Project goal: create an easy method to build the actuator with multiple strands of wire.
A similar project was undertaken at McGill 20 years ago http://www.cim.mcgill.ca/~grant/sma.html.
A shape memory alloy actuator that can move useful loads over decent distances.
What about for short distances? Do you think you could get a decent resolution (~micron) if you could control the temperature relatively precisely?
