Features & Specifications
Haasoscope Pro:
- 2 analog input channels
- 50 Ohm (<1 pF) or 1 MOhm (10 pF) input impedance
- 2 GHz analog bandwidth at 50 Ohm, 500 MHz at 1 MOhm
- 3.2 GS/s for 1 channel or 1.6 GS/s for 2 channels, doubled to 6.4 GS/s with two synced Haasoscope Pro's
- 12 bits of real-time vertical resolution per sample
- Up to 40k samples per trigger, with adjustable trigger time offset
- 100 ps/div to 24 hour/div, for 10 div
- Max analog input of +-5V (50 Ohm) or +-3V (1 MOhm), +-50V or +-30V with x10 probe
- Sensitivity of 1.6 V/div down to 8 mV/div, for 10 div, in x1 mode
- Programmable AC or DC input coupling
- Programmable DC offsets per channel
- External trigger in and aux trigger out
- Multiple Haasoscope Pros can be connected for more channels or to oversample at 6.4 GS/s, with synchronized timing and triggers
- Standard set of triggers (rising / falling edge, time over threshold, etc.), customizable in firmware
- Qt-based python software interface for Windows/Mac/Linux
- Standard set of signal measurements in software
- 5 V 1.5 A USB Type-C powered (or using 12 V 1 A 2.1 mm barrel connector)
- Aluminum case with quiet 40 mm internal fan
- 220 x 165 x 35 mm (8.66 x 6.5 x 1.38 in), 0.9 kg (1.98 lbs)
Active Probe:
- DC - 2 GHz analog bandwidth
- Flat response from DC -1 GHz within 0.3 dB
- 1 MOhm input resistance
- 1.1 pF input capacitance
- 100 Ohm minimum impedance, near 1.6 GHz
- x10 probe attenuation, input voltage range +-30V
- 50 Ohm SMA output, 1m cable
- 12 V power at ~80 mA, via 2.1 mm barrel connector, or 5V 200 mA USB using included cable
haas
Pavel
Peter Hizalev
Eric Hertz
i'm not sure how you get 2GHz, if the ADC is 3.2GS/s? Doesn't Mr. Nyquist want a word with you?
