Tetrinsic [gd0041]
A motorised fader that is continuous, pressure sensitive, haptic and water resistant.
To get the most bandwidth out of my dual hands, I am designing an input element that can obtain more data than a standard keyboard switch.
Tetrinsic is designed to be used for input devices such as Tetent [gd0090].
Inspiration and/or examples of working principle
Tetrinsic can be thought of as a merge between the form factor of a motorised fader, the infinite movement and adjustable configurations of the SmartKnob View and the force/position sensing like a Force Sensitive Linear Resistor (FSLR).
Instead of a single Force Sensing Linear Resistor (FSLR), the above video use a Force Sensing Resistor (FSR) and soft membrane potentiometer (trade name SoftPot / ThinPot) to get the same thing. Tetrinsic obtains position via a magnetic angle sensor like SmartKnob View.
Another goal was to look as minimalist as possible, so that things like an LCD backlight may be used for designs:
Unlike the Flux Keyboard, tactility and actuation force can be tuned to ones precise tastes in software.
Navigation
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
L1
[M] Test log 1
L2
[P] Printed concept in resin
L3
[M] Wider and shorter
L4
[R] Redesign options
L5
[A][R] Motorized Switches
L6
[T] Force sensor instead of magnets?!
L7
[M] Switch mounting hardware
L8
[P][M][R] Sensors and drivers
L9
[R] Sourcing chips
L10
[T] Other uses of Tetrinsic
L11
[M][T] PCB concept (and project name)
L12
[M] PCB Schematic
L13
[T] PCB schematic... fails.
L14
[M] I/O Expander
L15
[M] Direct ADC connection
L16
[T] Using a microcontroller
L17
[T] Tetrinsic as master control
L18
[M] Starting the PCB
L19
[M] Populated MCU
L20
[M] PCB Rerouting
L21
[M] 1000 Pages
L22
[M] Motor Pad
L23
[M] 40mm Long
L24
[M] PCB slowly being rerouted
L25
[P] Micro Motor and Belt
L26
[M] Updated CAD issues
L27
[T] Thinner solution idea
L28
[T] Ball chains?
L29
[T] To LED or not to LED...
L30
[T] TFT, angle sensor and 16MB flash
L31
[M] The All New Tetrinsic 2.0: Initial concept
L32
[M] Load Cell Simulations
L33
[T] USB Connection?
L34
[R] Looking at the start of Plover
L35
[P] Chain in a channel
L36
[A] Mining for a solution... ends, in 30 days.
L37
[T] Even thinner? Solution required.
L38
[T] Current Tetent layout
L39
[T] Focus on obtaining TestCut?
L40
[M][R] CAD redesign... started.
L41
[B][M] Initial BOM made
L42
[M] Tetrinsic Gen 3X1 Concept
L43
[M] Drawing a theoretical layout
L44
[T] Bolt reinforcement under LCD?
L45
[T] Sloped Tetrinsics?
L46
[T] Space for an off-the-shelf load cell?
L47
[T] Mounting options
L48
[M] Sculpting a look
L49
[M] Mining for a flat-top solution
L50
[T] Joysticks for thumbs?
L51
[R] Taking load cells out of pocket scales
L52
[A] A solution... failed, in the time provided.
L53
[T] Cutting the load cell
L54
[P] LCD and Steel Tubes
L55
[T] LCD-down mounting
L56
[P] Small 500g Precision Scale Teardown
L57
[M] Load cell update
L58
[M] Detailed modelling started: LCD Holder
L59
[M][T] ESP32-S3 MINI and other changes
L60
[R][T] Plans going forward
L61
[M] Slow foundations
L62
[M] Chain Pathway
L63
[M] Chain aligned
L64
[M] PCB on side?
L65
[L] First symbol in Fusion360 Electronics
L66
[L] ADC schematic entry
L67
[L] Created BMI160 footprint
L68
[T] Tetrinsic Taic: Solar panel variant
L69
[L] BMI160
L70
[M] Solar Cells
L71
[M] Photovoltaic cell implemented
L72
[R] Solar Cells: Polycrystaline and Amorphous
L73
[L] MP6543 BLDC Controller
L74
[L] ESP32-S3-MINI-1U component
L75
[L] Pins and the GPIO Matrix
L76
[L] LBS147TC-IG01 (1.47" LCD) Pad
L77
[L] 580KV Motor Pad
L78
[L] Tetrinsic Pad
L79
[L] MIP LCD and Not Enough Pins
L80
[L] BMI160 3D package and 74HC595 output extension
L81
[L] Expansion Pins
L82
[T] Looking ahead: USB Type-C system
L83
[R] Are better components now available?
L84
[L] DRV8311P Motor Controller Component
L85
[T] Eliminate interconnects?
L86
[L] Updated Schematic with New Components
L87
[L] The start of the PCB
L88
[L] Component alignment and solar pads
L89
[L] Vias (and other DRC things)
L90
[L] The Magic of QuickRoute Airwire
L91
[L] Milestone: PCB Fully Connected
L92
[L] 3DPCB
L93
[L][R] Trace Polishing, USB and the AAT101 capacitor
L94
[L][T] PCB pre-assembled with passives?
L95
[L] Increased vias to 0.3 : 0.45mm
L96
[L] Silkscreen Issues
L97
[M] Single Path 3.2mm Edition
L98
[B][M] Pulley, sprocket, slider mount and BOM
L99
[R] LT6911C...
  • [E1][M] 4PJ Orange Belt
    kelvinA06/09/2025 at 11:09 0 comments
    325mm Belt
    Looking at the design after almost a year, I realise I was much too optimistic about the fitting of components. My focus should be on getting anything that works first and only then seeing if I should try and shrink things down. Ergonomics already imposes strict and tedious limitations. I guess this entire project has essentially been me reluctantly making Tetrinsic larger and larger.
    Anyway, in that time, I know that the black 280mm belt has been discontinued. I've now modelled a 325mm belt and 1-inch pulleys to allow for more space. The 24T is replaced with the 32T already in the pulley for one less unique part.
    If I hadn't already purchased the rotors last year, I would've increased the shaft length from 54mm to 63mm for more design flexibility, but I'm stuck with what I've got now. The issue is that all this stuff here is unreasonably small. That red cross section is 0.8mm, for example:
    I might have to use set-screws to hold the bearing in place.
    Maybe the real issue is that I just don't want to buy anything. I know inventing things that doesn't exists costs a lot of money, but it sure feels cold and soggy when you're having to spend your own instead of merely watching someone on YouTube spend theirs. You know, "Think how many [insert item I don't need, especially in the quantity required to make a point] I could buy with that kind of money!" and all that.
    [Aug 12]
    304mm Belt
    It's not actually mentioned in the title or images, but the seller actually offers a few belt sizes in between 280mm and 325mm:
    I looked into worm gears and 3mm width MXL belts as possible ways to reduce the amount of bearings and overall size of the torque transmission, but have currently decided on a 24T-40T gear train:
    Understandably, I still want to prioritise compactness. The length is currently 141mm.
  • [M][T] Flat flexible cable
    kelvinA08/01/2024 at 11:25 0 comments
    So I've recently designed the new PCB for Tetoroidiv and now I've tried adding an 80mm FFC to it.
    The annoying thing about Fusion is that it will preview a 180 degree bend but will not actually allow the OK button to be pressed, so I had to work around it:
    Then I click the bottom line with setting "Start" and the top line with setting "End".
    Since there's space, I'm considering actually just soldering all the wires from Tetrinsic to the Tetoroidiv PCB and then potting the entire thing to achieve water protection. The less separate things I need to waterproof, the better, and if I use silicone, it seems (from the video below, timestamp 4:33) that it should be easily removable if needed:
  • [E4][M] Geartrain
    kelvinA06/29/2024 at 12:05 0 comments
    Except for the pulley itself, I've modelled the gears and overall geartrain assembly.
    [Jul 09] - I've figured out a more compact solution. This reduces the length by up to 9mm, the specific gears are cheaper (79p savings) and means one less bearing is needed. Due to this, I can now use the more popular and cheaper 4PJ280 v-ribbed belt.
    J102A > C242A > J082A > 242A > 34T for a 10.2:1 reduction.
    The theoretical top travel speed and power consumption are slightly reduced.
    [Jul 10] Against the odds, there just happens to be a dual layer crown gear that has the right number of teeth and fits in the space available:
    J082A > C24102A > 242A > 30T for 9:1 reduction.
    It's the C24102A and it's only 0.1mm longer than the space I have. If needed, I likely can file down the tiny excess. This both saves a bit more money, reduces the manufacturing complexity and allows enough space to actually centre the main body portion of #Tetoroidiv [gd0152]!
    Symmetry, one of the foundational pillars of Aesthetic Compliance.
    Since a 30T on the end pulley still means that the theoretical max power consumption is under 0.2W, I'm going to use it instead of a larger gear to reduce any dogbone-shaped curve of the LED strip around it. A rough drawing of what I mean is below:
    [Jul 11] I've hit some issues that are at odds with each other.
    For aesthetic compliance, ideally the LED strip would look like this:
    For the total width to be limited to 17mm whilst still protecting the LED strip from the elements, the strip has to actually be slightly under the belt. Unfortunately, this would intersect both the 322A gear and the FSR:
    Why is there a 322A gear instead of the printed 30T as planned yesterday? Well, the teeth are so small that it's unlikely going to print with any adequacy, and 32 teeth was more power efficient.
    I'd much rather not have to resort to things like 1 strip per Tetrinsic because then the belt won't be centered and it could be visually ambiguous which LED corresponds to which belt. It also notably reduces the future-science vibe.
    Another issue is that the wall thickness specified in the product listing is for when it's not heat-shrunk. It looks like the waterproofing heat-shrink actually thickens quite a bit after:
    [Jul 12] So I was able to compute a new solution, and there also happens to be enough space (a handful of microns worth) that I can "bend" the geartrain so that the center of the motor stays aligned with the center of Tetrinsic:
    The driving pulley is split in two, where the 322A fits inside. The 242A gear is where the tooth gap of the belt is, so hopefully this strategy should be fine. I've decided to use 2pcs J082A so that I don't have to spend time ensuring I haven't accidentally picked up a J102A or vise versa. Lastly, I've gone back to the C202A which allows the geartrain to be a crip 10 : 1 reduction.
    I also didn't have confidence that one bearing per M2 pin would suffice, so that's why they're all double bearings now.
    I'm hoping that I can connect all the pulley SLS/MJF prints similar to a hobby kit (see below) so that I can avoid having to spend $1 for each individual part. The other pulley is one solid part:
    Ideally, I'd just order one single "part" from JLC and then snip off the connecting cylinders.
    I've also tried aligning the individual LEDs in the strip. I do hope that a 320LED/m option comes out eventually, because the coverage is rather sparse:
    Taking a step back, I'm not sure if designing something that currently looks sci-fi (without it ever being the goal) means I'm on the right track or not, but the coolness is coursing through my veins so I'll just keep calm and carry on.
  • [E1][R] Waterproofing strategies
    kelvinA06/19/2024 at 16:09 0 comments
    One of the issues with waterproofing Tetrinsic are the LEDs. They're COB, yet still only IP20 rated, and I can't find anything that has a higher rating with similar features and formfactor. So I turned to searching for a DIY solution and found this:
    The video can be summarised by this image found on LinkedIn:
    To get IP65, the strip has been coated with heat shrink tubing. This tubing exists on AliExpress and sounds like it'll turn a 2.7mm LED strip into a 4.3mm one:
    In regards to the PCB, it's probably possible to use shrinkwrap here too as it looks like its what the industry does:
    On the other hand, another idea was from the comment section of the below video:
    A commenter suggested to use mineral oil. This seems like a nice idea since I'd be able to confirm an airtight seal before this touches water, and the oil will prevent the enclosure from being crushed by water pressure. I then wondered if the MEMS microphone would be ok, but a hacker has actually used mineral oil specifically to make an underwater microphone:
    [Jul 13] I'm thinking of using the same M2 pin (as used by the gears) to terminate the side of the LED strip that doesn't have wires connecting to it. I'd need to use multi-core wire so that the adhesive seal works on that side too.
  • [R] Bearings for underwater use
    kelvinA06/19/2024 at 07:58 0 comments
    The standard ABEC1 bearings I originally found have questionable tolerances:
    I bought the mr52zz Not all bearings have the same internal measurement, I noticed that some are very loose when inserted into a shaft 2mm, being inserted with the hand without problems, others are very tight, and others simply do not pass on the 2mm axis, probably these have to hit with hammer. Please be aware that it may not work on your project.
    --- 2-star reviewer on AliExpress
    At the same time, I wanted to confirm my suspicions that standard bearings could corrode when submerged in water.
    Looking to see what options I had for water resistance in regards to robotics, I watched the following:
    Bearings indeed were listed as something that could corrode.
    I soon found out about hybrid ceramic bearings, and it's probably not a coincidence why they're advertised for things such as RC cars and fishing reels.
    From what I understand, there are 3 options for bearings used in water: stainless steel, ceramic, and a hybrid of the two. Hybrids and ceramics seem to be 3x and 6x the price of stainless respectively.
    On my search, one listing essentially said the following for ABEC ratings:
    • ABEC1: Low speed, low requirements
    • ABEC3: Sub-6kRPM, suitable for motors
    • ABEC5: Over-6kRPM, suitable for high-speed motors and precision equipment
    Thus, it seems that I require ABEC3 at the minimum. I found some, but I later found some ABEC5's for £1 more (at 50pcs) (see further below).
    Ceramic and hybrids are preferable since they use dry/no lubrication. This is useful for both longevity, reducing the "sticktion" and rotational friction. The drawback is that they would add £8/ea to the BOM, compared to £2/ea for stainless steel.
    I looked at a rollerskate stress test and the ceramic hybrid was the only one that didn't seize up:
    There's also this free-spin test with miniature bearings very similar to the size I'm looking for. They're MR63 bearings, meaning that the only difference is that the inner diameter is 3mm not 2mm. The ceramic bearings were the only ones that needed a 10x timelapse, and the bearings were so low-friction that it was noticeable that the wheel wasn't balanced.
    Considering that downtime is problematic, a frictionless sliding experience is highly desired and expected usage is "daily for years", hybrids seem to be the leading choice. To reduce the quantity of bearings needed, I've tweaked the gearing plan so that the moments are reduced:
    With this, I'm planning to use 5 bearings instead of 10.
    However, the price alone is the biggest drawback and the reason why I'm considering stainless steel.
  • [B] Unfortunately over £40 each
    kelvinA06/17/2024 at 18:31 0 comments
    I'm not sure if I ever mentioned it anywhere, but one of my price targets for Tetrinsic was £20/ea.
    While making this BOM, I determined that it was best to continue the strategy I had for the 11P cable to Tetent by making sure that I can't accidentally solder the LED strip backwards. At the same time, there isn't a 2P FPC. Instead of 2 separate cables, I'm going to use a single 7P cable. This saves both money and simplifies manufacturing. The pinout is below:
    1. 5V
    2. LED
    3. GND
    4. Force
    5. GND
    6. LED
    7. 5V
    Then it's conveniently broken out with this through-hole connector:
    This would allow me to create Tetrinsic separately to Tetoroidiv.
    At this price, I'm further considering the potential for water resistance. The current limitations at the moment are:
    • IP20-rated LED strip
    • MR62ZZ bearings might be prone to rusting
    In other news, this is how close to the wire everything is fitting:
    The top flat bar corresponds to the total active length of the force sensor.
    In other news, I've cobbled together a low-resolution render to finally replace the outdated one:
  • [R] Force Sensitive Linear Potentiometers and ThinPots
    kelvinA05/12/2024 at 11:21 0 comments
    Something I've known about for perhaps a week are these FSLPs:
    These are the only ones I can find, which are allegedly 100 x 10mm, though the black film certainly looks a lot wider than 10mm.
    Today, I've found out that there is a thin-film style of potentiometer, and it seems only one manufacturer makes it commercially:
    The ThinPot, a narrower version of the SoftPot.
    I also assume that, unlike FSRs and the aforementioned FSLP, it's not cuttable.
    Below, I found some videos of people layering these pots ontop of an FSR:
    While I think it would be nice to be able to just touch anywhere on the belt and Tetrinsic can sense exactly where, I see it as an added luxury considering that the price would be a considerable percentage of the BOM and the position in day-to-day use is already acquired via the magnetic encoder on a motor.
  • [M] Gearing strategy of 7.2:1
    kelvinA05/07/2024 at 12:54 0 comments
    The new gearing strategy (including the 16mm pulley). It's 45mm end-to-end. Everything has at least 0.5mm tolerance for non-meshing locations.
    The gear reductions blend the domains of Tetrinsic and Tetoroidiv together, and since the gears themselves are likely to be mounted on Tetrinsic, I'm writing the log here.
    I started looking into it because I thought "If I could get 2x the reduction, I could use the 1-pole-pair solution. with a 40mm rotor".
    So after going through Pinion Parts Store on AliExpress, this is the compact solution I landed on after about an hour:
    "Mkay... that should be a 15.6 : 1 reduction. Bit high but maybe it's ok?"
    Then I started sketching the other gearing strategy planned to be used with a 58mm rotor. It was then that I realised that I just assumed "smaller number over bigger number" for the gearing calculation, and that the gearing ratio wasn't 2.6 : 1, it was 0.78 : 1! This was me when I put the new calculation into the Excel spreadsheet and saw the wattage numbers of motors such as Toroid-58mm and the 1656:
    So I already weakened after that realisation, but the "Instant Damage" potion that took me down to "half-a-heart" (speaking in Minecraft terms) was when I then looked at my gearing strategy again and realised it's all backwards! I had created a 1-to-16 torque destroyer!
    It took me over 12 hours to recover from that emotional damage yesterday.
    Knowing that all the 50mm+ motors I had found now weren't going to fit, I went looking around. Most of the motors I found in the sub-40mm range all used 2mm shafts, and I can use a C202A for that.
    Today, I've converged on the following 16mm-wide solution, providing a reduction of 7.2 : 1:
    It might also be possible to integrate the 242A into the print so that the teeth don't have to be printed. Also, not sure why Fusion wants to colour some lines blue when the sketch is fully defined.
    I've also learned how to read the names. 2A means "2mm shaft, tight". Then it's just listing one or both teeth counts. For example "24082A" means "24 teeth connected to 8 teeth. Tight fit on 2mm shaft.". "C" stands for "crown".
    Additionally, the idea is to potentially use the same bearings inside Tetoroidiv, as well as omit the crown gear and connect the motor directly to 20102A for the thumb Tetrinsics.
    The current centre-to-centre spacing between the proposed motor location and the pulley is 28.5mm, which should be enough to put the thumb Tetrinsic motor right beside the finger ones and still allow a square form factor.
    The height of the gearing is defined by the largest gear, so that's why there are many with the same 24 teeth. The length of the gearing could be shortened slightly by using 18102A -> 22082A -> 222A -> 22 teeth print.
  • [E2][T] Spin-off motor, PCB and UV LED?
    kelvinA04/29/2024 at 15:59 0 comments
    • Looking at my options, i think the best thing to do now is make a prototype that doesn't include a motor.
      • This would also make it easier to implement if someone just wants to have an LED lit, force sensitive but otherwise basic slider, similar in nature to the encoders installed in some hobbyist keyboards.
      • At least if literally everything else about the current concept works, it would be easier to justify £50 and up for a prototype motor or spending days making my own.
      • [E2] The proposal... fails. I need a haptic source, where the lack of which was partially responsible for the non-use of #AirBerries and SpaceExplorer
    • I've created project #Tetrinsic Toroid [gd0152] which would contain the BLDC + PCB.
      • [E2: May 1] - Renamed to a trendier "Tetoroidiv" to keep with the coincidental tradition of an ever so slightly longer name on each subproject;
    • Move the UV LED out of Tetrinsic's domain
      • I've computed a new Tetent solution, and started on an Itinervate one too, and it seems that the LED would be better mounted on the enclosure or PCB mounted with Tetrinsic, and not something to bundle along with it.
      • The above is the potential Tetent solution side profile. The top/right orange part is the belt, and the left orange is an LED that just lines up with the ones on Tetrinsic to give the illusion that it's continuous. In actuality, this curve has the 21700 cell.. The grey lines is supposed to be a 3D texture of diamond squares.
      • [E1] Cleaner, 1:1 sketch:
      • I'm calling this Concept Solution Epsilon, named after the Overlord character, because it's a potential solution and I wrongly thought ' Σ ' was capital epsilon until I looked it up right now.
    • Additionally, water resistance becomes mandatory.
      • I need to get "that 99.9% uptime". What I mean by this is that I want to be able to use it in 99.9% of reasonable situations. Thinking through thoughts during a shower or while running in the rain between locations is what I'd call a reasonable situation.
      • I think there's a notable and valuable gain from the difference between a 90%, 99% and 99.9% solution.
      • [E1] Unfortunately, the COB strip is IP20, so not off to a good start.
  • [E1][T] More accurate power estimates
    kelvinA04/29/2024 at 07:45 0 comments
    So I've added torque radius into the equation, which essentially is the effective radius of the force if  there was no gearing or reductions. This paints a very different picture now that there is a 2.6 : 1 reduction for getting the power from the motor and into the belt.
    Additionally, my current understanding that, all else being equal, the proportionality of rotor radius, rotor length and number-of-turns is quadratic, linear and linear respectively. Thus, I've calculated the expected torque constant difference from the motor mentioned in the paper with a 40mm long rotor and 78 turns. There is barely enough space for a 50mm rotor and that would increase the torque constant to 43.5. This calculation assumes that a 4-pole rotor can be obtained. I'd expect less torque if using the 2-pole magnet I found on aliexpress.
    The $32 1656-18W motor also now has more favourable power consumption now.
    I'll have to see what the torque numbers are when at the new max expected speed of approximately 1200RPM.
    [Apr30] So I can see the amp-turns in action. I can fit 36 turns at 0.25mm diameter, 78 at 0.18 and 106 at 0.15mm, and with a 50mm rotor, they all get essentially 0.6W peak when putting in the resistances and compensating the amp. The only thing that changes is the minimum drive voltage, dropping down to 1.29V for the 36 turns configuration.
    Thus, I think the strategy needs to optimised from other perspectives. For example, If I aim for a minimum drive just under 3V, such as the 78 turns configuration, I could use the battery voltage directly. I'm already planning to read the currents drawn by the motor, thus I'd save on voltage conversion losses. With this in mind, the 18V version of the 1656 makes more sense:
    I've shuffled the order and added in the 1659RB motor mentioned in a 4th edit a few logs back.
View all 149 project logs
RunnerPack wrote 02/06/2023 at 18:22 point
(EDIT: This was supposed to be a reply to the other thread; I don't know what happened)
Well, I love blinkenlichten as much as the next guy, but if I ever made any of these, that would likely be omitted entirely or perhaps replaced by a single WS2812 LED. My ideal input device is something I never have to look at, anyway.
I didn't use the term "voice coils" but that's what a PCB motor (or, really, any electromagnetic motor) boils down to. The whole point of the magnets and (PCB) coils is to eliminate the BLDC motor for haptic/tactile feedback. As I stated, I think the hall-effect sensors would offer good enough position sensing for both motor feedback and reporting motion to the host device.
Absolute position would be easy enough to keep track of in software, and I don't see why you would need absolute positioning across power cycles in this application (although I admit I only vaguely understand the concept beyond "one slider per finger that are also analog buttons" at this point). As the "belt motor" would be coreless, I don't think cogging would be an issue.
"Are there any specific optimisations you're trying to achieve with your idea, such as footprint / price / ease of manufacturability?"
It's just a gut feeling, but I think eliminating the rotary motor & mechanics would positively affect all of these, and maybe even improve user experience. (Although I've never tried it, I'm not enthusiastic about trying to drag bead chains across an OLED with my fingertips for any length of time, with or without a 240g opposing force).
Anyway, I was just brainstorming possible alternative ways of achieving the basic idea, not trying to upend the entire project.
kelvinA wrote 02/06/2023 at 23:49 point
When I was talking about the voice coils, I intended to mean a vibration originating from underneath the entire sliding surface and not just the (PCB) motor position.
The Ahmsville Dial sounds to be the type of encoding closest to what you're describing, but it seems to also require an analog comparator chip for interrupt signals. I'd have to see if the 24-bit ADC (which I need for the load cell) has any interrupt features I could use.
The main issue I have with the idea is the non-automated manufacture of 10 magnet-infused belts at even basic mouse resolution of 800dpi, or 31 dots per millimeter. I'll calculate it now:
For a 10mm diameter, one "dot" of distance is 0.03226mm, the chord angle is 0.369672 and thus the minimum required steps per revolution is 974. Hm... that sounds kind of manageable actually. I'll assume 1.5x1.5x1.5mm square magnets since they'd be stronger than the 1mm^3 ones and I'd need less of them to cover the approx 130mm length. Assuming a 1.5mm gap between magnets, I'd need 43 magnets in the belt, where about 5 would fit in the motor semicircle and the equivalent full circle encoder would have 10 magnets. Going off the Ahmsville provided formulae [https://youtu.be/_1tGosBLRB0?t=147], base resolution would be 20, but the hall effect sensors can detect a range of values. Practical resolution was found to be 25% of the theoretical resolution taking this range into account, for a 64.5X multiplier. Thus the resolution in this system is 1290. It might work, but I've only really used mice with >=2000 DPI.
Still not a fan of accurately positioning and casting 430 tiny magnets though, and it still requires the stator to be able to somehow generate 240gf. The magnets also have a higher mass -- and as such, inertia -- which would have to be overcome for any haptics to be felt.
RunnerPack wrote 02/07/2023 at 15:33 point
Yes, the assembly process has always been my greatest concern.  My first thought was a plastic fixture to hold the ring of magnets while the outside of the belt is cast, then transferring that to another mold to do the inside of the belt.
It's too bad one can't get the raw, sintered, plated NdFeB pills and magnetize them in-situ, but I think they have to be magnetized before sintering.
Oh, well, probably not worth pursuing, then.  Thanks for entertaining the idea.
kelvinA wrote 02/07/2023 at 17:38 point
I've been scanning the interwebs for concept ideas, so of course I'm going to explore any idea I just get given.
A 3D printer like the SecSavr Suspense would be able to print the belt (in a silicone-like material) and pick+place the magnets into place mid-print, as well as a good-enough-for-me chance of being able to print the stator too, but I'm making Tetrinsic to use in Tetent to create the Suspense much faster than I'd otherwise be able to; that's a circular dependency.
A jig could be used that accepts 2 magnet stacks (where one is the opposite polarity as the other) and it pushes 2 magnets into mid-print voids at a time.
kelvinA wrote 08/29/2023 at 15:53 point
I think I might need to look further into this potential solution, now that the motor I've been designing around has disappeared from AliExpress and the SmartKnob project still has trouble sourcing low-cogging motors.
RunnerPack wrote 02/01/2023 at 20:26 point
Idea: cast a belt from clear silicone/polyurethane with embedded magnets. Wrap it around a stack consisting of the screen and a PCB with printed coils (a PCB motor). Making it slide smoothly over all the internal surfaces might be an issue. Bearings + PTFE, perhaps?
If the coils aren't enough for position sensing, you could add hall-effect sensors. You could use a pair of simple hall switches, mounted such that you get a quadrature output as the magnets go by (one lined up with a magnet, the other half way between two magnets). This might be a good idea, anyway, as brushless motors are easier to control at low speeds with feedback.
kelvinA wrote 02/01/2023 at 21:14 point
I ran a mental simulation using the assumption of 1x1x1mm magnetic cubes of alternating polarity orientation cast into a 1.5x1.5mm (square cross section) silicone belt.
The proposed solution... failed, due to:
- PCB motor unlikely to generate 240g of opposing force
- Silicone likely to absorb haptic vibrations
- Friction of silicone against screen surface
- Additional circuitry needed for hall effect sensors, providing less resolution than what [magnetoresistive sensor -> 24-bit ADC] can provide
- Hall effect sensors do not offer absolute encoding of rotor position
RunnerPack wrote 02/02/2023 at 15:36 point
- Since you wouldn't want to obscure the screen, I was thinking two rings of magnets; one on each rim of the belt, rather than a single ring. This would double the force metric in your mental simulation. To double it again, a second PCB on the underside of the belt could be used (i.e. belt, screen, PCB, belt, PCB).
- I disagree with your vibration damping theory; both silicones and urethanes come in a range of hardnesses. If nothing suitable can be found, perhaps the magnets could be linked using e.g. nylon belts, which are then over-molded with the silicone/PU.
- The friction of the belt is still an issue, but I don't think it's insurmountable.
- I didn't know absolute position sensing was a requirement. I thought this was essentially a flat scroll-wheel with a screen inside (and, in any case, I question the utility of having a screen under your fingers on a chording keyer).
kelvinA wrote 02/02/2023 at 21:57 point
- The screen is not a fundamental requirement and more of an aesthetic Quality Of Life feature. It's easy for a maker to omit the screen in favour of another flat material, but difficult to go the other way around. For this application, think of it more as a thin, uniformally lit RGB led backlight in the exact size I need that just happens to be able to show visual animations instead of block colours.
- I was simulating a belt that's flexible enough to take a 5mm radius pulley turn. You haven't mentioned the use of voice coils or a vibration motor, so I simulated the haptic events originating from the main motor.
- UWMPE tape is the best candidate I know of for friction reduction. It wasn't mentioned so I didn't simulate it.
- Absolute encoding is used for BLDC current control and analog alternate modes for Tetent. Ideally, it could also be used to mitigate natural cogging in the motor with software.
