Testing Macro Drawings
2 hours ago • 0 commentsFirst Macro drawing for FreeCad is just to check it can be done easily. It works. Here is the first Macro:
import FreeCAD as App import Part import math try: from PySide import QtCore except ImportError: from PySide6 import QtCore doc_name = "Chain_Sprocket_13T_15T_Simulation" doc = App.newDocument(doc_name) # --- 1. System Parameters --- t1 = 13 # Left Sprocket Teeth t2 = 15 # Right Sprocket Teeth pitch = 9.525 roller_diameter = 6.35 bore_diameter = 10.0 plate_thickness = 5.3 num_links = 32 # Increased chain length to accommodate larger sprocket # Chain Link Specs inner_width = 5.72 pin_diameter = 3.28 link_plate_thickness = 1.3 # Calculated Radii R1 = pitch / (2 * math.sin(math.pi / t1)) R2 = pitch / (2 * math.sin(math.pi / t2)) root1 = R1 - (roller_diameter / 2.0) root2 = R2 - (roller_diameter / 2.0) # --- 2. Iterative Solver for Exact Center Distance (C) --- # A closed chain requires a geometrically perfect loop length. L_target = num_links * pitch C = 85.0 # Initial guess for _ in range(50): # Newton-Raphson method for exact distance theta = math.asin((R2 - R1) / C) L_calc = 2 * C * math.cos(theta) + R1 * (math.pi - 2*theta) + R2 * (math.pi + 2*theta) C -= (L_calc - L_target) / (2 * math.cos(theta)) # Final Path Geometry Variables theta = math.asin((R2 - R1) / C) L_str = C * math.cos(theta) L_arc1 = R1 * (math.pi - 2 * theta) L_arc2 = R2 * (math.pi + 2 * theta) L_total = L_arc1 + L_arc2 + 2 * L_str # Tangent Points defining the path layout T1top = App.Vector(-R1 * math.sin(theta), R1 * math.cos(theta), 0) T1bot = App.Vector(-R1 * math.sin(theta), -R1 * math.cos(theta), 0) T2top = App.Vector(C - R2 * math.sin(theta), R2 * math.cos(theta), 0) T2bot = App.Vector(C - R2 * math.sin(theta), -R2 * math.cos(theta), 0) # --- 3. Dynamic Sprocket Generator --- def create_sprocket(name, teeth, R_pitch, R_root): R_outer = R_pitch + 2.3 # Scaled OD base_cylinder = Part.makeCylinder(R_outer, plate_thickness) scale_y = 0.85 # Parameterized Wedge Cutter to adapt to different radii p_root = App.Vector(R_root, 0, 0) p_A = App.Vector(R_pitch - 1.6, 2.77 * scale_y, 0) p_B = App.Vector(R_pitch - 1.6, -2.77 * scale_y, 0) p_M_up = App.Vector(R_pitch + 1.75, 4.5 * scale_y, 0) p_M_low = App.Vector(R_pitch + 1.75, -4.5 * scale_y, 0) p_3 = App.Vector(R_pitch + 5.1, 5.5 * scale_y, 0) p_4 = App.Vector(R_pitch + 5.1, -5.5 * scale_y, 0) arc_root = Part.Arc(p_B, p_root, p_A).toShape() arc_up = Part.Arc(p_A, p_M_up, p_3).toShape() arc_low = Part.Arc(p_4, p_M_low, p_B).toShape() line_out = Part.LineSegment(p_3, p_4).toShape() wedge_wire = Part.Wire([arc_root, arc_up, line_out, arc_low]) wedge_solid = Part.Face(wedge_wire).extrude(App.Vector(0, 0, plate_thickness + 2.0)) wedge_solid.translate(App.Vector(0, 0, -1.0)) sprocket = base_cylinder for i in range(teeth): cutter = wedge_solid.copy() cutter.rotate(App.Vector(0, 0, 0), App.Vector(0, 0, 1), i * (360.0 / teeth)) sprocket = sprocket.cut(cutter) bore = Part.makeCylinder(bore_diameter / 2.0, plate_thickness + 2.0) bore.translate(App.Vector(0, 0, -1.0)) obj = doc.addObject("Part::Feature", name) obj.Shape = sprocket.cut(bore) obj.ViewObject.ShapeColor = (0.2, 0.2, 0.2) return obj sprocket_1 = create_sprocket("Sprocket_13T", t1, R1, root1) sprocket_2 = create_sprocket("Sprocket_15T", t2, R2, root2) sprocket_2.Placement.Base = App.Vector(C, 0, 0) # --- 4. Chain Link Geometry --- def create_link_plate(thickness, z_offset): r = 4.0 cyl1 = Part.makeCylinder(r, thickness, App.Vector(0,0,z_offset)) cyl2 = Part.makeCylinder(r, thickness, App.Vector(pitch,0,z_offset)) box = Part.makeBox(pitch, r*2, thickness, App.Vector(0, -r, z_offset)) return cyl1.fuse(cyl2).fuse(box) inner_plate_z1 = plate_thickness/2 + inner_width/2 inner_plate_z2 = plate_thickness/2 - inner_width/2 - link_plate_thickness p1 = create_link_plate(link_plate_thickness, inner_plate_z1) p2 = create_link_plate(link_plate_thickness, inner_plate_z2) r1 = Part.makeCylinder(roller_diameter/2, inner_width, App.Vector(0,0, plate_thickness/2 - inner_width/2)) r2 = Part.makeCylinder(roller_diameter/2, inner_width, App.Vector(pitch,0, plate_thickness/2 - inner_width/2)) inner_link_shape = p1.fuse(p2).fuse(r1).fuse(r2) outer_plate_z1 = inner_plate_z1 + link_plate_thickness + 0.2 outer_plate_z2 = inner_plate_z2 - link_plate_thickness - 0.2 op1 = create_link_plate(link_plate_thickness, outer_plate_z1) op2 = create_link_plate(link_plate_thickness, outer_plate_z2) pin_len = (outer_plate_z1 - outer_plate_z2) + link_plate_thickness + 1.0 pin1 = Part.makeCylinder(pin_diameter/2, pin_len, App.Vector(0,0, outer_plate_z2 - 0.5)) pin2 = Part.makeCylinder(pin_diameter/2, pin_len, App.Vector(pitch,0, outer_plate_z2 - 0.5)) outer_link_shape = op1.fuse(op2).fuse(pin1).fuse(pin2) links = [] for i in range(num_links): link_obj = doc.addObject("Part::Feature", f"Link_{i:02d}") link_obj.Shape = inner_link_shape if i % 2 == 0 else outer_link_shape link_obj.ViewObject.ShapeColor = (0.7, 0.7, 0.7) if i % 2 == 0 else (0.5, 0.5, 0.5) links.append(link_obj) # --- 5. Complex Tangent Kinematics --- def get_path_pos(d): d = d % L_total if d < L_arc1: # Wrap CCW around S1 angle = math.pi/2 + theta + (d / R1) return App.Vector(R1 * math.cos(angle), R1 * math.sin(angle), 0) elif d < L_arc1 + L_str: # Straight bottom return dist = d - L_arc1 return T1bot + (T2bot - T1bot) * (dist / L_str) elif d < L_arc1 + L_str + L_arc2: # Wrap CCW around S2 dist = d - (L_arc1 + L_str) angle = -math.pi/2 - theta + (dist / R2) return App.Vector(C + R2 * math.cos(angle), R2 * math.sin(angle), 0) else: # Straight top feed dist = d - (L_arc1 + L_str + L_arc2) return T2top + (T1top - T2top) * (dist / L_str) # --- 6. Animation Engine --- global anim_offset anim_offset = 0.0 # Initial phase alignments to nest teeth into the chain offset_1 = math.degrees(theta) - 13.8 offset_2 = math.degrees(-theta) + 12.0 def update_simulation(): global anim_offset anim_offset += 1.0 # Simulation speed. # Track discrete link paths for i, link in enumerate(links): d1 = (i * pitch + anim_offset) % L_total d2 = ((i + 1) * pitch + anim_offset) % L_total pos1 = get_path_pos(d1) pos2 = get_path_pos(d2) yaw = math.degrees(math.atan2(pos2.y - pos1.y, pos2.x - pos1.x)) link.Placement = App.Placement(pos1, App.Rotation(App.Vector(0,0,1), yaw)) # Rotate independently according to varied geometries and chain speed sprocket_1.Placement.Rotation = App.Rotation(App.Vector(0,0,1), math.degrees(anim_offset / R1) + offset_1) sprocket_2.Placement.Rotation = App.Rotation(App.Vector(0,0,1), math.degrees(anim_offset / R2) + offset_2) App.Gui.updateGui() doc.recompute() try: import FreeCADGui as Gui Gui.activeDocument().activeView().viewAxometric() Gui.SendMsgToActiveView("ViewFit") App.sim_timer = QtCore.QTimer() App.sim_timer.timeout.connect(update_simulation) App.sim_timer.start(10) App.Console.PrintMessage("Simulation running ........ type 'App.sim_timer.stop()' in Python console to halt.\n") except Exception: pass
GOAT INDUSTRIES
