Papaya Pathfinder
Papaya Pathfinder is an open-source family of small remote-controlled rovers based on the ESP32.
The project currently includes two rover variants, designed for different sizes, motors, and power requirements.
All mechanical parts of the rovers are fully 3D-printable, and all models are available in the 3d-models/ directories of each rover variant.
The rovers can be operated using either WiFi or ExpressLRS (ELRS), depending on the firmware configuration.
Watch the Papaya Pathfinder demo on YouTube
Papaya Pathfinder
- Controller: ESP32
- Radio: ELRS receiver (required only when running
firmware-elrs) - Motor Drivers: 2× BTS7960 43A (or similar high-current driver)
- Motors: 6× GA25 DC gear motors
- Steering: 4× MS24 servos
- Power: LiPo 3S Battery
- Voltage Regulation:
- 1× UBEC 5V/3A (for ESP32)
- 1× UBEC 6V/8A (High current supply for Servos)
Firmware
The rover supports multiple firmware configurations, each enabling a different communication method.
firmware-wifi- WiFi-based control
- HTTP API for movement commands
- Compatible controllers:
- Python desktop controller — sends gamepad-based control commands to the rover via HTTP.
- Android mobile app — enables rover control using a gamepad, providing the same driving experience available on the desktop controller.
firmware-elrs- Control via ExpressLRS (ELRS)
3D-Printed Parts
All STL files for this rover are available in: pathfinder/3d-models/
The complete mechanical design is also available in STEP format: pathfinder/cad/papaya-pathfinder.step
Use PETG or PLA for the structural parts, and TPU for the tires. All parts are designed to be assembled using M3 screws and nuts.
| File | Qty | Material | Notes |
body.stl |
1 | PETG / PLA | Main chassis |
arm_left.stl |
1 | PETG / PLA | Left suspension arm |
arm_right.stl |
1 | PETG / PLA | Right suspension arm |
pivot_left.stl |
1 | PETG / PLA | Left pivot mount |
pivot_right.stl |
1 | PETG / PLA | Right pivot mount |
differential_bar.stl |
1 | PETG / PLA | Central rocker-bogie differential bar |
differential_link_left.stl |
1 | PETG / PLA | Left link between differential bar and suspension arm |
differential_link_right.stl |
1 | PETG / PLA | Right link between differential bar and suspension arm |
motor_mount.stl |
4 | PETG / PLA | Motor mounts for GA25 motors used on steering arms |
horn_adapter.stl |
4 | PETG / PLA | Servo horn adapters for steering servos. Print horizontally for strength. |
rim.stl |
6 | PETG / PLA | Standard option. Connects directly to the motor shaft (D-shape). Simple, but can strip over time under high torque. |
rim_hexagonal.stl |
6 | PETG / PLA | Pro option (Recommended). Requires 12mm brass hex adapters. Much stronger connection, prevents the motor shaft from stripping the plastic. |
tire.stl |
6 | TPU | Tires |
Wiring Diagram
Power Distribution: Shows the rover power distribution, including the LiPo 3S battery,
separate UBECs for logic (5V) and servos (6V), and the motor power rails.
Motors: Motor wiring using two BTS7960 drivers, each controlling one side of the rover.
The ESP32 provides PWM control signals to each driver.
Servos: Servo wiring powered by a dedicated 6V UBEC. PWM control signals are provided by the ESP32.
System Overview: High-level overview of the complete rover wiring, combining power,
motor drivers, servos and control logic.
Papaya Pathfinder Mini
- ESP32 with camera (ESP32-CAM / ESP32-S3-CAM) (required only when running
firmware-wifi) - ELRS receiver (required only when running
firmware-elrs) - 6× N20 DC gear motors
- Power supply: LiPo 2S
- Voltage regulation:
- 1× DC-DC step-down to 5V (ESP32 / ESP32-CAM)
- 1× DC-DC step-down to 6V (N20 motors)
Firmware
Sergio García Sánchez
Stanislav Britanishskii
Eugene Lamnek
JohnsonFarms.us
gokux
Just starting the assembly, can you let me know what hardware you used to join everything? jut bolts and nuts, or something else?
