Mackerel-68k Linux SBCs
A series of m68k-based single-board computers built to run Linux
Mackerel is a series of single-board computers based on the Motorola 68k CPU family. The goal of this project is to build SBCs capable of running Linux based on several of the key CPUs in the lineup, specifically the 68008, 68010, 68030, and 68040.
Mackerel-08
This SBC combines the 52-pin PLCC MC68008, a 512KB EEPROM, 3.5MB of SRAM, and a XR68C681 DUART on a single PCB. The DUART provides two serial ports and three bit-banged SPI connections. One of these connections is used with an SD card breakout board to act as permanent storage for the system.
Mackerel-10
Mackerel-10 is the second phase of the project, It expands the design of Mackerel-08 with a 68010 CPU and 16-bit databus. Additionally, it increases the memory capacity with a DRAM controller implemented in a CPLD and up to 16 MB of 30-pin DRAM. The onboard IDE header allows a real hard drive or SD-to-IDE adapter to be used as a block device in uClinux.
Mackerel-30
The first iteration with a 32-bit external bus, Mackerel-30 is built around the 68030 CPU running at 24 MHz. The DRAM controller from Mackerel-10 has been upgraded to support 72-pin SIMMs, allowing up to 128 MB of DRAM. It also includes the MC68882 FPU and it has a modern Linux port (kernel v6.17) with support for virtual memory.
mackerel-10-v1.2-RELEASE.zip
Mackerel-10 v1.2 - Schematic, Gerbers, Firmware, PLD files
Zip Archive - 1.40 MB - 12/12/2024 at 16:33
Download
mackerel-08-v1.1-RELEASE.zip
Mackerel-08 v1.1 - Schematic, Gerbers, Firmware, PLD files
Zip Archive - 2.32 MB - 12/12/2024 at 16:33
Download
  • Linux 6.17 On Mackerel-30
    Colin Maykish10/17/2025 at 05:16 2 comments
    After a long battle with toolchains, head.S, and a serial driver, Mackerel-30 now boots Linux kernel 6.17 (the latest release at the time of writing) and hands control over to an interactive Toybox shell. A minimal system for sure, but a fully functional, standalone, and modern Linux installation on an almost 40 year-old CPU. I'm feeling pretty good about this accomplishment. Here's a rough outline of how I got here.
    The first hurdle is setting up a toolchain. Unlike with Mackerel-08 and Mackerel-10, I didn't have the advantage of a complete build system with precompiled toolchain like the one provided by uClinux. Every piece had to be put together manually. I settled on using crosstools-ng to assist in the toolchain setup. Like the Linux kernel itself, crosstools-ng still supports the m68k architecture. It took a lot of trial and error (and many objdumps), but I settled on a toolchain consisting of gcc 15, binutils 2.45, and musl as the C library. The most painful part of this step was figuring out the right combination of crosstools config settings and CFLAGs to get a binary that contained only 68030-supported instructions and no FPU instructions (my FPU is still disabled).
    With a functioning toolchain, I could compile the kernel. I started working my way through early kernel boot code, methodically placing putc calls all over the head.S assembly file. I spent what felt like too much time trying to coerce Linux to work with my memory map until I gave up and adjusted the address decoding on the CPLD to align with the Linux m68k expectations, removing the SRAM chip entirely and remapping the 128 MB of DRAM to 0x00000000-0x7FFFFFFF. The MMU was set up to pass these physical addresses to the same virtual addresses. Mackerel-30 had finally reached start_kernel().
    Optimistically, the hard part was now over - the kernel was booting and I had output coming through the early console. I had to write a proper serial driver for the XR68C681 DUART, move the timer interrupt duty to the CPLD, and debug a few minor issues, but before too long, Mackerel-30 was making the jump to userspace. This event was anticlimactic as there wasn't one.
    There are a million options when it comes to building a userspace and it's where a lot of the fun of building a Linux system happens. With a modern kernel, MMU support, and working console I/O, the possibilities are endless, but it's best to start simple. I chose a barebones root filesystem populated almost exclusively by a single Toybox binary and a few symlinks. Toybox can act as the init system as well as the interactive shell with a handful of useful commands. I used cpio to pack this barebones filesystem into an initramfs and bundled it with the kernel image. Mackerel-30 is now a complete Linux system:
    $ hostname
    mackerel
    $ uname -a
    Linux mackerel 6.17.1-multi-00013-g4a905c110481-dirty #5 Thu Oct 16 18:39:30 EDT 2025 m68k Toybox
    $ cat /proc/cpuinfo
    CPU: 68030
    MMU: 68030
    FPU: none(soft float)
    Clocking: 8.1MHz
    BogoMips: 2.04
    Calibration: 10240 loops
    $ free -h
         total used free shared buffers
    Mem: 123M 4.1M 119M 736K 0
    -/+ buffers/cache: 4.1M 119M
    Swap: 0 0 0
    $ mount
    rootfs on / type rootfs (rw,size=62652k,nr_inodes=15663)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=62652k,nr_inodes=15663,mode=755)
    proc on /proc type proc (rw,relatime)
    sysfs on /sys type sysfs (rw,relatime)
    Next up is a lot of cleanup. There were definite corners cut in the bring-up process and now is a good time to revisit some of the dirtier hacks before I forget everything and move on.
    On the top of the todo list is an IDE driver. I implemented a crude PIO-based driver on Mackerel-10 and that's working well enough, but it relies on an older driver interface. I think there are more modern examples to explore on Mackerel-30. Either way, permanent storage unlocks a lot of functionality and gives me the option to boot from a real drive instead of a temporary RAM-based filesystem.
    I'd also like to finish bringing up the...
  • 128MB Ought To Be Enough For Anybody
    Colin Maykish01/04/2025 at 17:59 4 comments
    I was a bit premature in declaring the DRAM controller for Mackerel-30 complete. It was minimally functional as an 8-bit wide memory, but failed for any multi-byte or offset bus cycles. Implementing these wider memory cycles correctly requires some additional logic in the controller to correctly select the CAS lines for all possible bus cycle types.
    On 72-pin SIMMs, there are four RAS lines and four CAS lines. Asserting a pair of RAS lines (0,2 or 1,3) selects between the two "sides" of the SIMM in the case of double-sided SIMMs (Note: these sides refer to how the DRAM chips are wired electrically, not necessarily how they are physically soldered to the PCB). Each of the CAS lines acts like a byte-select pin for the four bytes in the 32-bit wide SIMM. The trick to getting the correct bytes from DRAM onto the data bus requires decoding the SIZ0, SIZ1, A0, and A1 pins from the CPU into the right combination of CAS signals for the SIMM.
    Top to bottom: 8 MB, 32 MB, 64 MB, and 128 MB SIMMs. The 64 MB SIMM is electrically single-sided (i.e. one-rank), the others are all electrically double-sided (i.e. two-rank).
    Fortunately, the MC68030 datasheet covers all of this in detail.
    These two tables show how the SIZ0 and SIZ1 pins can be used to determine the requested bus width and how the A0 and A1 pins are used to set an offset if the request is not long word-aligned.
    This huge table displays all possible combinations of bus width and offset and shows where the data is expected to be in each case. Since the DRAM always acts as a 32-bit wide memory, each of the entries in the Long-Word Port column map to a combination of CAS lines. For example, if the CPU requests a 16-bit word with an offset of 1 (row 6), the second and third bytes of the DRAM need to be read, so the CAS pattern is 0110 (active high).
    The easiest way to translate this information into Verilog for the DRAM controller is with a case statement:
    wire [3:0] CYCLE_TYPE = {SIZ1, SIZ0, ADDR[1], ADDR[0]};
    reg [3:0] CAS;    // active high
    always @(*) begin
        case (CYCLE_TYPE)
            // CYCLE TYPE <= CAS[3:0]
            // byte
            4'b0100: CAS <= 4'b1000;
            4'b0101: CAS <= 4'b0100;
            4'b0110: CAS <= 4'b0010;
            4'b0111: CAS <= 4'b0001;
            // word
            4'b1000: CAS <= 4'b1100;
            4'b1001: CAS <= 4'b0110;
            4'b1010: CAS <= 4'b0011;
            4'b1011: CAS <= 4'b0001;
            // 3-byte
            4'b1100: CAS <= 4'b1110;
            4'b1101: CAS <= 4'b0111;
            4'b1110: CAS <= 4'b0011;
            4'b1111: CAS <= 4'b0001;
            // long word
            4'b0000: CAS <= 4'b1111;
            4'b0001: CAS <= 4'b0111;
            4'b0010: CAS <= 4'b0011;
            4'b0011: CAS <= 4'b0001;
            default: CAS <= 4'b1111;
        endcase
    end
    One issue I ran into while putting this solution together was strange RAS behavior. Each pair of RAS lines is supposed to act as a bank selector, but when I implemented this, I lost access to half the bytes in the memory. It turns out I mislabeled the RAS pins on the SIMM slot in my schematic and had RAS1 and RAS2 swapped. Fortunately, this is all semantics and swapping RAS1 and RAS2 in the CPLD pin mapping solved this problem entirely.
    Can you spot the problem?
    With the DRAM now handling different cycle types correctly, I set up address decoding to handle 64 or 128 MB SIMMs. The SIMM bank is selected based on the A26 line. If A26 is 0, RAS0 and RAS2 will be asserted, if A26 is 1, RAS1 and RAS3 will be asserted instead. This allows support for either a 64 or 128 MB SIMM, only the addressable size of the DRAM will change: 0x4000000 or 0x8000000 respectively. Smaller single-sided SIMMs (4 and 16 MB) should also work without modification, but other sizes of double-sided SIMMs would require modification to this address decoding scheme to be fully mapped, but who doesn't want as much RAM as possible anyway!?
    Mackerel-30 with 128 MB SIMM installed
    To wrap up this DRAM improvement, I revamped the memory test code in the bootloader. There are now two ways to test memory: a simple 8-bit read and write test and a new 32-bit test that can cover the entire 128 MB memory space. The 32-bit...
  • More Mackerel-30 Bringup Progress
    Colin Maykish12/15/2024 at 00:27 0 comments
    Current state of the Mackerel-30 prototype board
    Mackerel-30 board bringup is going well for the most part. I've got the IDE interface and DRAM controller hooked up and functional. I did make a mistake in IDE wiring though. One of the buffer chips between the IDE interface and the CPU data bus has the bits wired in reverse order, i.e. bits 0-7 are mapped to 7-0. Fortunately, the rest of the control circuitry is wired correctly and the bits can be reversed in software for now. This adds a bit of overhead, but Mackerel-30 is not winning any speed contests right now anyway. I'll add it to the list of fixes for the next PCB revision.
    I also ported over my DRAM controller from Mackerel-10. Going from four 30-pin SIMMs to a single 72-pin SIMM required a bit of adjustment to the CAS and RAS logic, but the state machine and refresh timing is almost unchanged. Unfortunately when I bought DRAM sticks for this project, I didn't notice that the 64 MB modules I ordered were 3.3v only. I've ordered some more 32 MB and 64 MB modules that will work at 5v, but for now I'm using a backup 8 MB stick.
    There seems to be some inconsistencies with how 72-pin SIMMs have their RAS and CAS lines wired up to the individual DRAM ICs. The 8 MB sticks I have seem to map one RAS line to each of the 4 8-bit DRAM ICs on the stick, but based on other datasheets and information I've seen online, this may not be 100% standardized. My interpretation is that normally the four RAS pins operate in two pairs of two, effectively acting as a bank switch for double-sided modules. I'll have to experiment when I receive the new batch of SIMMs, but in the worst case, I can make some minor adjustments to the DRAM controller logic to compensate. I'm feeling pretty confident in the core functionality of the controller at this point.
    My intention was to finish out this update with a proof-of-concept FPU test, but I realized the libc library I'm using doesn't support floating point at all. I could still add the new decoding logic to the CPLD and do some tests in assembly, but I think I will wait on the FPU for now. I've got the hardware far enough along to start porting Linux to Mackerel-30 and I'm much more excited to get started on that than to worry about the FPU at the moment.
  • Mackerel-10 Nearing Completion
    Colin Maykish12/12/2024 at 16:12 0 comments
    I've put together a new revision of the Mackerel-10 PCB to fix the issues in v1.0. The main problems with v1.0 were in the IDE interface. I had the direction of the buffers reversed which required a cut trace and a bodge to fix. I also failed to connect the second IDE chip-select pin to the CPLD, so that had to be bodged in as well to enable control of the IDE interrupts. With the circuit corrected, the IDE interface is working as expected without any bodges.
    There are actually two very similar versions of the revised PCB. Originally I created v1.1 which fixes the issues listed above. After experimenting with the DS1233 reset circuit on Mackerel-30, I decided to add it to Mackerel-10 as well, replacing the 555 circuit that was doing the job previously. This version is v1.2 and is identical to v1.1 other than the reset circuit. If you would like to build one of these boards, I'd recommend v1.2, but v1.1 is still an option if you'd prefer to use the 555 reset.
    As discussed in a previous post, the DRAM controller is running at 50 MHz with good stability. It is also decoupled from the CPU clock. My 68010s start to have issues with even a slight overclock, but the system runs well with the CPU clock at the rated maximum of 10 MHz. Using the 68SEC000, I'm able to run at 20 MHz. The SEC chip is capable of much more, but the DUART and IDE interfaces start to behave erratically beyond that point. It's possible that some additional wait-state logic would remove this bottleneck.
    Finally, I've made some progress on the software side as well. The bootloader now supports the FAT16 filesystem and can load the Linux image from a file on the IDE drive instead of reading raw sectors into memory. I've set up the SD card with a small FAT16 partition containing the kernel image file and a larger ext2 partition. The ext2 partition can be mounted from uClinux and gives Mackerel-10 an option for writable persistent storage.
    Mackerel-10 v1.2 with IDE drive
    At this point, I don't have any immediate plans for more hardware changes to Mackerel-10. The current PCB satisfies all of the requirements I had for this system when I started. My focus has shifted to Mackerel-30, but there are still some interesting software options to explore on Mackerel-10.
    Mackerel-10 Release Files: https://github.com/crmaykish/mackerel-68k/tree/master/releases/mackerel-10
  • 68030 Is Executing Code!
    Colin Maykish11/25/2024 at 18:17 0 comments
    The first prototype of Mackerel-30 is alive! After many hours of soldering, updating Verilog, and modifying memory maps and Makefiles, the 68030 is up and running. Better yet, it's running the same bootloader code as Mackerel-08 and -10 and loading programs over serial. Since the 68030 is more or less a superset of the earlier CPUs, very little C code needs to change from previous iterations of Mackerel.
    Mackerel-30 v0.1 minimal configuration for board bring-up
    So far I have verified the basics of the system. Only the ROM, SRAM, and DUART have been tested, but there's enough glue logic implemented to run the bootloader and handle vectored interrupts from the DUART.
    Seeing a new design come to life really never gets old. That said, this is a prototype and there are already some problems. For one, the serial header is backwards from previous Mackerel hardware. This caused a slight panic when the code appeared to be running, but no serial output was displayed. Fortunately, flipping the USB-serial adapter solved that issue.
    I also managed to export the Gerbers without noticing that the VIN pin of the 3.3v regulator was not connected to anything. I need to figure out why KiCAD didn't complain about this, but the 3.3v power is not actually needed for the board to run, it's just there for external hardware, so no harm done. It's also easy enough to bodge the VIN pin to a nearby 5v rail if necessary.
    I haven't hooked up the FPU yet, but I am missing A13-A15 pins on the glue CPLD. I think these are required as part of address decoding for the FPU, so they may need to be bodged in.
    Finally, there are a few footprint issues. The mounting holes for the 72-pin SIMM are not all sized correctly, requiring some "plastic surgery" to solder in the socket.
    The DIN 41612 connector footprint also has issues. The holes are all way too small to fit the pins of the connectors I have. This is not a custom footprint, it was pulled from the KiCAD library, so it's possible I just have non-standard connectors, but either way, it makes the expansion header pretty unusable.
    With the basics working, my plan is to finish assembly and test the DRAM, IDE, and FPU. If at least the DRAM and IDE are functional, I should be able to start on the Linux port. If I find any showstopping issues, I guess Linux will have wait for the next revision.
  • What's New For Mackerel-30?
    Colin Maykish11/10/2024 at 02:02 0 comments
    Rather than design a bare minimum prototype for Mackerel-30, I decided to take a bit more risk and incorporate most of features I want from the start. Moving from the 68008 to the 68010 was a reasonable step up in complexity. Jumping to the 68030 presents another significant leap with 32-bit buses and more complicated control logic. In some ways, it's actually easier to deal with though. The dynamic bus sizing removes the requirement for 16-bit ROM and RAM chips. A single 8-bit ROM and SRAM should be enough to bootstrap the system.
    Besides the new CPU, I've included a few other hardware upgrades. I'm looking forward to getting the MC68882 FPU up and running. It should be supported by Linux and might give a boost in performance for things like scripting languages or graphics support if and when I get to those.
    I've also upgraded to 72-pin SIMMs for the DRAM. Each SIMM is 32-bits wide which makes the wiring straightforward and requires only a single module. The available capacities are also quite a bit higher than 30-pin modules, going up to at least 128MB. The DRAM controller will be adapted from the one I designed for Mackerel-10.
    The only piece I have not included in this first prototype is networking hardware. I'm still exploring some options in this area and I'm not ready to commit to one design. Once the base system is brought up, I plan to build a network card to connect to the expansion header.
  • Another Word On DRAM
    Colin Maykish10/25/2024 at 04:15 0 comments
    Getting a DRAM controller working at all feels like a great accomplishment, and while it has been stable and functional, there were some situations I couldn't explain. For example, it was not possible to run the DRAM controller at anything other than twice the CPU speed, even running them at the same frequency failed completely. I was not satisfied with my understanding of my own design. I also wanted the option to run the DRAM on its own independent clock to completely free up the choice of oscillator for the CPU.
    With the goal of better understanding and more flexibility, I took the lessons learned from my first iteration and went back to the drawing board, starting with the datasheet. The simplest place to start is the CAS-before-RAS refresh.
    CAS-before-RAS Refresh
    CAS-before-RAS refresh timing diagram from the TMS417400 datasheet
    The refresh process is not complicated: pull CAS low, then pull RAS low, raise CAS, and then raise RAS again. One thing worth noting here is that the WE pin has to be HIGH by the time RAS is lowered. Since the state of the WE pin is "don't care" for the rest of the refresh cycle, I chose to pull it HIGH in the first state of the refresh state machine. Note: Mackerel-10 has four 30-pin SIMMs in two 16-bit pairs, A and B. RAS is shared between SIMMs in a pair, but the CAS lines are all independent, thus two RAS pins and four CAS pins in my controller.
    REFRESH1: begin
        // Acknowledge the refresh request
        refresh_ack <= 1'b1;
        // Lower CAS
        CASA0 <= 1'b0;
        CASA1 <= 1'b0;
        CASB0 <= 1'b0;
        CASB1 <= 1'b0;
        WRA <= 1'b1;
        WRB <= 1'b1;
        state <= REFRESH2;
    end
    REFRESH2: begin
        // Lower RAS
        RASA <= 1'b0;
        RASB <= 1'b0;
        state <= REFRESH3;
    end
    REFRESH3: begin
        // Raise CAS
        CASA0 <= 1'b1;
        CASA1 <= 1'b1;
        CASB0 <= 1'b1;
        CASB1 <= 1'b1;
        state <= REFRESH4;
    end
    REFRESH4: begin
        // Raise RAS
        RASA <= 1'b1;
        RASB <= 1'b1;
        state <= PRECHARGE;
    end
    The final piece of the DRAM refresh cycle is determining how often it needs to happen. According to the datasheet, all 2048 rows need to be refreshed every 32 ms. If we refresh each cell incrementally with CBR, that means we need to refresh a cell every 32 ms / 2048 = 0.015625 ms. That equates to 64 kHz. Finally, the DRAM controller is running from a 50 MHz oscillator, so 50 MHz / 64 kHz = 781 cycles between refreshes.
    The Verilog for counting cycles is basic, but I'll include it here for reference. The two refresh_ registers are used to pass the refresh state back and forth between this generator code and the main state machine. REFRESH_CYCLE_CNT is set to 781.
    // ==== Periodic refresh generator
    reg refresh_request = 1'b0;
    reg refresh_ack = 1'b0;
    reg [11:0] cycle_count = 12'b0;
    always @(posedge CLK_ALT) begin
        if (~RST) cycle_count <= 12'b0;
        else begin
            cycle_count <= cycle_count + 12'b1;
            if (cycle_count == REFRESH_CYCLE_CNT) begin
                refresh_request <= 1'b1;
            end
            if (refresh_ack) refresh_request <= 1'b0;
        end
    end
    CAS-before-RAS refresh cycle running at 64 kHz as calculated
    Read/Write Cycles
    With the CBR refresh behavior confirmed, I started to revamp the rest of the state machine, i.e. the process of actually reading and writing memory. As mentioned, my first implementation worked, but just barely. One of the issues I had was a dozen or more compiler warnings in Quartus that looked something like this: Warning (163076): Macrocell buffer inserted after node. I could not track down an exact cause, but the little information I found online and my own testing seemed to indicate that this error basically means "you're trying to do much work at once". By breaking up my state machine into more smaller states and removing highly parallel pieces of code, I was able to get rid of all all these warnings. It seems like the key is not to change too many register values per clock cycle, but to instead pipeline the design.
    DRAM read cycle timing diagram from the TMS417400 datasheet
    The actual logic of the DRAM read and write...
  • Linux IDE Driver And Hardware Updates
    Colin Maykish10/20/2024 at 22:27 1 comment
    I've been making steady progress on Mackerel-10 since initial board bringup. The most exciting development is a working Linux driver for the IDE interface. There's now a real /dev/hda device accessible and this comes with all of the built in tools and filesystem support from the kernel. After adding fdisk and mkfs to the Linux image, the IDE drive can be partitioned and mounted as a persistent storage device right from Linux. This is a huge step in improving the usability of the system and it's a milestone for the project as a whole.
    Mackerel-10 with SD-to-IDE adapter
    Hardware Changes and Glue Logic
    The hardware design of the IDE interface was mostly complete before I started work on the driver, but there were a few updates to get everything fully supported. While it's possible to use IDE devices without interrupts, the Linux driver interface requires a working interrupt from the drive. This interrupt pin was already routed to the CPLD, so I updated the interrupt control Verilog to handle the extra source.
    The only sticking point on the wiring side was the missing second chip select line. IDE devices have two CS pins: CS0 and CS1. Only CS0 is required for basic functionality, but CS1 enables access to the alternate status register, a.k.a. the device control register. This register is needed to control interrupts on the drive. I did not have this pin connected to the CPLD, but it was connected to 5v through a pull-up, so I bodged a connection to one of the spare IO pins on the CPLD and updated the address decoding to make this device control register accessible to the CPU.
    Writing a Linux IDE Driver
    With the hardware and glue logic updated and tested in isolation, I started work on a Linux driver. There are a few different ways to implement IDE on Linux. The traditional (i.e. deprecated) way is to implement an ide_host and the associated functions for communicated with the drive(s). There's also a newer approach based on libata. This is a more modern solution, but it is not supported on m68k architecture, at least in the 4.4 kernel I'm running, so I implemented the traditional driver.
    Conceptually, the IDE driver interface is pretty simple. There are a handful of operations that the driver needs to define and the driver requires an interrupt number. On Mackerel-10, the IDE interrupt is autovectored to IRQ number 3. Implementing the required functions is fairly straightforward. For example, here are the commands that read the status, execute IDE commands, and read blocks of data:
    static u8 mackerel_ide_read_status(ide_hwif_t *hwif)
        return MEM(MACKEREL_IDE_STATUS);
    static void mackerel_ide_exec_command(ide_hwif_t *hwif, u8 cmd)
        MEM(MACKEREL_IDE_COMMAND) = cmd;
    static void mackerel_ide_input_data(ide_drive_t *drive, struct ide_cmd *cmd, void *buf, unsigned int len)
        int i;
        int count = (len + 1) / 2;
        u16 *ptr = (u16 *)buf;
        for (i = 0; i < count; i++)
            ptr[i] = MEM16(MACKEREL_IDE_DATA);
    The full driver code is available here: https://github.com/crmaykish/mackerel-uclinux-20160919/blob/master/linux/drivers/ide/mackerel-ide.c
    Dirty Hacks
    One issue remains with this driver. Normally, when an IDE interrupt is generated, the drive will assert the IRQ line and hold it until the CPU reads the status register. This clears the interrupt and normal operation resumes. For some reason, the interrupt on my system is never getting cleared. This means that after the first IDE interrupt, the driver just hangs and the system can't boot further.
    I managed to "solve" this by reading the status register manually in the process_int() function in ints.c if the vector number matches the IDE IRQ number, but this is a total hack. I don't know why the driver is not doing this automatically. It's entirely possible there's an issue with my interrupt glue logic or something dumb I missed in the driver code itself. I need to figure this out, but my hack is working for now and the IDE driver is fully functional.
    IDE drive partitioned...
  • Mackerel-10 v1: Lots of DRAM And A Hard Drive
    Colin Maykish10/17/2024 at 16:54 0 comments
    The first round of PCBs for the Mackerel-10 SBC are in and I've begun assembly and board bringup. There aren't too many software changes going from the prototype to v1, but the hardware changed a little bit. There are now four 30-pin SIMM slots instead of two. These are arranged in two pairs to allow a 4x4MB DRAM configuration. Additionally, the IDE interface is now buffered through a set of 74HC245 chips to handle longer ribbon cables. The upper and lower bytes of the 16-bit IDE interface are also swapped in the layout to transparently convert the IDE little-endianness to the 68k's big-endianness. Finally, the pinouts of both CPLDs were completely changed to facilitate the routing of this board, so all of the pin mappings had to be updated in the Verilog projects.
    Mackerel-10 SBC v1 assembled
    The core system (CPU, ROM, SRAM, DUART) came up pretty quickly once the glue logic and memory map was updated. The DRAM controller also works as expected. I had to update the DRAM controller to handle the extra two SIMM slots, but Mackerel-10 now has access to 14MB of DRAM. One megabyte is still used by the SRAM and the ROM and I/O share the remaining megabyte of address space. All in, that means we've now got 15MB of usable RAM on board.
    My DRAM controller is currently running fairly slowly (12.5MHz) at twice the CPU clock frequency (6.25 MHz). I added a second oscillator to the CPLDs with the hope of running the CPU and the DRAM controller on independent clocks, but I have not spent any time working on this. Ideally, the DRAM controller runs at whatever maximum frequency it can without having to worry about being in sync with the CPU clock. Since the DRAM bus access is asynchronous using its own DTACK signal, this should be possible, but I'll need to do some experimentaton and timing analysis.
    The new IDE interface caused me some trouble. In the prototype, the 16-bit data bus from the CPU was wired directly to the IDE drive. Adding buffers between them will help with stability and lighten the load on the CPU data bus, but it adds a little more complexity and enough room to screw something up, which I did. After a lot of debugging with the oscilloscope, I realized the buffers are working fine, but the direction pin was inverted (or the A and B buses on the buffers were inverted, depending on your perspective). This meant the buffers were always pointing the wrong direction when the CPU tried to access the IDE registers. This was a dumb mistake I made in the schematic, but I was able to fix it by cutting the trace from the RW pin to the DIR pins on the buffers and creating the proper direction signal from one of the spare CPLD pins. With this bodge in place, IDE was functioning again.
    Bodge to fix the direction pin of the IDE buffers
    There is minimal software support for IDE devices at the moment, but Mackerel-10 can read and write arbitrary sectors from the disk and print out drive identification info. I've done most of my testing with a SD-to-IDE adapter for simplicity, but I wanted to hook up a real IDE hard drive to make sure that was also working.
    Mackerel-10 with a real 2.5 inch IDE hard drive
    I'm a little disappointed about the IDE bodge, but I'm really pleased with the overall SBC. There are a few other minor issues with the v1 design that I will address in a future PCB revision, but my focus will now turn back to the uClinux port. I have a lot more RAM to play with and a real IDE device opens up a lot of options, at least once I figure out how to write a driver for it.
  • Mackerel-10 v1 PCB Design
    Colin Maykish10/05/2024 at 23:09 0 comments
    In my last couple posts, I described the DRAM controller and IDE interface I've been working on. With both features working reliably, it's time to combine them together and build an SBC. One element I did not consider when making the jump from the 68008 to the 68010 is how much more complicated the actual PCB routing would be with all those extra pins. The DRAM controller also adds a lot of complexity to the routing and takes up a lot of board space.
    I designed Mackerel-10 v1 as a four-layer board with the same stack-up as Mackerel-08, signal/ground/power/signal. The circuit design is not drastically different than the prototype PCBs I've been working with until now. The main difference is the on board IDE header and the addition of two extra SIMM slots. I wanted the option to use 4x4MB DRAM.
    I also broke out more I/O from the DUART and more power pins in general. I decided to keep the system expansion header limited to an 8-bit data bus with A1-A15 exposed, plus enough control signals to attach reasonable I/O devices. It did not feel necessary to expose the full 16-bit data bus or all of the address pins when most of the address space will be filled with on-board DRAM anyway.
    Finally, I added an optional second clock oscillator to both the system and DRAM CPLDs. I'd like to experiment with running the DRAM state machine on its own clock in an attempt to maximize both the CPU speed and the DRAM access efficiency.
    This is the biggest and most complex board I've routed so far. PCB manufacturing prices don't increase that substantially as the board size grows, so I did not go crazy trying to keep it as small as possible. It ended up being 210x170mm.
    Mackerel-10 v1 PCB signal layers
    Mackerel-10 v1 PCB render
View all 33 project logs
tdurland wrote 05/02/2026 at 03:57 point
### Mackerel-08 Bootloader v0.1.2 ###
###       crmaykish - 2024        ###
> boot
Loading Linux from SD card...
Sending SD init command...
Failed to initialize SD card
SD card ready!
Image size: 0
Loading kernel into 0x400...
Done
Jumping to 0x400
PANIC: Unimplemented instruction
Any ideas?
tdurland wrote 04/29/2026 at 23:35 point
Hello
### Mackerel-08 Bootloader v0.1 ###
> boot
SD card ready!
Image size: 0
Done
Jumping to 0x400
PANIC: Address error
Am I using the correct Bootloader ?
Malcolm Harrow wrote 03/01/2025 at 23:29 point
I'm having some fun building a mackerel-10! I have the main computer and DRAM working, now waiting on an IDE cable to arrive.  My SIMMs are 1Mb .. so there maybe some repeated memory/memory unaccessible .. I need to test!  For the CPLDs I used ATF1508s and the pof2jed utility to create a jed file for programming - that that seemed to run without a hitch.  One small feedback - on the schematic both crystals are labelled as 50MHz .. the one that generates CLK_SRC should be 20 MHz (I think).  A great board, lots of fun!
Colin Maykish wrote 03/02/2025 at 01:12 point
Cool! Glad you've got a board up and running
The 1MB SIMMs should work fine, but the DRAM address space won't be contiguous without some changes to the address mapping in the DRAM controller Verilog. Send me a DM if you need help modifying it.
Nice to know the ATF chips work as a drop-in replacement. I bought a bulk lot of the Altera CPLDs and haven't explored anything else, but having alternatives for these old chips is always nice.
The CPU runs at half the CLK_SRC oscillator frequency, but that's technically configurable to 1x or 1/4. For normal 10 MHz CPUs, a 20 MHz oscillator is the right choice and it's what the timers expect as well. I've had the SEC CPUs running at 40 and 50 MHz without dividing down the frequency, but that's probably not a common use case. I'll add a note to the schematic about oscillator choice.Thanks!
Malcolm Harrow wrote 11/27/2024 at 01:32 point
The 030 board is looking very nice !  Why do you use SOJ memory chips on a header rather than native DIP32 5v memory chips - is it speed ?  Same question for the flash ..
Colin Maykish wrote 11/27/2024 at 02:01 point
Originally it was for speed, yea. I wanted to see if the slower DIP packages were actually a bottleneck. For the most part, they aren't, but I ended up really liking the increased durability of the adapter PCBs with machined pin headers compared to the fragile DIP legs. The SOJ SRAM chips are also about half the price of the DIP versions, though the cost of the adapters cancels that out somewhat.
tdurland wrote 10/28/2024 at 03:47 point
What speed are the 22v10c parts, on your BOM you left off the speed
Colin Maykish wrote 11/07/2024 at 15:19 point
I'm using 15ns parts from Atmel.
tdurland wrote 11/13/2024 at 03:01 point
Could you post the jed files for the 3 gal chips and the hex file for the eprom
for the 68008 version 1.1
Thanks
Colin Maykish wrote 11/13/2024 at 23:05 point
I've added the three JEDs and the bootloader binary here:
https://github.com/crmaykish/mackerel-68k/tree/master/releases/mackerel-08/v1.1
If you're putting together a board, send me a DM. I'd be interested to hear how it's going.
Daniel Palmer wrote 10/25/2024 at 13:44 point
I just stumbled across this project. Its possible to run a modern (as in Linus' master branch) kernel on 68000 as long as you have ~8MB of memory.
If you're interested I can point you to my repos with the changes needed and you could have a good getting it working on your board?
Colin Maykish wrote 11/07/2024 at 15:16 point
Sure, I'd be happy to take a look. Building the latest kernel for m68knommu isn't too bad. I've gotten that far, but getting libc and a userspace all working was where I gave up.
Daniel Palmer wrote 11/08/2024 at 10:21 point
I have you covered on userland too. I have a recentish buildroot fork with enough patches to build a modern (ish, gcc 12 right now) toolchain and userland.
It's a bit broken for 68000 I think right now as I'm halfway through making 030, 040 and 060 work as well but I have buildroot, u-boot, linux and QEMU as a package here:
https://github.com/fifteenhex/m68kjunk
kanomi wrote 09/24/2024 at 22:20 point
In the schematic of  Mackerel-08-v1, I could not find any values of resistors (R1 to R20?).
In addition, those values were not printed on the PCB either. Can you tell me those resistor values?
Colin Maykish wrote 09/24/2024 at 23:18 point
Sure, you've reminded me I need to clean up the schematic and post the BOM list. Until then, the resistor values are:
1k: R15, R20, R23
10k: R21, R22
4.7k: everything else
Also I realized that the PDF schematic I had on this project page was for v1. I've uploaded the v1.1 schematic. I'd recommend referencing that one. The resistor values and labels are the same on both, but v1.1 fixes some other issues.
Edit:
Here's the updated schematic with resistor values:
https://cdn.hackaday.io/files/1838617866309024/mackerel-08-v1.1-updated.pdf
Malcolm Harrow wrote 09/24/2024 at 13:25 point
Any early indications how much faster the IDE interface is compared to the SPI SD Card ?
Colin Maykish wrote 09/24/2024 at 15:18 point
It's so much faster... On Mack-08, it takes 3m 46s to load the 1.2MB Linux image from the SD card. That works out to about 5.5 kB/s. On Mack-10, I was able to load 1024000 bytes in about 5.5 seconds - about 181 kB/s. That's a 32x speed increase.
Neither version of the code is well-optimized. I'm sure there are ways to improve the bitbang SD performance, but a 32x difference makes sense in a way. Mack-08 takes two memory cycles to read a single bit at a time (toggling the SPI clock up and down), whereas Mack-10 can read 16 bits in one memory cycle.
Malcolm Harrow wrote 09/22/2024 at 14:32 point
You may want to take a look here .. https://github.com/rosco-m68k/rosco_m68k/tree/develop/code/software/updateflash
there is some code to update the flash in situ if you write enable the chip (achieved on the board via a jumper).  Then you may not need the zif socket :)
Colin Maykish wrote 09/22/2024 at 15:34 point
I considered implementing something like this early on in the project, but I never got to it. My issue was that once I could run code from ROM, I no longer needed to flash ROM very often - I'd just load new code over the serial port - so this just fell off the priorities list. Still a good reference though, thanks.
Malcolm Harrow wrote 09/22/2024 at 14:27 point
Very nice project.  I agree with you on Quartus, spend as little time as possible there!!   I have been trying to recompile the uClinux 4 source for the rosco_m68k board, but it’s complaining that it can’t find elf.h.  I’m working on a Mac and using the rosco cross compiler.   Could you let me know your setup to get a clean compile ?
Colin Maykish wrote 09/22/2024 at 15:28 point
I'm not familiar with the compiler used by rosco, but Linux (and especially uClinux) is very picky about which compilers will actually build the kernel. You'll need a toolchain created specifically for it. Doing this natively on Mac is probably not going to work. You'll also need a x64 Linux machine or VM.
My setup looks like this:
1. Debian 12 (Ubuntu 22 or 24 should also work)
2. `apt install build-essential`
3. Download the uClinux 2016 toolchain: https://sourceforge.net/projects/uclinux/files/Tools/m68k-uclinux-20160822/m68k-uclinux-tools-20160822.tar.bz2/download
4. Extract that toolchain and make sure the `usr/local/bin/` folder is on your `$PATH`
5. From the root of the uClinux project, you should now be able to run `make menuconfig` and then `make`.
That's a pretty high level view. If you get this far though, you should be ready start porting uClinux to your rosco board.
If you get stuck, feel free to send me a PM. Happy to help.
Malcolm Harrow wrote 09/23/2024 at 00:10 point
Many thanks for the quick response .. I now have a compiling system !
I also had to apt install libncurses-dev to get the menu to work
There is also a newer version of the tools using gcc 12.3 .. its on the same account and called m68k-uclinux-tools-20231026.tar.xz
I will let you know I get on ..
Malcolm
Bharbour wrote 08/07/2024 at 02:44 point
Thats a good looking board!
Colin Maykish wrote 08/07/2024 at 03:07 point
Thank you! There's always some minor things, but I'm really happy with how it came out.
teraz wrote 03/08/2022 at 19:53 point
Is possible make a mobile version? for example 24h working time?
Colin Maykish wrote 03/09/2022 at 01:03 point
Sorry, not sure what you mean. Like a portable version of the computer?
teraz wrote 03/09/2022 at 10:44 point
yes, similar https://github.com/penk/penkesu , meybe solar panel too. motorola is power eficient
p.s. look this too https://hackaday.io/project/643-minibsd-laptop-computer
Keith wrote 02/23/2022 at 22:34 point
I have designs for the 68008, 68000 and 68020. They all use SRAM so they would need hacking to exceed the 24 megabyte needed for an OS like Linux. My boards ran OS9/68K on a SCSI disk.
https://hackaday.io/project/28957-stebus-68008
https://hackaday.io/project/28960-stebus-68000 (board only, no cct or manual)
https://hackaday.io/project/28959-stebus-68020
Colin Maykish wrote 02/24/2022 at 00:32 point
Nice looking boards. I like the idea of STEbus, but I'm not sure I'd want to invest a lot into it knowing I'll be expanding the bus width when I move up the 68k family tree. I guess most of the CPUs (other than the 68000) could actually use an 8-bit bus directly though.
I think I'm going to have to tackle DRAM when I need more than the 4MB that the 68008 can address. Buying and soldering all that SRAM sounds expensive and time-consuming.
Keith wrote 02/24/2022 at 00:44 point
The STEbus is 8-bit data but that does not stop processors being any data width they wish inside the board. For example, the 68020 board makes 16-bit accesses  to the ROM and 32-bit accesses to the RAM. The 68020 has "dynamic bus sizing", and will make accesses in whatever width the board logic tells it to. The STEbus is really just for i/o, not main memory. In the olden days, memory chip capacity was so small that extra boards were the only way to carry them. These days memory is big and cheap, and can easily fit on the processor board.
Colin Maykish wrote 02/24/2022 at 00:55 point
Ah, that makes a lot more sense how you could get away with an 8-bit bus. I'm coming from a software background, so the system architecture, especially when it comes to things more complicated than SBCs, is definitely a learning opportunity for me.
Alexandra Bastet Stehr wrote 02/23/2022 at 07:07 point
Regarding memory size, 24 MBytes seems to be the bare minimum these days for a recent kernel. How we found out? OpenComputers2 came around for Minecraft 1.18 and that one implements a RiscV64 VM with a barebone Linux on top. We tried to fire up a machine with just 16 MB inserted and got a genuine kernel panic as the userland refused to come up with just 4 MB of RAM left, the kernel alone eats up around 12 MByte. Inserted the 2*4 MByte from our very first try and voila, the machine came up to a login and we could run anything.
Colin Maykish wrote 02/23/2022 at 15:03 point
This was on kernel v5?
I'll admit I've done very little research on what it will take to run Linux on this machine so far. Might have to stretch my definition of "modern Linux" a little to accommodate the 68008 limitations.
Alexandra Bastet Stehr wrote 03/24/2022 at 09:51 point
Yep, made with recent buildroot, here is the fork: https://github.com/fnuecke/buildroot
Boxerbomb wrote 02/05/2022 at 19:11 point
Nice man, I will be following the project. I love 68k computers and I think that you are making the right choice trying to work your way up to the 30. I have been thinking about starting up a project like this and maybe using some sort of interface to a large RAM chip to avoid having to reprogram EEPROMS.
Colin Maykish wrote 02/06/2022 at 04:46 point
Thanks, appreciate the interest. The build up from the 68008 is definitely less daunting than jumping straight into a 68030. My solution to constantly flashing ROM is a serial bootloader. I can load new programs into RAM over the serial port. The actual ROM code changes a lot less frequently that way. The only downside is you lose your program when you lose power.
I'm also working on a more direct boot-from-USB using the CH376S module. That will get its own write-up when I get it finished.
John Smith wrote 03/15/2023 at 18:16 point
Hi. Have you had a chance to complete the project and publish PCB gerbers for backplane and PLCC adapters?
