SD Card Reader
05/19/2022 at 06:16 • 0 commentsThe SD card reader is a lightweight and compact base device. To connect successfully and begin using it, simply insert the SD card into the SD card reader in the correct direction. Some SD card readers require you to insert the SD card upside down. The device is then connected to another electronic terminal (such as a laptop) to view the files on the SD card.
The card reader is similar to a computer's USB floppy drive; the only difference is that the card reader can read a variety of flash memory cards, whereas the USB floppy drive can only read floppy disks.
the Motion Sensor
05/12/2022 at 03:53 • 0 commentsA motion sensor, also known as a motion detector, is an electronic device that detects nearby humans or objects using sensors. Motion sensors, unlike many other types of sensors, are typically embedded systems comprised of three major components: a sensor unit, an embedded computer, and hardware (or consisting of mechanical components). When the motion sensor detects a moving object, the system performs data analysis and data comparison and sends an alarm message to your mobile device via the Internet, letting you know right away if there is a security issue in the detection area. Furthermore, if you subscribe to a merchant's monitoring service, you can set up motion sensors to send alerts to the monitoring team automatically.
MMBT2222ALT1G General Purpose Transistor
05/09/2022 at 02:04 • 0 commentsWhat is the difference between PNP and NPN transistors?
A positive voltage is applied to an NPN transistor's collector terminal to cause current to flow from the collector to the emitter. A positive voltage is applied to the PNP transistor's emitter terminal to cause current to flow from the emitter to the collector.
In everyday life, what is the function of a transistor?
Transistors can be found in almost any electronic device, from stoves to computers, pacemakers to airplanes. 9. The military used the transistor's high-power radio frequency (RF) capabilities in radar and hand-held two-way radios. -
Three Prong Plug
04/29/2022 at 07:39 • 0 comments![]()
Why is there a third prong on an electrical plug? In case you didn't know, the ground connector is located on the third prong of a plug. It is circular in shape and sits beneath the two blade-style plug protrusions. It's a must-have for outdoor extension cords and any device that isn't completely shielded. Consider it an emergency route for electricity to take if an electrical device experiences a short circuit or other fault.
CA3046 Bulkhead Cable
04/21/2022 at 09:18 • 0 commentsThe LCCA30465-FT10 from L-com is a BNC female to TNC female bulkhead cable assembly with 10 FT of LC141TB coax that ships same-day. The PTFE dielectric is used in the LC141TB coax of this BNC cable, which has a VoP of 69.5 percent. Because they can be hand formed to fit specific designs, these formable RF cable assemblies are a great alternative to expensive semi-rigid assemblies. Our L-com BNC to TNC cable assembly has a female to female gender configuration and operates up to 2 GHz using formable LC141TB series coax.
Waveform Generator ICL8038
04/09/2022 at 03:01 • 0 comments![]()
The ICL8038 waveform generator is a monolithic integrated circuit that can generate high-accuracy sine, square, triangular, sawtooth, and pulse waveforms with very few external components. External resistors or capacitors can be used to adjust the frequency (or repetition rate) from 0.001Hz to more than 300kHz, and an external voltage can be used to modulate and sweep the frequency. The output of the ICL8038 is stable over a wide range of temperature and supply variations, thanks to advanced monolithic technology that includes Schottky barrier diodes and thin film resistors. Temperature drift of less than 250ppm/oC can be achieved by combining these devices with phase locked loop circuitry.
BAT17 Schottky Barrier Diode
03/14/2022 at 09:19 • 0 commentsBAT17 Schottky Barrier Diode:bat17 diode
FEATURES
- Low forward voltage
- Small SMD package
- Low capacitance.
AD8606 Operational Amplifier
03/07/2022 at 10:04 • 0 commentsThe AD8605, AD8606, and AD86081 are single-supply, rail-to-rail input and output amplifiers with single, dual, or quad rails. They have a very low offset voltage, a low input voltage and current noise, and a broad signal bandwidth. They use the patented DigiTrim® trimming technique developed by Analog Devices, Inc., which achieves superior precision without the use of lasers.
These amplifiers' low offsets, low noise, very low input bias currents, and high speed make them useful in a wide range of applications. The combination of performance features benefits filters, integrators, photodiode amplifiers, and high impedance sensors. The wide bandwidth and low distortion benefit audio and other ac applications. Optical control loops, portable and loop-powered instrumentation, and audio amplification for portable devices are all applications for these amplifiers.
LMC6482 Operational Amplifier
02/12/2022 at 04:02 • 0 commentsThe LMC6482 device has a common-mode range that includes both supply rails. This device's rail-to-rail performance, combined with excellent accuracy due to a high CMRR, distinguishes it among rail-to-rail input amplifiers. The device is an excellent choice for systems requiring a wide input signal range, such as data acquisition. The LMC6482 is also an excellent upgrade for circuits that use TLC272 and TLC277 limited common-mode range amplifiers.
The rail-to-rail output swing of the LMC6482 provides maximum dynamic signal range in low voltage and single supply systems. For loads as low as 600, the rail-to-rail output swing is maintained. The LMC6482 is an excellent choice for battery-powered systems due to its specified low-voltage characteristics and low power dissipation.
Difference Between CR2016 Battery and CR2032 Battery
01/27/2022 at 07:23 • 1 commentCR2032 batteries and CR2016 batteries that are round, flat, and resemble small silver buttons can appear to be the same at times. Can they be used universally because they all look the same?
Stop! Wait a second!
Although the CR2032 and CR2016 batteries are similar, there are DIFFERENCES in battery thickness and capacity. As a result, we can't just use the two batteries.
If you make an error by accident, you will have to place a new order to purchase it lol. So, to clarify the difference between a CR2032 battery and a CR2016 battery, and to avoid being confused by their similar appearance when purchasing the battery, read the following.
MIC2026-1YM-TR High-Side MOSFET Switch
12/23/2021 at 08:44 • 0 commentsThe MIC2026 and MIC2076 are high-side MOSFET switches that are optimized for general-purpose power distribution with circuit protection. The MIC2026/76 have an internal current limit and a thermal shutdown to protect the device and load. The MIC2076 includes "smart" thermal shutdown, which reduces current consumption during fault modes. When there is a thermal shutdown fault, the output is latched off until the faulty load is removed. The device output is reset when the load is removed or the enable input is toggled. Both devices use soft-start circuitry to reduce inrush current in applications with highly capacitive loads.
DRV8301DCAR Controller
12/15/2021 at 10:04 • 0 commentsThe DRV8301is a gate driver integrated circuit designed for three-phase motor drive applications. The device includes three half-bridge drivers, each of which can drive two Nchannel MOSFETs. The DRV8301 has a source current capability of up to 1.7 A and a peak current capability of 2.3 A. The DRV8301 can be powered by a single power supply ranging from 6-V to 60-V. To support 100 percent duty cycle, the device employs a bootstrap gate driver architecture with trickle charge circuitry. To prevent current flow, the DRV8301 employs automatic handshaking when the high-side or low-side MOSFET switches. To protect the external power stage from overcurrent conditions, integrated VDS sensing of the high-side and low-side MOSFETs is used.
For accurate current measurement, the DRV8301 includes two current shunt amplifiers. The amplifiers support bidirectional current sensing and have an output offset of up to 3 V that can be adjusted.
DMM6500 Digital Multimeter
12/01/2021 at 09:40 • 0 comments![]()
The DMM6500 is a modern bench/system DMM that provides more measurement functionality, best-in-class measurement insight, and a low price. The DMM6500's most distinguishing feature is its large 5-inch (12.7 cm) capacitive touch screen display, which allows users to observe, interact with, and explore measurements with 'pinch and zoom' ease. Aside from its display technology, the DMM 6500 superior analog measurement performance provides 25 PPM basic DCV accuracy for one year and 30 PPM basic DCV accuracy for two years, potentially allowing you to extend your calibration cycles.
BME280 Sensor
11/29/2021 at 09:33 • 0 comments![]()
The BME280 is a digital humidity, pressure, and temperature sensor that is based on well-established sensing principles. The sensor module is housed in a metal-lid LGA package with a footprint of 2.5 2.5 mm2 and a height of 0.93 mm. Because of its small size and low power consumption, it can be used in battery-powered devices such as handsets, GPS modules, and watches. The BME280 digital pressure sensor is register and performance compatible with the Bosch Sensortec BMP280 digital pressure sensor.
CPC1017NTR Solid State Relay
11/02/2021 at 04:01 • 0 commentsThe CPC1017N is a 4-pin SOP miniature single-pole, normally-open (1-Form-A) solid state relay with optically coupled MOSFET technology that provides 1500Vrms of input to output isolation. The super-efficient MOSFET switches and photovoltaic die are powered by IXYS Integrated Circuits Division's patented OptoMOS architecture, and the optically coupled output is controlled by a high-efficiency infrared LED. CPC1017N is one of the world's smallest relays thanks to IXYS Integrated Circuits Division's cutting-edge double-molded vertical construction packaging. It saves at least 20% more board space than the competitor's larger 4-pin SOP relay.
Now you can go for a look to learn more about the CPC1017NTR Solid State Relay
if you have more ideas , please let me know
CY7C68013A USB Microcontroller
09/13/2021 at 09:30 • 0 comments![]()
USB Signaling Speed FX2LP operates at two of the three rates defined in the USB Specification Revision 2.0, dated April 27, 2000:
■ Full speed, with a signaling bit rate of 12 Mbps
■ High speed, with a signaling bit rate of 480 Mbps FX2LP does not support the low speed signaling mode of 1.5 Mbps.
8051 Microprocessor The 8051 microprocessor embedded in the FX2LP family has 256 bytes of register RAM, an expanded interrupt system, three timer/counters, and two USARTs.
To get more ideas, you can check this article:CY7C68013A USB Microcontroller:Datasheet,Features and Block Diagram
Introduction to Tire Pressure Sensors
08/31/2021 at 09:29 • 0 comments![]()
With the advancement of automobile technology, an increasing number of cars are equipped with car tire pressure monitoring systems, which provide us with a quick and real-time understanding of the car tire pressure, and we no longer have to worry about insufficient and excessive tire pressure before driving, and the car tire pressure monitoring system has brought great convenience to our car. Currently, most car tires are equipped with pressure sensors to detect pressure changes in order to ensure the safety of car driving. According to relevant statistics, tire pressure reaches a reasonable value, which can not only improve driving safety but also reduce fuel consumption. So, how does a car tire pressure sensor work? This article will introduce in detail...
If you want to learn more about the tire pressure sensors,please read this article:
https://www.apogeeweb.net/electron/operating-principle-of-tire-pressure-sensors.html
