Extended SRAM Test
04/29/2022 at 14:04 • 0 commentsThe RETRO-EP4CE15 card has 1MB of SRAM on the card. The SRAM is in (2) 8KB windows with 64 banks in each window.
I wrote a test routine that writes ramp values to the SRAM and verifies it works.
The test program prints:
S0++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++D
Where:
- S = start
- 0/1 = block number
- + = block good
- X = bad
- D = done
Hit a key at end to avoid resetting the Serial port until done.
Jumps back to SmithBUG when done.
Takes ~2 secs to run with 25MHz ROM/Internal SRAM and 16.7 MHz for External SRAM.
Assembled using A68 assembler
"..\..\A68 6800 Assembler\a68.exe" XRAMTEST.ASM -l XRAMTEST.LST -s XRAMTEST.SRE
Memory Map
- 0xA000-0xBFFF - 512KB External SRAM
- 8KB Windows, 64 frames
- MMU0 provides additional address bit
- MMU0 initialized to 0
- 0xC000-0xDFFF - 512KB External SRAM
- 8KB Window, 64 frames
- MMU2 provides additional address bits
- MMU2 initialized to 0
- 0xFC30 - MMU0 Latch 6-bits
- 0xFC31 - MMU1 Latch 6-bits
FigForth Built-In Words
04/27/2022 at 18:29 • 0 commentsTASK FORTH NOOP VLIST TRIAD INDEX LIST ? . D.
D.R .R #S # SIGN #> <#
SPACES WHILE ELSE IF REPEAT AGAIN END UNTIL
+LOOP LOOP DO THEN ENDIF BEGIN
BACK FORGET ' R/W HI LO BLOCK_READ BLOCK_WRITE
?DISC --> LOAD MESSAGE .LINE (LINE) BLOCK BUFFER
DR1 DR0 EMPTY-BUFFERS UPDATE +BUF PREV USE DABS
ABS M/MOD
*/ */MOD MOD / /MOD * S->D COLD ABORT QUIT
( DEFINITIONS VOCABULARY IMMEDIATE INTERPRET DLITERAL
LITERAL [COMPILE] CREATE ID. ERROR (ABORT) -FIND
NUMBER (NUMBER)
LABD______________ PAD HOLD BLANKS ERASE FILL
QUERY EXPECT ?STACK ." (.") -TRAILING
TYPE COUNT DOES> <BUILDS ;CODE (:CODE) DECIMAL
HEX SMUDGE ] [ COMPILE ?LOADING
?CSP ?PAIRS ?EXEC ?COMP ?ERROR !CSP PFA NFA
CFA LFA LATEST TRAVERSE -DUP MAX
MIN SPACE ROT > < = - C, , ALLOT HERE 2+ 1+COLUMNS HLD R# CSP FLD
DPL BASE STATE CURRENT CONTEXT OFFSET SCR
OUT IN BLK VOC-LINK DP FENCE WARNING
WIDTH TIB R0 S0 +ORIGIN B/SCR B/BUF LIMIT FIRSTBL 3 2 1 0 USER VARIABLE
CONSTANT ; : C! ! C@ @ TOGGLE +! DUP SWAP
DROP OVER DMINUS MINUS D+ +
0< 0= R R> >R LEAVE ;S RP! SP! SP@ XOR OR
AND U/ U* CMOVE CR ?TERMINAL
KEY EMIT ENCLOSE (FIND) DIGIT I (DO) (+LOOP)
(LOOP) 0BRANCH BRANCH EXECUTE LIT OK
figFORTH in ROM
04/27/2022 at 14:55 • 0 commentsReplace SmithBUG with FigForth ROM
figFORTH can be loaded into ROM in the build instead of the SmithBUG ROM. The reset vector has to point to the FigForth COLD Start.
Memory Map
0x0000-0x0FFF - 4KB SRAM 0x1000-0x2FFF - 6K ROM (using 8KB entity, but only using 6KB) 0x3000-0x3FFF - 4KB SRAM 0x4000-0x7FFF - 16KB SRAM 0xFC00-0xFCFF - I/O Space 0xFFFE-0xFFFF - ROM start vector (physically top of the 8KB ROM)
Assemble
Assemble fig-Forth code using A68 Assembler.
"..\..\A68 6800 Assembler\a68.exe" fig-FORTH_6800.asm -l fig-FORTH_6800.lst -s fig-FORTH_6800.s
Manually delete top lines in S record file. After deleting, top lines should be:
S1131000017E1FA3017E1FD3680000000000007F43 S113101001000F300FFE0F30001F00000183018319
This matches the source:
1000 01 ORIG nop 1001 7e 1f a3 jmp CENT ;************************** ;* W A R M E N T R Y ** ;************************** 1004 01 nop 1005 7e 1f d3 jmp WENT ;warm-sta a rt code, keeps current dictionary intactUse srec_cat to shift addresses down and make Hex file:
srec_cat fig-FORTH_6800.s -offset - -minimum-addr fig-FORTH_6800.s -o fig-FORTH_6800.hex -Intel
Clone FPGA Folder
Archived M6800_MIKBUG_20220427.qar the project as it currently is since it's working well, as-is. Put into new folder and set new entity name (M6800_figForth). Tested as-is and it built/worked.
Update FPGA Entity
Bunch of stuff to do.
- Set up memories
- Add address selects
w_SRAMAdr_1 <= '1' when w_cpuAddress(15 downto 12) = x"0" else '0'; w_SRAMAdr_2 <= '1' when w_cpuAddress(15 downto 12) = x"3" else '0'; w_SRAMAdr_3 <= '1' when w_cpuAddress(15 downto 14) = "01" else '0'; w_ROMAdr <= '1' when w_cpuAddress(15 downto 12) = x"1" else '1' when w_cpuAddress(15 downto 12) = x"2" else '0';- Add SRAM entities (2 of 4KB, 1 of 16KB SRAM blocks from Common VHDL folder)
- No output q latch
- Add 8KB FigForth ROM entity
- No output q latch
- Add reset vector "manually" to read data multiplexer (0xFFFE-0xFFFF = 0x1000)
-- ____________________________________________________________________________________ -- CPU Read Data multiplexer w_cpuDataIn <= io_extSRamData when w_extSRAM = '1' else -- External SRAM (0xA000-0xDFFF) ... x"10" when w_cpuAddress = x"FFFE" else -- Reset vector Upper ($1000) x"00" when w_cpuAddress = x"FFFF" else -- Reset vector Lower w_romData when w_ROMAdr = '1' else -- ROM
Create FPGA .jic file and Download
Runs!!!
Saved M6800_FigForth_20220427.qar archive file.
Issues
Output looks good on Serial port, but tabbed? over in VDU.
- Set up memories
FigFORTH Running
04/26/2022 at 19:22 • 0 commentsPorted figFORTH to the card. It runs. Banner is Forth-68.
Running
Type J 0100 to run.
Sources
Required a bit of tweeking the assembly code so that it would assemble using A68.
Ported Source is here.
Original Source is here.
Front Panel for 6800 CPU
04/22/2022 at 15:44 • 0 comments -
04/22/2022 at 15:41 • 0 comments -
SmithBug at 0xF000
04/22/2022 at 15:30 • 0 commentsNotes on SmithBug at 0xF000
- SmithBug is a variant of MIKBUG
- Updated by Herb Johnson to add S Record loader
- 60KB SRAM variant
- Supports much smaller SRAM sizes but requires scratchpad SRAM if ther is less than 60KB of SRAM
- Scratchpad RAM has to be at 0xEF00-0xEFFF (minimum 256 bytes)
SmithBug Memory Map
- 0x0000-0x7FFF - 32KB Internal SRAM
- 0XEC00-0xEFFF - 1KB Internal SRAM (SCRATCHPAD SRAM USED BY MIKBUG)
- 0xFC18-0xFC19 - VDU (serSelect J3 JUMPER REMOVED)
- 0xFC28-0xFC19 - ACIA (serSelect J3 JUMPER installed)
- 0xFC30-0xFC3F - Front Panel
- 0xF000-0xFFFF - MIKBUG (Actually SMITHBUG) ROM
Hardware
- Tested/runs on all MultiComp based designs
- SRAM accesses run at 25 MHz on Internal SRAM
- Different FPGAs can support more of less internal SRAM
- EP2C5 FPGA supports 3KB internal SRAM
- EP4CE15 FPGA supports 32KB internal SRAM
- Cyclone V FPGA supports 60KB internal SRAM
- External SRAM works on all MultiComp based designs and supports 60KB SRAM
- SRAM accesses run at 16.6 MHz on External SRAM
Commands
Build Instructions
- Creates .hex file load load in Quartus II
..\a68 DGG_MIKBUG.ASM -l DGG_MIKBUG.LST -s DGG_MIKBUG.s ..\srec_cat DGG_MIKBUG.s -offset - -minimum-addr DGG_MIKBUG.s -o DGG_MIKBUG.hex -Intel
Links
04/20/2022 at 14:07 • 0 comments -
Minimal Build
06/26/2021 at 14:24 • 0 commentsPut together a minimal build which runs in the EP2C5 FPGA. It does not use any external SRAM. The features are:
-- MC6800 CPU -- Running MIKBUG from back in the day (SmithBug ACIA version) -- 25 MHz -- 4K (internal) RAM version -- MC6850 ACIA UART -- VDU -- XGA 80x25 ANSI character display -- PS/2 keyboard -- SD Card -- Not used -- Included in pin list with inactive levels (in case a card is installed) -- -- The Memory Map is: -- $0000-$0DFF - 3.5KB SRAM (internal RAM in the EPCE15) -- $7E00-$7FFF - 512B SRAM (internal RAM in the EPCE15) -- $7F00-$7FFF are used as scratchpad RAM by MIKBUG -- $7E00-$7EFF can be used by application program -- $8018-$8019 - VDU -- $8028-$8029 - ACIA -- i_SerSelect (Pin_60 of the FPGA) swaps addresses of VDU and ACIA port (requires pullup in FPGA) -- Installed (Pin_60 to Ground) uses Serial port -- $C000-$FFFF - MIKBUG ROM (repeats 4 times from $C000-$FFFF)
It works. It's a good baseline for starting a larger build.
Speeding Up the CPU
06/02/2021 at 10:17 • 0 commentsI was running the CPU at 12.5 MHz. Speeding up the CPU will requires some attention due to the external SRAM speed. The RETRO-EP4CE15 Card uses a 1MB 45 nS SRAM, the IS62WV10248EBLL-45TLI.
The critical timing is the write enable strobe:
The FPGA clock is 50 MHz or 20 nS per clock. Asserting the Write Enable (WE*) for 2 clocks works for the 45 nS parts that are used. 55 nS parts would be marginal but probably would work fine.
Write Enable should only be asserted while the CPU clock is high so it gets gated with the clock. Note, the logic shown here is inverted, eg, the signal goes high when the active low write enable is NOT asserted.
o_n_extSRamWE <= w_n_SRAMCE or w_R1W0 or (not w_vma) or (w_cpuClock);This all says we can run the CPU clock at 16.67 Mhz with one 20 nS clock low and 2 clocks high.
The VHDL code for the CPU clock is:
-- ____________________________________________________________________________________ -- CPU Clock -- Need 2 clocks high for externl SRAM can get by with 1 clock low -- Produces a 40 nS wide wriye strobe - 45 nS SRAMs need a 35 nS write pulse, so this works process (i_CLOCK_50) begin if rising_edge(i_CLOCK_50) then if q_cpuClkCount < 2 then -- 50 MHz / 3 = 16.7 end if; if q_cpuClkCount < 1 then -- 2 clocks high, one low w_cpuClock <= '0'; else w_cpuClock <= '1'; end if; end if; end process;And it works!
25 MHz CPU Speed Upgrade
It could be possible to run faster by only stretching the CPU clock high width when the external SRAM is accessed. This way the CPU would run at 25 MHz when running from Internal SRAM and only drop to 16.7 Mhz for external SRAM accesses The change to the clock generator is fairly minor:
-- ____________________________________________________________________________________ -- CPU Clock -- Need 2 clocks high for externl SRAM can get by with 1 clock low -- Produces a 40 nS wide wriye strobe - 45 nS SRAMs need a 35 nS write pulse, so this works process (i_CLOCK_50, w_n_SRAMCE) begin if rising_edge(i_CLOCK_50) then if w_n_SRAMCE = '0' then if q_cpuClkCount < 2 then -- 50 MHz / 3 = 16.7 q_cpuClkCount <= q_cpuClkCount + 1; else q_cpuClkCount <= (others=>'0'); end if; else if q_cpuClkCount < 1 then -- 50 MHz / 2 = 25 q_cpuClkCount <= q_cpuClkCount + 1; else q_cpuClkCount <= (others=>'0'); end if; end if; if q_cpuClkCount < 1 then -- 2 clocks high, one low w_cpuClock <= '0'; else w_cpuClock <= '1'; end if; end if; end process;That worked, too!
land-boards.com
