Everything in this project can kill you.
I'm not an engineer, I'm not a programmer nor do I have any kind of useful expertise.
You shouldn't be doing this DIY project without professional help.
You can die. You've been warned.
Project summary:
https://docs.google.com/document/d/1qyQYm0QjpYjyiu1zU5EMsVFoiNilVkun_hlkQe6SLAA/edit?usp=sharing
It reached 135 pages of length, which makes me wonder if I should make another document summarizing the summary...
I can't believe I actually did this, but here is the summarization of the summary: https://docs.google.com/document/d/1ZvMbKShCkE3SBjmZKuf8KzD9dwsU5JJg2uKle2R-5nA/edit?usp=sharing (75 pages long [such summarization])
Basically, what it concludes:
- It is too complex for a single person to make it alone, I would need a degree on electrical engineering, mechanical engineering, electronic engineering and electrochemistry in order to design and build everything from scratch.
- I would need to build components multiple times using multiple tools while working in a homemade lab, which I can't afford.
- To this day I still couldn't find exactly how much power each actuator in the mech's body would need to output, so if I'm having difficult with just that, imagine the rest.
(I only talk about the essentials and more promising ideas of the project, however, none of them are proved to work, this project was researched knowingly it was doomed to never work, but it was done so for fun.)
Well, the thing is: I kinda wanted to make Project Log 90 the final project log...
However, I kept procrastinating, and procrastinating, and procrastinating, and procrastinating so much that I eventually reached 800 pages on google docs (link). And now I kinda gave up on the project... (I still add new stuff time to time)
... At least until I feel like trying to continue it again.
So, from Project Log 91 to Project Log 121, I'm just copy-pasting the Project Log 90 into the Hackaday blog because it is too long to fit in a single project log.
Confusing? Yeah, sometimes I feel like whatever the hell I write looks like the ramblings of a madman.
(I have ADHD, Depression and Anxiety [I am medicated {I've done this project just to keep me sane as a distraction to everything happening in the world and around me}])
(Just a few months ago I was finally diagnosed with psychosis, and one of its symptoms is delusions of grandeur, which explains why I wrote 2000 fucking pages on this project without making any progress at all. I was just gushing about mechs [and in the end it really was the ramblings of a madman])
Anteneh Gashaw
MECHANICUS
WalkerDev
