Semifinalist and Best Product Finalist Spreadsheet
08/25/2015 at 05:26 • 0 commentsTo coincide with Hackaday releasing today's Semifinalist and Best Product Finalist lists, we've created a new spreadsheet which should include all of the finalists:
2015 Hackaday Prize Semifinalist and Best Product Finalist Spreadsheet
Congratulations!
Sortable and Searchable Project Spreadsheet
08/21/2015 at 04:28 • 4 commentsOver the last two days, we created a list of all of the projects tagged with the correct tags for the 2015 Hackaday Prize or Best Product*. You can find our spreadsheet here:
( Editor: This is now archived. 2015 Hackaday Prize and Best Product Spreadsheet.)
*(Note we're estimating if projects qualify based on the tags and our scraping - our columns on Best Product and the Quarterfinals are not canonical. Please let us know if you see an entry mislabeled.)
Project Log Creation Graphs
08/20/2015 at 04:50 • 0 commentsProjects Added Per Day:
Data - https://gist.github.com/anonymous/747e8acd2fae96421a93
Total Number of Projects:
Data - https://gist.github.com/anonymous/00ff97cfc206f78afe47
The data was obtained from the "Created on" project date and the graphs were scaled to the duration of the prize (so projects added before this aren't shown in the first graph).
While there is a small inflection at the end, the growth rate was pretty steady this year. Can anyone name the spike events?
Tag Cloud
08/19/2015 at 03:25 • 0 comments![]()
And something different:
And if you hate angles:
Generated using tagxedo.
Word list here - https://gist.github.com/alpha-ninja/64a99368d230a22f2af2
Top 100 of all 2015 Hackaday Prize entries
08/18/2015 at 10:32 • 0 commentsA quick and dirty Top 100 by copy/paste the projects webpage text, then arrange the data in a spreadsheet pivot table
Grand Totals
Authors: 672
Projects: 910
Comments: 3 169
Skulls: 7 947
Followers: 22 421
View Count: 1 544 197Top 100 projects and authors, by skulls, followers, views or comments
- Top 100 Projects by Skulls
- Top 100 Projects by Followers
- Top 100 Projects by View Count
- Top 100 Projects by Comments
- Top 100 Authors by Projects
- Top 100 Authors by Skulls
- Top 100 Authors by Followers
- Top 100 Authors by Comments
- Top 100 Authors by Views
Raw data available in the initial project, Statistics for 2015 Hackaday Prize Entries.
Analyzing The 2015 Hackaday Prize From Your Console!
08/18/2015 at 08:03 • 2 commentsHave a *NIX based system? I've got some bash magic here to help you examine the Hackaday Prize 2015 entries, thanks to @alpha_ninja dumping all of the data as of 8/17/2015 into Github.
Yes, there are faster ways to do these things - but it's 2015 and these commands are fast enough for our purposes:
git clone https://github.com/alpha-ninja/had-data.git cd had-data/had # First, get all L.txt files, (which is the project log dump) ls *L.txt | tr '\n' '\n' > filenames # Quick cut - how many projects had > 3 logs? for fn in `cat filenames`; do filelogs=$(grep -i "#discussion-list" $fn | grep -i "log" | wc -l); if [ $filelogs -gt 3 ] ; then echo $fn ; fi; done | wc -l # Blecky, alpha_ninja and I all get 406 # Now do video references > 0 and logs > 3 for fn in `cat filenames`; do filelogs=$(grep -i "#discussion-list" $fn | grep -i "log" | wc -l); videos=$(grep -Ei -e youtube -e youkou -e video $fn | wc -l); if [ $filelogs -gt 3 ] && [ $videos -gt 0 ] ; then echo $fn ; fi; done | wc -l # (Remove wc -l to see the file names) # I got 219, which is lower than @Blecky and @alpha_ninja; use their lists most likely. # Now, best product. It is self-selected, so put everything in a file. grep -i "bestproduct" * | grep "submissions" | awk -F'.' '{print $1}' > bproduct # Now loop and search for greater than 7 logs and greater than one references to video for fn in `cat bproduct`; do fn2=L.txt; fnold=$fn; fn=$fn$fn2; videos=$(grep -Ei -e youtube -e youkou -e video -e youtu $fn | wc -l); filelogs=$(grep -i "#discussion-list" $fn | grep -i "log" | wc -l); if [ $videos -gt 1 ] && [ $filelogs -gt 7 ]; then echo $fnold ; fi; done | wc -l # I get 20 - check my workDefinitely check my work, and remove the "wc -l" if you want to see individual IDs (to check if it matches up with projects you know qualified, for example).
Have fun!
Insights From Amazon Machine Learning
06/18/2015 at 05:59 • 10 commentsI took the most recent CSV (which does not include the most recent data on views), removed some projects with irregular data, removed some attributes that I did not want in the analysis, and uploaded the data into a S3 bucket on Amazon Web Services.
I then created an Amazon Machine Learning model with the modified CSV. Of the attributes included in the analysis, I decided that I most wanted to analyze the factors to determine the likelihood of not just winning a prize, but winning multiple prizes. So I set the "Prize Count" attribute as the Target. Below is a summary of the stats for the numerical categories:
Attributes
Correlations to target
Range
Mean
Median
Comments 0.02909 0 - 58 5.2 2 Number of Entries 0.03509 1.595238095 1 Followers 0.07032 0 - 242 28.8952381 15 Prize Count 1.619047619 1 Skulls 0.12469 0 - 93 10.93333333 5 Views 0.22347 50 - 13300 685.4809524 73 My conclusion from the summary above is that Project Views will most likely translate to prizes on Hackaday!
...but wait, the model also included a categorical attribute:
Attributes
Unique values
Most frequent categories
Least frequent
Win Date 0.28765 10 5/14/2015 4/7/2015 Wow, the "Win Date" category (which is based on the first date with which a specific project won a prize) had the highest correlation towards winning multiple prizes.
In conclusion, if you wanted to win prizes in the first 10 weeks of giveaways, your best bet was to submit your project as early as possible, and update project logs as much as possible so as to garner more views from the "trending projects" feed. Skulls matter, but not as much as "Views" and "Date Submitted". Comments don't really seem to matter.
Going forward, I am not sure how reliable this data will be as prizes will now be based on community voting as well as inclusion in sponsor lists. All I know is that I am glad that I found Hackaday as a venue for my projects. Prizes are the best!
(I will edit this log with a link to my modified CSV shortly)
Most Wanted Hackaday Top 10 Lists
06/10/2015 at 23:30 • 12 comments(Spoiler Alert: This may contain the future finalists)
This was easy to put together from the last log. The views:skulls suggestion was not as helpful as expected, but I think the last list "Top 10 Number of Times in Top 10 Lists" is a good indicator of whats happening here.
The Unofficial Top 10 Lists of the Hackaday Prize Prizewinners So Far:
Top 10 Most Skulled Views Comm Foll Skull Entries Realtime PCR Diagnostic Device 8000 21 219 93 1 Bench Power Supply 10600 41 242 82 3 Arduino MPPT Solar Charge Controller 5200 36 162 79 2 Eye drive wheelchair 9 58 70 1 EM-Drive 58 185 70 5 Medical tricorder 903 6 71 54 3 6DOF Robot Arm 10800 8 134 53 1 low-field MRI 1100 5 85 51 2 Power Monitor 8000 15 168 50 1 Portable environmental monitor 550 12 68 48 1 Top 10 Most Followed Views Comm Foll Skull Entries Bench Power Supply 10600 41 242 82 3 Realtime PCR Diagnostic Device 8000 21 219 93 1 EM-Drive 58 185 70 5 Power Monitor 8000 15 168 50 1 Arduino MPPT Solar Charge Controller 5200 36 162 79 2 6DOF Robot Arm 10800 8 134 53 1 Your satellite devkit and launch 11600 50 133 43 5 nRFIoT – Easy IoT Sensors 4100 13 125 30 1 Open Ground Penetrating Radar 766 15 116 36 1 DIY Smartphone 13300 6 111 38 2 Top 10 Most Views Views Comm Foll Skull Entries DIY Smartphone 13300 6 111 38 2 Your satellite devkit and launch 11600 50 133 43 5 6DOF Robot Arm 10800 8 134 53 1 Bench Power Supply 10600 41 242 82 3 Realtime PCR Diagnostic Device 8000 21 219 93 1 Power Monitor 8000 15 168 50 1 Arduino MPPT Solar Charge Controller 5200 36 162 79 2 Electric Ninja 4800 7 49 19 1 Portable tiny IoT device solving general problem 4400 13 46 17 3 nRFIoT – Easy IoT Sensors 4100 13 125 30 1 Top 10 Most Commented Views Comm Foll Skull Entries EM-Drive 58 185 70 5 SubPos - Positioning System 3000 53 90 39 2 Your satellite devkit and launch 11600 50 133 43 5 Bench Power Supply 10600 41 242 82 3 Arduino MPPT Solar Charge Controller 5200 36 162 79 2 Open source two stroke diesel engine 34 74 26 1 Open source sport watch 2800 27 92 41 1 C12666MA Micro-Spectrometer 2100 23 107 34 1 Realtime PCR Diagnostic Device 8000 21 219 93 1 Chocometer 491 19 79 35 1 Top 10 with 4 or More Prize Wins Views Comm Foll Skull Entries Prizes Indoor air pollution reduction 2 10 1 1 5 Eye drive wheelchair 9 58 70 1 4 Medical tricorder 903 6 71 54 3 4 Chocometer 491 19 79 35 1 4 Wireless Batteryless Mouse 553 2 28 13 5 4 An IOT Device That Tells Dad the Stove is Off 530 3 17 7 1 4 ESPLux - Smarts for your downlights 467 4 12 7 1 4 BLE Intertial Measurement Unit 0 13 5 1 4 Reagent Robot 323 14 22 4 1 4 Tact-Tiles 66 1 12 4 1 4 Top 10 Views per Skull Views Comm Foll Skull Entries view:skull In-Line Battery Back-Up Module for Ham Radio 1500 0 17 3 1 500 DIY Smartphone 13300 6 111 38 2 350 Domestic Geothermal Stirling Power Unit 635 4 12 2 2 318 Your satellite devkit and launch 11600 50 133 43 5 270 PixiFlood 789 0 19 3 1 263 Portable tiny IoT device solving general problem 4400 13 46 17 3 259 Electric Ninja 4800 7 49 19 1 253 sat.Send 2700 3 43 12 1 225 uBBB 32u4 447 15 17 2 3 224 6DOF Robot Arm 10800 8 134 53 1 204 Top 10 Number of Times in Top 10 Lists Views Comm Foll Skull Entries Lists Realtime PCR Diagnostic Device 8000 21 219 93 1 4 Bench Power Supply 10600 41 242 82 3 4 Arduino MPPT Solar Charge Controller 5200 36 162 79 2 4 6DOF Robot Arm 10800 8 134 53 1 4 Your satellite devkit and launch 11600 50 133 43 5 4 EM-Drive 58 185 70 5 3 Power Monitor 8000 15 168 50 1 3 DIY Smartphone 13300 6 111 38 2 3 Eye drive wheelchair 9 58 70 1 2 Medical tricorder 903 6 71 54 3 2 -
A Better Sheet
06/10/2015 at 09:17 • 1 commentA new and improved spreadsheet is now sorted by project, instead of by contest, making it easier to sort and analyze (no more double entries!) Get the spreadsheet, it looks much better. Download the new one here. It has presorted sheets for most Skulls, most Followers, and the new column sorted by a Views to Skulls ratio, with the data that was available (see feedback 6-10-2015.)
Someone won five times. You can find other information hidden in here also.Column Names:
Project Name, Views, Comments, Followers, Skulls, Number of Entries, Data collection date, Number of Wins, Win Dates, and Views:Skulls.Project Name Views Com Foll Skull Ent Date of data Wins Win Date Win Date Win Date Win Date Win Date Views:Skulls Improve the Bosch-Haber process 2700 16 75 36 1 06-08 1 03-31 75.00 DayBreaker 374 8 12 5 3 06-08 3 03-31 05-07 05-14 74.80 Domestic Geothermal Stirling Power Unit 635 4 12 2 2 06-08 1 03-31 317.50 Personal Medical Assistant 517 0 11 5 1 06-08 3 04-07 05-07 05-14 103.40 Julia's Speakerphone 643 2 10 12 1 06-08 1 04-07 53.58 Aging in Place: Being There with Pi 688 2 13 4 7 06-08 1 04-07 172.00 The Smart Garden 612 4 35 8 4 06-08 3 04-14 05-07 05-14 76.50 Soil Moisture Sensor for Agriculture 58 13 13 3 1 06-08 1 04-14 19.33 Solar Water Pump 626 0 14 4 1 06-08 1 04-14 156.50 AKER 0 33 12 1 06-08 1 04-21 #VALUE! Modular Vertical Farming 551 1 51 14 1 06-08 3 04-21 05-14 05-28 39.36 Condensate capture for micro-irrigation 4 7 1 1 06-08 1 04-21 #VALUE! 100$ Xray desktop CT scanner 1200 4 68 21 5 06-08 3 04-30 05-14 05-21 57.14 Algorithmic Composter 124 3 13 2 2 06-08 1 04-30 62.00 An IOT Device That Tells Dad the Stove is Off 530 3 17 7 1 06-08 4 04-30 05-07 05-14 06-04 75.71 Arduino MPPT Solar Charge Controller 5200 36 162 79 2 06-08 2 04-30 06-04 65.82 Binary Fuel Tank Err? 06-08 1 04-30 #VALUE! BLE Intertial Measurement Unit 0 13 5 1 06-08 4 04-30 05-07 05-14 06-04 #VALUE! Blockits 276 2 11 4 1 06-08 2 04-30 05-14 69.00 Chocometer 491 19 79 35 1 06-08 4 04-30 05-07 05-28 06-04 14.03 Dual Channel Battery Charger/Analyzer 377 0 25 3 4 06-08 2 04-30 06-04 125.67 E-ink Raspberry Pi display 1500 9 65 20 3 06-08 1 04-30 75.00 ESPLux - Smarts for your downlights 467 4 12 7 1 06-08 4 04-30 05-07 05-14 06-04 66.71 Eye drive wheelchair 9 58 70 1 06-08 4 04-30 05-14 05-21 06-04 #VALUE! Gas Sensor For Emergency Workers 373 4 25 22 1 06-08 3 04-30 05-07 05-14 16.95 guerillamesh.net 202 2 20 8 1 06-08 1 04-30 25.25 Internet enabled smoke alarm 0 11 3 1 06-08 3 04-30 05-14 06-04 #VALUE! Medical tricorder 903 6 71 54 3 06-08 4 04-30 05-14 05-21 06-04 16.72 Open Ground Penetrating Radar 766 15 116 36 1 06-08 3 04-30 05-14 05-21 21.28 Open Source Cell Phone 1100 2 65 20 1 06-08 2 04-30 05-14 55.00 Pathfinder - Haptic Navigation 424 4 41 14 1 06-08 2 04-30 05-21 30.29 Portable environmental monitor 550 12 68 48 1 06-08 3 04-30 05-14 06-04 11.46 sat.Send 2700 3 43 12 1 06-08 1 04-30 225.00 SentriFarm (Farmer stay in Bed, too hot to reap!) 617 11 27 5 2 06-08 3 04-30 05-14 06-04 123.40 Share the Warmth 0 11 4 1 06-08 2 04-30 05-14 #VALUE! A Smart Fridge With Brains 187 0 15 2 1 06-08 2 04-30 05-14 93.50 Smart Solar Lamp 261 9 11 4 1 06-08 1 04-30 65.25 SubPos - Positioning System 3000 53 90 39 2 06-08 3 04-30 05-14 05-21 76.92 Tact-Tiles 66 1 12 4 1 06-08 4 04-30 05-14 05-21 05-28 16.50 Terra Spider 899 0 33 13 1 06-08 3 04-30 05-14 06-04 69.15 The Vision Project 237 9 24 10 4 06-08 2 04-30 05-14 23.70 Wireless Batteryless Mouse 553 2 28 13 5 06-08 4 04-30 05-07 05-21 06-04 42.54 A Wireless I2C Bridge for Amateur Radio Use 0 5 2 1 06-08 3 05-07 05-14 06-04 #VALUE! Automatic Plant Watering System 5 25 8 2 06-08 2 05-07 05-14 #VALUE! Bicycle Computer 160 2 16 7 4 06-08 3 05-07 05-14 05-21 22.86 BloodWatch 0 20 5 1 06-08 3 05-07 05-14 05-21 #VALUE! Braille Computer 9 22 15 4 06-08 3 05-07 05-14 06-04 #VALUE! BSU – BS Free USB 571 15 52 22 1 06-08 1 05-07 25.95 CoreConduit: Automated Garden Controller System 0 15 3 1 06-08 1 05-07 #VALUE! CTRL-BA 110 0 6 1 1 06-08 2 05-07 05-14 110.00 Density Altitude Gauge 0 8 6 1 06-08 3 05-07 05-14 05-21 #VALUE! Dusty – The smart dustbin 193 0 13 3 1 06-08 1 05-07 64.33 FacilTempo – weather station 735 7 40 11 4 06-08 2 05-07 05-14 66.82 HydroPWNics 64 9 78 31 1 06-08 2 05-07 05-14 2.06 Indoor air pollution reduction 2 10 1 1 06-08 5 05-07 05-14 05-21 05-28 06-04 #VALUE! Inexpensive Water Quality Testing System 3 12 2 1 06-08 1 05-07 #VALUE! Instant Traffic Collision Notifier 1200 9 18 8 4 06-08 1 05-07 150.00 LiteHouse 55 0 1 0 3 06-08 2 05-07 05-14 #DIV/0! Low Cost Wireless Home Automation and Security 2 43 8 2 06-08 3 05-07 05-14 06-04 #VALUE! Low-noise, Easy-to-use Analog Data Logger: SiGZiG 229 8 16 6 1 06-08 3 05-07 05-14 06-04 38.17 LTA based Farm Monitoring Solution 2 4 2 1 06-08 2 05-07 05-14 #VALUE! Mesh network based Internet access 1 7 0 3 06-08 2 05-07 05-14 #VALUE! MiCubes are your cubes! 0 15 5 1 06-08 1 05-07 #VALUE! NIRGM – Non-Invasive NIR Glucose Meter 18 67 22 1 06-08 2 05-07 05-14 #VALUE! Open Sensor Array 145 0 13 0 2 06-08 1 05-07 #DIV/0! PixiFlood 789 0 19 3 1 06-08 1 05-07 263.00 Portable tiny IoT device solving general problem 4400 13 46 17 3 06-08 3 05-07 05-14 06-04 258.82 Power Monitor 8000 15 168 50 1 06-08 1 05-07 160.00 Reagent Robot 323 14 22 4 1 06-08 4 05-07 05-14 05-21 05-28 80.75 Rice Ridiculously Automated Dorm (RRAD!) 128 0 14 3 2 06-08 1 05-07 42.67 SciPIo 402 9 13 5 1 06-08 1 05-07 80.40 Smartphone Tricorder 0 4 3 3 06-08 2 05-07 05-14 #VALUE! Squirco Smart Home System – Sensor Network 876 2 56 11 3 06-08 2 05-07 05-14 79.64 StormSafe 6 23 6 1 06-08 2 05-07 05-14 #VALUE! Teleimperium 2 12 3 1 06-08 2 05-07 06-04 #VALUE! the HOT project 0 0 2 1 06-08 1 05-07 #VALUE! The ProReg – Fuel Monitoring System 368 17 12 7 4 06-08 1 05-07 52.57 Theme Park of Everyday Installation 0 7 6 1 06-08 1 05-07 #VALUE! Timstock Slim – a tool for the autistic 5 20 13 2 06-08 3 05-07 05-14 06-04 #VALUE! Very Expensive Tool + Green Lasers 188 1 6 3 1 06-08 1 05-07 62.67 Very thin (but touch type-able) USB keyboard ! 858 0 21 10 3 06-08 2 05-07 05-21 85.80 Weather Controlled SmartWindow 181 4 21 5 1 06-08 3 05-07 05-21 06-04 36.20 Your satellite devkit and launch 11600 50 133 43 5 06-08 1 05-07 269.77 Poor Man's "Laser" Cutter 248 19 25 8 2 06-08 1 05-14 31.00 C12666MA Micro-Spectrometer 2100 23 107 34 1 06-08 2 05-14 06-04 61.76 NodeUSB- 'Eat your own dog food' WiFi IoT DevKit 555 0 25 6 1 06-08 2 05-14 06-04 92.50 AltiRocket 1 7 6 1 06-08 1 05-14 #VALUE! Home automation using RF mesh network and arduino 4 31 9 1 06-08 1 05-14 #VALUE! Low Cost Weather Station 475 10 56 12 1 06-08 1 05-14 39.58 Impact 10 24 12 1 06-08 2 05-14 05-21 #VALUE! Sunburn Monitor 5 12 4 1 06-08 2 05-14 05-28 #VALUE! Driverless Mouse and Keyboard Sharing 407 12 64 22 2 06-08 2 05-14 06-04 18.50 Keep the basil alive 0 6 1 1 06-08 1 05-14 #VALUE! Mute-ation 166 1 10 4 1 06-08 2 05-14 06-04 41.50 EzeeSample 0 3 1 1 06-08 2 05-14 06-04 #VALUE! Wi-Fi Gauge 0 6 1 1 06-08 1 05-14 #VALUE! A low cost multispectral imaging payload for a UAV 417 0 36 10 1 06-08 2 05-14 06-04 41.70 8-bit binary/hex/braille keyboard 51 5 19 7 4 06-08 3 05-14 05-21 05-28 7.29 Bench Power Supply 10600 41 242 82 3 06-08 2 05-14 06-04 129.27 DC Motor Controller for CNC Router 532 5 41 9 2 06-08 3 05-14 05-21 06-04 59.11 Earthquake Early Warning and Monitoring System 1 10 6 1 06-08 1 05-14 #VALUE! Data-Theft-Detecting Router & Server 1 17 4 2 06-08 1 05-14 #VALUE! Smart Dew-Point Water Harvester 422 7 29 6 1 06-08 1 05-14 70.33 The Temperizer 3 8 3 1 06-08 2 05-14 05-21 #VALUE! Pill Minder – Automatic Pill Dispenser 473 5 22 8 1 06-08 2 05-14 05-21 59.13 Cheepit: Sparrow (dev boards for smartphones) 1100 2 23 14 1 06-08 1 05-14 78.57 #T_H_S 195 4 16 3 1 06-08 1 05-14 65.00 Indoor Aquaponics now: AAGriculture 281 5 33 5 1 06-08 1 05-14 56.20 Big Old Bus RV Conversion 793 0 13 4 1 06-08 1 05-14 198.25 TeensyGLCD 52 0 23 1 1 06-08 2 05-14 05-28 52.00 The Informer 0 17 1 1 06-08 1 05-14 #VALUE! Smart Hot Water Heater Controller 0 1 0 1 06-08 1 05-14 #VALUE! Squirco Smart Home System – Hub + Thermostat 61 3 11 2 3 06-08 2 05-14 05-28 30.50 ButlerBOT 115 0 9 1 1 06-08 2 05-14 06-04 115.00 Automatic Hydroponic Greenhouse 0 3 0 1 06-08 1 05-14 #VALUE! Turbidity Sensor 173 4 17 4 1 06-08 3 05-14 05-21 05-28 43.25 Moisture monitoring mesh network 156 2 9 1 3 06-08 1 05-14 156.00 Eco-Friendly Solar-io Cart 3 12 3 1 06-08 1 05-14 #VALUE! DepressionAlarm 281 4 26 16 1 06-08 1 05-14 17.56 Low power smartphone OS 73 4 24 2 1 06-08 1 05-14 36.50 Open Source Fitness Band 0 8 1 2 06-08 1 05-14 #VALUE! BarT – The Automated Bartender 1 11 1 1 06-08 1 05-14 #VALUE! Iridium Eye: A 3d Mapping Drone 791 4 78 21 1 06-08 2 05-14 05-28 37.67 Environmental Condition Monitor 0 3 0 2 06-08 1 05-14 #VALUE! Smart Juggling Balls 0 18 15 2 06-08 1 05-14 #VALUE! Open Source Industrial Smart Camera 98 2 15 3 1 06-08 3 05-14 05-28 06-04 32.67 ScrolLED watch 5 7 4 3 06-08 2 05-14 05-21 #VALUE! Beer Menu Please 0 3 1 1 06-08 1 05-14 #VALUE! Noise Cancelling Headphone 0 5 0 1 06-08 1 05-14 #VALUE! PASS: Pollution Analytics Shared Socially 2 2 0 1 06-08 1 05-14 #VALUE! Low cost Android USB vital signs monitor 0 1 1 1 06-08 1 05-14 #VALUE! TheSixthSense 4 10 5 1 06-08 2 05-14 05-21 #VALUE! SenseBoard 0 0 0 1 06-08 1 05-14 #VALUE! BBQ Smoker Temp Control 0 4 1 2 06-08 1 05-14 #VALUE! Home Automation – BT Modules 0 8 0 1 06-08 1 05-14 #VALUE! SD card back up tool 0 12 0 1 06-08 1 05-14 #VALUE! Portable information player by Teensy LC Err? 06-08 1 05-14 #VALUE! Iron Man gauntlet 0 0 0 2 06-08 1 05-14 #VALUE! K-9 robotic pet 205 2 38 5 2 06-08 1 05-14 41.00 EnVision 1 4 1 2 06-08 1 05-14 #VALUE! Inline Keymap Switcher 6 1 1 1 06-08 1 05-14 #VALUE! Search & Rescue / Disaster relief WiFi 1 2 0 1 06-08 1 05-14 #VALUE! ikebike 1 5 2 1 06-08 1 05-14 #VALUE! fHome, a cheap and easy home automation system 0 12 1 1 06-08 1 05-14 #VALUE! Navigating Poet 3 5 3 1 06-08 1 05-14 #VALUE! Retro Modules 1 2 2 1 06-08 1 05-14 #VALUE! Low cost compact drone 0 1 0 1 06-08 1 05-14 #VALUE! DC UPS and Wallwarts Eliminator 4 10 6 4 06-08 2 05-14 06-04 #VALUE! PQ60 – EPS 472 8 12 4 1 06-08 1 05-14 118.00 Reverse Vending Machine 260 3 15 6 1 06-08 2 05-14 05-28 43.33 FlexSEA: Wearable robotics toolkit 0 11 7 1 06-08 1 05-14 #VALUE! Strain Indicator V2.0 55 7 11 4 1 06-08 1 05-14 13.75 Virtual Printer 0 2 1 1 06-08 1 05-14 #VALUE! Re_Arm 1 0 1 1 06-08 1 05-14 #VALUE! LaserOscope 290 0 9 4 1 06-08 1 05-14 72.50 XORYA – extremely low cost game console on PIC32 13 29 11 1 06-08 1 05-14 #VALUE! Takologic 5 5 1 1 06-08 1 05-14 #VALUE! Responsive Planter 2 7 2 2 06-08 1 05-14 #VALUE! 256 Channel Firework Controller 0 5 0 2 06-08 1 05-14 #VALUE! On-Demand Sprinkler System 1 12 5 1 06-08 1 05-14 #VALUE! Cinebike Human Powered Cinema 3 7 10 1 06-08 1 05-14 #VALUE! Malti 628 2 15 11 1 06-08 1 05-14 57.09 energy wristband 718 3 21 7 1 06-08 1 05-14 102.57 Redtree Hydra: A modular platform for robotics 0 14 11 1 06-08 1 05-21 #VALUE! Aspirin for everyone 17 36 30 1 06-08 1 05-21 #VALUE! EM-Drive 58 185 70 5 06-08 2 05-21 06-04 #VALUE! UV-badge 710 11 43 18 1 06-08 2 05-21 05-28 39.44 Small $100 Braille Printer 3 3 2 4 06-08 1 05-21 #VALUE! Calculator For 3D Printed Parametric Motor 160 4 48 21 3 06-08 1 05-21 7.62 NeoLimb 671 2 47 5 1 06-08 1 05-21 134.20 Nutritional Content of Food with RamanPi 123 1 9 4 1 06-08 1 05-21 30.75 low-field MRI 1100 5 85 51 2 06-08 2 05-21 06-04 21.57 DIY Smartphone 13300 6 111 38 2 06-08 1 05-21 350.00 6DOF Robot Arm 10800 8 134 53 1 06-08 1 05-21 203.77 Open source sport watch 2800 27 92 41 1 06-08 1 05-21 68.29 Open-source USB CPAP machine 124 0 12 7 1 06-08 1 05-21 17.71 Realtime PCR Diagnostic Device 8000 21 219 93 1 06-08 1 05-21 86.02 A tiny scientific calculator 222 6 12 6 3 06-08 3 05-21 05-28 06-04 37.00 OpenVideoMagnifier 0 6 4 1 06-08 1 05-21 #VALUE! OpenBionics Affordable Prosthetic Hands 722 6 49 23 1 06-08 1 05-21 31.39 Binary Pomodoro Timer 0 1 2 1 06-08 2 05-28 06-04 #VALUE! Ultra-Portable Sustainable Electric Generator 0 15 8 2 06-08 1 05-28 #VALUE! Light Electric Utility Vehicle 409 10 42 29 1 06-08 1 05-28 14.10 Open source two stroke diesel engine 34 74 26 1 06-08 1 05-28 #VALUE! Ultrasonic range finder for the visually impaired 4 16 8 4 06-08 2 05-28 06-04 #VALUE! nRFIoT – Easy IoT Sensors 4100 13 125 30 1 06-08 1 06-04 136.67 AluPi – Pocketable Game and Computer System 0 4 1 1 06-08 1 06-04 #VALUE! WΛLLTΞCH PHΛNTOM: Bone-Conduction BT Audio Headset 7 18 7 1 06-08 1 06-04 #VALUE! Smart Battery makes a smarter Power Pack 0 8 2 2 06-08 1 06-04 #VALUE! Sit.Up 0 4 1 1 06-08 1 06-04 #VALUE! Car alarm secure remote with nRF24LE1 0 5 2 2 06-08 1 06-04 #VALUE! Aleph 630 10 20 8 1 06-08 1 06-04 78.75 ESP8266 Dev-Board 452 7 33 5 1 06-08 1 06-04 90.40 Health Maintenance Robot 224 4 28 10 1 06-08 1 06-04 22.40 uBBB 32u4 447 15 17 2 3 06-08 1 06-04 223.50 Residential Street Speed Watch 0 4 2 1 06-08 1 06-04 #VALUE! DIY Electric Vehicle from Recycled Parts 257 6 48 16 1 06-08 1 06-04 16.06 Python Powered Scientific Instrumentation tool 0 51 19 1 06-08 1 06-04 #VALUE! USB Booster 123 4 10 3 3 06-08 1 06-04 41.00 Muffsy Hifi Dual Power Supply 0 7 0 2 06-08 1 06-04 #VALUE! Pediatric Therapy Device 83 0 6 4 1 06-08 1 06-04 20.75 Biopotential Signal Library 1 42 16 1 06-08 1 06-04 #VALUE! Green eutectic rocket propellant 1 15 5 3 06-08 1 06-04 #VALUE! In-Line Battery Back-Up Module for Ham Radio 1500 0 17 3 1 06-08 1 06-04 500.00 Electric Ninja 4800 7 49 19 1 06-08 1 06-04 252.63 PICxie: A micro PIC18F development kit 2 8 2 1 06-08 1 06-04 #VALUE! BeagleLogic 223 4 50 20 2 06-08 1 06-04 11.15 Guard Llama 346 0 4 6 1 06-08 1 06-04 57.67 Iconic clock for deaf children 2 4 4 1 06-08 1 06-04 #VALUE! Artificial Muscles and Ultra-capacitors 1000 2 44 10 2 06-08 1 06-04 100.00 MultiSpork 700 3 79 38 1 06-08 1 06-04 18.42 Tote, affordable spider robot 6 29 19 1 06-08 1 06-04 #VALUE! Please check for mistakes. Thank you!
I finally finished the number of entries column, so "most" of the data is from 6-8.
Want to Hack the Hackaday Prize?
06/08/2015 at 11:52 • 0 commentsUpdate: I added that stubborn LibreOffice pie chart at the end ;)
What does it take to be a winner? Getting an entry in early sure helps.
I think projects with pictures, videos, and clear details, look like they get more attention.Here is the competition, see if you can find a pattern. Congratulations to all you winners!
The unofficial list of winners projects with views, comments, followers, skulls, and some with number of projects entered by the same hacker:
Contest / Date Project Name View Com Follw Skull Ent Environment-Related Ideas Improve the Bosch-Haber process 2700 16 75 36 1 March 31 DayBreaker 374 8 12 5 3 Domestic Geothermal Stirling Power Unit 635 4 12 2 2 Aging in Place Personal Medical Assistant 517 0 11 5 1 April 07 Julia's Speakerphone 643 2 10 12 1 Aging in Place: Being There with Pi 688 2 13 4 7 Urban Gardening The Smart Garden 612 4 35 8 4 April 14 Soil Moisture Sensor for Agriculture 58 13 13 3 1 Solar Water Pump 626 0 14 4 1 Water Problems AKER 0 33 12 1 April 21 Modular Vertical Farming 551 1 51 14 1 Condensate capture for micro-irrigation 4 7 1 1 $50 at OSH Park (30) 100$ Xray desktop CT scanner 1200 4 68 21 April 30 Algorithmic Composter 124 3 13 2 An IOT Device That Tells Dad the Stove is Off 530 3 17 7 Arduino MPPT Solar Charge Controller 5200 36 162 79 Binary Fuel Tank Err? :( BLE Intertial Measurement Unit 0 13 5 Blockits 276 2 11 4 Chocometer 491 19 79 35 Dual Channel Battery Charger/Analyzer 377 0 25 3 E-ink Raspberry Pi display 1500 9 65 20 ESPLux - Smarts for your downlights 467 4 12 7 Eye drive wheelchair 9 58 70 Gas Sensor For Emergency Workers 373 4 25 22 http://guerillamesh.net 202 2 20 8 Internet enabled smoke alarm 0 11 3 Medical tricorder 903 6 71 54 Open Ground Penetrating Radar 766 15 116 36 Open Source Cell Phone 1100 2 65 20 Pathfinder - Haptic Navigation 424 4 41 14 Portable environmental monitor 550 12 68 48 sat.Send 2700 3 43 12 SentriFarm (Farmer stay in Bed, too hot to reap!) 617 11 27 5 Share the Warmth 0 11 4 A Smart Fridge With Brains 187 0 15 2 Smart Solar Lamp 261 9 11 4 SubPos - Positioning System 3000 53 90 39 Tact-Tiles 66 1 12 4 Terra Spider 899 0 33 13 The Vision Project 237 9 24 10 Wireless Batteryless Mouse 553 2 28 13 LightBlue Bean (50) A Wireless I2C Bridge for Amateur Radio Use 0 5 2 May 07 An IOT Device That Tells Dad the Stove is Off. 530 3 17 7 Automatic Plant Watering System 5 25 8 Bicycle Computer 160 2 16 7 BLE Intertial Measurement Unit 0 13 5 BloodWatch 0 20 5 Braille Computer 9 22 15 BSU – BS Free USB 571 15 52 22 Chocometer 491 19 79 35 CoreConduit: Automated Garden Controller System 0 15 3 CTRL-BA 110 0 6 1 DayBreaker 374 8 12 5 Density Altitude Gauge 0 8 6 Dusty – The smart dustbin 193 0 13 3 ESPLux – Smarts for your downlights 467 4 12 7 FacilTempo – weather station 735 7 40 11 Gas Sensor For Emergency Workers 373 4 25 22 HydroPWNics 64 9 78 31 Indoor air pollution reduction 2 10 1 Inexpensive Water Quality Testing System 3 12 2 Instant Traffic Collision Notifier 1200 9 18 8 LiteHouse 55 0 1 0 Low Cost Wireless Home Automation and Security 2 43 8 Low-noise, Easy-to-use Analog Data Logger: SiGZiG 229 8 16 6 LTA based Farm Monitoring Solution 2 4 2 Mesh network based Internet access 1 7 0 MiCubes are your cubes! 0 15 5 NIRGM – Non-Invasive NIR Glucose Meter 18 67 22 Open Sensor Array 145 0 13 0 Personal Medical Assistant 517 0 11 5 PixiFlood 789 0 19 3 Portable tiny IoT device solving general problem 4400 13 46 17 Power Monitor 8000 15 168 50 Reagent Robot 323 14 22 4 Rice Ridiculously Automated Dorm (RRAD!) 128 0 14 3 SciPIo 402 9 13 5 Smartphone Tricorder 0 4 3 Squirco Smart Home System – Sensor Network 876 2 56 11 StormSafe 6 23 6 Teleimperium 2 12 3 the HOT project 0 0 2 The ProReg – Fuel Monitoring System 368 17 12 7 The Smart Garden 612 4 35 8 Theme Park of Everyday Installation 0 7 6 Timstock Slim – a tool for the autistic 5 20 13 Very Expensive Tool + Green Lasers 188 1 6 3 Very thin (but touch type-able) USB keyboard ! 858 0 21 10 Weather Controlled SmartWindow 181 4 21 5 Wireless Batteryless Mouse 553 2 28 13 Your satellite devkit and launch 11600 50 133 43 Teensy-LC (125) Poor Man's "Laser" Cutter 248 19 25 8 2 May 14 C12666MA Micro-Spectrometer 2100 23 107 34 1 HydroPWNics 64 9 78 31 1 NodeUSB- 'Eat your own dog food' WiFi IoT DevKit 555 0 25 6 1 AltiRocket 1 7 6 1 Home automation using RF mesh network and arduino 4 31 9 1 Timstock Slim – a tool for the autistic 5 20 13 2 Squirco Smart Home System – Sensor Network 876 2 56 11 3 Low Cost Weather Station 475 10 56 12 1 Impact 10 24 12 1 Sunburn Monitor 5 12 4 1 Indoor air pollution reduction 2 10 1 1 Driverless Mouse and Keyboard Sharing 407 12 64 22 2 Keep the basil alive 0 6 1 1 An IOT Device That Tells Dad the Stove is Off. 530 3 17 7 1 Mute-ation 166 1 10 4 1 EzeeSample 0 3 1 1 Portable environmental monitor 550 12 68 48 1 Eye drive wheelchair 9 58 70 1 Low Cost Wireless Home Automation and Security 2 43 8 2 ESPLux – Smarts for your downlights 467 4 12 7 1 SubPos – Positioning System 3000 53 90 39 2 Wi-Fi Gauge 0 6 1 1 A low cost multispectral imaging payload for a UAV 417 0 36 10 1 Portable tiny IoT device solving general problem 4400 13 46 17 3 NIRGM – Non-Invasive NIR Glucose Meter 18 67 22 1 Braille Computer 9 22 15 4 8-bit binary/hex/braille keyboard 51 5 19 7 4 Bench Power Supply 10600 41 242 82 3 Gas Sensor For Emergency Workers 373 4 25 22 1 BLE Intertial Measurement Unit 0 13 5 1 DC Motor Controller for CNC Router 532 5 41 9 2 Bicycle Computer 160 2 16 7 4 FacilTempo – weather station 735 7 40 11 4 Earthquake Early Warning and Monitoring System 1 10 6 1 Data-Theft-Detecting Router & Server 1 17 4 2 Smart Dew-Point Water Harvester 422 7 29 6 1 The Temperizer 3 8 3 1 BloodWatch 0 19 5 1 Pill Minder – Automatic Pill Dispenser 473 5 22 8 1 Cheepit: Sparrow (dev boards for smartphones) 1100 2 23 14 1 #T_H_S 195 4 16 3 1 Modular Vertical Farming 551 1 51 14 1 Indoor Aquaponics now: AAGriculture 281 5 33 5 1 Density Altitude Gauge 0 8 6 1 The Smart Garden 612 4 35 8 4 100$ Xray desktop CT scanner 1200 4 68 21 5 A Smart Fridge With Brains 187 0 15 2 1 Personal Medical Assistant 517 0 11 5 1 Big Old Bus RV Conversion 793 0 13 4 1 Open Source Cell Phone 1100 2 65 20 1 TeensyGLCD 52 0 23 1 1 The Informer 0 17 1 1 Smart Hot Water Heater Controller 0 1 0 1 Squirco Smart Home System – Hub + Thermostat 61 3 11 2 3 ButlerBOT 115 0 9 1 1 Tact-Tiles 66 1 12 4 1 Terra Spider 899 0 33 13 1 Automatic Hydroponic Greenhouse 0 3 0 1 Turbidity Sensor 173 4 17 4 1 Moisture monitoring mesh network 156 2 9 1 3 Eco-Friendly Solar-io Cart 3 12 3 1 DepressionAlarm 281 4 26 16 1 CTRL-BA 110 0 6 1 1 Low power smartphone OS 73 4 24 2 1 Blockits 276 2 11 4 1 Open Source Fitness Band 0 8 1 2 BarT – The Automated Bartender 1 11 1 1 Iridium Eye: A 3d Mapping Drone 791 4 78 21 1 Environmental Condition Monitor 0 3 0 2 Smart Juggling Balls 0 18 15 2 Automatic Plant Watering System 5 25 8 2 Open Source Industrial Smart Camera 98 2 15 3 1 Internet enabled smoke alarm 0 11 3 1 LiteHouse 55 0 1 0 3 DayBreaker 374 8 12 5 3 Low-noise, Easy-to-use Analog Data Logger: SiGZiG 229 8 16 6 1 ScrolLED watch 5 7 4 3 Beer Menu Please 0 3 1 1 Noise Cancelling Headphone 0 5 0 1 LTA based Farm Monitoring Solution 2 4 2 1 Smartphone Tricorder 0 4 3 3 PASS: Pollution Analytics Shared Socially 2 2 0 1 A Wireless I2C Bridge for Amateur Radio Use 0 5 2 1 Low cost Android USB vital signs monitor 0 1 1 1 TheSixthSense 4 10 5 1 SenseBoard 0 0 0 1 BBQ Smoker Temp Control 0 4 1 2 Home Automation – BT Modules 0 8 0 1 SD card back up tool 0 12 0 1 Portable information player by Teensy LC Err? :( Iron Man gauntlet 0 0 0 2 K-9 robotic pet 205 2 38 5 2 EnVision 1 4 1 2 Inline Keymap Switcher 6 1 1 1 Search & Rescue / Disaster relief WiFi 1 2 0 1 ikebike 1 5 2 1 fHome, a cheap and easy home automation system 0 12 1 1 Navigating Poet 3 5 3 1 Retro Modules 1 2 2 1 Low cost compact drone 0 1 0 1 DC UPS and Wallwarts Eliminator 4 10 6 4 PQ60 – EPS 472 8 12 4 1 Reverse Vending Machine 260 3 15 6 1 Reagent Robot 323 14 22 4 1 FlexSEA: Wearable robotics toolkit 0 11 7 1 Strain Indicator V2.0 55 7 11 4 1 Virtual Printer 0 2 1 1 Re_Arm 1 0 1 1 LaserOscope 290 0 9 4 1 XORYA – extremely low cost game console on PIC32 13 29 11 1 Takologic 5 5 1 1 Responsive Planter 2 7 2 2 256 Channel Firework Controller 0 5 0 2 Medical tricorder 903 6 71 54 3 On-Demand Sprinkler System 1 12 5 1 Mesh network based Internet access 1 7 0 3 SentriFarm (Farmer stay in Bed, too hot to reap!) 617 11 27 5 2 Cinebike Human Powered Cinema 3 7 10 1 Open Ground Penetrating Radar 766 15 116 36 1 Malti 628 2 15 11 1 StormSafe 6 23 6 1 Share the Warmth 0 11 4 1 energy wristband 718 3 21 7 1 The Vision Project 237 9 24 10 4 $50 at Shapeways (40) Redtree Hydra: A modular platform for robotics 0 14 11 May 21 Eye drive wheelchair 9 58 70 Aspirin for everyone 17 36 30 Bicycle Computer 160 2 16 7 Medical tricorder 903 6 71 54 Wireless Batteryless Mouse 553 2 28 13 EM-Drive 58 185 70 UV-badge 710 11 43 18 Small $100 Braille Printer 3 3 2 ScrolLED watch 5 7 4 Calculator For 3D Printed Parametric Motor 160 4 48 21 8-bit binary/hex/braille keyboard 51 5 19 7 Open Ground Penetrating Radar 766 15 116 36 NeoLimb 671 2 47 5 Nutritional Content of Food with RamanPi 123 1 9 4 low-field MRI 1100 5 85 51 Tact-Tiles 66 1 12 4 Turbidity Sensor 173 4 17 4 DIY Smartphone 13300 6 111 38 SubPos – Positioning System 3000 53 90 39 100$ Xray desktop CT scanner 1200 4 68 21 6DOF Robot Arm 10800 8 134 53 Open source sport watch 2800 27 92 41 Density Altitude Gauge 0 8 6 DC Motor Controller for CNC Router 532 5 41 9 Pill Minder – Automatic Pill Dispenser 437 5 22 8 Open-source USB CPAP machine 124 0 12 7 Realtime PCR Diagnostic Device 8000 21 219 93 A tiny scientific calculator 222 6 12 6 Very thin (but touch type-able) USB keyboard ! 858 0 21 10 Weather Controlled SmartWindow 181 4 21 5 Pathfinder – Haptic Navigation 424 4 41 14 TheSixthSense 4 10 5 Impact 10 24 12 Indoor air pollution reduction 2 10 1 The Temperizer 3 9 3 BloodWatch 0 20 5 OpenVideoMagnifier 0 6 4 Reagent Robot 323 14 22 4 OpenBionics Affordable Prosthetic Hands 722 6 49 23 Bulbdial Clock Kit (20) Tact-Tiles 66 1 12 4 May 28 Reverse Vending Machine 260 3 15 6 Binary Pomodoro Timer 0 1 2 8-bit binary/hex/braille keyboard 51 5 19 7 Chocometer 491 19 79 35 Reagent Robot 323 14 22 4 A tiny scientific calculator 222 6 12 6 Turbidity Sensor 173 4 17 4 Iridium Eye: A 3d Mapping Drone 791 4 78 21 TeensyGLCD 52 0 23 1 Ultra-Portable Sustainable Electric Generator 0 15 8 Light Electric Utility Vehicle 409 10 42 29 Sunburn Monitor 5 12 4 Squirco Smart Home System – Hub + Thermostat 61 3 11 2 Open source two stroke diesel engine 34 74 26 Open Source Industrial Smart Camera 98 2 15 3 Ultrasonic range finder for the visually impaired 4 16 8 Modular Vertical Farming 551 1 51 14 Indoor air pollution reduction 2 10 1 UV-badge 710 11 43 18 Stickvise (65) nRFIoT – Easy IoT Sensors 4100 13 125 30 June 04 AluPi – Pocketable Game and Computer System 0 4 1 Portable environmental monitor 550 12 68 48 Mute-ation 166 1 10 4 WΛLLTΞCH PHΛNTOM: Bone-Conduction BT Audio Headset 7 18 7 Dual Channel Battery Charger/Analyzer 337 0 25 3 low-field MRI 1100 5 85 51 Smart Battery makes a smarter Power Pack 0 8 2 Indoor air pollution reduction 2 10 1 A low cost multispectral imaging payload for a UAV 417 0 36 10 Medical tricorder 903 6 71 54 A tiny scientific calculator 222 6 12 6 EzeeSample 0 3 1 Open Source Industrial Smart Camera 98 2 15 3 Eye drive wheelchair 9 58 70 Teleimperium 2 12 3 An IOT Device That Tells Dad the Stove is Off. 530 3 17 7 DC Motor Controller for CNC Router 532 5 41 9 Terra Spider 899 0 33 13 Chocometer 491 19 79 35 Ultrasonic range finder for the visually impaired 4 16 8 Sit.Up 0 4 1 Car alarm secure remote with nRF24LE1 0 5 2 Bench Power Supply 10600 41 242 82 Aleph 630 10 20 8 Weather Controlled SmartWindow 181 4 21 5 ESP8266 Dev-Board 452 7 33 5 Health Maintenance Robot 224 4 28 10 uBBB 32u4 447 15 17 2 BLE Intertial Measurement Unit 0 13 5 ButlerBOT 115 0 9 1 Driverless Mouse and Keyboard Sharing 407 12 64 22 Residential Street Speed Watch 0 4 2 DIY Electric Vehicle from Recycled Parts 257 6 48 16 Internet enabled smoke alarm 0 11 3 ARDUINO MPPT SOLAR CHARGE CONTROLLER 5200 36 162 79 Python Powered Scientific Instrumentation tool 0 51 19 USB Booster 123 4 10 3 Muffsy Hifi Dual Power Supply 0 7 0 Pediatric Therapy Device 83 0 6 4 DC UPS and Wallwarts Eliminator 4 10 6 A Wireless I2C Bridge for Amateur Radio Use 0 5 2 Timstock Slim – a tool for the autistic 5 20 13 C12666MA Micro-Spectrometer 2100 23 107 34 Wireless Batteryless Mouse 553 2 28 13 Biopotential Signal Library 1 42 16 Green eutectic rocket propellant 1 15 5 Portable tiny IoT device solving general problem 4400 13 46 17 In-Line Battery Back-Up Module for Ham Radio 1500 0 17 3 Electric Ninja 4800 7 49 19 Low-noise, Easy-to-use Analog Data Logger: SiGZiG 229 8 16 6 Low Cost Wireless Home Automation and Security 2 43 8 EM-Drive 58 188 71 NodeUSB- 'Eat your own dog food' WiFi IoT DevKit 555 0 25 6 PICxie: A micro PIC18F development kit 2 8 2 BeagleLogic 223 4 50 20 Binary Pomodoro Timer 0 1 2 SentriFarm (Farmer stay in Bed, too hot to reap!) 617 12 27 5 ESPLux – Smarts for your downlights 467 4 12 7 Guard Llama 346 0 4 6 Iconic clock for deaf children 2 4 4 Braille Computer 9 22 15 Artificial Muscles and Ultra-capacitors 1000 2 44 10 MultiSpork 700 3 79 38 Tote, affordable spider robot 6 29 19 Totals: Prizes View Com Follw Skull 342 208490 1935 10527 4187 Sorry about the duplicates, but they are listed by contest nicely. Data taken 6-7 and 6-8-2015. Let me know if you find mistakes. Spreadsheet available (two sheets with both log data) in my dropbox.
Stubborn LibreOffice pie chart:
alpha_ninja
