (machine word sized), that means no SET OF CHAR
- array literals with IN-operator, which can replace most uses of SET OF CHAR
- nested procedures
- procedure/function parameters as specified in Wirth Pascal
- 32 bit software floating point with low precision (5-6 digits)
- break and exit statements, no continue yet
- static variable initialization for global variables
- non-standard file i/o (because the standard sucks, obl. XKCD reference)
Standard Library
- everything from Wirth Pascal
- some things from TP3.0
- some graphics functionality (to be expanded in the future)
Operating System
- not a real operating system, more of a program loader
- some assembly routines for I/O resident in memory
- one program image loaded at a time at a fixed address
- most parts of the operating system are contained in the program image
- file system is very primitive: only contiguous blocks, no subdirectories
- simple shell reminiscent of TP3.0, edit, compile, run programs
Building the Compiler
- you need to have FPC and Python3 installed
- on Linux, you need make installed
- in the pcomp directory, run make (or make.bat on Windows)
- on Linux, you can also run make nativeprogs and make examples
Getting the ROM image
- there are two formats for the ROM image, one for the emulator (rommon.prog) and one for building the FPGA bitstream (rom.mem)
- to get the rommon.prog file, either copy it from the tridoraemu package file or build it
- for rom.mem and rommon.prog, find both files in the lib directory after running make nativeprogs (or make.bat) in the pcomp directory (see above)
Building the FPGA bitstream
- install Vivado (known to work with 2024.2)
- install the package for your board in Vivado (Tools -> Vivado Store -> Boards)
- copy the ROM image (rom.mem) into the tridoracpu directory (see above)
- start Vivado and open the project file tridoracpu.xpr in the tridoracpu directory
- run synthesis, implementation and bitstream generation (Flow -> Generate Bitstream)
- program your device (Flow...
slederer
Jara
Foxchild
Matt Stock
land-boards.com
Very impressive project, lot to learn from here! Was the CPU design done to facilitate easy execution of the P-code? However it is not a P-code CPU to allow efficient running of other programming languages or environments?
