Simulation
A Simulation is available since the Log 07/13/2017
Magnetic lens system Vacuum and electron beam
I have a magneticlens system since 11/06/2017
Housing
Since 12/28/2017 I have a improved housing
Electron detector
I have a schematic since 02/21/2018 for the detector amplifier
High voltage shield for Arduino
I populated the bare PCB about 03/16/2018
Overview and Introduction of SEM
1965 was the first Scanning Electron Microscope (SEM) commercially available (wiki). 2011 Ben build the first SEM at home. He used special equipment to build it. Now 2017 I start to build the first SEM with common available components. I would like to create imanges like these.
I will not explain the principles of a SEM because the explanation on the homepage of ammrf.org.au is great and I can't do it better.
Also the overview video from Ben is great for the introduction. But for a deep understanding I recommend the book Physical Principles of Electron Microscopy from author Ray F. Egerton.
My plan is to go ahead with the following steps:
- Simulation
- Vacuum and electron beam
- Housing
- Magnetic lens system
- Electron detector
- High voltage shield for Arduino
1. Build a simulation with a magnetic field simulation tool to determine the dimensions
I want use the tool FEMM 4.2. This tool is free and it is possible to create code based on Lua 4.0.
Chris.deerleg
One of my first test was just to point the photomultipler to the wall and illuminate it with my desk lamp. In this test I figured out that i need an aperture.
I decided to make a new chamber because I need more space in the chamber that I can begin to build the electron detector. In the image above are the single parts of the chamber shown. The parts are made of 3mm acrylic sheet. The 5mm golden pogo pins are from Ebay and the black rubber rings are from sealing kit from Amazon.
On the image above are the connections in side the chamber shown. The black tube is the connection to the vacuum pump. The clear tube below is the entrance for the electron beam. Left to the tubes are the pogo pins and a nut. These elements should connect the electron detector to the outside. On right side are three pegs visible. With these pegs I want to measure the vacuum because I had a lot of trouble with the vacuum in the past.
Christian Walther
rawe
mircemk
Thank you for a great project! It gives inspiration for so many. I watched and rewatched the video and something is not clear to me if you see glowing in the tubes it means there is air leftovers and electrons hitting it makes air glow. I think vacuum system must be revised (missing turbo molecular/defussion pump?)
Anyway the project is too amazing not to be finished. If you would not continue in six months I will... YOU HAD BEEN WARNED 😉
