There is a new board with PD3.1 EPR 28 V 5A:
https://hackaday.io/project/205857-usb-c-pd-31-epr-power-delivery-sink-ap33771c
This board has the goal to replace random power adapters with a standardized way to use a USB-C power delivery (USB PD) adapter instead. For regular operation, no programming or software configuration is involved with this design. All options are set through the switches or resistor values. If needed an I2C interface to a microcontroller is available, to access status and control registers. This part of the board is separated through a break-off tab (mouse bites) and can be snapped off. I made the conscious design decision to not add a USB-A connector option at the output end. I did not want to build a device, that is capable of putting more than 5V on the VBUS pin of a regular USB cable and potentially destroy the device that is plugged in. A heatshrink tube can protect the board in a permanent installation.
This is a set and forget device. Set your current and voltage needs before plugging the device to your USB-PD source and enjoy the power at the output. This is not a power supply to change voltage and current during operation.
All Features:
- USB-C PD Power Delivery PD Sink Decoy / Trigger
- Selector switch S1 for 5V, 9V, 15V (12V with solder bridge), or 20V
- Selector switch S2 for 1A, 2A, 3A, or 5A
- Max current 5A, settable in 250mA steps through resistor options
- Red LED to indicate failed power request
- I2C telemetry interface to controller chip
- Snap off option for telemetry interface
- For fixed voltage, the switch can be replaced by wire jumper
- Small form factor to be heat shrinked as part of the power cable
- Size 53mm x 15.4mm (without telemetry interface)
- Height 12mm with screw terminal and switch, 6mm without.
- 3" (7.5cm) heatshrink tube for protected installation
- 2oz copper to safely handle 5A
- Lead free assembly
MagicWolfi
CentyLab
Brian Lough
jeremy.geppert
Martin
Hi Wolfgang, Is there a way to ask a power supply for 14.6V, the ideal charging voltage for many LiFePO4 batteries. Your current limits of 2, 3, 4 and 6A are perfect for that application.
