prism laser scanner
bringing additive manufacturing to the next level
An open hardware fast high resolution LASER suited for Printed Circuit Board (PCB) manufacturing or 3D printing. The laser head can be used to write to a substrate. I am working on reading from a substrate.
The goal of this project is to develop a laser head for 3D printing or PCB manufacturing which uses a rotating prism and is easy to assemble.
Cyanotype paper is currently used as it can be developed with water.
Specifications
Specifications are determined by exposure onto a camera without lens and OpenCV. More technical details are available in the whitepaper or the business case pitch.
  • wavelength: 405 nm
  • rotation frequency:  up to 21000 RPM, current 2400 RPM
  • line speed: up to 34 meters per second @ 21000 RPM
  • spot size FWHM: circular, 25 micrometers diameter
  • cross scanner error: 40 micrometers  (error orthogonal to scan line)
  • stabilization accuracy scanning direction:  2.2 micrometers (disabling/enabling scan head)
  • jitter: 35 microns (error parallel to scan line)
  • duty cycle: 47%
  • laser driver frequency: 2.6 MHz
  • maximum scan line length: 24 mm
  • typical scan line length: 8 mm
  • optical power: 500 mW
  • facets: prism has 4 facets
  • prism dimensions: 30x30x2 mm
Electronics
  • FPGA ICE40UP5K-SG48 with Icestorm toolchain
  • laser driver, 3x TMC2209 stepper drivers
  • ESP32S3
Status
An image can be exported from Kicad to SVG and converted to instruction for the laserhead. An exposure result on a printed circuit board with close up is shown below.
Resolution below 100 microns can be achhieved. Stitching is between lanes is quite good on cyanotype paper but still a bit uneven on PCB. Exposure below is done without cylinder lenses.
An exposure goes as follows (for the result see above).
Acknowledgement
Special thanks go to Henner Zeller for his work on LDGraphy. The electronics and software in this project helped me a lot with constructing the laser scanner, see video.
The initial idea of using a prism for laser scanning originates from Dr. Jacobus Jamar. The first system used a plurality of laser bundles in a thicker prism under an angle.  TNO, a research institute of the Netherlands, still pursues this idea, in an entity known as Amsystems.
The current gateware relies on Amaranth HDL and some components from Luna. This is the work of white-quark and ktemkin.
Software
Amaranth HDL gateware for Hexastorm
Optical design
Electronics
PCB design
Hardware designs
CAD files
Literature Research
White paper @ Reprap
Other Links
Official website
boxblend.7z
blender file used to render the main board
7-Zip - 20.82 MB - 02/16/2024 at 13:45
Download
assembly_compact.7z
blender file used in render
7-Zip - 30.82 MB - 06/29/2023 at 19:07
Download
crosscanerrorsprisms.zip
Cross scan error measurements for seven prisms.
Zip Archive - 95.89 kB - 04/04/2023 at 13:57
Download
technical_presentation_2019.pdf
Technical deck presented to selected audience. Deck does not cover LIFT, laser microscope and latest improvements on tech.
Adobe Portable Document Format - 9.11 MB - 12/10/2021 at 08:28
Preview
pitchdeck.pdf
New pitch deck of 16-9-2021, also available as video on Youtube.
Adobe Portable Document Format - 2.03 MB - 09/16/2021 at 17:50
Preview
View all 7 files
  • 1 × prism, 30x30x2 mm edges parallel to < 1 arc minute 40pcs @ 20 euro per piece @ ebetteroptics
  • 1 × ESP32-S3-WROOM2 7 euros
  • 1 × Brass Laser Module Housing for 5.6mm TO-18 LD 5 euro
  • 1 × BDR-S06J 405nm / Nichia S06J 405nm 22 euro (eBay)
  • 1 × 10x10x1 first surface PMMA mirror 2.5 euro per 20 aliexpress (alternative edmund optics #45-517 18 euro per 10 including shipping)
View all 12 components
  • Industrial Precision from DIY Hardware: Conquering 2D Prism Distortion
    Hexastorm2 days ago 1 comment
    If you've been following along with the Prism Laser Scanner, you know that moving from a wobbly galvanometer to a high-speed rotating prism introduces a whole new nightmare of optical aberrations. In my previous logs, we could clearly see massive orthogonal errors (pyramidal tilt between facets) and scan line jitter (timing differences). This is due to that each facet pair is not perfectly planar and at 90 degrees, also the mounting is not exactly at 90 degrees.
    I am thrilled to report that the main technical challenge seems fixed. We can now  correct for facet distortion both along (scan) and orthogonal (orth) to the scanline and create perfect exposures. The hardware might be cheap and DIY, but the correction algorithm now guarantees industrial-grade results. It allows you to use all four facets and not use additional lenses and still have top results. More proof will follow, just look at the commit history https://github.com/hstarmans/hexastorm/commits/master/ and results below to gauge the effort required.
    Here is how we got there.
    1. The Median Average Reference
    Previously, the calibration relied on picking a single facet as the "master" reference. The problem? If that specific facet was an outlier, it skewed the entire baseline. Furthermore, the coefficients of one facet were fixed to zero, so we didn't use all coefficients.
    I achieved a major stability upgrade by ditching the single-facet reference. The system now calculates a virtual "median average" across all facets. This spatial median acts as a perfect, idealized virtual facet that we use to anchor the correction math, preventing any single highly-skewed facet from throwing off the calibration table.
    2. Proving Statistical Stability
    To prove this wasn't just a one-off lucky measurement, I automated a baseline calibration cycle to take 10 consecutive measurements. The results show that our underlying hardware timing is remarkably stable. A challenge with my previous log is that you just look at one result. How repeatable is this?
    Here is the raw statistical payload using 10 measurements per facet. Notice the standard deviations (std_um): our orthogonal jitter is hovering between 0.25 and 0.8 microns, and scan jitter is around 0.5 to 1.0 microns. We have a spot diameter of 40 microns and eccentricity of around 1.5. The spot can be made smaller and circular with cylindrical lenses so take this into account. Also, vibration artifacts can be removed further with cylinder optics.
    Facet Scan Shift (mm) Orth Shift (mm) Angle (°) Scan Std (µm) Orth Std (µm) Scan Spread PtP (µm) Spot Size (µm)
    0 0.0229 0.0109 -86.5079 1.063 0.257 3.118 40.366
    1 -0.0452 -0.0306 -86.3956 1.020 0.244 2.973 43.464
    2 0.0032 -0.0109 -86.5607 0.476 0.257 1.853 40.266
    3 -0.0032 0.0569 -86.3327 0.476 0.809 1.853 41.549
    3. Verification: The 2D Dot Grid Simulation
    To visually and mathematically prove the correction works, I wrote a routine that measures the 2D error by projecting a dot grid pattern.
    Because my global shutter camera is stationary, we can't physically move the stage to expose a 2D area. I create a SVG with a dot grid, send it to the slicer using calbiration and projects it onto the camera sensor line by line. It then simulates the physical movement of the stage by stacking these individual 1D exposures into a single 2D image using a custom LaserStackSimulator class.
    The routine evaluates the hardware twice: once without correction, and once with the active calibration profile fed into the slicer. It verifies if the optical correction forces the dots from all 4 facets to align perfectly.  There is an algorithm which detects the centroids of the final dot pattern an matches them. It then computes the average offset.
    The Results
    The log output speaks for itself:
    15:28:48 - INFO - Uncorrected 2D Errors (um) [Scan, Orth]: [[20.073, 11.351],...
  • Taming a prism Scanner with Computer Vision
    Hexastorm12/24/2025 at 15:35 1 comment
    We all love laser scanners, but moving from a wobbly galvanometer to a high-speed rotating prism introduces a whole new nightmare of aberrations. In my previous blog posts, you clearly see that there is an orthogonal error between the scan lines. In addition, there are small timing differences (jitter). So far, no one has been able to handle, let alone quantify this.
    My four-facet prism is spinning at 3000 RPM. While the motor controller is keeping the facet timing stable to within 0.2% (where the mean is 5ms per facet), each facet has a slightly different timing signature, which actually allows me to detect which facet is active.
    To get usable data, I needed to map the imperfections of every single facet. "Close enough" wasn't going to cut it.
    The Setup and The Hack
    My optical setup involves a spinning prism directing a laser onto an OV2311 global shutter camera (2MP, with nice square 3.0μm pixels). To see what was happening, I set the camera exposure long (~1000ms) and modulated the laser with a sparse repetitive pattern: a single pulse followed by a long gap [1] * 1 + [0] * 39. This turned the scan lines into distinct strings of dots, freezing the scanner's behavior in time and space. The images are multiple exposures of a facet imposed on top of each other. You can see that the projection is extremely stable. All the smearing or ghost pixels are gone.
    The Metrology
    Using OpenCV, I grabbed images from all four facets. I detected the dots and fitted ellipses to find their precise sub-pixel centroids. By defining Facet 0 as the "golden" reference, I calculated the relative horizontal and vertical shifts for the other three faces.
    The results gave me a perfect digital signature of the prism's physical defects:
    Facet Timing Shift (Scan μm) Mechanical Tilt (Orth μm) Spot Diameter (μm) Eccentricity
    0 (Ref) 0.0 0.0 23.023 1.307
    1 18.171 4.177 22.35 1.464
    2 13.45 77.707 24.801 1.577
    3 44.907 48.889 22.826 1.363
    The data is revealing. While the motor timing is stable, the timing synchronization (Scan) varies by over 44 microns between facets. More dramatically, we see massive pyramidal errors (orth-shift). Facets 1, 2, and 3 are all tilted significantly compared to Facet 0, shifting the scan line vertically by nearly 78μm. This is exactly what we were seeing before!
    We also see high eccentricity (~1.6). This is expected as I don't use cylinder optics yet but a simple aspherical lens. Still, I am surpised. If the laser spot is 30 microns, we should be able to get much better results; previously, we never really got beyond 75 microns.
    Verification
    To prove the calibration model works, I did a lot. I repeated the measurements. I switched facets to see if the algorithm is stable. I moved the camera around the laser line to see if the result is consistent. This all proved to be the case.
    Finally, I generated a composite verification image by stacking the raw captures from all four facets ( a single image is seen all the way on the end).
    • Hollow colored circles (cyan, green, red, yellow) are the detected centroids of the actual laser spots.
    • Small red 'x' marks are where my calibration model predicts those spots should be after applying the calculated X and Y shifts.
    As you can see, the red crosses land dead-center in the detected circles. With this calibration table, I can finally close the loop and feed these precise offsets into the slicer. As a final remark, LLMs are really accelerating the technology innovation here. I really think I am 3 to 4 times faster. Also some problems like, my pi's wifi is not working. Are fixed almost immediately, as the LLM states switch of your power management. This speeds up development 10-fold. As I would previously simply accept and not debug it.
    Superimposed facets verification
    All facets superimposed: Dots show the center of detected spots, while the 'x' marks show the model's approximation....
  • Jitter test
    Hexastorm10/04/2025 at 14:45 1 comment
    Five months have passed since my last cross-scan test results.
    Jitter and Scanline Error Resolution
    The extended delay was primarily due to addressing extremely poor initial results from the jitter test, i.e. error along scanline. Resolving this critical issue required a deep dive and specific hardware/software adjustments. I will not outline all of the code optimizations but want to highlight two main changes:
    1.  Mirror Position Adjustment: The physical position of the mirror was moved, allowing the laser's position to be measured at the start of the scanline instead of the end.
    2.  Photodiode Trigger Algorithm Change: A key change was made to the algorithm governing the photodiode trigger timing. The algorithm was proposed by a LLM (https://github.com/hstarmans/hexastorm/blob/master/src/hexastorm/blocks/photodiode_debounce.py).
    These fixes now allow for successful photodiode detection and consistent measurement. The table below shows the resulting timing statistics for each facet (there are four). It's hard to stratify samples. I now set a minimum i.e. 32 which can result in more samples for other facets. Each row corresponds with a different facet. They are ordered sequentially.
    SamplesMean (ms)Standard Deviation (ms)
    325.001330.00076
    4515.00226
    0.00037
    34 4.997970.00036
    4584.998180.00031
    Experimental Notes
    Operational Parameters:
    Laser Power:  130/255, both channels of laser driver
    Exposures: Four exposures are used per line.
    Facets: All facets were used, testing confirmed that using a single facet did not improve the overall results.
    Lines seem to wide in the image, spacing should equal line width,  I probably need to add an erosion operation.
    Focusing Procedure:
    Achieving accurate laser focus is critical. A white sheet of paper is placed on the exposure plane, and the laser is focused using a single channel of the laser diode driver at 133 a.u (digipot) to draw a test line. Successful focus is immediately confirmed by drawing a sharp, visible line (burning)
    Future work
    I need to pin facet data to certain facet, so I can use measurements to  correct for each facet.
  • Cross scan exposures (without cylinder optics)
    Hexastorm05/12/2025 at 12:18 0 comments
    In the following images, the scan direction is along the x-axis direction. Lines are projected parallel to this direction. As such, the error in the y-axis represents the cross scan error. Substrate is solar-fotopapier, 20 blatt, format 14x19 cm. Using a scissor I cut a good sized rectangle (4x4 cm)
    Each line is exposed four times at a rate of 3000 RPM, i.e. 12000 facets per minute. Laser current is assumed to be 500 mA.
    Using all four facets
    Using a single facet
    With a single facet lines are much sharper and 75 micron seems achievable. Stitching between lanes is a challenge as well. Odd lane (backward) have an other offset than even lanes (stage moves forward).
    Gravis pointed out that potentially, an algorithm, which takes the facet number into account could correct for the cross scan error. This is easy to imagine and can be executed, it is just hard to do so.
    Patterns is created via python, see crosscantest in  https://github.com/hstarmans/hexastorm/blob/master/src/hexastorm/interpolator/patterns/create.py . In the pictures, on the left axis you see the lane width.  There are ten lines per group where width and spacing are equal to the number denoted e.g. 50 microns. On the x-axis the distance between 0 and 10, is 10 mm. It just measures actual distance along x axis.
  • Reducing cross scan error
    Hexastorm04/11/2025 at 15:17 3 comments
    The polygon mirror (PM) is often used for fast scanning applications due to its superior scanning speed and large scanning angle. However, PM-based laser scanning systems are prone to cross-scan errors, restricting scanning precision. The facet tilt and scanhead dynamics are considered as two primary sources contributing to cross-scan errors.  A treaty of cross scan error in polygon mirrors can be found here https://www.acin.tuwien.ac.at/file/publications/iat/pre_post_print/2024_cong_aim.pdf .
    Luckily, cross scan error is zero in a laser prism scanner with two cylindrical lenses.
    In a prism scanner, the laser diode is first collimated with an aspherical lens. The bundle is then focused by a cylindrical lens in a direction parallel to the prism. The bundle is deflected by refracting it through a tilted transparent plate. The bundle is finally focused by a second cylindrical lens orthogonal to the scan line.
    This has two advantages; the bundle is circularized (cylinder lenses have different focal lengths) and the cross scan error is removed (explained hereafter). Scanhead dynamics introduce noise into the system BUT the refracted laser bundle remains parallel to the incoming laser bundle as this is always the case for a planar prism. As such, the second cylinder lens removes the cross scan caused by vibrations as all parallel rays are focused in the same point. This is a fundamental advantage of prism laser scanning, minimal cross scan error. In polygon mirror systems this is solved by active compensation via a galvo scanner, see https://repositum.tuwien.at/handle/20.500.12708/213517. In a polygon mirror system the outgoing rays are not parallel to the incoming rays so the cylindrical lens trick doesn't work as well.
    Below we see a side view of the new laser head and a camera with neutral density filters.  If you look carefully, you can see a two cylinder lenses. The one between the laser and the prism is the hardest to see.
    Cross scan measurement  is shown below, a line which is around 12 pixels wide implying around 36 microns error. Camera has a pixel size of 3 micron, see https://hackaday.io/project/21933-prism-laser-scanner/log/217210-cross-scan-error-measurements-new-bearing
    two cylinder lenses, one channel, current 80 a.u. (scale 1-255), 4 facets, polygon speed 2000 rpm,
    exposure time is set to minimize overexposure and have a stable image
    An exposure without cylinder lenses is shown below. Here you can clearly see the individual lines produced by the facets which are removed by the cylinder lens.
  • Champions team with PCBWay
    Hexastorm02/19/2025 at 15:27 0 comments
    New version of Hexastorm first look and feel. Video reviews boards of PCBWay, build of the module, its looks and the new software flow!
  • Progress
    Hexastorm01/09/2025 at 14:54 0 comments
    The boards sponsored by PCBWay are shown below. Progress in the last days has been good.
    Following things are working: prism motor (spins), laserdiode (can turn on & pogo pin system works), TMC2209 communications work, ESP32 and ICEUP5K (FPGA) work.
    Progress has been as follows:
        -  9 december:  received boards
        -  14 december  boards populated & compute board working
                                  numbers of some parts where wrong, which required extra shipment from mouser
        -  19 december extension board populated (after receipt parts)
                                 I encountered a bug.
        -  30 december  bug has been resolved
                                  Two issues: - schema error (5V connected to 3.3V, this has been mitigated with soldering tricks)
                                                      - stepper motors communicate via UART1 which can create issues with UART0 (micropython repl)
                                                        this is a bug upstream but can be mitigated by a trick in the boot.py script.
      -  2 january       Destroyed laptop (applied 12V over USB input)
      -  6 january       Mounted motor, encountered issues moved to different board
      -  7,8 january     Changed code, ESP32 communicates with FPGA,  spinning of prism work
      -  9 january        Laser works (forward diode voltage of 2.5V)
      - 13 january        Laser can be calibrated while on (pogo sytem works good)
                                 Laser diode prism test --> pass
     - 14 january         Stability test / Mounting on machine
                                  laser reaches stability criterion
                                  mirror position without cylinder lens does work
                                  mirror position for cylinder does not work
                                      (cylinder lens might work, mirror position not optimal, needs testing)
    -  18 january         x and y motor work, homing switches work
  • PCBWay sponsors next iteration
    Hexastorm11/27/2024 at 10:10 0 comments
    I'm thrilled to announce that PCBWay is sponsoring the PCBs for my next version of the laser direct imaging head! Their generous support will help me push the boundaries of this exciting technology and create something truly innovative.
    I'm incredibly grateful for their commitment to supporting the open hardware community. Be sure to check out PCBWay for all your PCB needs!
    pcbway - logo - Maker Faire NoVa
  • Hardware Update 2024
    Hexastorm11/07/2024 at 14:55 0 comments
    Update of the hardware of 2024 using AI voice. I plan to test it in December.
  • Render of the polygon mirror motor
    Hexastorm09/06/2024 at 10:02 0 comments
    The laser head, version 0.1, is compatible with a brushless motor. While the PCB motor is also supported, it won't be the default configuration. To accurately visualize the mirror motor, a more detailed render was necessary. The NBC3111 mirror motor and a cad  model in freecad is depicted below. Below a head is shown which supports the prism or mirror which is spinning.
View all 168 project logs
Mehran KORDI wrote 01/13/2025 at 18:49 point
I have been following this project for a few years now. Can't wait to see the end results. Thanks for sharing the journey !
Hexastorm wrote 01/18/2025 at 15:27 point
Nice you are following along.. I have quite a lot of time of the moment... hope I can something working again this month. let's see.
Hexastorm wrote 12/30/2019 at 15:53 point
No it wouldn't work.. you need edges polished, not the top and the bottom.
I am not shipping out prism at the moment as they r not balanced yet (working on this). I am also working on a FPGA toolchain, will post an update on my progress here soon.
Ben Wishoshavich wrote 10/27/2019 at 04:56 point
Can you recommend a specific polygon motor module on alibaba? I don't know if there are any differences and I'd like to order one. THanks!
Hexastorm wrote 10/27/2019 at 13:37 point
Yes, you should buy exactly this motor https://nl.aliexpress.com/item/32824649951.html . It uses the NBC3111 chip. I had problems with other motors. Make sure you buy at least 2, although they are quite hard to break.
Ben Wishoshavich wrote 10/23/2019 at 21:59 point
Dude, this is some pretty awesome work. I'd love to help refine some of the manufacturing and board designs, let me know how I can best help
Hexastorm wrote 10/24/2019 at 17:55 point
Thanks! There are two other people who have shown interest. I need at least 10 people to do a run as I have to buy the prisms in bulk. Turn around time would be significant. Producing the prism takes at least a month.
I am fixing the low hanging fruits at the moment. It is hard to help with these as you don't have a laser head. I am building a new one but there is still only one in the world :-).
Things you could look in to;
- a better alignment system for the laser; this uses four screws and is over dimensioned --> see my free cad design files
- a better alignment system for the cylinder lenses; the screw system is not really comfortable --> see my freecad design files
-  how do i put my state machine on an fpga; I have been looking into https://github.com/m-labs/misoc as a replacer for the beaglebone.
This task seems rather complicated but I guess this knowledge could be really help full. The statemachine now runs on pru of the beaglebone and is limited at around 2 MHz.
- how do i balance the prism; i have done some preliminary experiments but still works needs to be done. You could also try to figure this out with a regular polygon motor. Add an imbalance and try to analyze this.
- the slicer or interpolater can only be run on a computer, as it overflows the ram of the beaglebone https://github.com/hstarmans/ldgraphy/blob/master/interpolator/interpolator.py . Remove this problem, optimize the code.
In the mean time, I am cleaning up the code, building a second head and still have to do more experiments.
I am also waiting for news on the hackaday prize. That's also why I have been quiet on the blog.
Ben Wishoshavich wrote 10/24/2019 at 22:57 point
I'm wondering if there isn't a BLDC motor that could be substituted for the polygon motor, hopefully something that is more available. And then I'd need an encoder. I'll take a look at this, although I suspect going greater than 20k rpm requries air bearings and a custom design.
The rectangular prism does seem to be a challenge. I'll let you worry about that. Out of curiosity, do you know how much it'd cost for a custom order?
An FPGA should be able to handle the state machine. I'm working on the FPGA that's in the Hackaday Superconference badge, and it's got an open toolchain. It might be overkill though. The ICE40 may be better(and cheaper). I might be in the minority in that I'm not sure this is a huge priority, as your electronics are pretty cheap. It's probably a pretty significant time sync to rewrite the assembly for the PRUs into a state machine. I'd probably focus on a command and control system to interact with GCODE or something else.
 I could jump into the MCAD, but I only know Solidworks. I suspect someone else might be better suited for that.
At work, we have specifications for balancing motors for EVs. The most relevant standard is ISO1940. Let me know if that's useful for you. Usually a balancing machine is used to detect vibrations while the part is rotated. They're pretty rare and fairly expensive though. They do make some simple ones for balancing quadcopter props you could look into. Usually you have to add or remove material in a specific spot to make it work.
I already have some of the parts you've used. Perhaps it won't be as hard to duplicate some version of this as I expect.(expect for that lens).
Hexastorm wrote 10/25/2019 at 17:13 point
-  i wouldn't substitute the motors; they have been used in this application for years by a large industry. Rotating polygon mirrors are produced in the tens of thousands. Motors can handle up to 21000 RPM.  This is more than what is needed at the moment, 2400 RPM, as the beaglebone can't go faster.
- custom order is around 500-600$ and MOQ is 10. for the prisms
- Henner zeller wrote a GCODE parser for the beaglebone called beagleg; my idea is that this used and you simply flip the machine between gcode mode and laser writing mode
- never heard of this standard good tip
- all parts are easy to obtain including lenses, motor etc; the only challenge is the prism and time. You will need time :-)
rajhlinux wrote 01/01/2021 at 08:17 point
well you can count me in, i'm interested with this project
Robert Mateja wrote 07/31/2019 at 11:48 point
Congratulations on winning Hackaday Prize 2019!  (at least in my opinion)
Hexastorm wrote 08/01/2019 at 09:30 point
Robert, thank you for supporting me! Winning the prize would be amazing.  My current target is to get other people to try out the technology, I am really trying to make it more accessible. I hope I can show an improved prototype of the scan head soon.
Conny G wrote 05/27/2019 at 12:36 point
What material is the prism made from? How is it manufactured?
Can i make it in my "maker lab"?
Hexastorm wrote 05/29/2019 at 11:39 point
Prism has the following properties; 2 mm thick, 30x30 mm square,  faces 60/40 < 5 arc min, chamfers 0.10 – 0.30mm, edges Polished 60/40, top bottom polished 60/40.   You will have to discuss details with manufacturers in China over Alibaba. I made the first in a maker styled lab, a description of the process is in this log https://hackaday.io/project/21933-open-hardware-fast-high-resolution-laser/log/167433-how-to-be-transparent
Gravis wrote 02/03/2019 at 19:16 point
I'm also interested in the possibility of using a motor from a hard disk drive instead of a breaking down a polygon motor.  HDD motors are cheap to buy and (as I understand it,) contain an encoder and have screw holes which makes affixing things easier.
Hexastorm wrote 02/04/2019 at 08:48 point
HDD seem too slow.  They typically spin at 5400 or 7200 RPM.  At the moment, I can go up to 24000 RPM with polygon motor. For some applications, I would like 50000 RPM or 70.000 RPM, like the roadrunner sold by precision laser scanner. Also the motors are not too expensive, they are like 20 euros. I understand 20 euro's can still be a lot but if you look at total costs; you can better pay attention to other components.
Gravis wrote 02/05/2019 at 06:00 point
Oh, I had no idea you were planning on high speed.  Where can you get the motors in the 20 euros range?
Hexastorm wrote 02/06/2019 at 13:40 point
You can find polygon motors at alibaba (https://www.alibaba.com/showroom/polygon-motor-ricoh.html) .  The system is a proof of concept; for desktop PCB prototyping 2400 RPM is fine. If you plan to compete with Kleo https://www.youtube.com/watch?v=7R464iHaTQU . You will need at least 50K RPM.  An option would be to encase the prism and remove the air. This will reduce the drag. You could also fill the encasing with Helium as it has low drag and a high thermal conductivity.  Like the roadrunner the encasing windows would be tilted out of plane to minimize back reflections, see https://precisionlaserscanning.com/2016/03/road-runner-70000-rpm-polygon-scanner-solves-the-noise-problem/
Gravis wrote 02/03/2019 at 15:57 point
My suggestion for this project is to isolate the scanner from the 3 axis robot part so that the scanner could be made into a tool that can be changed out.  I would also ditch using BB's PRU and instead use a dedicated chip (and maybe a RAM buffer) and connect it via CAN bus.
Hexastorm wrote 02/04/2019 at 08:58 point
I intend to isolate the scanner, and design it for specific machines. I like the idea of having a dedicated chip. In the past I used a FPGA (Xula-LX25) with RAM as  bufffer. I can imagine there are even better options. The problem is that developing a dedicated board costs time, money and a lot of experience. Zeller made a very accessible code for the Beaglebone, so I went with that. You are looking at a proof of concept. It's a technology demonstrator. Anyway if you have recommendations; or some example code; feel free to share.
Gravis wrote 02/05/2019 at 07:48 point
Considering this is a project where accurate timing is vital, I think an XMOS processor (e.g. XS1-L4A) would be a good fit.  Each 100MIPS processing unit is 100% deterministic with fast GPIOs.  I don't know the rate of data throughput you need but it may be easier to just cache to workload on a local FLASH chip than stream it.
Hexastorm wrote 02/05/2019 at 10:53 point
XS1-L4A is nice... but I rather like something with lot of support and examples... probably first gonna optimize the current code and balance my prism.
Gravis wrote 02/05/2019 at 20:37 point
XMOS stuff actually does have lot of support (https://www.xcore.com), examples (https://github.com/xcore/) and even an IDE but I somehow missed the part where you wrote that didn't want to build a custom board.  Sorry about that.  XMOS chips make it easy to glue things together since it's 99% software so it doesn't take too much skill to make a board with them.  Consider enlisting help to make a board as there is a good chance it will alleviate timing related issues.  Good luck! :)
rajhlinux wrote 01/03/2021 at 13:24 point
This is a good idea, but honestly I think the best thing is to focus on getting the precision as perfect as possible. There's no consumer grade PCB maker device that can give traces/spaces resolution down to 0.01mm. It's crazy we are still using tonner transfer and UV exposure. I'm planning to build a CNC gantry made from granite, magnetic actuators and air bearings to get the most accurate, friction free, repeatable long term PCB manufacturing with >0.7 traces and spaces. But yes, would be nice down the road to have the scanner head removed for another tool... but for now precision is priority. Precision & Resolution is the reason why this project brings my interest and everyone here.
Paul wrote 11/05/2017 at 03:49 point
You've certainly done your homework very thoroughly, and I see that in your application with very small optical cone angles (large focal ratio), the optical aberrations and field curvature appear to be tolerable.  That's great.
One question: You say that previous scan techniques require a large (and therefore expensive, you argue) f-theta lens, which must have one dimension at least as wide as the scan line.  In your approach, your polygons must be larger than the scan line length, but in *two* dimensions, making the volume of your optical element much larger.  Since either shape would use identical materials and fabrication processes in volume production (i.e. injection molding), one would naively expect the smaller element (the f-theta lens) to be cheaper.   How is this line of reasoning flawed?
Hexastorm wrote 11/05/2017 at 10:51 point
A telecentric f-theta lens requires one dimension at least as wide as the scan line. A non-telecentric f-theta lens does not require that.  In my approach, the polygon must have one dimension longer than the scan line. The second dimension is 2 mm. An f-theta lens consists out of multiple lens elements, e.g. a 3 element f-theta lens. These elements have curved surfaces. The prism consists out of a single element with a flat surface. You can't make the f-theta lens out of plastic, so you would have to injection mold quartz. I am unfamiliar with the prizes for that. Besides most likely a higher price and the fact you have to use multiple elements, you also need to worry about patents. Envisiontec patented the usage of reflective polygons; US 9079355 B2 . Finally, you need a thick reflective polygon as thick polygons can deflect collimated bundles with a large diameter and these can be focused to smaller spots.  A transparent prism uses a focused bundle and therefore typically can be thinner, which keeps the price of the bearing lower.
Paul wrote 11/05/2017 at 15:55 point
You have clearly thought about this a great deal, and have your arguments worked out well.
I wasn't considering that you might be requiring quartz.  I would have guessed even BK7 would be overkill for this application.
I mention injection molding because I look around my offices and see several laser printers.  Each of them contain a laser scanning unit with a rotating (reflective) polygon and a f-theta lens arrangement, with the final element being very large (>200 mm long).  All the optical elements of the ones I have inspected appear to be injection-molded PMMA or similar plastic.  The entire laser scanning unit must cost considerably less than $50, given the prices of the printers (all less than $200, two less than $70).  Granted, these are produced in huge volumes, but they serve as existence proof that these scanning systems with large optical elements are not intrinsically costly.
Hexastorm wrote 11/05/2017 at 16:52 point
PMMA absorbs light at 405 nm. The laser printers at your office use 800 nm and low power lasers. I use 405 nm and high power lasers. So yes; there is concrete proof that PMMA injection molded systems are not intrinsically costly. There is no proof that quartz systems are not intrinsically costly.  It's unclear what the prices of these systems would be .
Paul wrote 11/03/2017 at 13:21 point
A good variation on the usual way.  I build a few instruments based on this and similar methods between 1985-1989.  A couple of important notes:
1. The scanned field is NOT flat: The optical distance to the target plane *increases* as the polygon rotates away from normal.  Not only is it geometrically longer, some of the increased  path length is in the high-index polygon too, increasing the path length even more.  The result is a curved focal or scan plane.  One of my instruments actually depended on this: a rotating polygon was used to tune the optical path length inside an optical resonator cavity, to adjust a tunable laser that was phase-locked to that cavity.
2. You get some significant spherical aberration when you focus through a thick window like that, for similar reasons: the light rays at the periphery of the optical cone take a longer path to the target plane than rays going through the middle of the cone, with the result that they focus at a different depth.  For a laser at f/50 (or whatever it is), this probably isn't significant, but in an imaging system at f/2, it seriously degrades focus.
Hexastorm wrote 11/04/2017 at 22:09 point
Paul, thank you for your reply!
A transparent polygon scanner with a single laser bundle was first patented by Lindberg in 1962.  The scan field is not flat and you can get some significant optical aberrations. A full numerical model is available here https://github.com/hexastorm/opticaldesign . A description of this model is available in the technical presentation. The result shows that in practice the scan field is flat and the optical aberrations are not significant for the current spot size and line length.
Hexastorm wrote 11/03/2017 at 11:58 point
Well this is the first comment! If Hackers are interested in transparent polygon scanning let me know :P ..
