• Irrigation again
    MaBe4202/10/2025 at 19:58 0 comments
    Going back to my irrigation control: https://hackaday.io/project/198352-experiences-with-esphome/log/233542-replacing-ospi-opensprinkler
    This is controlled by automations on HA which switch on/off the valves by relays using the ESPhome switches. But what will happen if my HA crashed while the water is on? Perhaps while I'm on holiday?
    to be continued
  • Some interesting things
    MaBe4202/10/2025 at 19:52 0 comments
    Status LED:
    Most of the ESP boards have a status LED. There exists a primitive to directly access it:
    light:
      - platform: status_led
        pin:
          number: GPIO2
          inverted: true
        restore_mode: ALWAYS_OFF
     This allows easily using the status LED as an indicator when programming automations in ESPhome.
    HA Button:
    A switch from ESPhome shows as a switch in HA and can be toggled there. However, sometimes you would like to have the equivalent of a tactile button in HA, for example to press a button in the HA companion app on a smartphone to open a garage door.
    output:
      - platform: gpio
        pin: GPIO0
    switch:
      - platform: output
        name: "Generic yellow switch"
        output: gpio_d3
    button:
      - platform: template
        on_press:
          then:
            - switch.turn_on: yellow_switch
            - delay: 1s
            - switch.turn_off: yellow_switch
     So pressing on this button in HA turns the yellow switch on for 1 second. Similar to pressing a button for 1 second.
  • Measuring temperature
    MaBe4202/10/2025 at 19:36 0 comments
    There exist numerous possibilities to measure temperature. On is the Dallas DS1820 sensor. It uses a single GPIO. It is necessary to define that this GPIO is used for a 1-wire bus. And then, the 1-wire bus is referenced by its id in the sensor itself:
    one_wire:
      - platform: gpio
        pin: GPIO12
    sensor:
      - platform: dallas_temp
        update_interval: 5s
        one_wire_id: wire1
    and it shows in HA:
  • A rotary encoder
    MaBe4202/10/2025 at 19:27 0 comments
    Considering https://community.home-assistant.io/t/homeassistant-number-how-does-it-work/842982/10 let's make the device independent from HA, i.e. add the possibility to dim the LED. The most intuitive way is perhaps a rotary button.
    This can be done easily and just requires two GPIOs:
    The code needs to be added to the sensor section.
    sensor:
      - platform: rotary_encoder
        pin_a: GPIO4 #D2
        pin_b: GPIO5 #D1
        min_value: 0
        max_value: 100
        on_clockwise:
          - light.dim_relative:
              relative_brightness: 5%
              transition_length: 500ms
        on_anticlockwise:
              relative_brightness: -5%
    The code is pretty self-explanatory.
    This also turns up in the sensors field in HA. But to dim it from HA, the red LED needs to be clicked.
  • Basics: Input Button or Switch
    MaBe4202/10/2025 at 07:12 0 comments
    Of course, there need also to be inputs. For example a switch or a button. I added a button to toggle the red LED. To interact between different components, the components need to have an id. So, an id needs to be added to the red LED:
    light:
      - platform: monochromatic
        output: gpio_d7
        default_transition_length: 1.5s
    As can be seen, the transition length can be fractions of seconds.
    To add the button or switch as an input, a binary_sensor needs to be added:
    binary_sensor:
      - platform: gpio
        pin:
          number: GPIO14 #D5
          inverted: true
          mode:
            input: true
            pullup: true
        filters:
          - delayed_on: 50ms               # debouncing
        on_click:
          max_length: 1000ms
          then:
            - light.toggle: red_led
    The button connects the gpio pin to ground. Therefore, a pull-up resistor to Vcc is needed. This can be done using an internal pull-up. As the gpio goes to 0 when the button is pressed, inverted: true is used which provides a logic 1 when the button is pressed. max_length is used to define what is considered a click.
    Now, the red LED can be toggled using the button and in addition its intensity can be changed from HA.
    In HA, there is now an additional Sensors field which shows the state of the button:
  • PWM output (for lights)
    MaBe4202/09/2025 at 08:19 0 comments
    Something you quite often want to have with lights is that you can dim them.
    Ok. But don't look for something like Light-PWM. What you want to change is not the abstract light component but the underlying output. And here we find several components:
    - ESP32 LEDC
    - ESP8266 Software PWM
    - LibreTiny PWM
    - Slow PWM
    As I'm working with the Wemos D1 mini which is an ESP8266 board, I choose ESP8266 Software PWM.
    The first thing I have to change is a single line in my code to make the red LED dimmable:
      - platform: esp8266_pwm
    instead of gpio.
    But a dimmable light is not a binary one any more. Therefore, this needs to be changed, too and becomes:
    instead of  binary.
    The appearance in HA is the same but when clicking on the red LED, a widget pops up where the brightness can be set to anything between 0 and 100%.
    And looking at the log, the following can be seen:
    [09:06:28][D][light:036]: 'red LED' Setting:
    [09:06:28][D][light:047]:   State: ON
    [09:06:28][D][light:051]:   Brightness: 53%
    [09:06:28][D][light:085]:   Transition length: 1.0s
    [09:06:31][D][light:036]: 'red LED' Setting:
    [09:06:31][D][light:047]:   State: OFF
    [09:06:31][D][light:085]:   Transition length: 1.0s
    [09:06:32][D][light:036]: 'red LED' Setting:
    [09:06:32][D][light:047]:   State: ON
    [09:06:32][D][light:085]:   Transition length: 1.0s
    There is something called "Transition length" which defines how long it takes to fade-in/fade-out. And with the button below the slider, the light can be switched on/off. But "on" is then the previously set intensity. In the above case it means it will return again to 53% intensity - not to 100%.
    Looking into the documentation, (https://esphome.io/components/light/#config-light) there are plenty of possibilities for setting parameters like default_transition_length but not all can be used with the monochromatic light.
    For example:
    light:
        output: gpio_d7
        default_transition_length: 3s
  • Basics: Binary Output
    MaBe4202/08/2025 at 20:31 0 comments
    This can be something like a LED or a relay that can be switched by switching a digital output.
    There are several possibilities to do this which end up in slightly different appearances in HA:
    Output - GPIO
    output:
      - platform: gpio
        pin: GPIO13
     But this does not show up in HA.
    If you want it to be shown in HA, you can for example use
    Light - Binary Light
    You need to add a few lines to the above. The result is:
    output:
      - platform: gpio
        pin: GPIO13
    light:
      - platform: binary
        output: gpio_d7
     As you see, in the light you refer to the output's id.
    The result looks like this in HA:
    You could also define a
    Switch - GPIO Switch
    The code is:
    switch:
      - platform: gpio
        pin: GPIO12
     Result:
    or you can use
    Switch - Generic Output Switch
    Replace the above code with:
    output:
      - platform: gpio
        pin: GPIO12
    switch:
      - platform: output
        output: gpio_d6
     Beware, you can have only a single output section. So together with the red LED it looks like:
    output:
      - platform: gpio
        pin: GPIO12
      - platform: gpio
        pin: GPIO13
    light:
      - platform: binary
        output: gpio_d7
    switch:
      - platform: output
        output: gpio_d6
     And the result in HA:
    And there are other components which in the end only toggle a GPIO between 0 and 1.
  • Let's go back to the start
    MaBe4202/08/2025 at 19:57 0 comments
    The more I used ESPhome, the more confused I got. So I decided to start over again and provide some examples for things I had understood or which at least I thought I had understood.
    I took a Wemos D1 mini board and generated a new yaml to which I just added a wifi sensor, as it's always good to know the wifi strength when testing.
    esphome:
    esp8266:
      board: d1_mini
    # Enable logging
    logger:
    # Enable Home Assistant API
    api:
      password: ""
    ota:
      - platform: esphome
        password: ""
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      # Enable fallback hotspot (captive portal) in case wifi connection fails
      ap:
        ssid: "Eh-Test Fallback Hotspot"
        password: "password"
    captive_portal:
    sensor:
      - platform: wifi_signal
        name: "WiFi Signal Sensor"
        update_interval: 10s
     As for the wifi credentials, it's necessary to create a secrets.yaml in the same directory as the above yaml file and provide the credentials there:
    wifi_ssid: "your_ssid"
    wifi_password: "your_secret_password"
    In home assistant (HA) this can then be seen as
    (Settings -> Devices & Services -> ESPHome -> Devices)
  • Soil moisture sensor
    MaBe4201/01/2025 at 20:46 0 comments
    After my first positive experiences with ESPhome, I had a closer look into the documentation and found out that deepsleep is also implemented.
    I had some soil moisture sensors connected to an ESP8266 to detect if irrigation is necessary. The device is powered by an 18650 cell. It wakes up every 30 mins, switches on the power to the sensor, reads the sensor, sends the measured value via MQTT and goes back to deep sleep. It was not too difficult to implement it in ESPhome:
    esphome:
      on_boot:
        - switch.turn_on: Sensor_Vcc
        - delay: 1s
    # Terrassensensor
    esp8266:
      board: huzzah
    # Enable logging
    logger:
    api:
      password: ""
    ota:
      - platform: esphome
        password: ""
    wifi:
      ap:
        ssid: "Eh-Bodenfeuchte3"
        password: "EfGXNoIANTV5"
    captive_portal:
    deep_sleep:
      run_duration: 12s
      sleep_duration: 30min
    switch:
      - platform: gpio
        pin: GPIO14 #D5
    binary_sensor:
      - platform: homeassistant
        entity_id: input_boolean.no_deep_sleep
    mqtt:
      broker: 192.168.2.204
      discovery: false
      discover_ip: false
    sensor:
      - platform: adc
        pin: A0
        samples: 10
        update_interval: 8s
        filters:
          - multiply: 1000
        on_value:
          - mqtt.publish:
              topic: "ESP/H2O/Sensor3"
              payload: !lambda |-
                return to_string(int(1*id(terrassenfeuchte).state));
              retain: true
          - if:
              condition:
                binary_sensor.is_on: no_deep_sleep
              then:
                - deep_sleep.prevent: ds
    #            - logger.log: "No sleep!"
              else:
                - deep_sleep.allow: ds
    #            - logger.log: "Let's snooze!"
    Each time it wakes up, the **on_boot**-section is carried out. There I switch on the voltage for the sensor. As it does not draw much current, I power it directly from a GPIO.
    The implementation in ESPhome allowed me even to add a switch to HA to prevent the device from going to deep sleep again after the next time it wakes up again. This allows easily flashing OTA without opening the waterproof housing. A feature which I did not have before.
    I put the device into the soil in April and remove it at the end of October. I charge the cell at the beginning of August to be sure that it lasts. That's good enough for me.
  • LED lighting
    MaBe4212/27/2024 at 21:57 0 comments
    An incomplete yaml file to control two LED strips for illumination using two buttons. The buttons allow only to switch between on and off. From HomeAssistant dimming is possible.
    The device uses a Wemos D1 mini.
    The LEDs are controlled using PWM output and are connected using a logic-level n-MOSFET (IRLU 024N). The maximum level is set to 95% to prevent the LEDs from to early degradation (at least I hope so).
    The buttons used to toggle the lights include a very simple debouncing (filter).
    esp8266:
      board: d1_mini
    # LEDs: 13, 14 (D7, D5)
    # Taster: 5, 4 (D2, D1)
    output:
        pin: GPIO14 #D5
        frequency: 440 Hz
        min_power: 0
        max_power: 0.95
        min_power: 0
        max_power: 0.95
        frequency: 440 Hz
        pin: GPIO13 #D7
    light:
        output: Fenster_pwm
        output: Bett_pwm
    #  - platform: status_led
    #    name: "Status"
    #    pin:
    #      number: GPIO2
    #      inverted: true
    #    restore_mode: ALWAYS_OFF
    binary_sensor:
      - platform: gpio
        pin:
          number: GPIO4 #D1
          inverted: true
          mode:
            input: true
            pullup: true
        filters:
          - delayed_on: 50ms
        on_click:
          max_length: 500ms
          then:
            - light.toggle: Licht_Fenster
      - platform: gpio
        pin:
          number: GPIO5 #D2
          inverted: true
          mode:
            input: true
            pullup: true
        filters:
          - delayed_on: 50ms
        on_click:
          max_length: 500ms
          then:
            - light.toggle: Licht_Bett
    sensor:
        update_interval: 300s
