FairCharm_R3.kicad_sch
Revision 3 adds the possibility of adding external modules to your camera.
kicad_sch - 940.45 kB - 11/15/2026 at 11:41
Download
FairCharm_R3.kicad_pcb
Revision 3 adds the possibility of adding external modules to your camera. I also fixed AGAIN the UART trace and pinout, this time is right, sorry for the mistake.
kicad_pcb - 305.52 kB - 11/15/2026 at 11:41
Download
faircharm backplate v1.3.3.stl
Standard Tesselated Geometry - 235.73 kB - 11/01/2026 at 23:08
Download
faircharm body 1.7.stl
Standard Tesselated Geometry - 153.99 kB - 11/01/2026 at 23:08
Download
FairCharm_PCB_R2.3.kicad_pcb
Final revision, the dimension of the CKCS module was wrong, 3mm too short and the pads did not line up properly. Now it's fixed. This is the PCB schematics for the board.
kicad_pcb - 277.64 kB - 10/27/2026 at 07:52
Download
FairCharm_Gerber_R2.3.rar
Final revision, the dimension of the CKCS module was wrong, 3mm too short and the pads did not line up properly. Now it's fixed. This is the Gerber files you can just send to your manifacturer.
x-compressed - 55.65 kB - 10/27/2026 at 07:52
Download
FairCharm_FIRMWARE.rar
The actual firmware for the camera. This is an Alpha version, I'm still working on it and I'm waiting on the PCB to arrive, try to tinker yourself with this. I'll obviosly update it in the nearest possible future.
x-compressed - 10.99 kB - 10/13/2026 at 06:38
Download
FairCharm.kicad_sch
The Schematics.
kicad_sch - 932.67 kB - 10/12/2026 at 19:30
Download
faircharm backplate v1.0.stl
The basic backplate to close the camera. This might be changed very soon...
Standard Tesselated Geometry - 180.16 kB - 10/03/2026 at 16:05
Download
faircharm body v1.3.stl
The body of the camera, this will be changed very soon...
Standard Tesselated Geometry - 165.02 kB - 10/03/2026 at 16:05
Download
