µLind (micro-lind)
- a 6x09 based retro computer
Public Chat
This project started after my then 14 year old son found 3 intresting and for both of us unknown microprocessor: The 6809! I had since long been curious on how to build a microcomputer and was emediately intriged by the design of this exotic little chip. Being quite familiar with the 6502/6510 (both me and my son are avid Commodore users. GO 64!) I found the "advanced" features of the 6809 interesting. We started sketching on different ideas of what we would like a computer to be able to do. And my son who is an amazing datasheet reader found several features that made this processor intsesting to build a system on. For more in depth posts and info you are welcome to the project site: https://microlind.io
Disclaimer:
When I started this journey down the 6809 path I had never heard of the TRS-80 or any of its siblings, I'm European and very much loyal to Commodore, with both C64 and C128 on the desk. In later days I started tinkering with Z-80 and ended up getting 2 Speccys (Sinclair ZX Spectrum). So Z80 and MOS6502/8502 are the only processors I really worked with in the 8-bit universe.
Goal (or what do I want):
So what do I want the final product be? Well as long as me and my son keeps getting better and better ideas it will evolve slightly over time, but in general it will be:
  • a micro computer system based on a 6809/6309 microprocessor
  • a serial controller with a regular RS232 port and a USB port (This will be the terminal port for debugging and updating etc.)
  • a 6522 VIA based dual joystick port (for all your gaming needs)
  • 8kB EEPROM for BIOS, drivers and monitor code (size might change if needed later)
  • 512kB static RAM with option for 512kB more on board (the system itself supports up to 4MB of RAM)
  • fully programmable address and control logic (3 GAL chips)
  • a PS/2 keyboard and mouse interface
  • interrupt controller for 15 unique and prioritized interrupts (it is also possible to set a mask to hide interrupts)
  • an addon port for a audio card (I have already designed a SID 6581/8580/Arm2Sid based board and started on a OPL3 based board)
  • an addon port for a video card (I have a VDC 8563/8568 based one with 2kB character ROM and a working on a V9958 based one)
  • an expansion port with full access to entire address space and all control signals (to be able to implement some smart DMA stuff later on)
  • and a CompactFlash card interface for the "unlimited" storage we all dream of.
For the expansion port I have already started to design an similar sized expansion unit, with address logic, place for 2 extra 512kB RAM chips and 5 expansion ports. And I have designed a 24 bit parallel I/O module and started on a IEC interface for connecting Commodore drives to the system.
The beginning:
Soon we had so many ideas that a project started to take form, and I started to draw a possible schematic in KiCad. After some simple testing and "proofreading" by my son I felt that we could be able to make a board of this. I even sat some limitations on the board, just to spice it up a bit, but in the end I had to make it in 3 stages to be able to manage the full scope, it was just too much to put on one board in one go for an microcomputer-rookie like me.
Stage 1CPU, EEPROM for bios and test applications, RAM, address-logic (one GAL16v8), a serial controller and an expansion port.
Stage 2Stage 1 + Parallel port (6522), complete address logic (2 GAL22v10 and 1 GAL16v8), IRQ handler and addon ports for audio and video cards.
Stage 3Stage 2 + PS2 interface and CF Card addon port. There was no real estate left on the board for a full size CF socket.
Stage 1 ( status: TESTED):
So stage one was just a basic board with a EEPROM, a RAM, a GAL (for control signals) and a serial chip for communication. This basic board also have a single expansion port to be able to test small (and much cheaper) prototype boards for functions on later stages. This will hopefully let the next stage have lower probability for faults.
After assembly and testing of the stage 1 board, the conclusion is:
  • I forgot a pull-up on the DMA/BREQ pin on the CPU.
  • The power regulation and reset handling was not very good, has been complete re-drawn in stage 2.
  • The serial controller is very slow, is also replaced in stage 2.
  • I forgot to pull out the spare pins of the GAL to the expansion header (the prototype boards need to have an ENABLE signal hand soldered to the GAL)
Apart from these points was the first prototype board successful!
My son managed to write some code that simply echoes a word back when typed in the terminal in just some hours.
Now are we focusing on testing the prototype boards to validate design of:
  • the IRQ handler....
logic-stage2.zip
Logic chip code for stage 2.
x-zip-compressed - 2.13 kB - 04/01/2025 at 19:04
Download
motherboard-stage2.step
Model of stage 2 board in STEP format
step - 18.33 MB - 11/17/2024 at 18:43
Download
motherboard-Stage2.zip
Gerbers for the final stage 2 board.
x-zip-compressed - 2.04 MB - 11/17/2024 at 18:43
Download
motherboard-stage2.pdf
Final stage 2 board schematics.
Adobe Portable Document Format - 387.47 kB - 11/17/2024 at 18:43
Preview
  • 1 × MC6809 alt. HD63B09 Microprocessor
  • 1 × 28C64 Memory ICs / PROMs, OTP PROM
  • 1 × AS6C4008 Memory ICs / Static RAM (SRAM)
  • 4 × 74HCT245 Logic IC
  • 1 × 8MHz Crystal CPU Crystal
View all 24 components
  • Stage 2 is working!
    Eric Lind16 hours ago 0 comments
    Today we finally got the stage 2 to work properly, we got a led blinking!
    We started with a small code that should cycle thru the colors of the rgb led we got connected to a register.
    When we tried the code the led only blinked once and was dark after that. When we looked in to the schematics we found that we were generating a active low enable signal from our address-logic and the 373 chip needed active high logic.
    Easy fix, we just change a line in the GAL code:
    PIN 14		= !EXP_EN	; /* Enable Expansion Port     */
    PIN 15   	= !VDC_EN	; /* Enable Video Port         */
    PIN 16    	= !SNDR_EN	; /* Enable Sound Port Right   */
    PIN 17    	= !SNDL_EN	; /* Enable Sound Port Left    */
    PIN 18		= !CF_EN	; /* Enable Compact Flash      */
    PIN 19    	= !PAR_EN	; /* Enable Parallel Port      */
    PIN 20    	= !SER_EN	; /* Enable Serial Port        */
    PIN 21    	= PWR_EN     	; /* Enable PowerLed Port      */   <--- HERE!
    PIN 22    	= !IRQ_EN       ; /* Enable IRQ Handler        */
    PIN 23   	= !MEM_EN       ; /* Enable MMU                */
     After we fixed that we got it to light up, but not change color... Hmmm...  After some looking at the code we realized that if the stack was not properly set up the jump instructions used in the delay would not work. Said and done, we updated the code and added initialization of the bank register for good measure :
        org $FE00
    PWR_LED     EQU $F405
    BANK_REG_0  EQU $F400
    BANK_REG_1  EQU $F401
    BANK_REG_2  EQU $F402
    BANK_REG_3  EQU $F403
    _START:
        clrb
    LOOP:
        stb PWR_LED
        ldx #$03E8
        jsr DELAY_MS
        cmpb #$07
        beq _START
        incb
        bra LOOP
    DELAY_MS:
        lda #$7C            ; 2 cycles
    DELAY_MS_LOOP:
        nop                 ; 1 cycle
        nop                 ; 1 cycle
        nop                 ; 1 cycle
        deca                ; 1 cycles
        cmpa #$00           ; 4 cycles
        bne DELAY_MS_LOOP   ; 3 cycles
        nop                 ; 1 cycle
        nop                 ; 1 cycle
        nop                 ; 1 cycle
        nop                 ; 1 cycle
        nop                 ; 1 cycle
        nop                 ; 1 cycle
        leax ,-x            ; 5 cycles
        cmpx #$0000         ; 4 cycles
        bne DELAY_MS        ; 3 cycles
        rts                 ; 4 cycles
    STACK EQU $1000
        org $FF00
    HOOK_RESTART:
        ; Initialize the 6309 CPU in native mode
        ldmd #$01
        ; Initialize the bank registers
        clra
        sta BANK_REG_0
        sta BANK_REG_1
        sta BANK_REG_2
        sta BANK_REG_3
        ; Set up the stack
        lds #STACK
        lbra _START
    HANG:
        bra HANG
        org $FFF0
    vrestart: fdb HOOK_RESTART
     With this fixes the power led started cycling as expected! IT WORKS!
    This means that following works:
    • Signal logic
    • Address logic
    • Memory logic
    • Bank registers
    • PWR_LED register with led
    • Low RAM and ROM
    Next up is to get the serial port working, my son is working on a SREC parser so we will be able to upload code to execute and run.
  • Finally, all logic chips are validated!
    Eric Lind03/20/2025 at 18:59 0 comments
    Today we finally sat down and tested the Signal-Logic chip, the chip responsible for creating the RW and WR signals and also some other signals like the MEM_RD/MEM_WR that is used for the banking system.
    We have tried to validate this chip several times and did not get the correct functionality, on the contrary, we get the opposite functionality! Hmmm... When we expect a logical HIGH we got a LOW and vice versa. We even made a super simple 2 input and 2 output program to test but to no avail.
    After several attempts of testing and reading we finally got it to work as assumed (don't ask how we fixed it, it was magic...). So now we have all 3 logic chip working as intended and tested. So next step will be testing the new bus transceivers to make sure we don't fry our processor. And when that is done, we can start test ROM & RAM.
    Name     Test ;
    PartNo   00 ;
    Date     2025-03-29 ;
    Revision 1 ;
    Designer Engineer ;
    Company  Sperly Retro Electronics ;
    Assembly None ;
    Location  ;
    Device   G16V8A ;
    /* *************** INPUT PINS *********************/
    PIN 2    =  A                         ;
    PIN 3    =  B                         ;
    /* *************** OUTPUT PINS *********************/
    PIN 18    = Y                      ;
    PIN 19    = X                      ;
    /* ********************* LOGIC *********************/
    X = A & B;
    Y = A # B;
    This test program gave us inverted outputs and I did not figure out why.
  • I'm still here...
    Eric Lind03/04/2025 at 07:21 0 comments
    I haven't dropped the project, I've just been struggling with both GAL- problems and real life time issues. But my son has started to design and develop BIOS routines for the new stage 2 board.
    The issues with the GAL is either depending on my lack of programming knowledge regarding Goals or as I thought about this morning, a dodgy chip. Need to get a new one and try that. I have started building a test bench for Goals using an Arduino Mega, to be able to automate the testing of the address and logic GALs.
    I hope I can solve this soon, both me and my son are anxious to start SW development on the stage 2 board.
  • Building stage 2 board - a slight hickup
    Eric Lind12/14/2024 at 14:36 0 comments
    So after my son finally soldered the stage 2 board I started testing it, like checking all power connections, all grounds and generally check for shorts. And of course I found out that I had made a big mistake!
    The power pin and ground pin on the serial controller is connected to wrong pins. And if you look in the schematics you can see that I made the symbol for it wrong.
    Fortunately can it be "re-wired" to work. I will just bridge pin 44 to VCC, pin 40 is an unused input pin so it does not matter. And the ground had not been filled on pin 20 so that will not be a problem to just bridge pin 22 to GND.
    Crisis adverted!
    I will continue to check connections before i populate the board and power it up. I have measured the voltage from the regulator and it is nicely holding on 5.0v. Soon it is Christmas Hollydays and I will be able to take more time to test this bord.
  • Sometimes life comes in between
    Eric Lind12/03/2024 at 09:56 0 comments
    Sadly I haven't soldered the stage 2 board yet, I've had birthdays and other family celebration preparations to tend to. But I still got time to do a visual inspection and found a couple of things that need fixing to stage 3. But none of them was a showstopper yet!
    So what have I found so far:
    • I'm missing an chip name on U26 a GAL chip. Definitely not a deal-breaker!
    • Footprint on power switch SW1 is not correct (I made this my self and must have been holding my caliper upside down when i did it)
      The hold pins (pins that are not connected but just a part of the switch chassis) are to close to the other pins.
      The hole diameter is to small, the pins on the switch are quite large.
    • The USB socket is too far in to the board, it will not reach out of the case correctly.
    • The same goes to the power socket, but I'm looking for another type of socket for that.
    But none of these are bad enough to stop me from making a stage 2 machine to test on.
    When I finalized the basic tests and those are ok, I'm curious if any one else is interested in trying this computer? I will probably have 2 or 3 boards over after the I've made my prototypes. And I think I will be able to send them out if any one is interested in this project. The only thing I ask of is to get feedback and hope that you will share what you have been doing on it with the "community" (thats what I call my self for now).
  • Stage 2 has arrived!
    Eric Lind11/26/2024 at 19:36 0 comments
    Today I surprisingly received the stage 2 boards! They where supposed to arrive tomorrow! But I'm not sad! They look amazing!
    Huge thanks to PCBWay who reached out to me and wanted to support this project. They made a great job with these boards and the service was amazingly fast. As the buffoon I am I mistakingly chose wrong on some options when I ordered, but the sent me an question in just an hour to verify my choices. And all was cleared and the bords sent to production almost immediately.
    Now we will begin to assemble a board an hopefully we will be able to do tests this weekend!
  • Stage 2 - On the way, the PCBWay!
    Eric Lind11/17/2024 at 18:17 0 comments
    This weekend we finally got around to do all testing on the IRQ prototype board, in order to be able to get the stage2 board. There were some difficulties (mostly bad thinking from our side) but we managed to get it running with some small modifications. So now, with some minor updates we were able to order a batch of stage2 boards. One major step towards the complete system.
    And you know what? I was actually contacted by a representative from PCBWay who showed interest in this project, so now they are actually sponsoring it! I'm really looking forward to this!
    So what did we need to update after prototype testing?
    The output (the IRQ signal) is active high and the processor expects an active low signal, so here we got to insert the extra unused NOR-gate to invert it.
    The clock pulse was connected to an inverted read signal which means that it will not clock in an released interrupt in the register without reading it again. This was sorted by clocking it with Q, since that is a quarter pulse earlier than the read, it will always have fresh data in the register upon read.
    OE was connected to the read signal and since it is an active low input it needed to be inverted. So we reused the NOR-gate used for the previously used clock pulse.
    We also found that the NAND gates collecting the irq-levels (U5) was out of order so the interrupts came in in the wrong order.
  • One of the prototypes for stage 2 is tested!
    Eric Lind11/08/2024 at 21:45 0 comments
    Me and my son has tested the prototype for the joystick port controller. I had ordered prototype boards to be able to test the functionality of the joystick controller and the IRQ handler before ordering the stage 2 board.
    We found that I had mixed up the 2 ChipSelect inputs so it was active the entire time, killing the bord. And when I fixed that (by inverting the signal from the logic GAL) we found that 2 of the input pins on joystick A was swapped. I have now updated the schematics for coming stages and will update the uploaded files later this weekend.
    Next up will be the interrupt handler!
  • So I did a thing...
    Eric Lind11/03/2024 at 08:41 0 comments
    So i decided to make a simple case to protect the board, it is not in any way done or perfect, but it is sufficient for prototyping.
    Case for prototype
View all 9 project logs
Frank Swygert wrote 12/09/2024 at 13:27 point
You might want to consider NitrOS-9 as a multi-tasking OS. It would have to be modified to run on your 6809 board, but it should be doable.
Eric Lind wrote 12/09/2024 at 17:20 point
I was actually thinking about that. I need to look in to what needs to be modified.
Alexey Vazhnov wrote 12/06/2024 at 22:32 point
MIT license— awesome!
Eric Lind wrote 12/09/2024 at 17:21 point
I have always been a strong supporter of open and free hardware/software.
